Help me pick a receiver for my Technics sb-cr77 and sb-cr55 speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-30-2009, 12:34 PM - Thread Starter
Bwanamukubwa's Avatar
Good day sirs/madams,
I have:
- 2x sb-cr77 (200W @ 8 ohms), and
- 2x sb-cr55 (140W @ 8 ohms)
Technics speakers.
From all the receivers i have come across, only the Marantz SR-96 seems like a contender (225W/channel), but it doesn't have DTS..
Is there a reasonably new receiver out there that is not more expensive than the speakers combined that can handle them?
Bwanamukubwa is offline
post #2 of 4 Old 12-30-2009, 01:59 PM
phantom52's Avatar
Quoted: 232 Post(s)
Liked: 240
I have:
Technics speakers.
Budget would be helpful. And those numbers for those speakers are maximums not minimums. So there are a lot of receivers that will work with those speakers.
phantom52 is offline
post #3 of 4 Old 12-30-2009, 06:07 PM - Thread Starter
Well, the speakers are probably worth $200 for the lot, so somewhere around there.. i don't need anything really high end, just something that matches these speakers well, that can push them and still have fidelity such that it's not something i'm having to deal with.. any suggestions?
post #4 of 4 Old 12-30-2009, 07:26 PM
phantom52's Avatar
Quoted: 232 Post(s)
Liked: 240
This would work very well and is about as inexpensive as you can get.
http://www.accessories4less.com/make...-Silver/1.html
