Pioneer VSX-9040TXH Advanced MCACC blinking !!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 01-17-2010, 10:45 AM - Thread Starter
kcr6419's Avatar
The Advanced MCACC light on my VSX-9040TXH started blinking after a power outage. I just hooked everything up to it and got it set up last night. I've searched for hours and can't find a solution for this model.
The Enter + Video2 won't work because there's no video2 button.
From what I've been able to find, Pioneer's other models all have some type of button combination you can press to reset the problem.
Does anyone have any idea of the correct buttons to push for this model.
the VSX-9140TXH, VSX-21TXH and VSX-23TXH are all almost identical so if anyone has had the same problem with any of these and knows the solution, I'd greatly appreciate it.
kcr6419 is offline
post #2 of 18 Old 01-17-2010, 06:16 PM
drebit's Avatar
Will your unit power on?
On page 98 in the owners manual it says if the unit powers off and wont power on and the MCACC light is blinking you have a major problem and need to contact Pioneer for service.
drebit is offline
post #3 of 18 Old 01-17-2010, 07:40 PM - Thread Starter
kcr6419's Avatar
This is a common problems with previous models. They are very touchy when not powered off via the power button.
If the power flickers on and off repeatedly, they tend to go into a protected state.
Unfortunately, I didn't have mine on a UPS yet, just a surge protector.
If I can try the button sequence first before sending it out for service, I'm pretty confident it will take care of the problem.
Worst part of this is it happened on my birthday. Plus I had people over ready to watch the football games.
kcr6419 is offline
post #4 of 18 Old 01-17-2010, 08:23 PM
afrogt's Avatar
Quoted: 1357 Post(s)
Liked: 940
I'm sure there is a processor reset combination of buttons. Check the Pioneer Elite vsx-21/23 thread because that receiver is pretty much a VSX-21.
Afro GT
afrogt is online now
post #5 of 18 Old 02-04-2010, 07:31 PM
CRSO's Avatar
I have the same problem, flashing mcaac light on my vsx23.
Any button reset combo?
CRSO is offline
post #6 of 18 Old 07-09-2010, 07:15 PM
Liquidfire's Avatar
Hey guys,
The reset code you are looking for with the 23TXH is Tune - & Multi-Zone on-off buttons held simultaneously for 2 seconds. This will reset the power fault. Use at your own risk, since resetting is no guarantee that there is not a problem. My opinion though, is that a simple power fluctuation just causes the unit to self protect unnecessarily. I doubt whether a dealer visit is justified. Great source of income for the repair shops I bet.
Have no fear, Liquid's here...
Liquidfire is offline
post #7 of 18 Old 09-25-2011, 01:55 PM
siiix's Avatar
awesome it worked its actualy the tune(-) and multi-tume (control) buttons
i had the problem that some liquid spilled in it months ago, it went in to protective mode and untill now i assumes its broken ... YAY
siiix is offline
post #8 of 18 Old 12-13-2012, 08:47 PM
sc-1525's Avatar
I turned on my SC-1525 and it emited a loud beep, after that the advanced mcacc started blinking.... I tried the combo TUNE - MULTI ZONE ON OFF and it worked.
sc-1525 is offline
post #9 of 18 Old 05-27-2013, 06:20 PM
rolli7267's Avatar
hi, i have the SC86 model and got the blinking MCACC. will the procedure be the same for this model?
rolli7267 is offline
post #10 of 18 Old 12-15-2013, 02:58 PM
BisonFan2013's Avatar
Great advice. I pressed Multi-Zone Off/On and Tune (Down) together - it worked (Please note that the system may go back to blinking again but repeat the "Multi-Zone Off/On and Tube (Down)" process).
BisonFan2013 is offline
post #11 of 18 Old 02-01-2014, 02:49 AM
ljxx's Avatar
This topic just saved me a very stressful weekend!
Not being fully awake yet on a Saturday morning, I was measuring up for a new TV stand. Schoolboy error - I didn't power the receiver off before putting the metal end of the tape measure behind the amp. It only touched the very top/right/back corner but must have connected the back panel to the overlapping chassis surround. Result: a click, and no power light.
