PCM and DTS-HD 6.1 on Panasonic player and insignia receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-11-2009, 09:13 PM - Thread Starter
avfan9's Avatar
Will PCM and DTS-HD 6.1 work on a Panasonic player and Insignia 5.1 receiver? Both say they support DTS-HD.
avfan9 is offline
post #2 of 10 Old 10-11-2009, 09:27 PM
Knucklehead90's Avatar
Quoted: 388 Post(s)
Liked: 334
If they both say they will - then they should. You might post the models involved - someone may know something more about one or both.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #3 of 10 Old 10-11-2009, 09:32 PM
rdgrimes's Avatar
Quoted: 2008 Post(s)
Liked: 1341
DTS-HD-MA will be 7.1, not 6.1. There is a rare instance of DTS-MA having a ES core, which will get decoded to 6.1 in an AVR but not in a player. Some players will drop the ES flag on DTS so the AVR has to force that decoder manually.
rdgrimes is offline
post #4 of 10 Old 10-11-2009, 09:49 PM
M Code's Avatar
Quoted: 718 Post(s)
Liked: 423
The Insignia AVR (built by Sherwood) is 5.1 and HDMI 1.3a. When playing a 6.1 or 7.1 (Dolby and DTS) source material (SD or HD) through a digital port (coaxial, optical or HDMI) this will be collapsed down and played as 5.1....
Just my $0.015...
M Code is online now
post #5 of 10 Old 10-11-2009, 10:46 PM
bluesky636's Avatar
DTS HD-MA can support UP TO 7.1. It could be way less (mono) and is most commonly 5.1.
bluesky636 is offline
post #6 of 10 Old 10-12-2009, 07:14 AM - Thread Starter
avfan9's Avatar
so there won't be a decrease in sound quality?
avfan9 is offline
post #7 of 10 Old 10-12-2009, 08:00 AM
bluesky636's Avatar
Compared to what?
post #8 of 10 Old 10-12-2009, 01:04 PM
M Code's Avatar
Quoted: 718 Post(s)
Liked: 423
Correcto..
NO decrease in sonic quality..
The Center Back Channel audio content available in a 6.1 mix is outputted to the L & R surrounds. If the master mix is 7.1, then the L & R Back Surround channel saudio content is outputted to L & R Surrounds. Nothing is lost just merged into existing channels, note that the step to 7.1 is significant for expanding the soundstage if setup properly. The step to 6.1 was a bust as it usually collapsed the soundstage by reducing channel separation..
Just my $0.015...
post #9 of 10 Old 10-12-2009, 03:26 PM - Thread Starter
avfan9's Avatar
i'm just making sure--when a blu-ray says "DTS-HD Master Audio 6.1," and the player can decode DTS-HD Master Audio Essential, and the receiver can decode DTS-HD Master Audio, it would still work?
avfan9 is offline
post #10 of 10 Old 10-12-2009, 03:30 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Only need to decode once. If your receiver can decode, set your player to bitstream to the receiver.
JHAz is offline
