Onkyo 3007 and SVS PB13 ultra - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-29-2009, 08:31 AM - Thread Starter
gskinusa's Avatar
Quoted: 76 Post(s)
Liked: 32
Hi
I have received my 3007 last week and so far I really like it a lot. I have only one sub (PB-13 ultra) and as the sub has two inputs I was wondering whether I can take the Sub1 and Sub2 outputs from 3007 and connect it to the two inputs of PB-13 Ultra. I read somewhere that even though Onkyo "x.2" receivers are advertised as 2 sub supported it is actually splitting the signal so effectively its still "x.1". I am not sure that is the case with 1007 and 3007 as they provide the capability to tweak the individual subs. So my question is basically can I connect both the sub outs from 3007 and connect to the 2 inputs of single PB-13 ultra sub and is it better than using a single connection. All of your expert comments/suggestions are really appreciated.
HT Setup: http://www.avsforum.com/t/1520044/ou...ts-of-pictures
For Sale:
Nothing at this time.
gskinusa is offline
post #2 of 4 Old 09-29-2009, 08:33 AM
Dioneo's Avatar
I can't see any benefit to connecting your sub twice to the same component.
Dioneo is offline
post #3 of 4 Old 09-29-2009, 08:40 AM
seven lust's Avatar
Are you thinking it would give you more power? I do not believe it will. I am not sure why you would want to spend the money on another cable for no gain in performance. I think you are good to go the way it sits now......unless you want to get another pb-13 ultra
seven lust is offline
post #4 of 4 Old 09-29-2009, 08:58 AM - Thread Starter
gskinusa's Avatar
Quoted: 76 Post(s)
Liked: 32
Thanks guys. I was not sure whether it will make any difference but based on your inputs I will just leave them as it is.
I wish I can get another PB13 and have room to place it but unfortunately I do not have much room put another sub. Anyway, I like how it sounds now so I guess there is no point in messing it up
Thanks again for your help.
For Sale:
gskinusa is offline
