The Onkyo TX-NR3007/TX-NR5007 common questions/issues/hints/answers thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
Old 11-01-2009, 11:01 AM
william06's Avatar
Quoted: 111 Post(s)
Liked: 63
Originally Posted by dvdmann View Post
Just picked up a 3007 and I noticed that the top panel of the unit where all the air vents are located is not perfectly flat but it is slightly bowed upward from the edges to the center. I was wondering if this is normal for all units or maybe it was damaged in shipping.
Flat is normal
william06 is online now
Old 11-01-2009, 12:03 PM - Thread Starter
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
Originally Posted by mariob33 View Post
does anyone know if like resolution the option to turn video processing on or off ([VCR/DVR] and [RETURN]) or skip in these units is source specific or global? Based on what I have been able to see it seems to be global. so, if I set to skip no conversion is done to any sources. Is/does my assumption seem to be correct?
Not sure what you are asking but according to the manual, it looks like it only concerns analog output (Monitor Out Analog) from analog sources (component video, SVideo, and composite video)?
If Monitor Out setting is set to Analog, press [VCR/DVR] and [RETURN] buttons on the AV receiver at the same time.
Select Skip in the VideoProcessor setting by pressing the [RETURN] button repeatedly on the display.
To reset back to the original setting, press the same button at the same time.
If you select Use, the AV receiver will output video signals from the video processor.
rickardl is online now
Old 11-01-2009, 12:35 PM - Thread Starter
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
Originally Posted by JinGoomo View Post
Thank you very much rickardl, I learn a lot from your post.
I am new in AV World form Stereo. My 3007 has done new firmware update on 10/28/2009, it took about 30 min via wired LAN connection.
Firmware:
Main 1.18/09X23AH
DSP 1ST/NET: 1.14/09X23AHA
DSP 2ND: 1.03/09723AH2
DSP 3RD: 1.05/09914AH3
VIDEO: 1.12/09805AR
VSP(Reon): 1.02/09730AEO
Jin
Thanks! Have you noticed anything changed/improved/worsened with it?
Old 11-01-2009, 12:37 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
Send a message via Skype™ to mariob33
no if you set this it turns off the processing for everything (analog and digital). It is actually the only way I can see where 100% of processing can be completely turned off. The manual doesnt clearly spell this out. I played somemore last night and it appears this sets the processing off globally.
In search of video bliss...
mariob33 is offline
Old 11-01-2009, 01:38 PM - Thread Starter
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
I don't know what you are after but for last years models, it seemed that you needed to have Resolution: Through AND Immediate Display: Off
in order to get 36-bit output without conversion to 30-bit, have you tried that?
Old 11-01-2009, 03:21 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
What I want is when my oppo sends 36 bit for that to be whats sent to my displays. Today 36 bit out of the oppo shows as 24 bit out to the display with processing on.
I will give that a try and see.
mariob33 is offline
Old 11-02-2009, 12:43 AM - Thread Starter
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
Also, I recall someone mentioning that setting HDMI->x.v.Color: Enable
and was needed as well as Resolution:Through and Immediate Display: Off
and then turning power off/on for his setup.
All my sources deliver 24-bit so I can't try it out myself.
Old 11-02-2009, 11:58 AM
TTTHU's Avatar
Hi All,
I found this forum very useful, I found out some nice hidden features of my Onkyo PR-SC5507.
Maybe some of you have answer to my problems, or has the same issues.
First: HDMI outputs.
As an introduction I use both output, Main: Projector, Sub: TV, both 1080p/24 compatible. Cables: 1m ultra high speed 28AWG to TV and 10m 1.3 certified to projector. Both works fluently with my DVDO EDGE processor, in all resolutions up to 1080p/24.
With PR-SC5507 the following happens, when videoprocessor is set to USE:
HDMI Main: can output all resolutions, but the picture is very unreliable. Sometimes is OK, but sometimes blinking, sometimes dissorted. I think it can be a frame locking issue, because my projector can display proper input signal frame rate with decimals: when there are problems at 24hz picture the display shows values between 23.7 to 24.2 (I saw already almost all values, 23.7, 23.8, 24.2). If it is 24.0, the picture is nice and stable.
HDMI Sub: no 24 Hz output at all, the Onkyo outputs only 1080p at 60Hz and 576p, that is all.
If videoprocessor is set to "SKIP" things are OK, even HDMI Sub outputs 1080p/24.
Second issue: DSD audio when DAC direct mode is ON. It sends very loud LFE signal to SW, even with DSD 2CH mode, where there is no subwoofer in the signal.
I also made the firmware upgrade 2 days ago, it did not help yet.
Otherwise this unit is amazing, my system sounds like never before, a real WOW
Hope you can help
Thanks in advance
TTTHU is offline
Old 11-02-2009, 03:32 PM - Thread Starter
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
Originally Posted by TTTHU View Post
Hi All,
Hope you can help
Thanks in advance
Not sure it helps but I can output 1080p/24 from "HDMI Sub" through a 10m HDMI cable to my Sony Bravia LCD without any problems.
I am letting the Onkyo do the conversion from 480i to 1080p/24.
