Official Emotiva XPA-5 Owners Thread - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 102Likes
post #2521 of 2596 Old 04-04-2016, 04:25 AM
steveting99's Avatar
Quoted: 1787 Post(s)
Liked: 612
The 3rd generation of XPA amps are now available from Emotiva here: https://emotiva.com/products/amplifiers/xpa-gen3
The 3rd Gen XPA amps are build to order and based on the number of channels needed. Basic price of $899 is just for 2-channels in classic "solid" stereo mode. Note that maximum power is limited to what can be driven into 2-channels. The 3rd Gen XPA amps are now rated to drive 2-ohm loads.
Comparing the MSRP price of the 2nd Gen XPA-5 vs. 3rd Gen XPA-5, there is a cost increase of +$500. This is based on MSRP of the 2nd Gen XPA-5 being $999 vs. 3rd Gen XPA-5 being 899+600=$1,499
The increase in costs from 2nd Gen to 3rd Gen gives you a Class H type amp, switch mode power supply (lighter weight) and an additional 50W per channel.
Anyone willing to try out the new 3rd Gen XPA-5?
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
Last edited by steveting99; 04-04-2016 at 07:20 PM. Reason: amp class clarification
steveting99 is offline
post #2522 of 2596 Old 04-04-2016, 06:56 AM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
Class H, not G, according to their datasheet. Class G switches the power rails among different voltages based upon the input (and thus output) signal; class H uses a tracking power supply to follow the input. The basic amplifier is still class AB.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #2523 of 2596 Old 04-04-2016, 03:39 PM
audio4life's Avatar
Liked: 299
The increase in costs from 2nd Gen to 3rd Gen gives you a Class G type amp, switch mode power supply (lighter weight) and an additional 50W per channel.
Come again?
The max power is limited to what can be driven into 2 channels? Does that mean what I think it means, that the multi channel amps can't make rated power to all channels at the same time?
audio4life is offline
post #2524 of 2596 Old 04-04-2016, 04:04 PM
ALtlOff's Avatar
Quoted: 1042 Post(s)
Liked: 501
Originally Posted by audio4life View Post
Come again?
Their description and specs:
A Word About Power Ratings
Music is, by its nature, dynamic. While it’s relatively common for the two main channels in a stereo amplifier to be asked to simultaneously deliver high
power levels, it is very uncommon for more than two channels to be called upon to deliver high power continuously at the same time, and this almost
never occurs outside of laboratory test conditions.
In order to deliver the most dynamic performance where it counts - with real music - we have designed the XPA Gen3 modular power amplifier with a
single immense power supply, which is able to deliver massive power continuously to any two channels, and to deliver huge amounts of power dynamically
to any number of channels when and if called upon to do so.
The power ratings for the XPA Gen3 modular power amplifier are the same with both channels driven continuously in the two-channel version of the amplifier,
and for ANY TWO CHANNELS DRIVEN CONTINUOUSLY in the versions of the XPA Gen3 configured with three, four, five, six, or even seven output channels.
In addition to this, because we always aim to provide the most complete information possible, we have also rated the other versions in terms of continuous power
(under laboratory conditions) with all channels driven.
Also note that, while the exceptional sound quality of the XPA Gen3 modular power amplifier, and its two-channel continuous power rating, remain the same
whether you choose to use a 120 VAC line or a 230 VAC line, the multi-channel power ratings are somewhat higher when you power the XPA Gen3 from a 230 VAC circuit.
While the XPA Gen3 modular power amplifier will provide plenty of power for most home theater installations when run from a 120 VAC line, for the absolute
best possible performance, we recommend operating the XPA Gen3 from a 230 VAC line.
Circuit Topology
A fully modular audio power amplifier with a high-efficiency switch mode power supply (SMPS), independent, fully discrete, dual differential, high current,
short signal path Class A/B amplifier modules, Optimized Class H™ power supply topology, and microprocessor-controlled fault protection.
