Sherwood R-972 User Thread - Page 111 - AVS | Home Theater Discussions And Reviews
 4Likes
post #3301 of 3328 Old 12-21-2014, 10:14 AM
sandbagger's Avatar
Liked: 29
Time for an upgrade, new processor should be here before the first.
972 has been great but time to move forward( or at least I hope so) I will be putting it up for sale soon.
Kevin
Motor City Custom Audio
Bringing you Custom subwoofer kits, with flames if you want
Onix and Melody Valve Hi Fi Audio Dealer serving the Midwest and Canada
sandbagger is offline
post #3302 of 3328 Old 12-21-2014, 10:24 PM
islandman2020's Avatar
Quoted: 13 Post(s)
What are you "upgrading" to? Not sure what other RC system corrects in the Spatial Domain like Trinnov? For how much will you be selling the R-972?
islandman2020 is offline
post #3303 of 3328 Old 12-22-2014, 01:51 PM
dwk123's Avatar
It appears that my now non-HDMI R972 will spend the next phase of its life as a multi-channel integrated. I have it upstairs powering an active x-overed bi-amp setup using the NHT Xd monitors from the closeout sale several years back plus a set of woofer modules. I still need to dial things in, but it's working. Somewhat surprisingly, the 7.1 ext in actually obeys the speaker setup config. I had the unit set up in 2.1 mode, and when I switched to the ext.in input with L/R/SL/SR in use, only the L/R channels came through - I actually had to go back into the speaker config and enable the other channels.
I'm still not sure the 972 will be ideal for the 4-ohm woofer modules, but we'll see how it goes.
I've ordered an Emotiva 8100 to try out in the theater space.
dwk123 is offline
post #3304 of 3328 Old 01-02-2015, 12:16 AM
chrisreeves's Avatar
Quoted: 162 Post(s)
Liked: 65
I'm using Room EQ Wizard for the first time ever - but for some reason it does not seem to be sending any signals to my subwoofers when doing a signal sweep (and yes, I've confirmed this by doing sweeps with the subs powered off - and the results are the same as with them powered on).
However when playing movies the subs are clearly in action.
The setup is a Mac Pro connected to the R-972 via HDMI. The subs are connected to the R-972 via an inuke nu6000dsp two channel amp.
The on-screen display of the R-972 shows a stereo signal, and has the left, front, and subwoofer icons lit up.
"Don't forget that a significant contribution made by the use of high-end cabling is emotional. Knowing that you have the best available causes the listening and viewing to be that much more enjoyable. Observable improvements make it even better."
-From a post on the audio video improvements forum
chrisreeves is online now
post #3305 of 3328 Old 01-02-2015, 12:16 AM
Quoted: 162 Post(s)
Liked: 65
Help! I'm using Room EQ Wizard for the first time ever - but for some reason it does not seem to be sending any signals to my subwoofers when doing a signal sweep (and yes, I've confirmed this by doing sweeps with the subs powered off - and the results are the same as with them powered on).
post #3306 of 3328 Old 01-02-2015, 06:16 AM
tr4a's Avatar
Quoted: 20 Post(s)
Liked: 45
Chris
On the HDMI input you are using for the Mac did you turn on the
sub in the input setup to the 972?
I made this discovery when I added another input and my subs
sounded like they had lost half their output.
Turns out the bass was coming from my Kef LS50's full range.
Surprised me how much bass there was!
tr4a is online now
post #3307 of 3328 Old 01-02-2015, 11:35 AM
Quoted: 162 Post(s)
Liked: 65
Originally Posted by tr4a View Post
Chris
Thanks - I'll double check but I think it's on. The problem, I think now, is that Trinnov does not assign a crossover point to my full range L/R mains. I've run the calibration 4 or 5 times, and only got the 80hz -6db point one time. The rest of the time I get a "0hz" reading.
I confirmed this hunch by swapping a pair of bookshelves last night for the L/R mains - then doing Trinnov's calibration - and sure enough I got the 80hz -6db point. Ran REW again and now the bass frequencies on the sweep were coming out of the subwoofers.
So - it's not a REW problem, it's a Trinnov problem.
