The Onkyo TX-NR3007/TX-NR5007 common questions/issues/hints/answers thread - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #121 of 4737 Old 11-12-2009, 10:05 AM - Thread Starter
rickardl's Avatar
Quoted: 123 Post(s)
Liked: 95
Originally Posted by rickardl View Post
Yesterday I experienced audio drop outs combined with relay clicking for the
first time with my 3007.
It was a movie with a Dolby Digital 5.1 soundtrack recorded with my Humax HDPVR-1000C.
It occurs both with optical and HDMI audio connections.
It occurs sometimes with shorter intervals, say 2 minutes, and sometimes longer, say 10 minutes.
It occurs at the same places every time so I believe there is a fluctuation
with the Dolby Digital stream at those places.
Using the PCM track from the HDPVR does not cause any audible drop outs
or artefacts at those places with that movie.
I just confirmed that the audio drop out with relay clicking mentioned above is NOT a fault with the TX-NR3007.
I hooked up an old Yamaha RX-V1400 and connected it through optical to my HDPVR and yes, there was a significant audio drop out there as well.
Occurred at the exact same places so in this case, it is the dolby digital stream which is corrupt, the PCM audio track works fine.
rickardl is offline
post #122 of 4737 Old 11-12-2009, 01:06 PM
Ultimate Sound Wave
Adamg (Ret-Navy)'s Avatar
Quoted: 699 Post(s)
Liked: 1270
Quick question I need help with. Anyone with a 5007/3007 could please measure the length of the feet on the bottom of the unit. How far off the floor does the bottom of the unit sit?
AdamG, ...out!
The government cannot give to anybody,
anything that the government does not first,
take from somebody else.
Adamg (Ret-Navy) is online now
post #123 of 4737 Old 11-12-2009, 01:15 PM
Ultimate Sound Wave
Quoted: 699 Post(s)
Liked: 1270
The link has two sets of Firmware. I don't have my unit so I can't check it.
http://www.onkyousa.com/searchResult...Item=TX-NR5007
If anyone tries this please post results.
AdamG, ...out!
post #124 of 4737 Old 11-12-2009, 01:25 PM - Thread Starter
rickardl's Avatar
Quoted: 123 Post(s)
Liked: 95
One is the firmware, the larger one, and the other one is the pdf-instructions, the smaller one.
http://63.148.251.135/redirect_servi...REHAHA_103.zip
Product: TX-NR5007 (Firmware2)
Language: English
Category: Receiver
http://63.148.251.135/redirect_servi..._3007_5007.pdf
Product: TX-NR5007 (Firmware)
Language: English
Category: Receiver
rickardl is offline
post #125 of 4737 Old 11-12-2009, 01:27 PM
Ultimate Sound Wave
Quoted: 699 Post(s)
Liked: 1270
Thanks. Is the firmware file a differnt size than the previous file?
How long are the feet on your unit?
AdamG, ...out!
post #126 of 4737 Old 11-12-2009, 01:36 PM - Thread Starter
rickardl's Avatar
Quoted: 123 Post(s)
Liked: 95
Long? Do you mean the red or geen line?
the red is about 18 mm.
rickardl is offline
post #127 of 4737 Old 11-12-2009, 01:44 PM
Ultimate Sound Wave
Quoted: 699 Post(s)
Liked: 1270
How far off the ground? Length of the feet?
AdamG, ...out!
post #128 of 4737 Old 11-12-2009, 01:49 PM - Thread Starter
rickardl's Avatar
Quoted: 123 Post(s)
Liked: 95
How fart off the ground? Length of the feet?
The feet are about 18mm tall from what I can see. The red line.
rickardl is offline
post #129 of 4737 Old 11-12-2009, 01:52 PM
trallala's Avatar
I'm very curious about the new firmware! Anyone brave enough to try?
I have a question about Re-EQ as well, hoping you guys know how it works (my underline below).
First post, bottom:
High frequency roll-off with THX Re-EQ and/or Audyssey
The Audyssey target frequency curve is flat in the bass with a slight roll-off in the high frequencies.
The roll-off is not based on the type of content. It takes several factors into account including: (i) the difference in listening conditions that exist in the mixing environment and the home; (ii) the changes in speaker directivity that occur at higher frequencies, which affect the balance of direct and reverberant sound. Both of the above apply to movie and most properly produced TV content.
Caveat: If you use the Audyssey Reference Curve and THX Re-EQ then you will have double the roll off in the high frequencies.
There is no way to manually select Audyssey Reference Curve or Audyssey Flat except by using a THX listening mode.
Listening modes are either:
a) modes that use the Audyssey Flat Curve and THX Re-Eq can be 'On' or 'Off'.
b) modes that use the Audyssey Flat Curve and THX Re-Eq can not be applied.
c) modes that use the Audyssey Reference Curve and THX Re-Eq can be 'On' or 'Off'.
d) modes that use the Audyssey Reference Curve and THX Re-Eq can not be applied.
Basically, anything with 'THX' is either a) or b):
Anything with 'THX' combined with 'Cinema' or 'EX' fell into a).
