Official Emotiva XPA-5 Owners Thread - Page 72 - AVS Forum
 22Likes
post #2131 of 2156 Old 01-11-2015, 07:40 PM
groundtrac's Avatar
Quoted: 34 Post(s)
Originally Posted by steveting99 View Post
Quick question on the space requirement around the XPA5. How much head space is needed for cooling requirements? Is 1" sufficient? Or does it need more like 3"? What about at the sides of the XPA5? How much space is needed for the unit?
I can't find any minimum distance around the XPA5 needed for cooling in the owner's manual, other than the standard clause given in page 3.
Just from my personal experience, 1" is not enough unless you are using fans in your cabinet. I have about 3.5" in my cabinet with no fans, and I have never had a problem with heat in the least. I would note, that in the section of my cabinet where my Emotiva is located, I do not have any other A/V equipment located there.
groundtrac is offline
post #2132 of 2156 Old 01-11-2015, 07:57 PM
dmb12679's Avatar
Quoted: 24 Post(s)
Picking up my first amp tomorrow. XPA-3 gen 1
Buying just to see if it makes a difference, play around.
My AVR puts out 125wpc, I have high eff Klipsch speakers.
I heard it will make no difference with my AVR power and speakers.
Any recommendations?
What is the year difference in gen 1 and gen 2, and what are the differences. Any problems I might encounter.
Thanks in advance
Harman Kardon 3700
Klipsch RF-82 II
Klipsch RB-51 II
Klipsch RC-52 II
Klipsch SS-1's
Klipsch R-112SW
dmb12679 is offline
post #2133 of 2156 Old 01-12-2015, 01:39 AM
ac388's Avatar
If your Klipsch is very efficient, like over 100db, addl. amp. won't make as much difference(power handling wise) as on a 85db speaker.
Man see things as they were n say why. I dream of things that never were, n say why not ....... A Perfect PROJECTOR
ac388 is offline
post #2134 of 2156 Old 01-12-2015, 04:47 AM
fatbottom's Avatar
Quoted: 488 Post(s)
Liked: 211
OH DEAR LOL 27W a channel???
http://www.soundandvision.com/conten...ver-test-bench
"I heard it will make no difference with my AVR power and speakers."
27W is pretty poor, so your Emotiva will be upgrade. Actually Klipsch have been found to be less efficient than stated specifications.
Krell Evolution 900e x 7
Bose Jewel speakers.
Jealous of my speakers?
fatbottom is online now
post #2135 of 2156 Old 01-12-2015, 07:23 AM
dmb12679's Avatar
Quoted: 24 Post(s)
Wow that is poor for HK's highest offering AVR. I only run a 5.1 with occasional zone 2. If I run the front stage off the amp it would leave the 125wpc to run surrounds correct?
I tried finding a bench test for my old HK 354 and couldn't, any chance you could link one. I just want to see the two compared as the 354 with much lower rating, seemed to perform well. Thanks for the bench test link, it is valuable info that I probably should have looked at by now or before purchasing. Although I am happy with it overall
Harman Kardon 3700
Klipsch RF-82 II
Klipsch RB-51 II
Klipsch RC-52 II
Klipsch SS-1's
Klipsch R-112SW
dmb12679 is offline
post #2136 of 2156 Old 01-12-2015, 07:56 AM
fatbottom's Avatar
Quoted: 488 Post(s)
Liked: 211
yup. Basically it's ok for 2 channels. So if you buy a amp for sides, rears, and center then you can use the HK for L/R. Although you could just use the rears (2 channels) so a 5 channel for L/C/R and sides. I'd do that.
post #2137 of 2156 Old 01-12-2015, 09:12 AM
dmb12679's Avatar
Quoted: 24 Post(s)
I'm getting the XPA3, would I be better off running the FL/C/FR off the amp and let the hk do the surrounds? Not sure why I would have the higher watts split between front and back. Or does it really not matter how it is configured?
