Official Emotiva XPA-5 Owners Thread - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 102Likes
post #1441 of 2597 Old 07-15-2013, 02:13 PM
MegaJ's Avatar
If it is rated 135 wpc 2 channels driven than I would expect quite a difference. The XPA is rated 200 wpc all channels driven. Your current setup might drop to 50 wpc all driven, but that is guesstimation on my part.
MegaJ is offline
post #1442 of 2597 Old 07-15-2013, 02:43 PM
Tom Riddle's Avatar
Quoted: 511 Post(s)
Liked: 427
Thanks MegaJ. I found an equation on another thread that stated to take the wpcx2/channels to get your true wpc with all channles driven - so 38 wpc in my case. Now, how accurate the equation is, I don't know, but I figure it can't be too far off.
Klipsch RF-7 II's, RC-64II, RS-62 II's, RS-52 II's
PSA V3600I
Marantz SR7008 with TK421 Modification
Emotiva XPA-5
Sony XBR-75x940c with Ideal-Lume Panelight
Oppo UDP-203
Tom Riddle is offline
post #1443 of 2597 Old 07-15-2013, 03:33 PM
jslaw81's Avatar
Sorry if this has already been answered but I have a question. What is the difference between the First Gen xpa-5 and the new Gen 2 XPA-5? is it worth making a change? I just got an xpa-5 a couple months ago.
jslaw81 is offline
post #1444 of 2597 Old 07-15-2013, 04:48 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
The biggest technical change was done to the gain structure. The gen 1's have a 32db gain and the gen 2's are 29db. I really don't think this is enough difference to warrant an upgrade to the gen 2. I'm not upgrading my xpa-5 at this time.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #1445 of 2597 Old 07-16-2013, 03:01 AM
kbarnes701's Avatar
Quoted: 6818 Post(s)
Liked: 5247
The review linked to in this thread recently has all the differences detailed.
kbarnes701 is offline
post #1446 of 2597 Old 07-16-2013, 07:25 PM
kestube's Avatar
I think it's a pretty good idea. Hopefully it will stay focused and not go to far astray. thanks 21.gif
kestube is offline
post #1447 of 2597 Old 07-17-2013, 03:25 AM
kbarnes701's Avatar
Liked: 5247
Originally Posted by Tom Riddle View Post
Thanks MegaJ. kbarnes, do you think that this amp would be more than i need then? My current receiver is rated at 135 wpc with 2 channels driven - I'm running a 7.1 config, so I'm not sure what it equates to with all channels driven. I must say, it sounds great right now, but I'm always looking for more!
Whether you will hear a difference between the internal AVR amps and an external amp depends on several factors. If the AVR amp can power your speakers to the peak SPL levels you need, without clipping, then an external amp won't make much difference for you. If you are running into clipping, then more powerful external amps will definitely help.  Bear in mind that most people lope along using 1 to 3 watts for most of the time...
There are numerous SPL calculators on the Internet - plug your data in and it will tell you what you need to know. Speakers of average 87dB/1w/1m efficiency will deliver 87dB from just 1 watt at a distance of about 3 feet. At 6 feet you would get 81dB (inverse square law). At 9 feet, 77dB and at 12ft 75dB.  So, with those speakers, if you listen at 9 feet, 1 watt will give you 77dB. In fact it will give you more because of room gain, but ignore that for now as I have no idea what your room is like nor where your speakers are.
So, if your speakers are 87dB efficiency you will get 77dB from 1 watt at 9 feet. Raising that SPL to 85dB (average SPL for movies, Reference Level) would need about 6 or 7 watts. Now 85dB is pretty loud for most people, and you can get it, in my example, from 6 watts. Can your AVR deliver 6 watts to all channels?  I am guessing it can :)
But you want to hit 105dB for movie peaks if you are sticking with Reference Level (although few people listen at Reference Level at home). That would require you to have almost 400 watts available for peaks. Can your AVR deliver 400 watts momentarily for peaks?  Possibly.
Remember we have not taken into account room gain. Your speakers may be more efficient than 87dB/1w/1m. You may sit closer or further away than my assumption.
Go to one of the online calculators armed with your speaker efficiency and seating distance and you can see what watts you will need. Remember that it is unlikely you will peak at 105dB as most people find Reference Level at home unbearably loud.
Typical modern AVRs can easily deliver 50-80 watts with all channels driven. Also remember that in the real world, all channels will never be driven to max at the same time.
Can you hear clipping distortion when you listen at the loudest levels you normally listen at?  If not, then an external amp won’t make any real difference to your sound quality. If you are hearing clipping (a 'rough' or 'harsh' or 'grating' sound) on peaks, then an external amp will make a difference.
If, after all this, you decide you do not need an external amp, then spend the saved money on the areas where you will hear a HUGE difference in SQ: better speakers, better (or an additional) subs and acoustic room treatments.