I thought it was completely dead but after changing the power cable, checking the manual and searching online I found this topic.
Model: Pioneer SC LX81
Reset combination: Down arrow (over to the left) and Multi-Zone and Source "on/off" button.
It fired back into life pretty quickly, the (annoyingly bright) power LED came on. I can't remember if it took 2 seconds, but I'm not going to try it again!!!
ljxx is offline
post #12 of 18 Old 03-01-2015, 08:24 AM
Liked: 0
Just wanted to comment. I have a pioneer VSX-31. We had a bad ice storm about 3 weeks ago and lost power. When the power was restored I could see again, it was at night. I had a beer can on my computer desk. I went to pick it up and dump the rest out. It bounced of my computer chair and landed on my receiver. I quickly grabbed it and very little spilled into my receiver. It spilled in the front vent holes and I looked and saw there was nothing there but the back of a heat sink. I waited until the next day to try to turn it on. When I did the advanced mcacc started blinking. I was sick. I thought I had ruined my receiver! I found this thread and powered the receiver up and pressed and held the tune down and multi-zone on off buttons down at the same time. To my relief the receiver came back on and works fine. I think the loss of power caused the problem now after reading this thread. I decided to move my receiver anyway so a beer cannot accidentally fall onto it. Thanks for the advice on the reset! Peace
1bert1 is offline
post #13 of 18 Old 07-27-2015, 09:40 PM
Liked: 0
I have a pioneer elite vsx30 model and over tried the hold down multi zone and tune down button and the screen will say power on but then it turns off again and the mcacc light keeps blinking. Any thoughts on what else I can do before calling for service. Our system is only a little over 3 years old. Really frustrated right now. And all I did was turne off the tv after the Blackhawks . Ugh!
lbrigham is offline
post #14 of 18 Old 10-24-2015, 03:27 PM
yama6060's Avatar
Pioneer SC-25 Advanced MCACC blinking light.
Originally Posted by Liquidfire View Post
Hey guys,
This thread is saving me. I have Pioneer SC-25 model also WORKED (do it at your own risk)
"Tune - & Multi-Zone on-off buttons held simultaneously for 2 seconds"
Thank you very much for this thread.
yama6060 is offline
post #15 of 18 Old 12-15-2015, 05:31 AM
Liked: 0
Pioneer Elite SC-37 Standby light flashing blue no power.............
After a storm and quick power brown out my amp powered off and when I tried to turn back on NOTHING.
Only the blue standby light would continuously keep flashing in the power button....disconnected everything, unplugged and still same problem...Anyways after finding this post you guys saved me some time,stress and most importantly cash..I cant believe that this reset info ( PRESS down Arrow button and multi-zone on/off button together for 5 seconds) is not in the manual. Seems like a pretty douche bag thing to do..guess they want you to send it in for service and collect your cash while they look like heroes after charging you to push 2 buttons..WOW
Anyways enough of my rant just thought i would make an account and post my THANK YOU to you guys....CHEERS!!!
PMF23 is offline
post #16 of 18 Old 12-19-2015, 07:29 AM
Liked: 0
Unhappy Reset Sequence works... for 3 seconds!
I have the same issue. Did you get yours resolved? I'm 98% sure this solution will involve a soldering iron.
Ryan Potter is offline
post #17 of 18 Old 12-26-2015, 09:11 PM - Thread Starter
kcr6419's Avatar
Most likely, there's a blown fuse and it's not a fuse that you can just pull out and replace. I sent mine out for service because it was under warranty. The fuse cost a few cents but pioneer didn't have any available so I was left waiting over a month before I started bothering the service guy for status. I bugged him enough that he got Pioneer to agree to replace the entire amp board. It was a little fuse that is soldered to the board.
kcr6419 is offline
post #18 of 18 Old 12-03-2016, 02:59 PM
grahamhgreen's Avatar
Hi!
I've got the same issue on a Svc-1021.... We're you able to get yours working?
Last edited by grahamhgreen; 12-03-2016 at 03:09 PM. Reason: I see this was addressed in the thread already, thanks! The question now is the service charge VS replacement...
grahamhgreen is offline