Anything with 'THX' combined with 'Music' or 'Games' fell into b).
The listening modes were you can end up with double high frequency roll off from Audyssey Reference curve
combined with 'THX Re-Eq: On', category c), were:
- DTS Neo 6
- Dolby Prologic IIx Movie
- Dolby Digital EX
- Neural THX 7.1
- Dolby Digital
I sure wouldn't like ending up with double high roll off while playing DD content in TXX cinema mode. After some searching I found this: (first post "Official" Audyssey thread, about in the middle)
2. Re-Equalization technologies affect the target curve selection.
a. One component of THX is called Re-EQ, which applies a high frequency shelf cut filter. When listening in THX mode with Re-EQ on, it is recommended to use the Audyssey Flat target curve.
[cut some text here]
3. The selection of Audyssey target curves is performed manually in some products (e.g. Denon, NAD, Marantz) and automatically in others (e.g., Onkyo).
a. For products with manual selection follow the guidelines above.
b. For products with automatic selection, the following rules apply:
i. The Audyssey or Audyssey Reference target curve is selected after calibration.
ii. The Audyssey Flat target curve is selected automatically when you switch to a THX listening mode.
Does the target curve really change to flat automatically when Re-EQ is enabled? I can't confirm it in a the audio/Audyssey menu because the DD stream stops a s soon as I enter the menu. One solution would be to turn RE-EQ off permanently and always use Audysseys roll off in the reference target curve -- problem is I can't. Re-Eq is always enabled next time I power on the receiver and enter a THX mode. Also, I can't change the target curve to flat manually (in setup/audio/Audyssey) - it is grayed out in reference mode.
Thanks for any input regarding this.
Oh, and the firmware is a *really* slow download! Getting 4 KB/Sec
trallala is offline
post #130 of 4737 Old 11-12-2009, 02:03 PM - Thread Starter
rickardl's Avatar
Quoted: 123 Post(s)
Liked: 95
First post, bottom:
It is the THX mode that causes the flat "curve" to be used, not Re-EQ.
AFAIK, there is no way to see if the curve that is used is Audyssey Flat or Audyssey Reference
and there is no way to change it except implicitly by selecting/deselecting a THX mode.
rickardl is offline
post #131 of 4737 Old 11-12-2009, 02:23 PM - Thread Starter
rickardl's Avatar
Quoted: 123 Post(s)
Liked: 95
The firmware is the same as before; dates, filesizes, checksums...
rickardl is offline
post #132 of 4737 Old 11-12-2009, 02:59 PM
william06's Avatar
Quoted: 234 Post(s)
Liked: 126
I wonder if the first time caused some of the issues some of us had. I had none to speak of till I downloaded it.
By the way I should not say anything but since I reset my cable box and unplugged it for a half hour all the issues went away. I feel this is temp but shows the Onkyo is not the sole culprit.
Lg oled65G7P
Samsung K950
Sony x1000es
Lg 970
Toshiba X1 HD-DVD
Rocket fish HDMI 2.0 HDMI 4K switch 5x1
william06 is offline
post #133 of 4737 Old 11-12-2009, 03:33 PM
Ultimate Sound Wave
Quoted: 699 Post(s)
Liked: 1270
rickardl,
Thanks for the measurement. Onkyo does not provide Cut Sheets and I was in the middle of cutting a hole in the back of my TV Credenza for cable runs.
I understand the firmware I posted was the same as the previous version. Funny Onkyo had it Labeled as Firmware 2.
AdamG, ...out!
post #134 of 4737 Old 11-12-2009, 03:50 PM
Troll
ufokillerz's Avatar
Liked: 48
just noticed a open box nr-3007 on newegg, did anyone return this? seems like a good buy at the listed price, depending on what kind of problems it might have
ufokillerz is offline
post #135 of 4737 Old 11-12-2009, 05:22 PM
coral023's Avatar
I am a 905 owner and happy with my Onkyo experience with the exception of video switching. With DirecTV, it takes 4 or 5 seconds to get a picuture when switching from one HD channel to another. I am considering upgrading to the 5007 but am very interested to hear about the video switching performance in the 5007 especially as it compares to older Onkyo Reon implementions.
coral023 is offline
post #136 of 4737 Old 11-13-2009, 05:03 AM
CCONKLIN1's Avatar
channel surfing still sucks, especially from sd to hd channels and vice versa.
CCONKLIN1 is offline
post #137 of 4737 Old 11-13-2009, 11:06 AM
coral023's Avatar
Thats a disappintment. Are there any AVR's using video solutions like HQV or ABT or whatever that have good channel surfing performance or is it as good as it gets for now?
coral023 is offline
post #138 of 4737 Old 11-13-2009, 08:57 PM
Stix2's Avatar
I just noticed when running my computer thru the X007 series that it constantly clicks. This happens as sound is not always there it clicks off... someone IM's me and we have a conversation there is no sound only clicking. Yet I play music on media player and talk it works fine.