Maybe Trinnov is finding smoother bass response from my L/R mains due to their position at the front of the room. I dunno. But the bass readings from REW are definitely louder with the subs on using the bookshelves.
I may get in touch with Curt Hoyt and ask him to do some consulting on this.
post #3308 of 3328 Old 01-16-2015, 01:57 PM
Audio Geek's Avatar
Quoted: 82 Post(s)
Liked: 41
Has anyone wired up their receiver (using the serial port) to control it remotely?
The remote control capability via network is a feature I miss from my previous receiver (Pioneer VSX-1120-K).
Audio Geek is offline
post #3309 of 3328 Old 01-20-2015, 06:38 AM
twells's Avatar
Yes, and it works well (the direct volume settings are nice to put into start-up macros) but serial control is missing a major function... I can't recall which is missing off the top of my head but it's one of the power functions (either on or off) so I have IR hooked up just for that one function. I don't think you could get away with only serial control.
twells is online now
post #3310 of 3328 Old 01-20-2015, 09:10 AM
Audio Geek's Avatar
Quoted: 82 Post(s)
Liked: 41
Thanks for your response.
What do you have it hooked up to? I've got a Linux machine I can connect to but it's on the other side of the wall (and I have to figure out how to make the cable).
Hm. That's unfortunate about the power. What do you use for IR?
post #3311 of 3328 Old 01-20-2015, 10:08 AM
twells's Avatar
I use a URC system with an MSC 400 that does both serial and IR.
post #3312 of 3328 Old 02-01-2015, 07:43 PM
stucandu's Avatar
Upgrade Glitch - HELP!
Hi,
So I procured one of these beasts, got it partially set up and went to install the firmware upgrade from Ver 1.34 to Ver 1.47.
Got it loading, both the 972 display indicating upgrade in progress and my laptop showing the progress. Then, WHAM! the install stops on one of the files and after a couple of seconds, times out and re-sets the install over from the beginning. This continues like this ad infinitum, repeating over and over automatically. The install never completes and usually gets about half way through on the progress bar, sometimes more, sometimes less. It doesn't stop on the same file either, seems to be a different one every time.
I've had it going for over 4 hours now, hoping it will make it through, but kind of doubt that it will after so many attempts. I'm going to try using another computer, in case it's a computer problem. However, I am hoping someone on here can shed some light on what is going wrong and hopefully have a solution.
From what I've read, the upgrade is essential to improve the units' performance.
Please help if you can. Thanks
stucandu is online now
post #3313 of 3328 Old 02-03-2015, 07:13 PM
jasonmichaelh's Avatar
Quoted: 21 Post(s)
[QUOTE=stucandu;31388625}
Please help if you can. Thanks[/QUOTE]
Were you able to get the upgrade to take?
jasonmichaelh is offline
post #3314 of 3328 Old 02-04-2015, 06:09 AM
stucandu's Avatar
Unhappy
No, I think my unit is toast actually. I eventually stopped the program, but the 972 display still indicated the upgrade was in progress and stayed that way. I should have tried connecting my other computer first, but made the fatal mistake of trying to power the unit off and back on. I don't know if it was already seized up or not, but now it won't power back on, just stays in the standby mode. I tried to re-set it and nothing. Unplugged and replugged - nothing. I contacted Gary Graning at Sherwood and he said he would check with the tech guys, but I haven't heard anything back yet.
Pretty bummed, needless to say.
post #3315 of 3328 Old 02-04-2015, 06:53 AM
stucandu's Avatar
Not giving up hope but not looking good since SN has discontinued support.
I have to think the unit had some internal problem because why would it keep booting the install?
post #3316 of 3328 Old 02-07-2015, 04:54 AM
leaguer1leafs's Avatar
Where did u get the firmware upgrade from?
leaguer1leafs is offline
post #3317 of 3328 Old 02-07-2015, 07:10 AM
tr4a's Avatar
Quoted: 20 Post(s)
Liked: 45
I did not have to upgrade firmware but when
I tried loading the Bass targets I had the same problem.
