Newbie help: Will I notice a difference replacing my 12yo receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 37 Old 11-25-2009, 09:42 PM - Thread Starter
imblind's Avatar
I'm really not an audiophile at all. Honestly, I think my current receiver sounds pretty darn good. Its a 12yo Kenwood, all it has is composite inputs and dolby pro-logic running 5.1.
Will I notice a drastic difference switching over to say an Onkyo 507 using HDMI?
imblind is offline
post #2 of 37 Old 11-25-2009, 10:19 PM
bluesky636's Avatar
bluesky636 is offline
post #3 of 37 Old 11-25-2009, 10:32 PM
fafner's Avatar
Originally Posted by bluesky636 View Post
Yes.
Blue sky has it right.
fafner
fafner is offline
post #4 of 37 Old 11-25-2009, 10:36 PM
kitsum's Avatar
For sure.
kitsum is offline
post #5 of 37 Old 11-26-2009, 05:39 AM
Selden Ball's Avatar
Quoted: 3427 Post(s)
Liked: 1698
Of course, there's the matter of what is better and if that difference matters to you.
Modern receivers have many more audio and video decoding options. If you decide to upgrade to high-resolution video (1080p BluRay), then that will include the availability of high resolution digital video and audio formats which your current receiver can't handle: the audio bit rates are just too high and it can't process digital video at all.
Most modern receivers also include room audio equalization which can significantly improve the sound you hear.
Selden
Selden Ball is offline
post #6 of 37 Old 11-26-2009, 07:59 AM
mrjktcvs's Avatar
If you are using composite video, then a new receiver won't do much for you. Obviously, you haven't made the jump to HD. Get a new TV and video player first, then worry about sound.
mrjktcvs is offline
post #7 of 37 Old 11-26-2009, 08:08 AM
jdsmoothie's Avatar
Quoted: 15006 Post(s)
Liked: 7233
+1
No reason to make any change until you've joined the ranks of HD video and audio owners.
jdsmoothie is offline
post #8 of 37 Old 11-26-2009, 09:41 AM
BMaugans's Avatar
I'm not sure how everyone else is giving such definitive answers without knowing anything about the rest of your setup. Yes, the discrete surround (Dolby Digital, DTS and the HD formats) will all sound better than Pro Logic, but you may actually be hard pressed to hear much difference if your speakers and their placement is sub-par. On the flip side, Pro Logic with a great system can sound pretty good. I was watching a DVD the other night and didn't realize it was in "plain old" stereo until I looked at my receiver around 3/4 of the way through it and noticed the indicator lights.
In simple terms, if your speakers are good, then by all means get a modern receiver. If your speakers are old crap, then upgrade those first.
BMaugans is offline
post #9 of 37 Old 11-26-2009, 11:42 AM
WebEffect's Avatar
Quoted: 98 Post(s)
Liked: 44
If it sounds good to you then you're all set. 12 years is not a long time. You have 5.1, it works, it gives you SOUND, prologic is great, and you like it.
Don't let the money-burning fanatics convince you otherwise. In a blind test between your receiver and a newer 5.1 receiver with the same speakers, I can almost GUARANTEE you would not hear a sound difference.
WebEffect is offline
post #10 of 37 Old 11-26-2009, 01:45 PM
kitsum's Avatar
Big difference in SQ? Maybe, depending on speakers and room size.
Big difference in PQ? Yes, if you use HDMI.
Big difference on my rack-stand? Yes, that's not gonna look the same anymore.
kitsum is offline
post #11 of 37 Old 11-26-2009, 03:06 PM
ccotenj's Avatar
Liked: 101
i'll take that bet... i won't get into the codec wars, but the automatic room correction in a "new" avr will make an audible difference...
- chris
ccotenj is offline
post #12 of 37 Old 11-27-2009, 04:28 PM - Thread Starter
imblind's Avatar
+1
What gave you guys the idea that I was using composite video? I have the HDMI out of my cable box going straight to my projector for video.
imblind is offline
post #13 of 37 Old 11-27-2009, 04:39 PM - Thread Starter
imblind's Avatar
So what should I get? I want to get something cheap. Onkyo 507?
imblind is offline
post #14 of 37 Old 11-28-2009, 02:45 PM - Thread Starter
imblind's Avatar
Help
imblind is offline
post #15 of 37 Old 11-28-2009, 03:08 PM
fafner's Avatar
Originally Posted by imblind View Post
Help
If you are going to get something cheap, just forget about it. Wait until you can get something good.
fafner
fafner is offline
post #16 of 37 Old 11-28-2009, 03:34 PM - Thread Starter
imblind's Avatar
fafner
That does not seem very helpful.
imblind is offline
post #17 of 37 Old 11-28-2009, 06:53 PM - Thread Starter
imblind's Avatar
Ok lets say my budget is $400
I'm willing to buy used or refurb.
