The Subjective and Objective Evaluation of Room Correction Products - Page 20 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #571 of 591 Old 03-25-2010, 07:01 PM
SoundofMind's Avatar
Liked: 166
Maybe this thread is dead and I'm late to the party, but did anyone mention the Filipetti interviews on the Audyssey website (linked on the right in Archives)? Good stuff that pertains to much of the on-topic (non-hockey) debate here as to room correction in the mixing room.
Yes, I still like playing with Dalis.
SoundofMind is offline
post #572 of 591 Old 03-25-2010, 08:28 PM
Wireless member
pepar's Avatar
Quoted: 910 Post(s)
Liked: 502
Since you've woken the thread up, I might as well opine that somehow I don't think that news will be welcomed at this party.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
post #573 of 591 Old 03-29-2010, 08:36 PM
krabapple's Avatar
Quoted: 382 Post(s)
Liked: 371
Why not? What's objectionable in that review? The guy's subjective opinion of Audyssey Pro correction?
krabapple is offline
post #574 of 591 Old 10-03-2010, 07:06 AM
dweltman's Avatar
I did want to attempt to revive this topic, particularly to discuss the issue of using Room Correction software to EQ above the transition frequency.
Also, is using Room EQ to attempt to correct a deficiency in power response a good idea? What is the software actually doing? Is it boosting on-axis output to make up for a deficiency in off-axis response? Is this desirable?
dweltman is offline
post #575 of 591 Old 10-06-2010, 10:54 PM
hifisponge's Avatar
I'm probably a bit out my league with the company of guys posting here, but I do have a strong interest in acoustics and sound analysis, and since no one else has stepped up to answer this, I'll take a shot.
In my experience, the answer is, "it depends". I've owned speakers with power response problems that responded very well to Room EQ, and others that haven't. The problems tend to occur with attempting to correct the in-room response of speakers that show a dip at the mid / tweet crossover. If the EQ flattens the response through this region, sometimes the sound can become aggressive and harsh.
I think it is inevitable that if you correct a deficiency in the power response there will be a corresponding boost to that region in the direct sound. I don't know how much weight something like Audyssey gives to the direct vs. reflected sound, but I've often wondered if more weight should be given to the direct sound so that it doesn't "overcorrect" a dip in the power response.
hifisponge is offline
post #576 of 591 Old 10-07-2010, 05:45 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
How does it know which is which?
Gary J is offline
post #577 of 591 Old 10-07-2010, 11:15 AM
hifisponge's Avatar
Direct vs reflected sound can be distinguished by the arrival time of the test tone to the mic.
Two things come to mind that could help place more weight on the direct sound from the speaker.
A. Mic tip orientation: Point the tip of the mic towards the speaker.
B. Time-gated measurements: narrow the time window of the measurement so that the later-arriving reflected sounds contribute less to the reading.
post #578 of 591 Old 07-26-2011, 04:08 AM
Liked: 166
I believe this topic is still of interest and would encourage others to post here, ignoring the old thread warning, if that will resuscitate the thread. Otherwise we should start a new one.
post #579 of 591 Old 02-10-2012, 12:44 AM
nathan_h's Avatar
Quoted: 1007 Post(s)
Liked: 600
Originally Posted by Tonmeister2008 View Post
There has been a lot of research on this. If you look at pages 283 -287 of "Perceptual Audio Evaluation" by Soren Bech and Nick Zacharov you will find a summary of research on preferred listening levels or "most comfortable listening" levels (MCL) for different signals including the recommended levels from various standards. MLC for music varies from 69 to 85 dB depending on background noise. Mathers suggested an average level for music of 83.5 dB (A) which is close to what we used, and which our listening panel found comfortable and acceptable.
The MCL depends on many factors such as signal bandwidth, signal type, background noise, listening context (conversation versus entertainment), and age of listener (older people prefer higher levels for speech due to age-related hearing loss known as prebycusis: increasing the level improves speech intelligibility).
As far as standards go there are different recommended reference playback levels between SMPTE and ITU. ITU-R BS 1116-1 recommends a reference SPL of 85 dB(A) slow, which the authors claim is typically 5-10 dB too loud for subjects with most programs. I would tend to agree.
Wow I had to read a long way in this thread to get this nugget.
The Audyssey system used assumed 0dbfs on a recording is played back in the room at 105db, film industry standard.
But since the recordings used were pop records, where average levels were within 5db of 0dbfs, and the in room spl was about 80db, they had the system set more than 20db too low for Audyssey.... And the bass sounded anemic. Fletcher Munson, your dynamic loudness correction curve is calling and ready to assist.... If you want to use the system as intended, he says, turn me, dynamic EQ, on, or turn up the volume to theater reference levels....
Which I guess means that a room correction system without dynamic compensation for different mastering levels and playback volumes needs to assume compressed brick walled recordings played back at approx 80db?
____________________
Current theater & gear: "Nathan's Theater in Search of....".
nathan_h is offline
post #580 of 591 Old 02-10-2012, 02:50 AM
Roger Dressler's Avatar
Quoted: 1518 Post(s)
Liked: 710
Ok
I doubt that the average level of the pop recordings were -5 dBFS. But yes, they are indeed recorded at higher average levels than movies, typically 10-15 dB higher. In any case, it does not matter what modulation index is used on the delivery medium, as that is irrelevant to how loud we play music.
