Do I need a receiver for surround sound???? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-07-2009, 09:45 AM - Thread Starter
navvin1's Avatar
Do I need to buy a receiver to use a surround sound system? Will the surround system work without a receiver and if so what would the SS get connected to? I really need help
navvin1 is offline
post #2 of 12 Old 11-07-2009, 10:02 AM
Craig Woodhall's Avatar
you need a receiver to get surround sound. all your sources (satellite, cable, ps3, bluray) would connect to the receiver. Also all your speakers would connect to your receiver, it is the hub for your whole system.
Craig Woodhall is offline
post #3 of 12 Old 11-07-2009, 10:18 AM - Thread Starter
navvin1's Avatar
Thank you.
navvin1 is offline
post #4 of 12 Old 11-07-2009, 10:22 AM - Thread Starter
navvin1's Avatar
Any advice on the best receiver for the money under $300 ?
navvin1 is offline
post #5 of 12 Old 11-07-2009, 10:29 AM
Easyaspie's Avatar
No, you don't need a receiver. At least not a conventional one. Your options include an all in one system referred to as a Home Theater in a Box system. Some of those do actually use a receiver, some do not. The ones that don't have a receiver use a control console(basically a receiver) that sometimes includes a DVD player or Blu Ray player in one unit. Either way they include all the basic functions of a receiver.
Another option for some is to use whats called a "soundbar". These things give you simulated suround sound without having to position speakers around your room. Sound bars come in 2 flavors: powered and passive. The passive ones will require you to use a receiver, the powered ones do not. Again, the powered soundbars will have most of the functions of a receiver such as source selection and amplification. They usually have enough inputs to be adequate for someone looking for a modest system.
Easyaspie is offline
post #6 of 12 Old 11-07-2009, 10:36 AM - Thread Starter
navvin1's Avatar
OK, Well I just bought ,
samsung ln 46b750
sony bdp n460 blue ray
The speaker co. 5.1 surround system, I did not find a good htib so I bought seperate componets. Will the blue ray player act as my receiver like it would in a htib system or would my subwoofer included in my 5.1 system do the job?
navvin1 is offline
post #7 of 12 Old 11-07-2009, 10:44 AM
Selden Ball's Avatar
Quoted: 3046 Post(s)
Liked: 1494
Savvin,
You need a receiver to translate digital audio into analog speaker signals. Your Blu-Ray player has digital outputs. Your subwoofer needs an analog input.
Visit your local mass-market electronics store and get whatever the salesman recommends in your price range. He'll need to know exactly what you'll be connecting to it. Make sure it has a low-cost return-to-store policy or is available as a loaner. No matter what you get, you *will* want to get something different in a very short time. Without actually trying something, though, you won't have the personal experience to know what that should be.
Of course, everyone here will be glad to recommend their favorites.
Selden
Selden Ball is online now
post #8 of 12 Old 11-07-2009, 10:49 AM - Thread Starter
navvin1's Avatar
Originally Posted by Selden Ball View Post
Savvin,
Just when I thought I had everything I neededl lol. Can I get a decent receiver under $300? Any suggestions?
navvin1 is offline
post #9 of 12 Old 11-07-2009, 11:47 AM
PIRSQUARED's Avatar
If you have access to a Best Buy store (preferably one with a Magnolia Audio inside - I'm not sure if all BB stores have that, but many seem to now) then go down and listen to a demo. It's not likely you'll be able to get one of the models from the Magnolia section of the store, but you'll get a decent idea and the salesperson can recommend something in your price range. Typically you'd be looking at models like the Denon AVR-590 or Yamaha RX-V465 in your price range.
PIRSQUARED is offline
post #10 of 12 Old 11-07-2009, 01:13 PM
MLKstudios's Avatar
You can get a Sony soundbar with the AVR built into the sub for under $300 (try Amazon). Has plenty of HDMI in and one out.
eta I see you have Speaker Co. 5.1 speakers already. A refurb HK at eBay is the way to go. And yes, you DO need an AVR (Audio Video Receiver) to control everything.
MLKstudios is offline
post #11 of 12 Old 11-07-2009, 03:20 PM
dsmith901's Avatar
To the OP - no offense but you need to do much homework before proceeding any further. So please do yourself a big favor and go here and read the relevant articles:
http://www.ecoustics.com/Home/Home_A...iver_Articles/
As for the best value in receivers I highly recommend the fully warranted (2 yrs) Harman Kardon refurbs sold direct at harmanaudio.com (specials) and the H/K eBay store.
"The truth is out there!"
dsmith901 is offline
post #12 of 12 Old 11-08-2009, 07:47 AM
Easyaspie's Avatar
samsung ln 46b750
In your case to use the speakers you have already purchased you need a receiver.
No, your Blu Ray player will not function as a receiver. It is a source device, it has no switching, pre-amp or power amp provisions. Neither will the sub-woofer.
