List of AV Receivers & Pre/Pros with Pure DSD to Analog Processing - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 3 Post By vfalks
  • 1 Post By Shmockolovitch
post #1 of 23 Old 02-27-2010, 10:31 AM - Thread Starter
vfalks's Avatar
I thought I'd compile a massive list of receivers and pre/pros which accept digital DSD input and decode it to analog with no conversion to PCM or processing in between - for anyone interested in true "pure DSD" playback (whether that's the best solution or not).
It took me ages and what I discovered was that you can't TRULY know what's the case with a receiver/preamp unless you know the very path and design of the components and circuitry inside it - what chips are connected and how, the very pins that are used on those chips, the controllers, how the DAC operates and if it is doing so as hoped (pure DSD)!
Anyway, in a very post-modern way I've simply researched all I can and gathered everything (the info - or lack of info - from the horses' mouths, reported claims, evidence, proof etc) in the one place so that YOU can ultimately make your own conclusion. I have sorted the receiver models into two groups, ones that (supposedly ) DO have a pure DSD to analog path, and random ones that supposedly, or definitely don't. If you have any info to correct or add to what I have below please chime in with it!
Also good about this list is the usually obscure info on what DACs receivers use so it's a useful resource just for that too.
Criteria for pure DSD decoding
So the criteria I've established for a receiver to be confirmed (or at least to an extent believed) to have a 100% pure analog path, it has to have:
1. A digital DSD input (HDMI, i.LINK or DENON Link)
2. Some sort of pure DSD playback mode on the receiver whereby it (supposedly) forgoes any processing or conversion to PCM
3. A DSD-Capable DAC (that doesn't convert to a PCM signal before the analog output)
4. Whatever other info that helps us know its DSD status.
And at that point, YOU decide what your conclusion is. Some items have conflicting claims from different people and that's all the info we have.
And for the second big list of receivers (ones that don't have pure DSD decoding), it onlt needs one of the first three criteria above in order to be 100% confirmed as a NON pure a DSD receiver.
Other notes and useful links/quotes/claims/info
- PCM1792 DAC is a technically superior DSD DAC to the 1796! 1791 is worse than both...
- PCM1792 and DSD1792 ARE different but they both have the same identical DSD to analog design and capability, so if they're ever mixed up it doesn't matter if you are considering DSD to analog capability.
- BAH WHAT ABOUT DSD1791 AND PCM1791? LOL....:so much confusion:
- Some of the receiver model equivalents like Onkyo/Integra are not 100% identical with internal components but are considered equivalents and are identical in terms of DAC, and DSD processing.
- http://www.avsforum.com/avs-vb/showthread.php?t=982166
- The DSD1700/DSD1700E is a DSD-capable DAC.
- "All Burr-Brown decoders (I think that one of these is used by Onkyo) that are currently on the TI website do not submit the DSD stream via PCM but all streams are put through some form of "Enhanced Multilevel Delta-Sigma Modulator" before a final D/A step. Whether this is good, bad or a necessary step that all DSD converters would have I am not technically aware enough to comment"....hmm.....
- A good technique to dig around for info on DACs in receivers is to look up google images of receiver models...it can lead to webpages where people with screwdrivers have opened up their receivers to take a look at it...
List of Supposed Pure DSD receivers
MODEL:
Denon AVC-A11XV
DIGITAL DSD INPUT:
i.LINK/FireWire/IEEE 1394 DSD input
DENON Link DSD input
[Supposed] Pure DSD Listening Mode:
PURE DIRECT -> DSD DIRECT / DSD MULTI DIRECT
DSD-CAPABLE DAC:
Texas Instruments PCM1791A
Notes/unrefuted claims/evidence/proof REGARDING THEIR CASE:
The user manual states that When playing DSD signals in the DIRECT or PURE DIRECT mode, the DSD signals are converted into analog signals. When playing in other surround modes, the DSD signals are first converted into PCM signals with a sampling frequency of 88.2kHz.
http://www.denon.co.uk/site/datadir/..._AVC-A11XV.PDF
CURRENT CONCLUSION:
If one is to believe what the manual says, it's 100% pure DSD
MODEL:
Denon AVC-A1HDA (AVC-A1HD)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Burr-Brown PCM1796
The user manual states that When playing DSD signals in the DIRECT or PURE DIRECT mode, the DSD signals are converted as such into analog signals. When playing in other surround modes, the DSD signals are first converted into PCM format, then into analog signals. (http://www.denon.co.uk/site/download..._AVC-A1HDA.pdf)
CURRENT CONCLUSION:
MODEL:
Denon AVP-A1HDA (AVP-A1HD)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Burr-Brown PCM1796
The user manual states that When playing DSD signals in the DIRECT or PURE DIRECT mode, the DSD signals are converted as such into analog signals. When playing in other surround modes, the DSD signals are first converted into PCM format, then into analog signals. (http://www.denon.co.uk/site/download..._AVP-A1HDA.pdf)
http://www.avforums.com/forums/8923150-post10.html
CURRENT CONCLUSION:
MODEL:
Denon AVP-A1HDCI (AVP-A1HDCIA)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Burr-Brown PCM1796
The user manual states that When playing DSD signals in the DIRECT or PURE DIRECT mode, the DSD signals are converted as such into analog signals. When playing in other surround modes, the DSD signals are first converted into PCM format, then into analog signals. (http://www.usa.denon.com/AVP-A1HDCI-OM-E_101A.pdf)
