Integra DHC 40.1 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 785 Old 11-02-2009, 02:48 PM
66mgb's Avatar
KBMAN
Pandora and the Vtune internet radio tuner work great. I already had a Panodara account, so once I logged in on the 40.1 it had my station list and it was ready to go. The audio quality is surprisingly good on Pandora on the 40.1
66mgb is offline
post #62 of 785 Old 11-02-2009, 03:42 PM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
Good to hear 66mgb.....BTW, is Pandora a free music service?
KBMAN is offline
post #63 of 785 Old 11-02-2009, 05:36 PM
66mgb's Avatar
KBMAN
Pandora is free as well as the Onkyo/Integra Vtune which has many local stations through out the country.
66mgb is offline
post #64 of 785 Old 11-03-2009, 08:46 AM
alanl715's Avatar
okay...now u can purchase one !!
alanl715 is offline
post #65 of 785 Old 11-03-2009, 09:09 AM
highlife's Avatar
I am having a hard time justifying the cost difference between the 40.1 pre/pro and the 40.1 receiver. The receiver. which includes the amps, is quoted to me as $160 LESS than the pre/pro, which has no amps. Is this typical? $800 for a receiver vs. $1660 for comparable (really the same thing) pre/pro plus comparable separate amps? Does double the cost equate to double the sound quality? I was excited to try separates but the cost differences don't seem to be in check. Am I missing something?
Thank you -
Highlife
2 wrongs don't make a right, but 3 lefts do...
highlife is offline
post #66 of 785 Old 11-03-2009, 09:10 AM
Craig Woodhall's Avatar
ya that makes it tough..
Craig Woodhall is offline
post #67 of 785 Old 11-03-2009, 11:45 AM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
highlife,
I would say if you already have separate amps, then go for the pre/pro, for it will have all the benefits of more headroom and separate power supplies. If you don't have separate amps and you are on the fence, I would just go with the receiver version. I already have NAD separate amps, so I'm going the pre/pro model.....
AND yes Alan, I hear ya, I hear ya
KBMAN is offline
post #68 of 785 Old 11-03-2009, 02:06 PM
kwtoxman's Avatar
Thank you -
Highlife
Yes, just remember there are some feature differences between the 40.1 processor and receiver (besides amplification). E.g.'s include THX and ISF certifications, more hdmi connectivity, simultaneous or independently active HDMI outputs (Main / Sub), etc, etc. One just needs to go over the features list in detail to find them all.
kwtoxman is offline
post #69 of 785 Old 11-03-2009, 04:27 PM
QuadESL63's Avatar
Originally Posted by kwtoxman View Post
Simultaneous or Independently Active HDMI Outputs (Main / Sub), etc,
Can you have different output resolutions on each of the two HDMI output (e.g. 1080p on MAIN and 720p on SUB)? I've read the manual but I couldn't figure this out. Thanks!
EDIT: may be not simultaneously (prob. out of the question because there is only one scaler on board) but how about independently? I only need one active at the time but one will be at different output resolution than the other, such that I can switch from one (1080p) to (720p) w/o reconfiguring anything.
QuadESL63 is offline
post #70 of 785 Old 11-03-2009, 04:42 PM
kwtoxman's Avatar
Sorry I can't help, but I don't know yet. My 40.1 still on order. Can anybody here answer this??
kwtoxman is offline
post #71 of 785 Old 11-05-2009, 09:06 AM
dynaman2's Avatar
I've been looking at the 40.1 as well. I have a Rotel RSX-1056 at home, and while I love it, I need to get into HDMI. I think I'd have no problem using the Rotel as my amps and the 40.1 for pre/pro. I've got power hungry NHTs all the way around, but my thought is, if I like it now, this setup would definitely not be a step backwards. Any thoughts?
Also, there was talk about the Harmony One on here... I bought one when it first came out and loved it. Very easy to set up and use. However one fall from the sofa seat (20"?) to the hardwood floor and I cracked the LCD. It still works, but I do have to remind the wife where to tap to turn on the Blu-Ray.
dynaman2 is offline
post #72 of 785 Old 11-05-2009, 04:28 PM
kwtoxman's Avatar
An an FYI, my dealer took about 1 week from order to receiving the 40.1. I won't be able to pick it up for another week though myself.
kwtoxman is offline
post #73 of 785 Old 11-06-2009, 03:53 PM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
Well,
I just pulled the trigger on the 40.1. I will give it a good "listen" and see if it betters my Lexicon MC-1. Kal said the room correction alone was worth it, so I'm going to TRY to be as objective as I can. I will let you guys know in a couple of weeks of my comparative results....
KBMAN is offline
post #74 of 785 Old 11-06-2009, 08:23 PM
BobBart's Avatar
Anyone know where I can get one of these? There are no dealers listed in Maine.
BobBart is offline
post #75 of 785 Old 11-06-2009, 08:32 PM
kwtoxman's Avatar
Try by zip. It seems their search engine "sucks" because I got more hits by zip than by state.
kwtoxman is offline
post #76 of 785 Old 11-08-2009, 08:00 AM
kunstadt's Avatar
I had the same Rotel and I'm now using an Integra 7.8
I think you have the right idea.
