HDMI problems with Denon AVR2309 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-24-2009, 12:15 AM - Thread Starter
akeoo7's Avatar
Hi everybody
My Denon AVR2309 bought less than a year ago has stopped recognizing anything attached to its HDMI inputs, as if nothing is there.
Took it to the Denon dealer in my country, they recognized it's a problem with the HDMI module and needs to be replaced, they ordering one from Japan, so no HDMI components for at least a month now.
Has anyone in this forum had similar problems with Denon or any other brand?
I have 3 HDMI appliances attached to my receiver PS3, WD hdtv and my HTPC. Could my computer be the culprit here? since I was trying to watch a bluray movie with my pc being the source, since the movie was a zone A movie and my PS3 is a zone B one.
I would appreciate any help, suggestions or ideas.
akeoo7 is offline
post #2 of 8 Old 10-24-2009, 09:22 AM
Dragonfly47's Avatar
Originally Posted by akeoo7 View Post
Has anyone in this forum had similar problems with Denon or any other brand?(
Many Onkyo owners are seeing the same problem. HDMI board replacement in the manufacturer's solution. In the Onkyo case, some suspect that it's caused by heat since the board sits on top of the hottest part of the receiver.
I have an Onk 606 that's ten months old and just beginning to exhibit HDMI problems. Hoping it makes it through football season before I have to send it off for warranty repair.
Dragonfly47 is offline
post #3 of 8 Old 10-25-2009, 12:46 AM - Thread Starter
akeoo7's Avatar
Thank you dragonfly for your response
I was trying to figure out what made the HDMI fail, I mean is that normal?
My receiver is well cared for it is only on for short times the time to watch a movie or a couple of CDs, I don't listen to really high volumes I am mostly at -10 to -18db for movies and lower volumes for music, I rarely go to 0db or above and that is just for minutes and then down.
I am suspecting some wrong doing from my HTPC because I was trying to watch a bluray on my PC through the AVR and I was trying to adjust my second display when I lost the picture on my TV and could not get it back.
the next day I turned on my PS3 and nothing the AVR didn't know it was there, I turned on my WD HDTV, nothing also. The AVR was sending OK video through HDMI output, it was only the inputs that were busted.
now after I get my AVR repaired should I forget about hooking up my HTPC to my AVR just to be on the safe side.
Thanx and please I need your opinions.
akeoo7 is offline
post #4 of 8 Old 08-27-2013, 09:58 AM
peludo's Avatar
I lost the surround sound on my denon, so I recalibrated the whole audio system. It worked fine and then about half an hour later I lost the sound and also the video. I tried to change hdmi cables and the different input channels. Can I fix it or do I need to take it to a shop?
peludo is offline
post #5 of 8 Old 08-27-2013, 09:58 AM
peludo's Avatar
peludo is offline
post #6 of 8 Old 08-27-2013, 04:20 PM
jdsmoothie's Avatar
Quoted: 12157 Post(s)
Liked: 5538
How did you lose the surround sound? Have you tried resetting the microprocessor?
jdsmoothie is online now
post #7 of 8 Old 08-27-2013, 07:14 PM
peludo's Avatar
Yes, I reset the microprocessor.
peludo is offline
post #8 of 8 Old 08-27-2013, 07:24 PM
jdsmoothie's Avatar
Liked: 5538
When you say "lost the surround sound" do you mean the audio suddenly goes silent? Likely out of warranty, although if you have a repair facility in your local area, you could get an estimate on repair. Although likely to be in the $200-$300 range so you would be better served putting the money into a new model, most of which now all are networking capable.
Denon Avr 2309ci Receiver