Power Output
ALL MODELS: Power Output Per Channel
300 watts RMS per channel; 20 Hz - 20 kHz; THD < 0.1%; into 8 Ohms
550 watts RMS per channel; 20 Hz - 20 kHz; THD < 0.2%; into 4 Ohms
800 watts RMS per channel; 20 Hz - 20 kHz; THD < 0.5%; into 2 Ohms
ALL MODELS: FTC Rated Power; 2 Channels Driven; 20 Hz - 20 kHz; THD <0.1%
300 watts RMS per channel; THD < 0.1%; into 8 Ohms (120 VAC line).
490 watts RMS per channel; THD < 0.1%; into 4 Ohms (120 VAC line).
Power Output Per Channel: All Channels Driven; THD <0.1% ; into 8 ohms
XPA two Gen3: 300 watts RMS per channel
XPA three Gen3: 275 watts RMS per channel
XPA four Gen3: 260 watts RMS per channel
XPA five Gen3: 250 watts RMS per channel
XPA six Gen3: 225 watts RMS per channel
XPA seven Gen3: 200 watts RMS per channel
To me.... while the type G power switching is more efficient and allows for using a slightly smaller power supply for driving multiple amp blades (esp 5 & 7) it is still governed the total available power, they simply chose a power supply that would give you 200 w/ch with 7 channels driven and anything over that for less channels driven is just gravy.
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
http://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
post #2525 of 2596 Old 04-04-2016, 06:06 PM
audio4life's Avatar
Liked: 299
Yeah, I'm not sure what it means either. But if the XPA-5, which is rated by them at 250 wpc, can't do 250 with all channels driven, then they are playing with the numbers. Maybe it can do 200 x 5, I don't know.
post #2526 of 2596 Old 04-04-2016, 06:35 PM
ALtlOff's Avatar
Liked: 501
Edited my post with some color to highlight what you're looking for.
My Build Thread:
ALtlOff is offline
post #2527 of 2596 Old 04-04-2016, 07:23 PM
Liked: 612
Opps!
Post up-dated.
post #2528 of 2596 Old 04-14-2016, 10:35 AM
pacman9270's Avatar
Quoted: 83 Post(s)
Liked: 49
Just received noticed that my XPA-5 has shipped! Can't wait to test this out this weekend!
grtuck likes this.
Theater Setup: 5.2.5 (10.1 Auro3D) / ~3100 cu.ft. / Vaulted Ceiling
Projector:Sony VPL-HW30ES Screen:SI Performance Series 16:9 100" Source Player:Oppo BDP-103D Pre/Pro:Marantz AV8802A Amps:Emotiva XPA-5(Fronts/Surrounds) and BasX A500(Heights) Fronts/Surrounds:Sonus Faber Venere 2.0 Center:Sonus Faber Venere Center Front/Rear Heights:Definitive Technology PM1000 / ProCenter1000(VOG) Subwoofer:Dual SVS SB-2000 Speaker Wire:Monoprice CL2 12-AWG w/Bananas ICs:BlueJeanCables and Mediabridge
pacman9270 is offline
post #2529 of 2596 Old 04-14-2016, 07:35 PM
Liked: 612
Did you get the new Generation 3 or the older Generation 2?
post #2530 of 2596 Old 04-14-2016, 08:49 PM
pacman9270's Avatar
Quoted: 83 Post(s)
Liked: 49
I got the Gen2. Wanted to start off with this amp since it has a good reputation.
post #2531 of 2596 Old 04-15-2016, 11:17 AM
audio4life's Avatar
Liked: 299
Yes, I had seen that. My understanding, and please correct me if I'm wrong, is that those numbers are for 2 channel continuous power rating of each amp.
