Onkyo TX-SR607 Port Problem-NO SOUND - AVS Forum | Home Theater Discussions And Reviews
Old 12-27-2009, 06:53 AM - Thread Starter
quintr's Avatar
I have a new Onkyo TX-SR607 that I am in process of setting up. Pretty much everything is functional, except when I plug my Nano or other mp3 player into the Port jack on front of unit and receiver set to Port mode, I get no sound. Help???
quintr is offline
Old 12-27-2009, 07:35 AM
shinksma's Avatar
Location: Wandering the intertubes, on the way to damnation
Quoted: 80 Post(s)
Liked: 54
I suggest you ask this question in the 607's Official Owner's Thread - lots of folks there who have probably done the exact same thing and were either successful or had similar problems to provide hints:
http://www.avsforum.com/avs-vb/showthread.php?t=1136584
The thread is 49 pages long, but in a quick search I didn't find anything that sounded like your issue - however I'd suggest you also do a search before you ask the Q, just in case it has already been discussed.
shinksma
My opinions are my own, and do not necessarily reflect those of my captors.
shinksma is offline
Old 03-31-2012, 07:39 AM
leckig's Avatar
I just realized I have the same problem. I never used the PORT before. I plugged in my pm3 player and... nothing. Of course I switched the source correctly.
If this is not clear: this is about the front PORT 3.5 audio input.
leckig is offline
Old 03-31-2012, 07:44 AM
leckig's Avatar
SOLVED: the receiver needs to be in the AUX mode, not the PORT mode...
leckig is offline