Harman Kardon 3700
Klipsch RF-82 II
Klipsch RB-51 II
Klipsch RC-52 II
Klipsch SS-1's
Klipsch R-112SW
dmb12679 is offline
post #2138 of 2156 Old 01-12-2015, 09:31 AM
gadgtfreek's Avatar
Quoted: 209 Post(s)
Liked: 381
I'd guess, the way it feels that a good 3-4" would not a no worry situation. Ive got about 5-6 in mine and it barely gets warm. 1" may be pushing it without a fan. Not saying it would shut off, but the less heat the better.
65" VT50 / Oppo 103D
Denon 4520CI / Emotiva XPA-3
Klipsch RF82 II and RC62 II / Hsu VTF-15H (2)
Directv HR44-200 / HR24-500
gadgtfreek is online now
post #2139 of 2156 Old 01-12-2015, 12:27 PM
DonH50's Avatar
Quoted: 320 Post(s)
Liked: 326
Note the 27 W/ch test for the HK is all channels driven, which rarely if ever happens in the real world.
I had about 1" clearance over my XPA-3 (since changed to an XPA-5) and it ran pretty warm. I moved a shelf up to give it about 5" ~ 6" and it is fine. My anecdotal experience tells me 1" is not enough clearance but my gut says 3" ~ 4" is probably fine unless you are running it hard.
Note heat will shorten the life of electronics so I agree the cooler the better.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #2140 of 2156 Old 01-12-2015, 01:10 PM
fatbottom's Avatar
Quoted: 488 Post(s)
Liked: 211
Use the XPA3 for the front three. No it won't matter for power mismatch
"Note the 27 W/ch test for the HK is all channels driven, which rarely if ever happens in the real world."
I don't run a 2 channel home cinema.
post #2141 of 2156 Old 01-20-2015, 08:30 PM
singleton's Avatar
Really excited. I just ordered an XPA-5 as part of a complete HT overhaul. For the time being, it will be mated with a Sony STR-DA5300ES AVR, and driving 3x Definitive Technology RCS-II and 2x RSS-III (which are also new and haven't been installed), and an SVS SB-2000 dangling off the AVR. The new TV is being delivered Thursday, and installation will probably commence sometime next week. If everything I've read is true, this Emotive unit will kick some ass, especially in the price-to-value category!
singleton is offline
post #2142 of 2156 Old 01-20-2015, 08:39 PM
audio4life's Avatar
Liked: 167
I've noticed that the XPA-7 amp seems to not be getting any love. Over the years there's been a fair amount of clamouring for a 7 channel XPA amp, but perhaps the price tag is a little high?
audio4life is online now
post #2143 of 2156 Old 01-20-2015, 08:42 PM
sm4llz's Avatar
Quoted: 27 Post(s)
I have a xpa-5 driving a similar setup with uiw rss speakers for the rears and mythos st for the front. You're going to love it. I also have dual pb-2000 subs. All about that bass!
sm4llz is online now
post #2144 of 2156 Old 01-20-2015, 08:44 PM
sm4llz's Avatar
Quoted: 27 Post(s)
I got a great deal on my xpa-5 almost a year ago. I'm about to pick up a xpa-2 to drive the front and let the xpa-5 handle the center, surrounds, and surround backs. I'd take a xpa-7 just havent seen any around... Im a big fan of being the second owner
post #2145 of 2156 Old Yesterday, 07:10 AM
gadgtfreek's Avatar
Quoted: 209 Post(s)
Liked: 381
I think many haven't made the jump to 7.1 as well.
post #2146 of 2156 Old Yesterday, 08:38 AM
grtuck's Avatar
Quoted: 12 Post(s)
I have an XPA-7 running off my Onkyo and pushing 7 Triad Silver LCR's. It is a great amp so far, but I do think it is a little pricey compared to the XPA-5 considering you only get 2 more channels. I am very happy with it though, and don't plan on changing it out any time soon.
groundtrac and grigorianvlad like this.