CURRENT CONCLUSION:
MODEL:
Denon AVR-2808CI (AVR-2808) (AVC-2808)
DIGITAL DSD INPUT:
HDMI DSD input
YES:
DSD-CAPABLE DAC:
YES:
Burr-Brown DSD1608
The user manual states that When playing DSD signals in the DIRECT or PURE DIRECT mode, the DSD signals are converted as such into analog signals. When playing in other surround modes, the DSD signals are first converted into PCM format, then into analog signals. (http://www.denon.co.uk/site/download...d_AVR-2808.pdf)
CURRENT CONCLUSION:
MODEL:
Denon AVR-2809CI (AVR-2809)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
The user manual states that When playing DSD signals in the DIRECT or PURE DIRECT mode, the DSD signals are converted as such into analog signals. When playing in other surround modes, the DSD signals are first converted into PCM format, then into analog signals. (http://www.usa.denon.com/AVR-2809CI-OM-E_102A.pdf)
CURRENT CONCLUSION:
MODEL:
Denon AVR-3808CI (AVR-3808) (AVC-3808)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
The user manual states that When playing DSD signals in the DIRECT or PURE DIRECT mode, the DSD signals are converted as such into analog signals. When playing in other surround modes, the DSD signals are first converted into PCM format, then into analog signals. (http://www.usa.denon.com/AVR-3808CI-OM-E_404A.pdf)
http://www.sa-cd.net/faq
CURRENT CONCLUSION:
MODEL:
Denon AVR-4308CI (AVR-4308)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
The user manual states that When playing DSD signals in the DIRECT or PURE DIRECT mode, the DSD signals are converted as such into analog signals. When playing in other surround modes, the DSD signals are first converted into PCM format, then into analog signals. (http://www.usa.denon.com/AVR-4308CI-OM-E_305A.pdf)
CURRENT CONCLUSION:
MODEL:
Denon AVR-4310CI (AVR-4310) (AVC-4310)
DIGITAL DSD INPUT:
HDMI DSD input DENON Link DSD input
DSD-CAPABLE DAC:
The user manual states that When playing DSD signals in the DIRECT or PURE DIRECT mode, the DSD signals are converted as such into analog signals. When playing in other surround modes, the DSD signals are first converted into PCM format, then into analog signals. (http://www.usa.denon.com/AVR-4310CI-OM-E_109A.pdf)
CURRENT CONCLUSION:
MODEL:
Denon AVR-4810CI
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
The user manual states that When playing DSD signals in the DIRECT or PURE DIRECT mode, the DSD signals are converted as such into analog signals. When playing in other surround modes, the DSD signals are first convertedinto PCM format, then into analog signals. (http://www.usa.denon.com/AVR-4810CI-OM-E_007B.pdf)
CURRENT CONCLUSION:
MODEL:
Denon AVR-5308CI (AVR-5308CIA)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Burr-Brown PCM1796
The user manual states that When playing DSD signals in the DIRECT or PURE DIRECT mode, the DSD signals are converted as such into analog signals. When playing in other surround modes, the DSD signals are first convertedinto PCM format, then into analog signals. (http://www.usa.denon.com/AVR-5308CI-OM-E_207A.pdf)
CURRENT CONCLUSION:
MODEL:
Denon AVR-5805CI
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
Burr-Brown PCM1792 (DSD1792)
The user manual states that When playing DSD signals in the DIRECT or PURE DIRECT mode, the DSD signals are converted as such into analog signals. When playing in other surround modes, the DSD signals are first convertedinto PCM format, then into analog signals. (http://www.usa.denon.com/AVR-5805CI-OM.pdf)
CURRENT CONCLUSION:
MODEL:
Marantz SR6001
DIGITAL DSD INPUT:
HDMI DSD input
PURE DIRECT -> PURE DIRECT / DSD
DSD-CAPABLE DAC:
Cirrus Logic CS4382A
The user manual lists DSD direct conversion as a feature alongside DSD to PCM converter (http://us.marantz.com/DFU_SR6001_final_eng.pdf)
CURRENT CONCLUSION:
The manual seems pretty clear but there is no hard proof.
MODEL:
Marantz SR7001
DIGITAL DSD INPUT:
HDMI DSD input
PURE DIRECT -> PURE DIRECT / SA-CD
DSD-CAPABLE DAC:
The user manual lists DSD direct conversion as a feature alongside DSD to PCM converter(http://us.marantz.com/DFU_SR7001_SR8001_final_eng.pdf)
http://www.avsforum.com/avs-vb/showt...4#post10452794
CURRENT CONCLUSION:
MODEL:
Marantz SR7002
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Unlike Models like SR6001, Sr7001 and SR8002, the user manual fails to list DSD direct conversion as a feature and ONLY lists DSD to PCM converter. (http://us.marantz.com/DFU_SR7002_SR8002_final_eng.pdf)
CURRENT CONCLUSION:
The information in the user manual is unclear, if not pointing towards non pure DSD processing. No conclusion can be made.
MODEL:
Marantz SR8001
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
MODEL:
Marantz SR8002
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
MODEL:
Marantz AV8003
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Unlike Models like SR6001, Sr7001 and SR8002, the user manual fails to list DSD direct conversion as a feature and ONLY lists DSD to PCM converter. (http://www.marantz.com/pdfs/e_av8003_man.pdf)
http://www.hometheaterhifi.com/surro...3.html?start=5
CURRENT CONCLUSION:
MODEL:
Marantz SR9600
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
Cirrus Logic CS4397
The user manual lists DSD direct conversion as a feature alongside DSD to PCM converter( http://us.marantz.com/DFU_SR9600_Final_Eng.pdf)
The official info sheet mentions that DSD to PCM conversion It is bypassed in the DSD DIRECT mode. (http://us.marantz.com/SR9600_info_sheet.pdf)
CURRENT CONCLUSION:
The info stated by the official info sheet and user manual seems to be clear that it is pure DSD to analog processing.