What to do?
imblind is offline
post #18 of 37 Old 11-28-2009, 07:14 PM - Thread Starter
imblind's Avatar
Also I am curious about video upconversion. I hate watching standard def channels because they look terrible on my HD projector. Say if I get something like the Onkyo 707 that can upconvert SD to HD - will those channels look much better?
imblind is offline
post #19 of 37 Old 11-28-2009, 08:57 PM
fafner's Avatar
What to do?
Denon AVR-1610 listed as $379 at Crutchfield and probably around the same from other vendors. Denon receivers are great and retain their value so upgrading to a better AVR later is made easier. If you can get a used or refurb Denon AVR-XX08 for about the same or less check into that also.
fafner
fafner is offline
post #20 of 37 Old 11-28-2009, 09:00 PM
fafner's Avatar
In the Receiver field, "cheap" products most often get you very little. Always better to buy a "quality" brand even if it is a lower tier model, or the alternative is to wait until a budget allows for something better.
fafner
fafner is offline
post #21 of 37 Old 11-28-2009, 09:06 PM - Thread Starter
imblind's Avatar
fafner
I did not mean cheap as in crappy. I meant cheap as in low priced, such as buying a used onkyo 507 or 606 for $200.
imblind is offline
post #22 of 37 Old 11-29-2009, 09:18 AM
fafner's Avatar
I thought you meant low-price for new....which pretty much equals crappy. Any new receiver priced below say $249 I would consider cheap.
I have limited experience with Onkyo AVR's. What I found out however was that Onkyo tends to have more bells and whistles while Denon tends to have better build quality. Also Onkyo to me sounds overly bright and somewhat tinny while Denon tends to have a more rounded and warm sound.
Thus, that is why I recommended you look for a new or used Denon. If you can find used/refurb Onkyo AVR's for less money than comparable Denon models, that would tend to support my position that Denon products are both better to start with and that they also hold their value longer. Good luck.
fafner
fafner is offline
post #23 of 37 Old 11-29-2009, 09:30 AM
DarthNoom's Avatar
If you really want to hear and see the difference, you might want to start with a Blu-Ray player first. Then get a new receiver that will decode the new audio codecs.
DarthNoom is offline
post #24 of 37 Old 11-29-2009, 09:38 AM
mrjktcvs's Avatar
Reread your first post.
mrjktcvs is offline
post #25 of 37 Old 11-29-2009, 09:40 AM - Thread Starter
imblind's Avatar
Obviously you misunderstood and assumed incorrectly - it says nothing about video. Thanks.
imblind is offline
post #26 of 37 Old 11-29-2009, 11:30 AM
jdsmoothie's Avatar
Liked: 7233
If you really hate watching SD channels then man up and upgrade to an HD package. I've never really understood why folks go out and pay $1000+ on an HDTV only to feed them SD video when in virtually every case the SD video is worse on the HDTV then on their old CRT. Upgrade to an HD package and fully appreciate what your HD projector can do. Upscaled SD channels won't even come close to the picture quality of a true 1080i/p source. Also, as has been suggested several times now, upgrade to a Blu-Ray so you can actually take advantage of the HD audio codecs on BDs.
If you insist on keeping your SD cable package, AND you're itching to spend your $400 then the lowest level Denon AVR you'll want to consider is the 1910 which can upscale SD video as well as decode the HD audio codecs. It currently can be had near that price range at Electronic Expo and 6Ave.
post #27 of 37 Old 11-29-2009, 04:05 PM - Thread Starter
imblind's Avatar
Why do some of you keep assuming things? I DO have HD channels, all of them in fact. Unfortunately some programs I watch are not on HD channels, is this so surprising?...
I'm asking if an onkyo 707 will make SD look better than it is now, THAT'S ALL.
imblind is offline
post #28 of 37 Old 11-29-2009, 04:59 PM
jdsmoothie's Avatar
Liked: 7233
As it uses the older Faroudja chip technology, most likely no better than your existing HD cable box currently does. The 1910 with the newer ABT chip would most likely do a better job then either of the other two.
post #29 of 37 Old 11-29-2009, 05:10 PM - Thread Starter
imblind's Avatar
Thanks. I'll see if I can wing that much money for one.
imblind is offline
post #30 of 37 Old 11-29-2009, 06:13 PM
ccotenj's Avatar
Liked: 101
however, on a projector, if it looks like crap today, it's still gonna look like crap tomorrow, even with the better abt chip...
gigo... one of the universal laws of life, it's not unique to video...
- chris
ccotenj is offline
