Receiver Suggestions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-02-2010, 06:13 PM - Thread Starter
twin2's Avatar
I know there are several threads about this but I don't know enough about receivers to answer my own questions.
I'm moving into an apartment in a few months and I need advice for an adequate <400 dollar receiver. I'm in college, so it's a pretty small apartment and the distance from the speakers to the listener is probably 10ft max.
I'm looking to get either Polk Monitor 50's or 60's and I was looking at the Yamaha RX-V465 but after doing some research, primarily on here, I realized it might not be the best choice because the Polk's aren't the most efficient and need a steady current to sound their best.
Also connected to the receiver will be a PS3 and Digital cable box, both HDMI, and an LCD tv. The receiver has to have at least 2 HDMI in with audio/video passthrough.
The system will be used primarily for home theater, if that helps one way or another, but also for music listening. Primarily jazz.
With all that being said, would the RX-V465 get the job done? Any and all suggestions are welcome, whether it be for a different receiver or equivalent speakers that would mate better to the RX-V465. I'm also not opposed to buying used or refurbished if necessary. Thanks
twin2 is offline
post #2 of 9 Old 03-02-2010, 06:24 PM
afrogt's Avatar
Quoted: 1063 Post(s)
Liked: 769
The Monitor 50 and 60 have 89-90db sensitivity, that's pretty good. Doesn't take a powerful receiver to make them play loudly. If the sensitivity was 83-85 I'd see your point, but 90db is above average. Generally only Klipsch or other speakers with horn tweeters have higher ratings in the mid 90's and above.
That said I don't like the Yamaha 465 because the build quality looks cheap. It weighs about 4-5 lbs less than last years model it replaced plus it uses cheap spring clip terminals for the center and surround speakers. For $400 or less you can get a Denon 1610, 1910, Pioneer 919, Onkyo 607 or RC160 and if you wait until the weekend, you can get the Yamaha RX-V765 for $399 from newegg.com which would be much better than the 465.
Afro GT
afrogt is offline
post #3 of 9 Old 03-02-2010, 08:18 PM - Thread Starter
twin2's Avatar
Is the Denon AVR590 the same as the AVR1610? How much of a difference would the 120w/ch Pioneer 919 make vs the 75w/ch on the Denon, assuming the ratings are accurate.
twin2 is offline
post #4 of 9 Old 03-02-2010, 11:46 PM
Knucklehead90's Avatar
Quoted: 396 Post(s)
Liked: 336
There seems to be no discernable differences between the 590 and the 1610. Check out the side by side and compare them. Right now at Amazon the 1610 is a bit cheaper than the 590.
Pioneer seems to be inflating their power specs lately - but the difference between 75 and 110 wpc isn't a wide gulf. Look for features you want and need and don't put too much stock in the power specs.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #5 of 9 Old 03-03-2010, 12:18 AM - Thread Starter
twin2's Avatar
Seeing as its a pretty small room, I'll probably go with the Monitor 50's and possibly a sub. The Denon AVR1610 and Pioneer 919 both have more than enough inputs and all of the features that I want and need. Which would you pick? Are there any general facts about Denon/Pioneer receivers that could put one above the other?
twin2 is offline
post #6 of 9 Old 03-03-2010, 12:31 AM
afrogt's Avatar
Liked: 769
Even though your comparison charts shows everything is the same, if you look at the back of each receiver you'll notice the 1610 has TWO SETS of front speaker terminals, A & B. The 590 only has Speaker A terminals.
That's the lone difference I can see between two receivers. Power, inputs, specs, etc are the same. Go for the one with the lowest price unless you need the B speaker terminals to play music on the patio or something. it has to be the same source as the main room though.
By the way the 1610 can be had under $300 shipped if you buy from Electronics Expo and use AUDIOSALE promo code at checkout. Electronics Expo is an authorized Denon dealer too!
As far as 919 vs 1610, the 919 is 7.1 receiver with Zone 2 output. You can watch a movie in one room and listen to a different source in another room like the tuner, CD, etc. Plus the 919 has an iPod connection and comes with the cable.
Afro GT
afrogt is offline
post #7 of 9 Old 03-03-2010, 08:51 AM - Thread Starter
twin2's Avatar
Thanks for all of the help. I'm going to go with the 1610 because having 2 Zone audio isn't really a feature that I'll use and i can just plug my ipod in through one of the inputs. Also, the Pioneer 919 is 100 dollars more.
twin2 is offline
post #8 of 9 Old 03-03-2010, 08:53 AM
Quoted: 396 Post(s)
Liked: 336
Thanks - I knew there had to be a difference but the spec sheet wasn't giving up that difference.
***GO SEAHAWKS ***
post #9 of 9 Old 03-03-2010, 09:48 AM
Quoted: 73 Post(s)
Liked: 112
The 1610 has more real power than the 919. The 919's power consumption comes in at 290W and the Denon's at 516W. The 919 does have nice Ipod integration and a slicker GUI if that does anything for you.
rnatalli is offline
