Official Emotiva XPA-5 Owners Thread - Page 64 - AVS Forum | Home Theater Discussions And Reviews
 102Likes
post #1891 of 2597 Old 02-02-2014, 10:30 PM
audio4life's Avatar
Liked: 300
Happens a lot?  Sounds like a QC issue.  If it varies in loudness, that could be a noisy circuit too, but if your handy it wouldn't hurt to pop the lid off, just be careful you don't shock yourself.
audio4life is offline
post #1892 of 2597 Old 02-02-2014, 10:43 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4783
lovinthehd is offline
post #1893 of 2597 Old 02-03-2014, 01:31 AM
Lesmor's Avatar
Quoted: 450 Post(s)
Liked: 184
Originally Posted by lovinthehd View Post
You obviously know nothing about capacitors with that stupid comment
Lesmor is offline
post #1894 of 2597 Old 02-03-2014, 03:15 AM
lovinthehd's Avatar
Liked: 4783
Ok, how long do the capacitors in the XPA5 take to discharge?
post #1895 of 2597 Old 02-03-2014, 07:43 AM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
people who work on amps and don't want to die of electrocution discharge the caps manually even if the amp has not been turned on for years. Just to be on the safe side.
JHAz is offline
post #1896 of 2597 Old 02-03-2014, 07:46 AM
PretzelFisch's Avatar
Quoted: 407 Post(s)
Liked: 264
Originally Posted by lazzz View Post
The hum is coming from the XPA itself, it gets louder and softer, louder and softer... Again, it is not very noticeable but it is certainly present and not something i was expecting.
It sounds like it's oscillating. I had a similar issue with the xpa-5 I sent back but it also hummed/buzzed in the speakers. A low volume hum like your describing might be a dimmer somewhere in the house. My unit was pretty loud I could hear it 10 feet away. The higher the power toroidal transformer my exhibit this type of hum when there is a dc offset in the power line. you could try cmx2 to alleviate it, I don't know if it would work.
PretzelFisch is offline
post #1897 of 2597 Old 03-16-2014, 01:24 PM
swarm87's Avatar
Quoted: 141 Post(s)
Liked: 106
thinking of picking a gen2 up but my shelf is only 15" deep will 2" overhang on each end be a problem? should i look into a amp stand if there's space or will it be fine on the floor(wont know until after i move in a few months if carpeted or wood).
pcm=potato
bitstream=patato
swarm87 is offline
post #1898 of 2597 Old 03-16-2014, 01:54 PM
cableguy301's Avatar
Quoted: 75 Post(s)
Liked: 64
   im pretty sure you will be ok.. I don't have a xpa 5 but I have the the xpa 1s  and the feet start 2.5 inches inside the front and back outer edge..
   you will be impressed with amp power if you have never had one...
cableguy301 is offline
post #1899 of 2597 Old 03-16-2014, 03:22 PM
swarm87's Avatar
Quoted: 141 Post(s)
Liked: 106
thanks for the info; all dependent if the new landlord will let me wall mount the tv.
pcm=potato
bitstream=patato
swarm87 is offline
post #1900 of 2597 Old 03-16-2014, 07:41 PM
DonH50's Avatar
Quoted: 2222 Post(s)
Liked: 1828
If the feet hang over you can use a couple of 1" x 2" wooden furring strips to help support it. Just cut to the depth of the amp to help distribute the weight over the shelf.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #1901 of 2597 Old 03-16-2014, 08:41 PM
Quoted: 75 Post(s)
Liked: 64
  tv work just as well on a stand bro!!!   go for the amp bro!!!!!!  u will love the power
post #1902 of 2597 Old 03-16-2014, 08:54 PM
swarm87's Avatar
Quoted: 141 Post(s)
Liked: 106
the way my tv stand is i cant. its a cheap glass one that will only support ~65lbs per shelf but the top one that is meant for a tv can support up to a 250lb TV. or i could do it like this guy on another forum http://images2.static-bluray.com/htgallery/62882_full.jpg may end up as moot in my system has to be crammed into a small bedroom but 200w in a bedroom setup would be pretty sweet.
pcm=potato
bitstream=patato
swarm87 is offline
post #1903 of 2597 Old 03-17-2014, 05:47 AM
PeterK's Avatar
Quoted: 41 Post(s)
Liked: 54
If you are worried that the glass shelf is too thin to support the weight, you can go to any glass shop and order thicker glass plate. I did this for my over tv shelf for my very heavy center speaker.