I do not know if Root menu applies to the firmware updates
but it worked for the Bass targets.
tr4a is online now
post #3318 of 3328 Old 02-07-2015, 07:21 AM
stucandu's Avatar
Downloaded the firmware off Sherwoodusa.com:
http://www.sherwoodusa.com/product/view.asp
post #3319 of 3328 Old 02-07-2015, 07:24 AM
stucandu's Avatar
Question
This sounds promising, but I don't know what is involved to access this feature. Unit won't turn on at all. Perhaps you can fill in the details.
Thanks a lot.
Stu
post #3320 of 3328 Old 02-10-2015, 08:23 PM
slinkeey's Avatar
Originally Posted by busdepot View Post
Sherwood will not service or support your R972 in any way, nor supply any parts, in or out of warranty.
Welcome to the club. I couldn't get my Sherwood receiver fixed under warranty back in 2012.
Maybe this is the best thing that could have happened. I hope it causes more people that have been scammed by Sherwood to come out of the wood work.
This is not how reputable companies do business.
That's what I thought when they started playing games with me.
slinkeey is offline
post #3321 of 3328 Old 02-11-2015, 06:55 PM
stucandu's Avatar
Oddly enough, when I called Sherwood tech support on this, the rep didn't say anything about not servicing the 972 and suggested it probably needed to be shipped in for service. He transferred me to another dept. but no answer. Left a msg without indicating a 972 problem. No reply yet, but will call again tomorrow and follow up.
Maybe the Service division has more empathy than the bigwigs over in Korea.
Fingers crossed still...
post #3322 of 3328 Old 02-11-2015, 07:42 PM
slinkeey's Avatar
Don't forget about Gary "Kick the can until your warranty is up" Graning.
slinkeey is offline
post #3323 of 3328 Old 02-11-2015, 07:46 PM
stucandu's Avatar
Yeah, he was my first call.
Said he'd look into it, but haven't heard anything back yet.
There's still hope.
I hope.
post #3324 of 3328 Old 02-11-2015, 08:13 PM
slinkeey's Avatar
There's still hope.
I hope.
Good luck. You'll need it.
I shipped my Sherwood product back to them four times at $25 bucks a pop, and it is still broken.
slinkeey is offline
post #3325 of 3328 Old 03-20-2015, 11:18 PM
Archnmez's Avatar
Federal warranty laws allow for reasonable lawyer fees to be paid by the manufacturer. I think a group of users could definitely get a case going. Wouldn't hurt to contact a lawyer in that field. You should google warranty law and see what you can find. I wouldn't let them get away with it. Terrible.
Archnmez is offline
post #3326 of 3328 Old 03-21-2015, 07:53 PM
Liked: 0
Ironic, I just posted my first post to a similar forum yesterday. Seems like folks have had similar issues to mine with their receiver, and have received similar hassle from Sherwood. Here is what I posted, but the question remains the same for AVS Forum members:
Hello Gentlemen -
I have been following this forum and another similar site regarding my issues with the HDMI input boards on my 972. Both failed just before the end of the year. I have spoken to the same people (GG) mentioned above, and while he was kind enough to suggest I speak with a former Sherwood employee / Newcastle guru, we were unable to remedy my issues. I did get the email stating that Sherwood would not be able to honor the warranty due to lack of usable parts.
This is my first post. I am not bashing Sherwood or the receiver. It was great while it worked. My question is, has anyone attempted, or would anyone be interested in pursuing legal recourse? There are specific Federal laws that protect consumers from manufacturers that do not honor their stated or implied warranty.
My receiver worked for almost a year to the day. It was new/open box.
Just throwing this on the wall to see if anything sticks. I am pretty upset at how Sherwood is handling this and will not just "bend over and take it..."
Just a guy with a bricked receiver...
Caffinated Zen is offline
post #3327 of 3328 Old 03-21-2015, 07:55 PM
Liked: 0
It's called the Magnusen Moss Warranty Act. It's a Federal Statute. My brother is an attorney.
post #3328 of 3328 Unread Today, 09:15 AM
stucandu's Avatar
Well, I'm throwing in the towel and cutting my losses. My bricked unit is up for sale in the classifieds.
Sherwood Newcastle R-972 - Bricked - for component parts
I'm pretty sure all the other boards are okay, probably just the main board that is bricked, but I can't guarantee anything.
Best offer takes it.
Sherwood Newcastle R 972