MODEL:
Onkyo PR-SC885 (PR-SC885P) (Integra DTC-9.8)
DIGITAL DSD INPUT:
HDMI DSD input
Delay Enable set to No, DIRECT -> DSD Direct
DSD-CAPABLE DAC:
Burr-Brown ___ (whatever it is, it IS DSD capable...)
The user manual states "In listening modes other than DSD Direct and Pure Audio, DSD sources are converted and handled as PCM." (http://filedepot.onkyousa.com/Files/...SC885_En_A.pdf)
CURRENT CONCLUSION:
MODEL:
Onkyo PR-SC886 (Integra DTR-9.9) (Integra DHC-9.9)
DIGITAL DSD INPUT:
HDMI DSD input
DAC Direct set to Yes, DIRECT -> DSD Direct
DSD-CAPABLE DAC:
Burr-Brown PCM1796
AGAINST: the user manual states that DSD sources are converted and handled as PCM. (http://www.eu.onkyo.com/dl/1186948/M...86_English.pdf)
AGAINST: http://www.aperionaudio.com/communit...read.aspx#8507
FOR: "The latest Onkyo models 706 to 906 despite having misprinted inaccurate manuals do decode DSD direct to Analogue without PCM in Pure & Direct listening modes." (http://sa-cd.net/showthread/30517/33649#33308)
FOR: http://www.avsforum.com/avs-vb/showt...8#post16369728
FOR: I have a theory that the statement "DSD sources are converted and handled as PCM" is either a misprint or badly-written, due to inconsistencies with what the rest of the user manual says and infers. It might indeed do DSD direct to analog conversion in "DSD Direct" mode but nothing can be confirmed until someone contacts Onkyo and gets an answer from them.
CURRENT CONCLUSION:
No clear conclusion.
MODEL:
Onkyo PR-SC5507 (PR-SC887) (Integra DTS-80.1) (Integra DHC-80.1)
DIGITAL DSD INPUT:
HDMI DSD input
DAC Direct set to On, DIRECT -> DSD Direct
DSD-CAPABLE DAC:
Burr-Brown PCM1795
User manual is not 100% clear about whether the DSD signal merely bypasses the DSP operations or whether it bypasses conversion to PCM altogether. (http://www.eu.onkyo.com/dl/1459188/M...07_English.pdf) (http://filedepot.onkyousa.com/Files/...0.1_En_web.pdf)
http://www.sa-cd.net/showthread/49520/49621#49629
CURRENT CONCLUSION:
MODEL:
Onkyo TX-NR1007
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Burr-Brown PCM1796
User manual is not 100% clear about whether the DSD signal merely bypasses the DSP operations or whether it bypasses conversion to PCM altogether. (http://filedepot.onkyousa.com/Files/...En_webver2.pdf)
CURRENT CONCLUSION:
MODEL:
Onkyo TX-NR3007 (Integra DTR-70.1)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Burr-Brown PCM1796
User manual is not 100% clear about whether the DSD signal merely bypasses the DSP operations or whether it bypasses conversion to PCM altogether. (http://63.148.251.135/redirect_servi...En_webver2.pdf) (http://filedepot.onkyousa.com/Files/...0.1_En_web.pdf)
CURRENT CONCLUSION:
MODEL:
Onkyo TX-NR5007
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Burr-Brown PCM1795
CURRENT CONCLUSION:
MODEL:
Onkyo TX-SR706 (TX-SA706)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
MODEL:
Onkyo TX-SR805 (Integra DTR-7.8)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Burr-Brown PCM1796
The user manual states "In listening modes other than DSD Direct and Pure Audio, DSD sources are converted and handled as PCM." (http://filedepot.onkyousa.com/Files/...5_875_B_En.pdf)
CURRENT CONCLUSION:
MODEL:
Onkyo TX-SR806 (TX-SA806) (TX-SA806X)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
I think SA806x has Burr-Brown 1796
AGAINST: http://www.sa-cd.net/showthread/49520/49625#49625
CURRENT CONCLUSION:
MODEL:
Onkyo TX-SR875
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Burr-Brown PCM1796A
CURRENT CONCLUSION:
MODEL:
Onkyo TX-SR876 (Integra DTR-8.9)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Burr-Brown PCM1796
CURRENT CONCLUSION:
MODEL:
Onkyo TX-NR905 (TX-NA905) (Integra DTR-8.8)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Burr-Brown PCM1796
The user manual states "In listening modes other than DSD Direct and Pure Audio, DSD sources are converted and handled as PCM." (http://www.eu.onkyo.com/dl/1024083/M...0TXNR905_1.pdf)
http://forum.blu-ray.com/1271751-post18.html
CURRENT CONCLUSION:
MODEL:
Onkyo TX-NR906 (TX-SR906) (TX-NA906) (TX-NA906X)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Burr-Brown PCM1796
CURRENT CONCLUSION:
MODEL:
Pioneer SC-09TX (SC-LX90)
DIGITAL DSD INPUT:
HDMI DSD input
PURE DIRECT -> SACD DIRECT
DSD-CAPABLE DAC:
Wolfson WM8741
The user manual does not address DSD's processing in PURE DIRECT mode. (http://www.pioneerelectronics.com/St...ctions1213.pdf)
Note: the WM8741 DAC itself has an option to have DSD to PCM path!!!! So how do we know what the pioneer engineers have it set to? We need to email/ring them and ask...
CURRENT CONCLUSION:
MODEL:
Pioneer VSA-AX2AH
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Burr-Brown DSD1791
CURRENT CONCLUSION:
MODEL:
Pioneer VSA-AX4AH (VSA-LX70) (VSX-LX70)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Burr-Brown DSD1791
I think this does have a pure direct mode.
