Harmon Kardon HK 3490 with JBL L890s Not enough bass! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-09-2010, 04:32 PM - Thread Starter
GotAViper's Avatar
Hey Guys,
I purchased the HK 3490 and JBL L890s because i figured 2 channel amp, with 2 monsters speakers.. all I should need? I guess I was wrong.
With the bass all the way on high the speakers sound amazing but just not enough bass. I have to turn the receiver volume way way up to get them to really rumble the house but at that point the highs are just too loud to bear.
I am not good with this stuff but I figured 2 channel amp = 2 speakers only?
I see there is a subwoofer output on the receiver... Can I add a subwoofer to this receiver along with my 2 front speakers? Or will that take away power going to the 2 monster speakers i got? Should i buy an amplified subwoofer? or what should i do here?
Thanks in advance!
GotAViper is offline
post #2 of 9 Old 01-09-2010, 04:39 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Its doesn't take any power away from your JBL speakers because you use powered subwoofers! That means the sub has its own built in amp.
Afro GT
afrogt is offline
post #3 of 9 Old 01-09-2010, 06:17 PM
natchie's Avatar
Quoted: 23 Post(s)
Liked: 30
There is a separate bass volume on the front panel lower right. Did you try that yet?
(Oops..you already did...)
Yes, an amplified SW will help.
natchie is online now
post #4 of 9 Old 01-09-2010, 06:49 PM - Thread Starter
GotAViper's Avatar
So I can just buy a powered/amplified subwoofer and hook it into the receiver since it has sub outputs? Do i have to do/change anything on the receiver so its not sending power to the sub or does it automatically know somehow?
post #5 of 9 Old 01-09-2010, 06:50 PM - Thread Starter
GotAViper's Avatar
Also do you guys have any advice on a good powered subwoofer to add to my system?
post #6 of 9 Old 01-09-2010, 06:53 PM - Thread Starter
GotAViper's Avatar
Is the JBL L8400P 12" (300mm), 600-Watt, High-Performance Powered Subwoofer any good?
I can get one for $400 plus shipping.
post #7 of 9 Old 01-09-2010, 08:26 PM
natchie's Avatar
Quoted: 23 Post(s)
Liked: 30
That sounds like an awesome SW...I am not familiar with that one but it should do the job of blasting your walls...
post #8 of 9 Old 01-09-2010, 08:34 PM
Knucklehead90's Avatar
Quoted: 385 Post(s)
Liked: 332
Thats a decent enough sub - and the price is certainly good. There are other subs you might want to consider before you buy one. Elemental Designs - HSU - SVS - AV123 all make excellent subs in that price range.
The JBL Studio L series are noted for somewhat bright highs. A friend of mine has the L820s and they had to be tamed a bit for him. We added a sub.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #9 of 9 Old 06-10-2013, 06:04 PM
NotInvolved's Avatar
i can almost be 100% sure you are sitting in standing waves. use proper placement and your speakers will sound the best. i thought the same thing but then i read pages and pages of acoustic articles and things about placement and my system sounds so much better
-speakers: cerwin vega vs120s, cerwin vega LS12s, cerwin vega at12s, jbl S36II, pok audio psw10, realistic mc1000, paradigm 7se MKII, sanyo sx600
yamaha rxv375
NotInvolved is offline