I don't have a source which outputs 1080p/24 though.
Old 11-02-2009, 03:53 PM
TTTHU's Avatar
Thanks for the answer!
Good for you...
Do you think it can be a hardware issue with mine? Which model do you use?
I also have a Sony Bravia LCD TV, but HDMI Sub does not work. I tried with direct 1080p/24 signal, and upconversion of 576i signals as well from DVD player, but the result is the same: nothing displayed, pisture just blinks
TTTHU is offline
Old 11-02-2009, 07:30 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
thanks got it worked as soon as I powered on/off.
mariob33 is offline
Old 11-03-2009, 01:17 AM - Thread Starter
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
Good!
Do you know what step did the trick? or was it all of them?
x.v.Color: Enable, Resolution:Through, Immediate Display: Off, power off/on?
Old 11-03-2009, 01:24 AM - Thread Starter
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
Good for you...
just to be sure I understand: does the HDMI Sub output work when you let the Onkyo convert 576i to either 1080p/24 or plain 1080p?
From what I understand, it does not with either for you, correct?
576i to 1080p/24 "works" but it is jerky and unwatchable for me.
My Sony is KDL-D46000 and it is indicating 1080p24 on the screen.
Old 11-03-2009, 05:32 AM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
Good!
power off/on because all of the others seemed to already be engaged.
mariob33 is offline
Old 11-03-2009, 06:00 AM
william06's Avatar
Quoted: 111 Post(s)
Liked: 63
Originally Posted by william06 View Post
I did the hard reset, the factory reset and the firmware. It was after the firmware I had the issue. It did happen a couple of time before. The unit froze when I did the update the first time tech said do hard reset I did reran everything audessey etc that is when the problem started.
Last night after the post I unplugged it for several minutes after I turned it off. This morning I turned the tv on first than the 5007 and low and behold it worked fine. I really believe this is HDMI related somehow. I really would hate to send it back or disconnect all for service. I know different receivers react differently to different sources. I know also in the past the order you turn on some of your equiptment makes a difference. Thanks for the help will keep all posted. Any one else with similar issues should post and theyre solutions.
Well it definately was the HDMI handshake issue not the receiver in general. I have a Motorola 6416III box and it just seem incompatable with the 5007 enough to cause the lack of audio and occasional drops. The service center said if i keep it connected to the box it could eventually blow the HDMI circut. Just a FYI to anyone having problems. I currently have my Cable box connected Component and Optical. All else HDMI. I the receiver still is HDMI to tv.
So really it is a cable box issue. This reciver is working fine with above connection. Just for FYI for anyone having some issues.
Old 11-03-2009, 06:55 AM
iraweiss's Avatar
Quoted: 20 Post(s)
I wonder if there are also HDMI compatibility issues with the newer DCT-6416 design (large black panel on silver faceplate without III).
iraweiss is offline
Old 11-03-2009, 07:06 AM - Thread Starter
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
Any chance you could try to investigate this further so we know for sure?
Change x.v.Color: Disable,
power off/on and check for 36-bit
Change Immediate Display: On,
Change Resolution: 1080p
Old 11-03-2009, 08:59 AM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
ok. I tried all of these and actually have come to 2 conclusions.
1)It was the oppo CS setting that wasnt allowing anything higher than 30 bit. I changed the oppo CS from 4:2:2 to 4:4:4 and 36 bits now gets sent through the onkyo fine. So the power off effected the Oppo and not necessarily the Onkyo
2)However, i did do some other interesting testing just to easse my own mind.
What I found is that no matter what source sends in a 24 bit signal to the onkyo it will always send out 30 bit to my pioneer 141. I confirmed this by having
HDMI from DTV/Oppo player to TV input 6 TV handling all upconversion
DTV YCbcr 24 bits sent YCbcr 24 bits @ display
Oppo YCbcr 24 bits in YCbcr 24 bits @ display
Oppo YCbcr 30 bits in YCbcr 30 bits @ display
Oppo YCbcr 36 bits in YCbcr 36 bits @ display
HDMI from DTV + Oppo player to Onkyo 3007 to TV input 5 using
x.v.Color: Disable
Immediate Display: off
Resolution: Source
ISF Mode: Custom
Resolution: Through/1080p (tested both)
power off/on and check for bit
RESULTS
DTV 1080i/60 -->1080p/ YCbcr 24 bits sent YCbcr 30 bits @ display
Oppo 1080p/24 (no change) YCbcr deep color off YCbcr 30 bits @ display
Oppo 1080p/24 YCbcr 30 (deep color on) bits in YCbcr 30 bits @ display
Oppo 1080p/24 YCbcr 36 (deep color on) bits in YCbcr 36 bits @ display
x.v.Color: Enable
Immediate Display: on
Resolution: Source
ISF Mode: Custom
RESULTS
DTV 1080i/60 YCbcr 24 bits sent YCbcr 30 bits @ display
Oppo YCbcr 24 bits in YCbcr 30 bits @ display
so always uses 30 bits..
mariob33 is offline
Old 11-03-2009, 10:12 AM - Thread Starter
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
x.v.Color: Disable
Resolution: Source
ISF Mode: Custom
RESULTS
x.v.Color: Enable
Resolution: Source
ISF Mode: Custom
RESULTS
First, are you saying that x.v.Color, Immediate Display and Resolution Through/1080p has no effect
on it's capabilities to output 36-bit or not?
