The Official Integra DHC-80.1 Pre/Pro - Page 63 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1861 of 1873 Old 11-20-2013, 06:04 PM
SHadoWFoX's Avatar
Originally Posted by pittberto View Post
I i do have a 80.1 receiver the hdmi board was replace under warrenty few months after i got my reveiver now i got the same issue someone can help me i think if i do the repair agin il will fail again do i have reason or if integra as resolve the problem with their hdmi board... pittberto
Is your 80.1 currently out of warranty?
If so, did you purchase it with a credit card that offers extended warranty? This is the course I took and I only needed to pay for shipping.
The 80.1 does run hot during normal use (this seems to be common for other pre-pro too). It is best to place a fan to help with the heat issue which people believe is a contributing factor to the failure of the HDMI board.
Shadow Fox
SHadoWFoX is offline
post #1862 of 1873 Old 11-21-2013, 09:07 AM
pittberto's Avatar
Thank you for your reply but is all ready four year my receiver got lots of air to cool off I will try to find a answer il integra release some document abot the hdmi board heating
pittberto is offline
post #1863 of 1873 Old 09-12-2014, 08:41 AM
Majorseven's Avatar
Originally Posted by SHadoWFoX View Post
<br>
The On Screen Display feature on my 80.1 has just quit on me.<br><br>
I first noticed the volume display is not showing on the TV. Checked the Monitor Out setting and it is correct (HDMI Main) but I also tried all combinations, used both HDMI Main and Sub out, different HDMI cables. Nada. No OSD at all and this includes volume, setup menu, Audyssey control, all gone. I am still getting the video feed from connected devices (TivO and Oppo 83).<br><br>
Not sure has anyone got this kind of problem. I searched around and did not see problem reported like mine. Sigh. Seems like sign of "aging" equipment.
Hey Man,
I have the same problem with the OSD, other wise everything else works fine...how did you get it fixed?
Eyal
Majorseven is offline
post #1864 of 1873 Old 09-12-2014, 08:42 AM
Majorseven's Avatar
No OSD problem with Integra 80.1
<br>
Hey Man,
Eyal
post #1865 of 1873 Old 09-17-2014, 02:15 PM
pittberto's Avatar
Thumbs up
I just read your post i think is just inside your set-up programmation. When you set-up your TV somewhere is you send some signal to your tv some display will not show-up in the main screen is writing in the book to when you listen to the tv i hope this will help you bye
post #1866 of 1873 Old 12-14-2014, 03:15 PM
Rdrcr's Avatar
Alright guys, long story short, my new Condo is too small for my powered-speaker setup so I'm looking for ways that I can still enjoy my music without making guests question my decor choices, or annoying my new neighbors.
I'm considering some quality headphones. Aside from mobile devices...I've never used them. Does anybody have experience using decent headphones with the DHC-80.1? Do I need an additional headphone amp, or will the DHC-80.1 alone be capable of powering headphones?
Any help would be appreciated.
Mike
Rdrcr is offline
post #1867 of 1873 Old 06-08-2015, 03:34 AM
Majorseven's Avatar
Thumbs down Volume limit on Audessey
The volume seems to be limited on my DHC 80.1 whenever Audessey is engaged, simply put, from -10db or so turning the volume up doesn't affect the overall output, I tried turning the dynamic volume and Dolby on or off..no change
post #1868 of 1873 Old 06-08-2015, 04:34 AM
Tucker2's Avatar
Quoted: 13 Post(s)
I have never run into this. If everything else is working correctly I suspect a setting but don't know which to suggest. Is your firmware up to date?
Tucker2 is offline
post #1869 of 1873 Old 06-09-2015, 03:50 PM
Majorseven's Avatar
Yes.
Just to make clear when Audessey is disengaged for instance in Direct mode the phenomena disappears...
post #1870 of 1873 Old 06-23-2015, 12:14 PM
KBMAN's Avatar
Quoted: 219 Post(s)
Liked: 119
Wink
Did you recently do a system reset? I ask because in the menu, there is a setting that determines the 'power on' volume, and the 'max' volume, somewhere in the menu....
KBMAN is offline
post #1871 of 1873 Old 06-23-2015, 03:07 PM
Majorseven's Avatar
I know these items in the menu ...they have no effect on the issue..
topoftheroc likes this.
post #1872 of 1873 Old 06-23-2015, 03:17 PM
Majorseven's Avatar
I listen to music using my 80.1 with mu very hard to drive Senheisser HD580 and it sounds fine.
post #1873 of 1873 Old 06-23-2015, 03:20 PM
Majorseven's Avatar
Integra