CURRENT CONCLUSION:
MODEL:
Pioneer VSA-AX5i (VSA-AX5i-N)
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
MODEL:
Pioneer VSA-AX10i-S (VSA-AX10i)
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
MODEL:
Pioneer VSA-AX10Ai (VSA-AX10Ai-S)
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-55TXi
DIGITAL DSD INPUT:
SACD DIRECT set to ON -> SACD DIRECT
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-74TXVi (VSX-AX4AVi-S) (VSX-AX4AVi) (VSA-AX4AVi)
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
???? Burr-Brown __????__
The user manual talks about a DSD->PCM light that lights up when the incoming signal is being converted to PCM (supposedly when in non pure (DSP) mode), which suggests that when it is off, pure passthrough to the DAC is taking place.
http://www.avsforum.com/avs-vb/showt...29#post8051829
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-82TXS-S (VSX-82TXS) (VSX-AX2AS-S) (VSX-AX2AS) (VSX-AX2ASi-S?) (VSX-AX2ASi?)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
The user manual talks about a DSD->PCM light that lights up when the incoming signal is being converted to PCM (supposedly when in non pure (DSP) mode), which suggests that when it is off, pure passthrough to the DAC is taking place. (http://safemanuals.com/user-guide-in...VSX-AX2AS-S-_R)
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-84TXSi-S (VSX-84TXSi) (VSX-AX4ASi-G) (VSX-AX4ASi-S) (VSX-AX4ASi) (VSA-AX4ASi)
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
http://www.avsforum.com/avs-vb/showt...84#post8051984
The user manual talks about a DSD->PCM light that lights up when the incoming signal is being converted to PCM (supposedly when in non pure (DSP) mode), which suggests that when it is off, pure passthrough to the DAC is taking place. (http://safemanuals.com/user-guide-in...SX-AX4ASI-S-_U)
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-92THX
DIGITAL DSD INPUT:
HDMI DSD input
PURE DIRECT -> Straight decoding
DSD-CAPABLE DAC:
The user manual talks about a DSD->PCM light that lights up when the incoming signal is being converted to PCM (supposedly when in non pure (DSP) mode), which suggests that when it is off, pure passthrough to the DAC is taking place. (http://www.pioneerelectronics.com/pi...ctions0807.pdf)
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-94THX
DIGITAL DSD INPUT:
HDMI DSD input
DSD-CAPABLE DAC:
Burr-Brown DSD1791
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-AX5Ai-S (VSX-AX5Ai-G) (VSX-AX5Ai)
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
The user manual states With SACD discs, you will also be able to bypass the signal processing of this receiver to hear 1-bit Direct Stream Digital (DSD) audio directly (http://safemanuals.com/user-guide-in...VSX-AX5AI-S-_S)
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-AX5i (VSX-AX5i-S)
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
The user manual is not clear on how DSD is processed in PURE DIRECT mode.
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-AX10Ai (VSX-AX10Ai-G) (VSX-AX10Ai-S)
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
The user manual is not clear on how DSD is processed in PURE DIRECT mode. (http://dl.owneriq.net/2/2cffa0d9-308...c145370023.pdf) (http://www.pioneerchina.com/files/EN...AI%28EN%29.pdf)
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-LX50
DIGITAL DSD INPUT:
HDMI DSD input
PURE DIRECT
DSD-CAPABLE DAC:
The user manual talks about a DSD->PCM light that lights up when the incoming signal is being converted to PCM (supposedly when in non pure (DSP) mode), which suggests that when it is off, pure passthrough to the DAC is taking place. (http://dl.owneriq.net/2/2cffa0d9-308...c145370023.pdf)
CURRENT CONCLUSION:
MODEL:
Yamaha RX-V761 (DSP-AX761)
DIGITAL DSD INPUT:
HDMI DSD input
PURE DIRECT
DSD-CAPABLE DAC:
??? Apparently a Burr-Brown model that's DSD compatible
CURRENT CONCLUSION:
MODEL:
Yamaha RX-V861 (DSP-AX861)
DIGITAL DSD INPUT:
HDMI DSD input
PURE DIRECT
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
MODEL:
Yamaha RX-V863 (DSP-AX863)
DIGITAL DSD INPUT:
HDMI DSD input
PURE DIRECT
DSD-CAPABLE DAC:
http://www.sa-cd.net/showthread/30842/44772
I had tentatively decided on the Yamaha RX-V863, which, from what I understand, also decodes DSD direct.
CURRENT CONCLUSION:
MODEL:
Yamaha RX-V1700 (DSP-AX1700)
DIGITAL DSD INPUT:
HDMI DSD input
PURE DIRECT
DSD-CAPABLE DAC:
Burr-Brown DSD1791
The user manual states that When you play back DSD sources with any sound field program, this unit converts the DSD signals to PCM signals which COULD infer that when in PURE DIRECT mode, the DSD stays as such until conversion to analog.
CURRENT CONCLUSION:
No definite conclusion.