While the peak level of a movie channel is theoretically 105 dB (in one channel with a 0 dBFS sine wave), the average level of dialog is -27 dBFS, or 78 dB. That seems close enough to the 80 dB level of the music test.
Not needed in this case.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #581 of 591 Old 02-10-2012, 02:52 PM
nathan_h's Avatar
Liked: 600
Interesting. I cannot account for all the results of the listening test, but I have found the same anemic bass result with the older version of Audyssey when listening to music versus listening to movies. I guess I'm not explaining it well, but since it works when listening to a movie at reference level but not when listening to music, when I have to turn down the volume by 15 on the prepro to have e same impression of volume in the room, I surmise it has something to do with the program content.
nathan_h is offline
post #582 of 591 Old 02-10-2012, 08:09 PM
Liked: 710
Yes, I also find that movies generally have more bass than music, particularly those from the last decade. So I set up my processor's movie config with less bass than the music config to compensate.
post #583 of 591 Old 08-26-2014, 04:19 AM
dweltman's Avatar
Harman Seminar: “The Science of Loudspeaker-Room Calibration” – at CEDIA 2014 in the Coloradio Convention Center at 10 AM Wednesday Sept. 10, Dr. Sean Olive and Todd Welti of Harmon International will host a seminar examining the acoustic interactions between speakers and the listening room and their role in the perceived sound quality of a home theater or music system. These topics are among those that will be covered: The relationship between speaker measurements and listener preferences; Speaker/room resonances and reflections; Room acoustical treaments based on science; Do’s and don’ts of measuring and calibrating speakers in rooms; Optimizing the sweet spot, Does speaker/room correction thru EQ work?; Demonstration of a room-correction system.
dweltman is offline
post #584 of 591 Old 01-20-2015, 11:15 AM
wilbur_the_goose's Avatar
Quoted: 287 Post(s)
Liked: 135
Now that systems like Dirac are available, is there any consensus as to the best room correction out there today (2015)?
wilbur_the_goose is online now
post #585 of 591 Old 01-20-2015, 12:15 PM
krabapple's Avatar
Quoted: 382 Post(s)
Liked: 371
The problem is that no really well-done and useful comparison of current-generation room EQ tools has been published.
wilbur_the_goose likes this.
post #586 of 591 Old 01-28-2015, 01:20 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
Agreed, there are lots of auto-room EQ systems out there, need some un-biased testing and thread....
mtbdudex is online now
post #587 of 591 Old 04-20-2015, 09:13 AM
Quoted: 287 Post(s)
Liked: 135
This is a non-scientific opinion... But in my own experience, Dirac blows away Audyssey XT32.
post #588 of 591 Old 04-24-2015, 12:11 AM
Frank D's Avatar
Quoted: 273 Post(s)
Liked: 75
I have owned and tried all three and for me the order goes:
1 DIRAC with XMC-1
2 parametric eq with XMC-1
3 Anthem ARC w MRX 510
4 Audyssey x32 w Denon x4000
3 and 4 did not fix my issues but 2 did and 1 was even better.
Frank D is online now
post #589 of 591 Old 04-26-2015, 08:55 AM
dweltman's Avatar
I would be interested in a semi-scientific explanation as to what Dirac does better or different than ARC or Audyssey.
dweltman is offline
post #590 of 591 Old 04-26-2015, 10:26 AM
Nodscene's Avatar
Quoted: 123 Post(s)
Is that really your goal....to have good sound everywhere? My problem with your statement is that your room correction software/hardware is only available to rich people. Now maybe this is the cutting edge technology which is usually very expensive in the beginning, but do see a time in the near future where everyone (which is your stated goal) will be able to buy a stand alone system for their home theater setup ala Dirac?
"JBL Synthesis ARCOS is only available to trained and authorized JBL Synthesis dealers or through JBL Synthesis Factory Calibration or Authorized ARCOS Master Calibrators. ARCOS is supplied with all necessary equipment needed to calibrate a JBL Synthesis multichannel audio system, including: hardware, measurement microphones, computer, software and accessories. JBL Synthesis is part of the Harman Luxury Audio Group, therefore ARCOS is also available to systems that use Lexicon, Mark Levinson, or Revel products."
In my view, a room correction process should be nearly 100% automated, and not require the user to dial in a target curve or select one from 25 choices (that just tells me the manufacturer doesn't really know what the real target should be). The user shouldn't have to choose a subwoofer crossover or know what the LF limits are for their system. The more manual and labor-intensive the room correction calibration process becomes the more likely users will abuse it, or not use it at all. That gets us further away from the goal of having good sound everywhere.
Make something idiot-proof, and they will build a better idiot
Nodscene is offline
post #591 of 591 Old 04-26-2015, 01:15 PM
Quoted: 287 Post(s)
Liked: 135
My take as an admitted novice in this area:
1. The Dirac microphone used seems a lot sturdier than the Audyssey mic.
2. The mic positions seem to make a lot more sense (they ask for measurement positions above and below the listeners' ears).
3. Dirac uses the power of a PC/Mac to calculate filters. My Denon used only the CPU in the Denon, and we all know that a PC/Mac CPU(s) are going to be much more powerful than what's in an AVR.
4. Dirac gives you the opportunity to adjust your house curves.
5. I think that the Dirac servers in Sweden play a role during the process.
All I know is that it sounds a helluva lot better than Audyssey XT32, which I happily state that I loved before Dirac. And I still think it's a damn good ARC tool.