DonH50 likes this.
post #1448 of 2597 Old 07-17-2013, 01:10 PM
mogrub's Avatar
Quoted: 212 Post(s)
Liked: 180
Some of you have already seen this, and some others probably won't be interested, but I stumbled on Stereophile Magazine's year and a half old article on the XPA-5 today, and thought it might be of interest to at least a few.
Cheers.
http://www.stereophile.com/content/music-round-51
Every once in a while, quite inexplicably, things actually go according to plan.
mogrub is offline
post #1449 of 2597 Old 07-17-2013, 08:23 PM
DonH50's Avatar
Quoted: 2096 Post(s)
Liked: 1662
Kal posts here fairly regularly.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #1450 of 2597 Old 07-17-2013, 09:49 PM
GIEGAR's Avatar
Quoted: 766 Post(s)
Liked: 1319
What's also important is the associated increase in amplifier input sensitivity to 1.8V (for rated power; 8Ω load). I can't find the original XPA-5's input sensitivity in writing any more, but IIRC it was around 1.0 - 1.1V. (<-- correct me if I'm wrong).
GIEGAR is offline
post #1451 of 2597 Old 07-22-2013, 06:50 AM
mnc
mnc's Avatar
Quoted: 751 Post(s)
Liked: 564
So, wouldn't this mean that the Gen1's would be a better match for someone using a receiver with a 1V output as the pre/pro?
NHT speakers, Denon 4520, Panasonic 65VT50, DUAL PSA XS30SE's
mnc is offline
post #1452 of 2597 Old 07-25-2013, 07:36 AM
GIEGAR's Avatar
Quoted: 766 Post(s)
Liked: 1319
^^^ Yes, that's correct.
An AVR would need to deliver 1.8V peak at the pre-outs to drive the Gen 2 XPA-5 to full rated power.
GIEGAR is offline
post #1453 of 2597 Old 07-25-2013, 11:23 AM
mogrub's Avatar
Quoted: 212 Post(s)
Liked: 180
I just bought an XPA and wonder what you current owners are using as the ideal connection for the outbound speaker wires on your XPA -- Banana or Spade or Pin or just the speaker wire itself?
The XPA manual appears to show Bananas and that's what I would do unless someone here has user specific-insight that says use something else.
Thanks in advance.
mogrub is offline
post #1454 of 2597 Old 07-25-2013, 01:44 PM
cr136124's Avatar
Quoted: 70 Post(s)
Liked: 695
Thanks in advance.
I'm using Banana plugs at both ends with excellent results.
cr136124 is offline
post #1455 of 2597 Old 07-25-2013, 07:23 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
^^^ I use bare wire, no problem. Bananas or spades are nice (appearance, convenience) but really are not necessary.
67jason is offline
post #1456 of 2597 Old 07-26-2013, 10:01 AM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
but, can help prevent your wires touching each other, or somewhere else and causing some serious problems...
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
post #1457 of 2597 Old 07-30-2013, 09:02 AM
Longhorn69's Avatar
I just ordered an XPA-5 and XPA-2 (both Gen-2). I can't wait to get them installed and try them out. I'll post my impressions as soon as I can. Does anyone have a Gen-2 in use that can comment on it at this point?
Longhorn69 is offline
post #1458 of 2597 Old 07-30-2013, 10:06 AM
joseph10704's Avatar
Quoted: 258 Post(s)
Liked: 99
I wish i owned them But i dont.Maybe when u get them both in give us some picture's.
joseph10704 is offline
post #1459 of 2597 Old 07-30-2013, 08:35 PM
mogrub's Avatar
Quoted: 212 Post(s)
Liked: 180
Very amped, pun intended. XPA-3 installed today. Speakers arrive tomorrow. All that bad boy can do so far is look good.
Can't wait to start working those heat sinks just a little bit. 👍
mogrub is offline
post #1460 of 2597 Old 07-31-2013, 12:49 PM
Capt n Kirk's Avatar
I must say that I'm less then impressed with the 2 products that I purchased from Emotiva. I had written a long post but I deleted it as I don't like long post.
To make a long story short, I now have had 4 x UMC-1 replaced and should have a fifth one replaced but couldn't be bothered, this is all within 6 months of ownership. Now the XPA-5 stopped working and when instructed to, by their tech support, to plug the amplifier into a different circuit the unit went up in smoke.eek.gif So now I have to send a 85 pound amplifier back for repair that is just over a year old, pay for shipping there and hope it works when I get it back. Not to mention the down time.mad.gif
All I can say to anyone thinking of purchasing any of Emotiva's product is DON'T.
Buy something else there is a reason why it is cheaper then other products they claim to be in the same class, is because it is CHEAPER
Capt n Kirk is offline
post #1461 of 2597 Old 07-31-2013, 12:59 PM
kbarnes701's Avatar
Liked: 5247
Sorry to hear of the problems you've had. I can almost feel your frustration from here, thousands of miles away!