MODEL:
Yamaha RX-V1800 (DSP-AX1800)
DIGITAL DSD INPUT:
HDMI DSD input
PURE DIRECT
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
MODEL:
Yamaha RX-V1900 (DSP-AX1900)
DIGITAL DSD INPUT:
HDMI DSD input
PURE DIRECT
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
MODEL:
Yamaha RX-V2700 (DSP-AX2700)
DIGITAL DSD INPUT:
HDMI DSD input
PURE DIRECT
DSD-CAPABLE DAC:
Burr-Brown DSD1791
FOR: "I just looked at the manual for the 2700 and you will be fine. You will see that it will handle DSD on page 21. Good luck....you won't be disappointed in the sound." http://www.yamaha.com/yec/products/p...DETYP=RELATION
CURRENT CONCLUSION:
MODEL:
Yamaha RX-V3800 (DSP-AX3800)
DIGITAL DSD INPUT:
HDMI DSD input
PURE DIRECT
DSD-CAPABLE DAC:
http://www.sa-cd.net/showthread/25179/26138
http://www.sa-cd.net/showthread/30517/32640#32500
CURRENT CONCLUSION:
MODEL:
Yamaha RX-V3900 (DSP-AX3900)
DIGITAL DSD INPUT:
HDMI DSD input
PURE DIRECT
DSD-CAPABLE DAC:
http://forums.audioholics.com/forums...4&postcount=19
CURRENT CONCLUSION:
MODEL:
Yamaha RX-Z7 (DSP-Z7)
DIGITAL DSD INPUT:
HDMI DSD input
PURE DIRECT
DSD-CAPABLE DAC:
Burr-Brown DSD1791
CURRENT CONCLUSION:
MODEL:
Yamaha RX-Z9 (DSP-Z9)
DIGITAL DSD INPUT:
PURE DIRECT
DSD-CAPABLE DAC:
The user manual states that PURE DIRECT...bypasses all of this unit's decoders and circuitry to provide uncompromised audio fidelity. But that is not clear enough about DSD to analog conversion.
I don't believe that is indicative enough enough of whether the DSD signal is being fed directly to the DSD DAC or not.
CURRENT CONCLUSION:
MODEL:
Yamaha RX-Z11 (DSP-Z11)
DIGITAL DSD INPUT:
HDMI DSD input
PURE DIRECT
DSD-CAPABLE DAC:
Burr-Brown PCM1796
The user manual is not clear at all about whether Pure Direct mode means pure DSD to analog processing.
CURRENT CONCLUSION:
No conclusion even close to 100% can be made.
Random List of noted Supposed NON pure DSD receivers
MODEL:
Arcam AV888
DIGITAL DSD INPUT:
NO
DSD-CAPABLE DAC:
YES:
Wolfson WM8741
CURRENT CONCLUSION:
100% sure it's non pure or N/A
MODEL:
Denon AVR-2308CI
DIGITAL DSD INPUT:
NO
NO
DSD-CAPABLE DAC:
YES:
Burr-Brown DSD1608
No mention of DSD in the user manual.
http://www.usa.denon.com/AVR-2308CI-OM-E_109.pdf
CURRENT CONCLUSION:
MODEL:
Denon AVR-3310CI (AVR-3310) (AVC-3310)
DIGITAL DSD INPUT:
NO
NO
DSD-CAPABLE DAC:
YES:
Burr-Brown DSD1608
CURRENT CONCLUSION:
MODEL:
Harman Kardon AVR 254
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
Cirrus Logic CS42528
CURRENT CONCLUSION:
MODEL:
Harman Kardon AVR 255
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
CURRENT CONCLUSION:
MODEL:
Harman Kardon AVR 354
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
CURRENT CONCLUSION:
MODEL:
Harman Kardon AVR 355
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
CURRENT CONCLUSION:
MODEL:
Integra DTR-40.1
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
Burr-Brown PCM1690
CURRENT CONCLUSION:
MODEL:
Integra DTR-50.1
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
Burr-Brown PCM1690
CURRENT CONCLUSION:
MODEL:
Marantz SR5003
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
CURRENT CONCLUSION:
MODEL:
Marantz SR6004
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
CURRENT CONCLUSION:
MODEL:
Onkyo TX-SR507 (TX-SA507)
DIGITAL DSD INPUT:
YES:
HDMI DSD input
I don't think so
DSD-CAPABLE DAC:
I think it's a non dsd dac....
I don't think there's pure dsd mode, or dsd dac...
CURRENT CONCLUSION:
Pretty sure it's non pure.
MODEL:
Onkyo TX-SR606
DIGITAL DSD INPUT:
NO:
Cirrus Logic
CS42518 (this has been confirmed to NOT have the CS42528, that claim is wrong.)
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
MODEL:
Onkyo TX-SR705 (Integra DTR-6.8)
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
CURRENT CONCLUSION:
MODEL:
Onkyo TX-SR707
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
Burr-Brown PCM1690
There's some false claims out there. But its DAC is non DSD and that's that.
CURRENT CONCLUSION:
MODEL:
Onkyo TX-NR807
DIGITAL DSD INPUT:
YES:
HDMI DSD input
DSD-CAPABLE DAC:
NO:
Burr-Brown PCM1690
CURRENT CONCLUSION:
MODEL:
Pioneer SC-05TX (SC-LX71)
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
Wolfson WM8740
CURRENT CONCLUSION:
MODEL:
Pioneer SC-07TX (SC-LX81)
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
Wolfson WM8740
CURRENT CONCLUSION:
MODEL:
Pioneer SC-25
DIGITAL DSD INPUT:
YES:
HDMI DSD input
DSD-CAPABLE DAC:
NO:
Wolfson WM8740
CURRENT CONCLUSION:
MODEL:
Pioneer SC-27
DIGITAL DSD INPUT:
YES:
HDMI DSD input
DSD-CAPABLE DAC:
NO:
Wolfson WM8740
CURRENT CONCLUSION:
MODEL:
Pioneer SC-LX72
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
Wolfson WM8740
CURRENT CONCLUSION:
MODEL:
Pioneer SC-LX82
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
Wolfson WM8740
CURRENT CONCLUSION:
MODEL:
Pioneer VSA-919AH
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
MAYBE:
Wolfson WM8728
About the DAC: there seems to be two versions or revisions of the WM8728 (one and two), one with DSD decoding and one with only PCM decoding. We're not sure which one is used in this receiver so we have no idea!