Second, the always 30-bit must be display related, if I feed the Onkyo YCbCr
24bit from my DVD player, it outputs YCbCr 24bit to my TV.
Old 11-03-2009, 11:01 AM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
Yes that is correct. No effect enabled/disabled.
With my setup the oppo only sends out 36 bits when CS is set to 4:4:4 within the oppo menu. The good thing is that the 3007 does pass the higher bit rate when its sent one. That I understand is a good thing. Not sure the benefit unless there was source available to leverage it but I have been told its a good thing.
I believe you are correct the 3007 (video processing on) and the TV must understand each other well enough so that the 3007 always sends out 30 bit no matter if I have x.v.Color enabled or not.
I did one additional test and turned off video processing using {VCR/DVR Return -->"SKIP"} which disables, x.v.Color, Immediate Display and Resolution
This seems to allow source BIT rates to be sent or as the oppo/dtv/xbox360 is sending them.
DTV 1080i/60 YCbcr 24 bits sent YCbcr 24 bits @ display
Oppo 1080p/24 YCbcr 24 bits in YCbcr 24 bits @ display
Oppo 1080p/24 YCbcr 30 bits in YCbcr 30 bits @ display
Oppo 1080p/24 YCbcr 36 bits in YCbcr 36 bits @ display
XBOX 360 1080p/60 HDMI colorspace set to "Source" 24 bits in 24 bits @ display
I will perform some more testing with my ps3 and my sharp projector later.
mariob33 is offline
Old 11-03-2009, 11:05 AM
dvdmann's Avatar
Hi, I have the 3007 and when I bring up the setup screen on the 3007 and then I check the video resolution coming into my Panisonic 65S1 from the 3007 using HDMI out to the TV it shows 480p coming in to the TV. Is this correct? I thought the output from the 3007 would maybe be 1080p for the GUI or is that wishful thinking. I have the HDMI output set to output 1080p. Is there a setting I am missing or is the GUI limited to 480p.
dvdmann is offline
Old 11-03-2009, 11:14 AM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
the GUI is 480p only. However, it can be overlayed onto the actual image if you go into any setup menu and before picking an option hit the enter key. It will super-impose the selection over the image and allow you to see affects to the picture.
mariob33 is offline
Old 11-03-2009, 11:22 AM - Thread Starter
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
or 576p depending on what video source format you are watching...
Old 11-03-2009, 11:37 AM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
yes sorry. this is correct
mariob33 is offline
Old 11-03-2009, 11:43 AM
mot67's Avatar
Is anybody able to change the receiver settings via web page?
When I go to the Network Setting I get following:
The current page cannot be displayed properly.
Turn the AV receiver off and then back on again, wait a few minutes, and then try connecting again.
If it still doesn't work properly, try resetting the AV receiver.
(Message No.311)
I guess this would be only for changing the network settings, not picture and audio settings and such, am I correct?
Haven't tried resetting the receiver and see if that would help.
mot67 is offline
Old 11-03-2009, 12:07 PM
dvdmann's Avatar
Thanks for the responces.
I am trying to overlay as you mentioned above but I must be doing something wrong. Every time I hit the setup button I then hit the enter button and I only can see the setup menu, no actual image?
dvdmann is offline
Old 11-03-2009, 12:11 PM - Thread Starter
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
It is from the setup pages where you can modify picture settings,
such as noise reduction, brightness etc, that you can press Enter
and adjust the picture settings while you see how the picture changes.
Picture Adjust
Using Picture Adjust, you can adjust the picture quality and reduce any noise appearing on the screen.
To view the TV picture while setting, press [ENTER]. To return to the previous screen, press the [RETURN] button.
Old 11-03-2009, 12:15 PM
TTTHU's Avatar
It only outputs plain 1080p, nothing else. No matter, what is the input. Onkyo converts everything (from 576i to 1080p/24) to 1080p properly inside, but can output only plain 1080p.
Read posts above, I saw that some components can hurt the processor, so I disconnected all HDMIs, plus I changed my Blue-Ray player to PS3, made soft and hard reset, but nothing changed
TTTHU is offline
Old 11-03-2009, 12:16 PM
dvdmann's Avatar
Got It.
Thanks again.
dvdmann is offline
Old 11-03-2009, 12:26 PM - Thread Starter
rickardl's Avatar
Quoted: 101 Post(s)
Liked: 90
Unless someone else has another idea, I would suggest contacting Onkyo
about this.... But first, maybe the store where you bought it could swap it
for another sample to see if it behaves the same?
Onkyo , Onkyo Tx Nr3007 140 Watts 9 2 Channel Av Surround Home Network Receiver Black , Onkyo Tx Nr5007 145 Watts 9 2 Channel Av Surround Home Network Receiver Black , Receivers Amplifiers , Speaker Systems