But one bad experience out of hundreds of great experiences isn't really a good reason to advise people to not buy an Emo amp IMO. I have 4 of them and they have all been working here for a long, long time with no issues at all. I think my experience is more typical of Emo amps than your unfortunate experience has been. In general, judging by the posts here on AVS, most users have found the Emo amps to be very reliable.
WRT to the UMC-1, well what can I say?  Did you not read the various threads about it?  You are not the only one who has received a useless UMC-1. Almost everyone did! Emo never did get it working properly.
post #1462 of 2597 Old 07-31-2013, 01:09 PM
I understand you standing up for Emotiva but if the company is claiming high end audio without high end pricing and the failure rate on my purchases is as high as it is, I believe that people should know that the product is not as good as claimed.
post #1463 of 2597 Old 07-31-2013, 02:28 PM
kbarnes701's Avatar
Liked: 5247
It's just one of thousands. The overwhelming majority are reliable and they represent fabulous value for money.  I realise this is no consolation to you, and I too would be angry in your shoes, but it is an over-reaction of some magnitude IMO to brand the entire output as rubbish.
post #1464 of 2597 Old 07-31-2013, 02:42 PM
To say that I'm over-reacting is rubbish as well. I've not over reacted at all I have simply voiced my opinion about the experience I've had with Emotiva products. If I only had one issue and I posted my displeasure that would be an over reaction. Not the multiple problems across the only 2 products purchased.
When you have had as many problems as I have with the products in less then a year the conclusion is simple.
post #1465 of 2597 Old 07-31-2013, 04:30 PM
Quoted: 258 Post(s)
Liked: 99
Not trying to be rude,But u are over reacting just a little,Because u had problem's with there amp's ,Yes we get this But saying that there bad because only u had a downfall.Out of the hundred's and thousand's who own these amp's.And i am sure are doing very well with there amp's.U have to say DONT BUY.That's nut's.And emotiva is not even high end ,There amp's were made to compare TO THE HIGH END amp's that are MORE CASH.so what there doing is chargeing u LESS for MORE.If u dont think this is true then go on and look for review's.I am not saying emotiva is perfect.There not.every company who make's amp's or even other tec product's are her to compare what they can bring to the table.And not only bring to the table.To see who can get the job done for the right price,So idk i feel bad for what happened to u. But i need to ask u really tell us all what really happened to your amp's.How did they fail were do u have the amp's in are they breathing right ,U need to make sure the air temp's are not too hot.Just saying.Good luck and sorry if u feel if i said too much.I am only trying to say what i think and what's on my mind.
post #1466 of 2597 Old 07-31-2013, 08:20 PM
mogrub's Avatar
Quoted: 212 Post(s)
Liked: 180
Just received my XPA-3 today. Could not be happier. Everything looks superb.
Carefully focused on my installation, equipment, connection, load, wiring, cooling, ventilation, and home electricity / circuit issues.
Every single one of those details matters. True for Emo or anyone else at any price point. No way around it.
More updates as testing moves forward. ✌
mogrub is offline
post #1467 of 2597 Old 07-31-2013, 11:24 PM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 767
What is this Gen1 vs Gen2 stuff I read here?
My XPA-3 was bought Dec-2012, what Gen is that?
Sent from my 32GB iPhone4 using Tapatalk
mtbdudex is offline
post #1468 of 2597 Old 08-01-2013, 03:18 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
the xpa series is currently undergoing a mild update. the xpa-2 and xpa-5 were the first to be released with the updates a few weeks back...minor cosmetic changes, new rca plugs, a reworked gain structure (29db for the new ones, where the old ones were 31db's) and a couple of other minor changes/updates.
since the xpa-3 gen 2 hasn't been released yet, you have a first gen xpa-3.
For anyone wondering, my thoughts are if you already own an xpa series there is probably not much a reason to upgrade to the gen 2 of the same model you own, the expense vs the updates doesn't make it worth it. but if you are considering a new xpa model amp then I would get a new gen 2 of the model you may be interested in...even if that means waiting on the xpa-3 or xpa-1 gen 2's to be released.
XStanleyX likes this.
67jason is offline
post #1469 of 2597 Old 08-02-2013, 08:57 PM
mogrub's Avatar
Quoted: 212 Post(s)
Liked: 180
So our new XPA-3 is flawless. It's pushing a pair of gas-hungry Martin Logan Theos and a Stage-X center with ease.
Runs cool, super quiet, and looks great.
mogrub is offline
post #1470 of 2597 Old 08-02-2013, 10:18 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
^^^ nice!! I love hearing positive thoughts when it comes to emo amps. Outside of some pro amps, the emos are certainly amongst the best values on the market and are quite the perforrmers. Glad you are enjoying yours.
67jason is offline
Emotiva Xpa 5 5 Channel Power Amplifier