The 806 i had never clicked and worked all the time once engaged. These almost seem as they need a constant uninterrupted feed to stay engaged anything dirty or weak and it drops.
Stix2 is offline
post #139 of 4737 Old 11-14-2009, 03:06 AM - Thread Starter
rickardl's Avatar
Quoted: 123 Post(s)
Liked: 95
Has anyone verified the speaker levels after Audyssey setup?
Measured with a SPL meter, set C-slow, it should measure about 75dB
from the first measurement position.
False alarm... redid it today, it suddenly were almost spot on 75dB for all speakers using
the trims from Audyssey! Can't explain it.
I switched the dial
setting the scale to 70 and 80 back and forth a few times. Maybe the battery is playing tricks with the meter...
rickardl is offline
post #140 of 4737 Old 11-14-2009, 08:30 AM
dprose's Avatar
with all these issues with the 3007, i'm thinking of exchanging mine for the denon 431ci - has anyone else considered this?
dprose is offline
post #141 of 4737 Old 11-14-2009, 08:48 AM - Thread Starter
rickardl's Avatar
Quoted: 123 Post(s)
Liked: 95
Nope. What issues do you have?
rickardl is offline
post #142 of 4737 Old 11-14-2009, 09:10 AM
dprose's Avatar
audio has dropped playing cd's, cable and last night changed from listening to a cd in all channels to stereo and had a terrible noise (not 60hz) that i thought for a moment may have damaged my speakers
dprose is offline
post #143 of 4737 Old 11-14-2009, 10:18 AM
CCONKLIN1's Avatar
Ditto! I am not having any issues at all and after reading the threads think that the majority of issues are from crappy cable boxes.
Best
chris
post #144 of 4737 Old 11-14-2009, 01:34 PM
mikebridge's Avatar
Best
chris
nope, having audio and handshake/conversion issues with a tivo series3, a xbox 360 (hdmi version), and a PS3.
Neutral?
Blu: 54 Red: 25
Wii: 13 360: 32 PS3: 9
mikebridge is offline
post #145 of 4737 Old 11-14-2009, 01:54 PM
CCONKLIN1's Avatar
Weird! I have no problems with my Tivo HD and PS3 both slim and phat!
I should point out that I would rather watch paint dry than set my Tivo box to "native" and channel surf, though...
That is painful!
PS3 slim bitstreams and has had no issues on 4 movies I have watched so far. LPCM through the phat one has been fine as well.
I don't have an Xbox so can't comment on that one in my set up.
Chris
post #146 of 4737 Old 11-14-2009, 04:31 PM
mikebridge's Avatar
That is painful!
Chris
my audio issues seem to be related to switching inputs and the receiver then 'forgetting' or disabling all the speakers until i unplug/replug its power.
my handshake/conversion (1080p->1080i) issue seems to be gone for my 360 once i set the console to output 1080i instead of 1080p (1080i->1080i), and i never had the handshake/conversion issue w/ the tivo (1080i->1080i), but the tivo is hooked up via component since a hdmi cable broke the hdmi port. I still have issues w/ the PS3 occasionally (1080p->1080i).
*my 3007 converts everything to 1080i for my ancient sony 51" HD RP CRT which only supports 480p or 1080i natively, 720p gets downrez'ed to 480p so i try to avoid that resolution.
Neutral?
Blu: 54 Red: 25
post #147 of 4737 Old 11-14-2009, 07:23 PM
CCONKLIN1's Avatar
Plainfield IL? You are like 15 minutes from me. I am in Oswego IL. I have my Onkyo settings adjusted individually on a per input basis but everything that leaves the Onkyo at 1080p or 1080p24. Perhaps your 1080i setting is confusing things? I don't know why that would be, just tossing it out there as we have some of the same components...
Best,
Chris
post #148 of 4737 Old 11-15-2009, 03:10 PM
djradon's Avatar
Sorry to ask again, but does anybody have any ideas about reducing the overall audio delay? There's about a .500ms delay on all audio sources compared to when output from more low-tech receivers. Makes my 3007 pretty unusable for bad practice.
djradon is offline
post #149 of 4737 Old 11-15-2009, 09:35 PM
synfinatic's Avatar
So on page 24 of the manual it says:
"Use only front speakers with an impedance of 8 ohms or higher for bridging. Failure to do so may seriously damage the AV receiver."
So it sounds pretty clear: I should NOT bridge 6 ohm speakers.
synfinatic is offline
post #150 of 4737 Old 11-16-2009, 12:01 AM - Thread Starter
rickardl's Avatar
Quoted: 123 Post(s)
Liked: 95
Have you tried "Direct Mode" or "Pure Audio Mode"?
And are you using video? If so, use analog video and turn on the Picture Adjust->Game Mode:On.
And use the dedicated "Game" input connections.
rickardl is offline
Onkyo , Onkyo Tx Nr3007 140 Watts 9 2 Channel Av Surround Home Network Receiver Black , Onkyo Tx Nr5007 145 Watts 9 2 Channel Av Surround Home Network Receiver Black , Receivers Amplifiers , Speaker Systems