PeterK is offline
post #1904 of 2597 Old 03-17-2014, 05:59 AM
Lesmor's Avatar
Quoted: 450 Post(s)
Liked: 184
Or make a shelf with MDF to suit the unit and cover it with carpet tile ( Stuck on the MDF with spray adhesive ) which is what I did
Lesmor is offline
post #1905 of 2597 Old 03-17-2014, 06:12 AM
DonH50's Avatar
Liked: 1828
Using 1" MDF or plywood is not a bad idea, I suggested strips to provide more airflow beneath. I would not put carpet on it, however, as the carpet will reduce airflow and can collect dust as well as release dust and threads that could get pulled into the amp.
DonH50 is offline
post #1906 of 2597 Old 03-17-2014, 06:50 AM
Lesmor's Avatar
Quoted: 450 Post(s)
Liked: 184
First I am not proposing having it on a floor and walk on the carpet, clearly states to suit the unit
I cant see it reducing air flow as the feet maintain the correct clearance, we are not talking about a deep shag pile carpet tile here
The amp doesn't have fans that draws air underneath to exhaust at the top it cools by convection so don't see where threads come into the equation.
A glass shelf is a dust magnet and all your counter argument equally applies, how many times do people dismantle this beast of an amp to dust under it, or any other kit for that matter.
Lesmor is offline
post #1907 of 2597 Old 03-17-2014, 11:07 AM
DonH50's Avatar
Liked: 1828
Carpet attracts and holds dust ( and little dust bunnies). Convection can allow them to rise into the amp fan or no. The amp will settle a little into the carpet, reducing clearance underneath slightly (ok, that one is a stretch). Carpet induces more potential for static electricity (ESD); I prefer metal shelves myself but my components are currently wooden console so I violate my own rules (trade with looks, WAF). Carpet provides a more turbid airflow than over a smooth surface, admittedly again a stretch. I have not measured such a scenario but in my (long ago) pro audio days cooling was a major concern and we preferred open racks or slotted shelves, can't imagine using carpet.
I come from an engineering lab environment so am more sensitive to static and dust, occupational hazard. Your counter arguments are reasonable, I just have a carpet phobia. Where I live is also very dry so dust and static is a bigger problem than more humid climates. I do dust around my amps now and then but am probably in the minority. I know what dust can do to electrical and thermal integrity.
Experiences/backgrounds vary and I am probably more anal (can I say that here) than most. - Don
DonH50 is offline
post #1908 of 2597 Old 03-17-2014, 11:13 AM
Quoted: 75 Post(s)
Liked: 64
  few weeks ago I tried a Swiffer duster  wow really picked up the dust great off and under the av equipment  highly recommend for dusting    :)
post #1909 of 2597 Old 03-17-2014, 11:33 AM
Lesmor's Avatar
Quoted: 450 Post(s)
Liked: 184
  few weeks ago I tried a Swiffer duster  wow really picked up the dust great off and under the av equipment  highly recommend for dusting    smile.gif
The Swiffer is really good for getting under things, but dust is unavoidable whether Glass metal or carpet.
Depending on the nap and fibre of the carpet tile used (i.e Nylon not recommended) static might or might not be a problem
I used the same process to make a Gramma /Subdude type of platform for my subs years ago and they don't appear dusty at all
Dust build up internally with all equipment will happen whatever you do.
Anyway horses for courses, enough said
Lesmor is offline
post #1910 of 2597 Old 03-18-2014, 10:16 AM
kilabean's Avatar
Hey there everyone. I've had an xpa-5 for a few years now, maybe more, and I only have 3 speakers hooked up to it. Tried hooking up my surrounds to it but it kept shutting the amp down. My mains are 200w my center is 250 and my rears are 120w. I considered getting a upa 5 or 7 for rears, sides and then use what's left for the whole house audio I'm putting in. Anyhow is it possible to hook up several different wattage speakers to the same amp? My plan was to do the main 5 speakers and then bi-amp the side channels on my receiver. Didn't work when I tried it four years ago and I'm only now getting around to asking about it. haha biggrin.gif
Cheers
Mike
kilabean is offline
post #1911 of 2597 Old 03-18-2014, 12:00 PM
DonH50's Avatar
Liked: 1828
Speaker wattage and amplifier wattage are different things and are only loosely related. They do not need to be rated the same. If the amp is shutting down there is a short in the speaker wiring someplace, the speakers are bad, or the amp is bad. Try connecting a different (known-good) speaker to the amp channels to see if they work.