I am using an Odyssey poweramp for the fronts and it sounds amazing. I think the processing is really good on my Integra but I'm not too convinced about the Integra/Onkyo amps. At least compared to my Rotel (and definitely the Odyssey), they sound a little thin. So your setup might not be the cleanest looking (with a processor powering your speakers) but I believe it will sound great. Between hi-res audio and room-correction... you'll be blown away.
kunstadt is offline
post #77 of 785 Old 11-08-2009, 10:28 AM
alanl715's Avatar
why don't u just call Integra Product Support...800-225-1946...they r open Sat and Sun 1-4 pm est ( I believe)
alan
alanl715 is offline
post #78 of 785 Old 11-08-2009, 11:08 AM
alanl715's Avatar
just got off the phone w/Tech Supp. When u set one HDMI out both are set at the same resolution...you cannot set them independently.
that being said...until someone here tries it...
alan
alanl715 is offline
post #79 of 785 Old 11-08-2009, 03:16 PM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
got a question for you guys....When you setup Audyssey for the first time, is it necessary to calibrate for all six listening positions? Will I have better results in the primary seat if I do this? Thanks,
KBMAN is offline
post #80 of 785 Old 11-08-2009, 03:51 PM
alan
thanks Alan, I was wondering about that myself.
Craig
post #81 of 785 Old 11-08-2009, 06:00 PM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 460
You should be thinking not so much of "seats," but of measurement positions. Audyssey needs to sample the listening environment , even for one listening position. I generally use 8-12 positions for 1 position.
Yes.
I recommend the GUIDE linked in the first post of the "Official" Audyssey thread.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #82 of 785 Old 11-12-2009, 06:26 PM
cdvision's Avatar
My DHC-40.1 came in this afternoon. So i've been busy playing. SACD fed from my OPPO BDP-83 via DSD sounds great! Streaming audio from my Windows 7 and XP PC's is a snap. It even reads and plays my playlist and shows album art if its in the folder.
The MultiEq was a breeze to set up. So far everything sounds and looks great. Here's some pics including ones with the top off. Lots of open real estate inside.lol
The only negatives so far:
1)The head phone pre amp sucks-I get a loud hum through my SonyMDR-XB700'S and a slight hum through my Sennheiser HD-650's(higher load)
2)You can't shut off the front display-you can only dim and it's still to bright in a light controlled room.
3)This one's not Integra's fault but Logitech has no support for it yet. I had to use the DTR-40.1 setting to get it up and running but it's missing functions.
I also had to dampen the cover along the front edge as it was very resonant and rattled when you tapped it (no big deal and most people would never notice it). Easy fix.
Claude at Westcoast AV Gallery, Vancouver BC
https://westcoastavgallery.ca/
cdvision is offline
post #83 of 785 Old 11-12-2009, 07:03 PM
Brklyn Joe's Avatar
Cdvision, I can help you with the harmony codes. Go to the official Onkyo 876 forum, at the end of the first post is a link to every hex code you could ever want for most Onkyo/Integra products (thanks to Rickard L for posting this!). While the 40.1 is not on there the DHC 9.9 codes work perfectly! Make your own spreadsheet of the codes you want to add to your remote, email it to logitech supprt and in a few days you'll be good to go!
Brklyn Joe is offline
post #84 of 785 Old 11-12-2009, 07:19 PM
cdvision's Avatar
Thank but that's too much work for me.
I'll just wait for Logitech to add the DHC-40.1 to their database. It shouldn't take to long.
cdvision is offline
post #85 of 785 Old 11-12-2009, 07:29 PM
Brklyn Joe's Avatar
You could do that, but many of these codes are not even available on the 40.1 remote. It's real nice having direct access to Dyanamic Vol, Dynamic EQ, Audyssey just to name a few.
post #86 of 785 Old 11-12-2009, 08:05 PM
Bill Mac's Avatar
Quoted: 1265 Post(s)
Liked: 1441
Joe,
You are correct as I have all the codes you list above thanks to forum member jcalabria. I have the 886 and the direct access codes were not available as you mention. The 886 has been in the Harmony database for sometime but the direct access codes are not. You have to request them or you will be waiting for a long time.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
post #87 of 785 Old 11-13-2009, 01:01 AM
cdvision's Avatar
I just redid my Harmony 720 remote using the Onkyo TX NR807 code and it works flawless.
cdvision is offline
post #88 of 785 Old 11-13-2009, 01:08 AM
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
Originally Posted by Bill Mac View Post
Joe,
Bill
The remote codes in the document discussed seems to work ok for my TX-NR3007 except
Audyssey 2EQ/MultEQ/MultEQ XT Code
D21E 50 8E Off
D21E 50 8F On
D2AC DF Audyssey 2EQ/MultEQ/MultEQ XT(Wrap-Around Up)
instead, they acted like
Dynamic EQ Code
D21E 50 8B Off
D21E 50 8C On
D21E 50 8D Dynamic EQ(Wrap-Around Up)
which worked as they should though, as well as these ones which also works ok:
Dynamic Volume Code
D21E 50 80 Off
D21E 50 81 Light
D21E 50 82 Medium
D21E 50 83 Heavy
D21E 50 84 Dynamic Volume(Wrap-Around Up)
Listening Mode Code
D2AC 52 Straight Decode
Re-EQ/Cinema Filter Code
D26C D6 Re-EQ/Cinema (Wrap Around Up)
rickardl is offline
post #89 of 785 Old 11-13-2009, 05:25 AM
Bill Mac's Avatar
Liked: 1441
Are all the direct access codes available for the 807 (other --07 models as well) from Harmony?
Bill
Bill Mac is offline
post #90 of 785 Old 11-13-2009, 05:34 AM
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
Bill
Nope. Not all.
You still need to get Logitech to add Audyssey, ISF, StraightDecode etc for your x007 device.
rickardl is offline
Integra