CURRENT CONCLUSION:
MODEL:
Pioneer VSA-1017AV
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
AKM AK4628
CURRENT CONCLUSION:
MODEL:
Pioneer VSA-1019AH
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
MAYBE:
Wolfson WM8728
CURRENT CONCLUSION:
MODEL:
Pioneer VSA-AX1AH
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
AKM AK4359
CURRENT CONCLUSION:
MODEL:
Pioneer VSA-LX52
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
MAYBE:
Wolfson WM8728
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-01TXH
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
MAYBE:
Wolfson WM8728
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-03TXH
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
MAYBE:
Wolfson WM8728
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-21TXH
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
MAYBE:
Wolfson WM8728
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-23TXH
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
MAYBE:
Wolfson WM8728
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-49TXi
DIGITAL DSD INPUT:
YES:
NO
DSD-CAPABLE DAC:
http://www.pioneerelectronics.com/pi...4181175930.pdf
CURRENT CONCLUSION:
It doesn't seem to have pure DSD processing.
MODEL:
Pioneer VSX-59TXi
DIGITAL DSD INPUT:
YES:
NO
DSD-CAPABLE DAC:
http://www.pioneerelectronics.com/St...s%20Manual.pdf
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-72TXV (VSX-72TXV-S) (VSX-AX2AV-S) (VSX-AX2AV)
DIGITAL DSD INPUT:
NO
DSD-CAPABLE DAC:
Burr-Brown ____?
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-91THX
DIGITAL DSD INPUT:
YES:
HDMI DSD inputs
NO
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-AX3-S
DIGITAL DSD INPUT:
NO
DSD-CAPABLE DAC:
Manual: http://docs.pioneer.eu/Manuals/VSX_A...al/GetPDF.ashx
CURRENT CONCLUSION:
MODEL:
Pioneer VSX-LX51
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
MAYBE:
Wolfson WM8728
CURRENT CONCLUSION:
MODEL:
Sharp SM-SX100
DIGITAL DSD INPUT:
NO
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
MODEL:
Sony STR-DA2400
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
Seems to not be pure DSD.
MODEL:
Sony STR-DA4400ES
DIGITAL DSD INPUT:
YES:
HDMI DSD input
DSD-CAPABLE DAC:
The user manual does not indicate anything about how DSD sources are handled in the receiver. (http://www.docs.sony.com/release/STRDA4400ES.pdf)
CURRENT CONCLUSION:
MODEL:
Sony STR-DA5300ES (TA-DA5300ES)
DIGITAL DSD INPUT:
YES:
HDMI DSD input
DSD-CAPABLE DAC:
The user manual does not indicate anything about how DSD sources are handled in the receiver.(http://www.sonystyle.com/wcsstore/So...TRDA5300ES.pdf)
CURRENT CONCLUSION:
MODEL:
Sony STR-DA5400ES
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
I DON'T KNOW: it has a special Sony custom designed DSD DAC which is supposed to "represent the latest advancement in DSD D/A conversion. Some kind of unprecedented "no negative feedback I/V Converter" technology. Gone completely is any slight softness or distortion associate with converting DSD to analog. The output is very tight and crisp where as the XA9000ES and XA777ES are noticeably softer sounding by comparison." What actually happens, is that it converts the incoming dsd signal (via hdmi) to pcm format and processes the sound a little before converting to analog.
CURRENT CONCLUSION:
I'm not sure what to conclude about this receiver. Make your own conclusion about whetter this is good DSD to analog conversion or not. But it's not pure, that's for sure.
MODEL:
Sony STR-DA6400ES
DIGITAL DSD INPUT:
YES:
HDMI DSD input
DSD-CAPABLE DAC:
The user manual does not indicate anything about how DSD sources are handled in the receiver. (http://pdf.crse.com/manuals/3875814211.pdf)
Claim FOR: http://www.avsforum.com/avs-vb/showt...1#post15619571
CURRENT CONCLUSION:
MODEL:
Sony STR-DA7100ES
DIGITAL DSD INPUT:
YES:
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
MODEL:
Sony TA-DA3400ES
DIGITAL DSD INPUT:
NO
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
MODEL:
Sony TA-DA5500ES
DIGITAL DSD INPUT:
NO
DSD-CAPABLE DAC:
CURRENT CONCLUSION:
MODEL:
Sony TA-DA9000ES
DIGITAL DSD INPUT:
YES:
DSD-CAPABLE DAC:
NO:
Sony CXD9725
This receiver has i.LINK DSD input but the DAC isn't pure DSD to analog: http://www.agoraquest.com/viewtopic....zz0dXRlVx6i%22
CURRENT CONCLUSION:
MODEL:
Yamaha AX-V465
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
Burr-Brown PCM1680
CURRENT CONCLUSION:
MODEL:
Yamaha AX-V565
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
Burr-Brown PCM1680
CURRENT CONCLUSION:
MODEL:
Yamaha AX-V765
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
Burr-Brown PCM1680
CURRENT CONCLUSION:
MODEL:
Yamaha AX-V1065
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
Burr-Brown PCM1680
CURRENT CONCLUSION:
MODEL:
Yamaha DSP-AX768
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
Burr-Brown PCM1680
CURRENT CONCLUSION:
MODEL:
Yamaha DSP-AX863
DIGITAL DSD INPUT:
DSD-CAPABLE DAC:
NO:
Burr-Brown PCM1680
CURRENT CONCLUSION:
MODEL:
Yamaha RX-V661 (DSP-AX661)
DIGITAL DSD INPUT:
YES:
HDMI DSD input
NO (apparently)
DSD-CAPABLE DAC:
http://www.sa-cd.net/showthread.php?...ly=30901#30901
CURRENT CONCLUSION:
I think it isn't. Only from these claims I've found though.
vfalks is offline
post #2 of 23 Old 03-08-2010, 07:24 PM
Phantom Stranger's Avatar
Quoted: 380 Post(s)
Liked: 280
A truly substantial resource that needs a bump. Many manufacturers gloss over whether their receivers handle DSD in a pure manner, and finding information on a particular model can be very difficult. Thanks for compiling the list.