I personally consider bi-amping as implemented by most AVRs a waste of time, effort, and money but there are endless threads and debates on that subject..
DonH50 is offline
post #1912 of 2597 Old 03-18-2014, 12:35 PM
Quoted: 75 Post(s)
Liked: 64
yeah would agree bi amping an avr waste of time..
    yup I would think some short in speaker wire or surround speakers.. but just change the main to the other channels to test if its the amp.  I doubt it..
      cheers
post #1913 of 2597 Old 03-18-2014, 05:12 PM
jugger's Avatar
Liked: 55
Can anyone comment on if $500 for a used XPA-5 first generation is a good deal. They said all five channels work and no scratches. Thank you
RC-64 Center, RF-7 Fronts, RF-82 Sides, RW-12D, QTY=2, RSW-15, RS-52ii Rears, Pioneer SC-1522-K, Panasonic 65VT60, 65"
jugger is offline
post #1914 of 2597 Old 03-18-2014, 05:27 PM
Rabid 3-D Aficionado
marcuslaw's Avatar
Quoted: 702 Post(s)
Liked: 598
Find out approximately how many total hours the amp is been driven. It would also help to know where the unit was kept while in use. Obviously one with extensive use and kept in a confined media cabinet might be one to avoid despite looking good on the outside.
marcuslaw is offline
post #1915 of 2597 Old 03-18-2014, 05:30 PM
jugger's Avatar
Liked: 55
Unless there's a counter I'm not sure i would get the correct hours. He is also so second owner. He has only used three of the five channels but the previous owner was using all five.
jugger is offline
post #1916 of 2597 Old 03-18-2014, 06:15 PM
VINYLFREAK4's Avatar
I would also find out the original purchase date and how many years are left on the warranty.
Also, its not uncommon , for re-sellers to send units to Emotiva to be check out and tested prior to sale.
Find out , if this has been done.
Also seller reputation would be important ....E-Bay, Audigon, Emotiva Emporium etc......
Just my 2 cents.
VINYLFREAK4 is offline
post #1917 of 2597 Old 03-18-2014, 06:42 PM
cr136124's Avatar
Quoted: 70 Post(s)
Liked: 695
As the seller for his full name, as soon you have that information call Emotiva to validate the amp is under his/her name. They (Emotiva) should be able to tell you how many years / months are still left on the warranty.
If they are not able to find the person's name in their system, that means the original owner never transferred the warranty to the second owner. Emotiva uses names instead of serial numbers on the amps to track warranty. So, make sure to double check with Emotiva before you make a move. Working conditions, number of years left of warranty and the fact that unit is indeed correctly registered at Emotiva should drive the price of this unit.
If all of the above is in good shape (at least two years of warranty left), then the price is really good. Just do your homework to avoid issues down the road.
My 2 cents.
XStanleyX likes this.
cr136124 is offline
post #1918 of 2597 Old 03-18-2014, 08:16 PM
jugger's Avatar
Liked: 55
Thank you guys for the wise advice. I was very unsure it was a decent deal or not given it was a first generation, normal receivers (not amps) don't seems to hold their value this well, a new one that is generation 2 is $1,000 and in general it's a piece of electronics. I have been looking for a while for a used one and haven't found one so that should tell me something.
jugger is offline
post #1919 of 2597 Old 03-19-2014, 01:27 PM
jugger's Avatar
Liked: 55
My 2 cents.
He told me the 5 year warranty was up the end of last year. Does it still sound like a good deal?
jugger is offline
post #1920 of 2597 Old 03-19-2014, 01:33 PM
kilabean's Avatar
Great. Thanks for the info. I think I realized what the problem is... on the back of the amp the channels are arranged by 2 * 2 * 1. I had a 200w speaker and a 100w speaker in one of the "2" channel bays instead of the mains in one bay and the rears in another bay and the center on the single bay. Orrr.... that had nothing to do with it and I was just shorting somewhere. Either way it's working fine now. biggrin.gif
Cheers
Mike
kilabean is offline
Emotiva Xpa 5 5 Channel Power Amplifier