grtuck is online now
post #2147 of 2156 Old Yesterday, 12:50 PM
mpjmeyer's Avatar
Quoted: 91 Post(s)
I have a question that perhaps was already answered in this thread, however I'll just ask so I don't have to skim through 72 pages. I am getting ready to build my theater and have the Marantz AV7702, dual Emotiva XPA-5 amps to push the SVS Ultra bookshelf setup in a 7.2.2. Is there a start up power sequence that needs to be followed to avoid the dreadful "pop" noise you get when you turn on the amp before the source? I'm thinking to connect the amps to the AV preamp 12v trigger. By doing that, will I avoid that pop and will the amps automatically power on when the AV is powered on?
mpjmeyer is offline
post #2148 of 2156 Old Yesterday, 01:34 PM
gadgtfreek's Avatar
Quoted: 209 Post(s)
Liked: 381
My XPA3 is on a trigger from the Denon, and it has a slow soft startup. I hear a low hiss right before it comes on line, no pop at all.
post #2149 of 2156 Old Yesterday, 02:21 PM
DonH50's Avatar
Quoted: 320 Post(s)
Liked: 326
Maybe if you started an XPA-7 thread instead of posting in the XPA-5 thread?
Maybe this thread should be re-titled "XPA-x Amplifiers"?
DonH50 is offline
post #2150 of 2156 Old Yesterday, 05:12 PM
gadgtfreek's Avatar
Quoted: 209 Post(s)
Liked: 381
Re-title is a good idea. This is the only XPA thread with traffic when I got ready to by my 3 so I naturally came here.
post #2151 of 2156 Unread Yesterday, 05:17 PM
gtsum's Avatar
Quoted: 17 Post(s)
I run my Yamaha as a pre out to the xpa 5 and use the 12v trigger to turn the xpa on. No pops, hisses, etc. Works fine
gtsum is offline
post #2152 of 2156 Unread Yesterday, 10:12 PM
srjinatl's Avatar
I just switched over to an XPA-7 from a combo of XPA-5 and XPA-200 - right now driving 5 Triad silver LCRs and 2 Triad Silver surrounds - the latter of which are soon to be swapped out for two silver LCRs - so I will soon have the same config. Certainly don't expect any issues either with this setup.
grtuck likes this.
- Scott
srjinatl is offline
post #2153 of 2156 Unread Today, 12:45 PM
sm4llz's Avatar
Quoted: 27 Post(s)
Did you all think I should rerun ypao (yamaha) once I move my FL and FR off of my xpa-5 and onto my xpa-2? The wattage is slightly different but i'm not sure if that would be a big enough impact.
post #2154 of 2156 Unread Today, 01:03 PM
fatbottom's Avatar
Quoted: 488 Post(s)
Liked: 211
yes. Also gain differences between internal and external as well.
post #2155 of 2156 Unread Today, 04:03 PM
lovinthehd's Avatar
Quoted: 732 Post(s)
Liked: 1144
Definitely rerun any REQ program when moving speakers, changing speakers or changing amps. The wattage isn't the issue, its the gain differences between the units (if any, but I wouldn't assume they're the same even if similar amps) and can pretty much assume the gain structure will be different between the avr's internal amps and any external amp, as fatbottom mentioned.
"I realize that somebody playing free music isn't as commercial as a hamburger stand. But is it because you can eat a hamburger and hold it in your hand and you can't do that with music? Is it too free to control?" - Don Van Vliet (aka Captain Beefheart) discussing commercial success in the music biz
lovinthehd is online now
post #2156 of 2156 Unread Today, 04:06 PM
sm4llz's Avatar
Quoted: 27 Post(s)
thanks everybody. Once I get it setup I'll rerun it. I more excitd to have all of the surrounds and center running off one amp since I did have 2 of the surrounds still on my AVR. I know it won't make that big of a difference acoustically but I feel like I have a slight obsession in things being setup similar when it comes to this stuff.
Emotiva Xpa 5 5 Channel Power Amplifier