AVSforum's Blu-ray Picture Quality Rankings (Updated through May 30, 2016)
Phantom Stranger is offline
post #3 of 23 Old 05-01-2010, 10:35 AM
tribby2001's Avatar
I just want to post a very big Thank You for doing all this research and spending your time to post this fabulous information.
You have been instrumental to me in obtaining a factory refurbished Integra 7.8 primarilly for SACD listening. I am ecstatic over its performance. Again, Thank You!
tribby2001 is offline
post #4 of 23 Old 05-01-2010, 10:53 AM
Stilly77's Avatar
Great list, nice work! I have a Pioneer VSX-01TXH and VSX-919AH-K that show
DSD > PCM
no matter what mode is selected.
Stilly77 is offline
post #5 of 23 Old 05-01-2010, 12:04 PM - Thread Starter
vfalks's Avatar
Great to hear! And good choice of receiver . Whether for SACD or any other format playback
vfalks is offline
post #6 of 23 Old 08-04-2010, 06:59 PM
wse
wse's Avatar
Quoted: 1965 Post(s)
Liked: 739
Thank you vfalks
Do you know about Blu Ray players like the Oppo BDP-83?
wse is offline
post #7 of 23 Old 09-13-2010, 01:41 AM
jonfitch's Avatar
Very informative post. Big thank you.
jonfitch is offline
post #8 of 23 Old 09-13-2010, 02:35 AM
welwynnick's Avatar
Tremendous piece of work. I may be able to add a few things.
I owned a Sony DA9000ES and have schematics. All DSD signals are internally converted to PCM prior to amplifcation.
I owned a Sony DA7100ES and have schematics. Unlike the DA9000ES this does not convert the analogue and digital audio inputs to DSD - all processing is PCM.
I have full schematics for many of the amplifiers mentioned and may be able to help with specific questions.
BR, Nick
welwynnick is offline
post #9 of 23 Old 09-13-2010, 06:17 AM
Minge's Avatar
Quoted: 103 Post(s)
Liked: 37
This list is just what the Dr. ordered. I am in the market and if it does not do DSD it is a non starter for me...Incredible work and you just saved me a boatload of time.
Minge is offline
post #10 of 23 Old 09-13-2010, 06:51 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Does this have to do with 2 channel listening only or/and HT?
Panasonic AE-2000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is offline
post #11 of 23 Old 09-13-2010, 07:00 AM
Stereodude's Avatar
Quoted: 3084 Post(s)
Liked: 2236
I'll be the first to ask, Who cares?
If you want bass management, time alignment, or room correction you're going to need to turn that precious DSD to PCM first. And if you've got the perfect room & speakers and don't need any of that you're probably not using any of the gear listed in this thread.
Stereodude is offline
post #12 of 23 Old 09-18-2010, 01:52 PM
Beto3645's Avatar
Interesting... I have been having audio dropouts when feeding DSD via HDMI to an Integra DHC-40.2 preamp/processor. The DHC-40.2 features "DSD Processing" but not "DSD Direct." Accordingly, would it be correct to infer that the DSD processing in this model consists of converting DSD to PCM?
When I switch the feed from DSD to PCM (i.e. the player performing the conversion before sending it to the pre/pro), the audio dropouts do not occur. Since, as you say, bass management, time alignment, and room correction are all done in PCM (and I do want all those things!), should I simply set the player to output PCM and forget about the audio dropouts?
Beto3645 is offline
post #13 of 23 Old 09-18-2010, 05:56 PM
Stereodude's Avatar
Liked: 2236
That's what I would do. You might get hate mail from from some of the people posting in this thread though.
post #14 of 23 Old 09-19-2010, 04:09 AM
ematcion's Avatar
Quoted: 84 Post(s)
Liked: 121
In the September 2010 issue of the British hi-fi magazine, Hi-Fi World, there's a review of the Yamaha RX-V567 home theater receiver. In the review, the reviewer mentioned specifically that the V567 decoded DSD without switching to PCM when used with a Cambridge Audio universal player, which was set to output DSD through its HDMI output. The reviewer mentioned that the Yamaha was set to "Direct" and the playback sampling rate can be seen with the receiver's on-screen display (OSD).
Avatar - My guard dog, Bogi
Part of my ever-growing SACD collection
ematcion is offline
post #15 of 23 Old 01-07-2011, 02:53 PM
bryzmon's Avatar
Onkyo HT-RC270 verified DSD passthrough. Has the correct chip, manual is vague, but my SACD test confirms.
bryzmon is offline
post #16 of 23 Old 07-22-2012, 05:11 AM
marko7's Avatar
Quoted: 14 Post(s)
What about Yamaha BD-A1010?
marko7 is offline
post #17 of 23 Old 09-30-2012, 08:32 PM
madaudio's Avatar
Quoted: 116 Post(s)
Liked: 59
No mention of any of the NAD avrs, one way or the other?
I am currently playing a 5.1 SACD from my Oppo 95 via HDMI to my NAD T775 HD, and the on-screen info from the NAD advises PCM 5.1 at 88.2K. Would playing direct from Oppo to NAD via analogue outs be producing a higher level sound quality?
I suppose first of all this might depend on what sampling rate was used to produce the DSD recording in the beginning? I vaguely remember reading that most DSD recording is done at 2.something mhz, but also vaguely remember reading on recording site (may have been MA recording, not sure) that they sometimes used equipment that could sample at 5.something mhz.