post #2532 of 2596 Old 04-16-2016, 11:43 AM
pacman9270's Avatar
Quoted: 83 Post(s)
Liked: 49
XPA5 Gen2 came in last night. All hooked up to my 5.2 system consisting of:
PreAmp: Pioneer Elite SC-65
Source Player: Sony BDP S790 Bluray Player
Speakers:
Sonus Faber Venere 2.0 Bookshelves(Fronts) - 88dB / 6-Ohm / 200W
Sonus Faber Venere Center 89dB / 6-Ohm / 150W
Definitive Technology ProMonitor 1000 Bookshelves(Surrounds) 91dB / 8-Ohm / 200W
SVS SB-2000 Subs (Dual Setup on front stage)
Cabling: Monoprice 12AWG CL2 Speaker Wires, Monoprice HDMI Cable(6ft), Mediabridge RCA Cables(4ft)
Music demo'd so far:
Tommy Smith "Peace and Love" CD
Michael Jackson "Thriller - Special Edition" CD
Movies demo'd so far:
Transformers: Revenge of the Fallen Bluray
Avengers Bluray
Spectre Bluray
Initial Impressions:
- Sound seems more dynamic at low to medium volumes in both Stereo and Multi-Channel playback.
- Heat dissipation isn't bad.
- I have not noticed any "hissing" sounds from my speakers.
Will post more of my perceptions on this amp for those people still on the fence. I consider myself have novice to intermediate knowledge in this hobby. For those that this may relate to.
grtuck likes this.
post #2533 of 2596 Old 04-18-2016, 02:31 PM
pacman9270's Avatar
Quoted: 83 Post(s)
Liked: 49
More review:
Set SC-65 Amp to OFF. (Yeah, finally found the setting.)
Speaker Settings set for: Normal setup, distance set, phase control and standing wave. EQ set to OFF.
I re-watched Transformers: Age of Extinction in 3D, 5.1 TrueHD. First of all, I am not a big fan of the movie, but this series is just great to demo and test a system.
Believing that being forgiven would be better than asking for permission, I played the movie at my "Blockbuster Movie Night" level while my wife was still in the house. Before these parameter changes and the amp, she has complained about the volume level that I listen to. This past weekend? She had no complaints. She still had our bedroom door open and only had the TV's volume up a little louder that usual. Wow! I will continue my audition throughout the week and this coming weekend. About mid next week, I will go back to the previous setup to ensure I'm not "hearing my enthusiasm".
However, so far so staying home.
post #2534 of 2596 Old 04-18-2016, 03:29 PM
foobrew's Avatar
Liked: 2
Decided to bite the bullet and ordered an XPA-5 yesterday. I was planning on waiting a little longer before picking up another amp but after seeing all the other Gen 2 amps disappear from their site over the past few months, it seems inevitable that the 5 will be gone soon too. I'm also just not motivated at all to spend over $500 more for the Gen 3 version. If that was my only choice, I'd probably just go with the Outlaw 5000.
I was really only in the market for a three channel and was leaning towards the XPA-3..until it disappeared. I have a UPA-2 already and only a 5.1 setup right now and the UPA-2 provides plenty enough power for my mains. I was going to use the 3 ch amp to power my center and two surrounds (or maybe the front 3 and then put the UPA-2 on the surrounds.) I do plan on upgrading to a 5.1.4 setup later this year so both amps will still go to good use.
I'm specifically looking forward to watching Tron: Legacy with the new amp as that's the only movie I've seen which actually caused distortion in my surrounds during a few scenes. The soundtrack (and sound effects) to that movie are really incredible. Too bad the movie itself is only so-so. My surrounds (and center) are currently being driven by my Onkyo TX-SR706 (very outdated, I know) and it just can't handle it.
Looking forward to the new amp.
foobrew is offline
post #2535 of 2596 Old 05-09-2016, 05:15 PM
psalm234's Avatar
I was just wondering if there is an AVSForum sales contact for Emotiva amps?
psalm234 is offline
post #2536 of 2596 Old 05-09-2016, 07:12 PM
dwaleke's Avatar
Quoted: 1114 Post(s)
Liked: 515
I get a lot of my stuff from @SteveH here on the forum. He is an Emotiva dealer (along with a lot of other stuff).
