Upgraditis dialemma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-14-2009, 01:07 PM - Thread Starter
jaymalya's Avatar
hi folks
Christmas is round the corner & upgraditis has hit me ( like a lot of other forum members) - Santa needs to give me something :-)
My audio set up is mirage om-9/om-c2 ( LCR) being driven by Pioneer 82TXS . Sources are Oppo BDP & DirectTV HR21. Usage is 60/40 movies/music.
I am looking at Denon AVR-989/2809 ( you know, Pioneer doesn't do TrueHD,DTSMA etc plus I am attacted towards dolby volume functionality)
I am also looking at Emo XPA-3 . My room is 20x33 plus the whole kitchen at the back.
Now the catch is I have budget for only one of these. Which one gives the most bang ( read improvement) for the money - denon or emo?
jaymalya is offline
post #2 of 5 Old 12-14-2009, 04:24 PM
dan711's Avatar
Originally Posted by jaymalya View Post
hi folks
I doubt the 2809 will sound much different than the 82txs-it won't be a power upgrade for sure. If you're interested in Truehd, DTSMA, etc you need a blu-ray player as well. if the Oppo you referred to is a blu-ray player-then let it handle the new codecs. Picking up the amp might help-I have never heard your speakers though.
Upgraditus hits us all from time to time. Are you happy with your speakers? What kind of sub do you have?
dan711 is offline
post #3 of 5 Old 12-14-2009, 06:30 PM - Thread Starter
jaymalya's Avatar
Right now Oppo BDP-83 is doing all the decoding (DTSMA,TrueHD etc) & sending PCM to pioneer. Sub is HSU VTF2 MK3.
I have no complains about speakers - in two channel they sound great. The center is great as well, but since the fronts are bi-amped & center is not , I feel some difference in movie mode and also I need to bump the volume much higher in movie mode to get the same volume level as two channel
jaymalya is offline
post #4 of 5 Old 12-15-2009, 05:32 AM
Selden Ball's Avatar
Quoted: 3503 Post(s)
Liked: 1770
I'd suggest a receiver that includes Audyssey equalization. That'd probably make the most noticeable improvement. Assuming the old receiver has preamp inputs and the new one has preamp outputs, you might consider keeping the current one and splitting the speaker load between them.
Selden
Selden Ball is offline
post #5 of 5 Old 12-15-2009, 06:44 AM - Thread Starter
jaymalya's Avatar
My current receiver has pre-outs but not inputs
One more info - I use BFD for sub equalization
jaymalya is offline