To my (admittedly ageing) ears, not too much difference that I can detect., whenswitching from hdmi to analogue and back again (have to hit the pause or stop button on the player before switching as otherwise the Oppo seems to get itself into an unhappy knot if it is playing live when I do this - must have something to do with switching fromtrying to decode the disc itself or simply sending the un-coded bit-stream to the NAD)
Interested in any comments
For the record, the oppo setup in its Audio Format Setup had SACD output set to DSD
madaudio is offline
post #18 of 23 Old 09-30-2012, 10:57 PM
Kilian.ca's Avatar
Liked: 37
The long version:
The background in brief:
DSD uses sigma-delta 1-bit at 2.82MHz, which is different technology from PCM using 24-bit. Apples and oranges. For editing DSD is converted to high sample PCM 384kHz or similar or even higher, and back for authoring SACD.
Some have stated that native DSD is roughly equivalent to PCM 20-bit 100kHz. Someone else has shown graphically that for a pure tone DSD and 96kHz analogue waveforms are very close. I can't remember the sources but these are from the early days of SACD.
Native DSD recordings capture ultra-sonic frequencies (20kHz to 100kHz) which some argue are detrimental to the audible band, unless recording engineer filter these out.
Most SACDs are from original PCM recordings, some even 44.1kHz (CD quality), a lot are from 24/96. Only a few are higher sample rates. Some are from analogue but the medium has it's own limitation to start with, such as limited dynamic range.
I've argued that DSD decimated to PCM at high enough sample rate, 176.4kHz (in Sony BDPs) is for all intense and purpose sufficient and has no audible difference. If you believe sample rates make an audible difference, then a 96kHz recording would suffer some loss by conversion to DSD then back to 88.2kHz during playback. Decimation to 176.4kHz would be more than sufficient for original 96kHz recording.
Listening comparison between DSD and PCM is generally difficult to do because equipment set-up needs to be changed and this is usually not possible without some delay. Plus the need to ensure everything else (volume, processing or lack of) stays the same.
So there's really nothing much to be gained from preserving DSD signal all the way.
On the other hand, sending DSD to AVR have the following potential serious pitfalls:
1. Direct DSD-analogue decoding doesn't give you the option to do bass management and other processing like room correction. Unlike movie tracks, there is no uniform standard how the LFE is mixed for SACD. Without BM you need to have 5 full-range speakers and a sub, or as originally intended, 6 full-range speakers.
2. Even if you want BM and RC via PCM intermediate steps, you seldom know what the AVR does in terms of sample rate conversion. The Onkyo 606 is suspected of downsampling DSD to 44.1kHz PCM eek.gif. You seldom know what goes on inside AVRs as there's usually no way to tell.
3. Recently it's been found that some Denon AVRs do not apply sub boost to the DSD stream.
BTW, the thread title should be Pure DSD to Analog Decoding, as there's no processing implied.biggrin.gif
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #19 of 23 Old 11-29-2012, 01:59 PM
ematcion's Avatar
Quoted: 84 Post(s)
Liked: 121
I was looking at the latest firmware upgrade for the Onkyo 414 and 515 home theater receivers, and Onkyo mentioned the firmware upgrade will allow for these receivers to support DSD. I don't know whether this means these receivers will now be able to decode DSD to analog or simply that they can process an incoming DSD bitstream.
ematcion is offline
post #20 of 23 Old 03-25-2014, 07:17 PM
oOOBillO0o's Avatar
These receiver potentially are great DSD DACs. Anyone use Foobar or other software to get DSD over HDMI to a receiver?
McIntosh Labs! What am I listening to?
oOOBillO0o is offline
post #21 of 23 Old 09-03-2014, 11:13 AM
fireprix's Avatar
Quoted: 22 Post(s)
I'm not sure if this really has any bearing on the subject but my Integra DHC 40.2 is supposed to be able to decode DSD via HDMI. My player is an Oppo BDP-103D. I always had it set up to feed straight DSD but found on the display that the signal being input is 44.1khz. When I changed the Oppo's setting to feed PCM, it showed the input signal as 88.2khz. DVD Audio is shown as whatever the disc is labeled. For example The Eagles Hotel California in surround shows 96khz 5.1 and even shows 192khz 2.0 if the high resolution stereo is being input. I haven't tried switching back and forth to see if there is a difference in sound quality. I'm not sure what each unit has as far as a D/A converter inside. Does anyone know which of the units would do a better job with the DSD signal? In the court of public opinion most believe Oppo is a very high quality product while it seems Onkyo/Integra seems to be somewhat less respected. I didn't see anything specifically about the DHC40.2 except one complaint of audio drop out which I have yet to experience. However, I've only had mine for about a year. Anyone have any thoughts?
fireprix is offline
post #22 of 23 Old 10-28-2014, 10:09 PM
Liked: 1
I have an old(ish) Pioneer VSX921 and an Oppo103AU BR, and it DOES does DSD direct, even shows it on the readout!
HOWEVER I am in the process of getting either a Marantz sr5008 or Denon AVR-x3000, not sure if they do or have the same DAC???
noshank likes this.
Shmockolovitch is offline
post #23 of 23 Old 08-22-2016, 06:56 PM
2channel8's Avatar
Quoted: 45 Post(s)
Well, I don't know/care why I like listening to hybrid SACDs on my DV-980H better than my NAD C546BEE, even though CDs sound better on the NAD; but I do. So much so that I may be willing to invest in a better SACD transport.
Strictly for 2 channel audio through an analog receiver - Rotel RX-1052. Pretty good. Speakers are Canton Ergo 1002DC. Very good.
It is now 2016 (I hope you wise ones still follow) and as far as Oppo BDP pricing goes the 103 (nonD-auction) is less than 1/3 the price of a 95 and less than 1/2 the price of an 83SE. I am willing to believe that the 95 sounds better than the 103; but not necessarily worth the money for my system or ears. Could the 83 SE be that much better? Or an 83 EVS mod?
2channel8 is offline