E-mail or call him here:
www.soundvideo.com
(612) 308-7736
sales@soundvideo.com
dwaleke is offline
post #2537 of 2596 Old 06-27-2016, 12:28 PM
pacman9270's Avatar
Quoted: 83 Post(s)
Liked: 49
2 months later and still really liking my new amp. Went out and also bought a Marantz AV8802A prepro. These two mate together really well. I'm still in the trial phase of my purchase. Now looking for another XPA-5 so I can go Atmos or may just go with another AVR. Any suggestions from anyone?
Source Player: Oppo BDP-103D
Front and Rear Channels: Sonus Faber Venere 2.0 Bookshelves - 88dB / 6-Ohm / 200W
Center Channel: Sonus Faber Venere Center 89dB / 6-Ohm / 150W
Height Channels: TBD. May go with PM1000 speakers from DT or a much less expensive option with some Polk satellites.
Subwoofers: SVS SB-2000 Subs (Dual Setup on front stage)
My speaker configuration will have my height channels directly above the Front and Rear Channels, like the Auro 3D configuration.
Thanks and I look forward to the advice!
post #2538 of 2596 Old 07-04-2016, 02:20 AM
Liked: 612
If you wish to you to the full Atmos/DTS:X 7.1.4 speaker setup with the Marantz pre/pro then you'll need to get at least a 6-channel external amp with the XPA-5 to get up to 11 channels of amplification.
Might want to look at the Monoprice Monolith 7 which will give you the required number of channels.
Edit: If staying with the Emotiva brand, their new A-700 amp is lower powered (80W/channel) version which might be suitable depending on the sensitivity/distance/listening level of the ceiling and surround back speakers.
Last edited by steveting99; 07-04-2016 at 02:25 AM. Reason: alternative for the A-700
post #2539 of 2596 Old 07-04-2016, 08:08 PM
pacman9270's Avatar
Quoted: 83 Post(s)
Liked: 49
Exactly my plan. Already set for the A-700. I'm looking a some Polk satellites for height channels. Possible the TL1's.
post #2540 of 2596 Old 08-15-2016, 12:58 PM
lovingdvd's Avatar
Quoted: 2214 Post(s)
Liked: 360
Hey guys - is anyone in the U.S. using the XPA amps with 240v power? I have an XPA-5 gen3 that I want to power with 240v. I have a power isolation transformer with some 240v straight plug (not a twist) outlets on it. Can I simply just get the right type of power cord and plug it in and the Emotiva will automatically know that is 240v and run off of it just fine (no switches need to be flipped etc)? If so, what type of power cord do I need? A link to something on Amazon would be great! On a related note, are there any benefits to the power the Emotiva units have when running off of 240v (my main reason to do it is energy use efficiency, but wondering if there are other benefits as well). Likewise are there any potential downsides to running it with the 240v?
Thanks!!
lovingdvd is offline
post #2541 of 2596 Old 08-15-2016, 02:11 PM
DonH50's Avatar
Liked: 1325
From the Emotiva website for the new XPA series:
Power Requirements
Between 100 VAC and 250 VAC @ 50 / 60 Hz (automatically detected).
The power cord you need depends upon the type of 240 V wall outlet you have (there are several types depending upon the current rating). You can also buy adapters to convert your power plug to fit the 240 V outlet.
Not sure you will gain much if any efficiency going to 240 V with a SMPS (switch mode power supply) such as the Emotiva uses. At anything less than near full power it may actually be a little worse. There will be less current drawn from the wall socket and correspondingly less voltage drop across the power cord and internal traces to the actual SMPS but I doubt it is significant. That can reduce the overall circuit load, however. No real downsides other than higher voltage across (but lower current through) the power supply's input circuitry. There may be more chance of a ground loop, but that is fairly easily solved. If I had 220/240 V outlets in my media room I would run my amps off them.
DonH50 is offline
post #2542 of 2596 Old 08-24-2016, 08:08 PM
Quoted: 83 Post(s)
Hi all,
I've just gotten a great deal on an XPA-5, and will be pairing it with my Marantz SR7009. Wondering what experiences you've had in external amp with an AVR, or with this one specifically? I'm eventually transitioning to separates, so I won't be heartbroken if there's not a big sound quality boost. But...I'm optimistic.
Anyone have some thoughts?
This Week: Paradigm Prestige 85F mains | Paradigm Prestige 45c center | Paradigm Monitor 3 surrounds | Marantz SR7009 | Emotiva XPA-5 | Marantz 5005 Blu-Ray | Apple TV 4 | REGA DAC.
emptyo is online now
post #2543 of 2596 Old 08-24-2016, 08:14 PM
rpr
rpr's Avatar
Quoted: 42 Post(s)
I apologize in advance if this question has been addressed before but I cannot find it (at least with the search function using the site from my cell). Can one of the channels on the XPA-5 Gen 2 be used to power a passive sub as well as speakers on the other 4 channels?
rpr is offline
post #2544 of 2596 Old 08-24-2016, 08:55 PM
pacman9270's Avatar
Quoted: 83 Post(s)
Liked: 49
Originally Posted by emptyo View Post
Hi all,
This is a YMMV situation. In mine? Yes. I thought analog playback has more perception of depth, sound is more dynamic, and sounds have more "body". That's jmho.
post #2545 of 2596 Old 08-24-2016, 09:15 PM
Quoted: 525 Post(s)
Liked: 138
Hi all,
I went from Yamaha 1050 powering my polk rti12 fronts and csi5 center to xpa5 gen 1 and there was a substantial difference in audio quality. Those rti12 came alive. Now that being said, rti12 can soak a lot power and they do need it to open up. If you have efficient speakers like klipsch, you will not notice any difference.
nohcho is online now
post #2546 of 2596 Old 08-24-2016, 09:20 PM
Quoted: 83 Post(s)
The SR7009 has decent power at 125WPC, but I'm very curious about the 2 channel with the wattage jump. We'll see! Thanks.
post #2547 of 2596 Old 08-24-2016, 09:21 PM
Quoted: 83 Post(s)
I've got some Paradigm Prestige 85F's, and I think they're somewhat efficient, so maybe this will be a sidegrade.
post #2548 of 2596 Old 08-24-2016, 11:35 PM
duc135's Avatar
Quoted: 154 Post(s)
Liked: 219
Hi all,
I have a Denon AVR-4311 and went from the internal amps to an XPR-5 to power Revel Salon2s. Zero sound difference other than I can play a tad bit louder without any distortion from the tweeters. I sit ~9' from my speakers in an 18' x 17' x 8' sealed room.
Your experience may be different depending on your setup, but for music it would be highly unlikely unless you're already maxing out the internal power amps.
duc135 is online now
post #2549 of 2596 Old 08-24-2016, 11:40 PM
duc135's Avatar
Quoted: 154 Post(s)
Liked: 219
It all depends on the passive subs, how far you sit from the subs and how loud you plan on playing them. I have an XPR-5 powering a pair of Revel Salon2s, Voice2 center and a pair of 15" passive, sealed subs. The subs are on either side of my couch and can play extremely loud without issues. I just added the subs about a couple of hours ago though so no long term experience yet. This is a temporary setup used for testing as I already have another pro amp for the subs.
post #2550 of 2596 Old 08-26-2016, 05:52 AM
rpr
rpr's Avatar
Quoted: 42 Post(s)
Thanks for the feedback. So at least it appears to be a viable option. Just don't want to burn up my XPA-5. It will be on Zone 2 of my Denon which controls my outdoor system, so the passive sub will be in a large backyard, meaning I will have to push it and play it rather loud. 250W RMS is probably near the lower limit of what I need to drive this sub adequately (Terra AC.SUBe).
Anybody else have any thoughts or longer term experiences driving a sub with one channel of the XPA-5?
rpr is offline
Emotiva Xpa 5 5 Channel Power Amplifier
