Official Emotiva XPA-5 Owners Thread - Page 87 - AVS Forum | Home Theater Discussions And Reviews
 102Likes
post #2581 of 2597 Old 09-04-2016, 02:24 PM
goros's Avatar
Liked: 35
Originally Posted by emptyo View Post
I grabbed a cable from Radio Shack. All is well.
Next question: After running Audyssey, my settings are REALLY low, and it was suggested I turn the amp down. Is that even possible?
What settings are low? Any changes you make to the output of the amp will require a rerun of audyssey.
Are you hitting the negative 12.5db wall on your speakers?
goros is offline
post #2582 of 2597 Old 09-04-2016, 06:25 PM
DonH50's Avatar
Quoted: 2170 Post(s)
Liked: 1751
If you have very efficient speakers and/or are sitting fairly close to them then the gain trims may be set too low. Implies you don't really need the amplifier... You can pick up inline attenuators to reduce the effective amplifier gain.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #2583 of 2597 Old 09-04-2016, 08:47 PM
Quoted: 96 Post(s)
Here's what I ended up with after running Audyssey.
This Week: Paradigm Prestige 85F mains | Paradigm Prestige 45c center | Paradigm Monitor 3 surrounds | Marantz SR7009 | Emotiva XPA-5 | Marantz 5005 Blu-Ray | Apple TV 4 | REGA DAC.
emptyo is offline
post #2584 of 2597 Old 09-05-2016, 09:06 AM
goros's Avatar
Liked: 35
That's really weird. Did you use the correct microphone that came with the avr and on a mic stand?
goros is offline
post #2585 of 2597 Old 09-05-2016, 10:33 AM
DonH50's Avatar
Liked: 1751
It is indicative of a system with too much gain from AVR to ears. And that you may not have needed to add the amplifier at all. Or simply that the external amplifier has more gain than the internal amplifiers (not unusual) so you need to adjust the gain someplace before the amplifier.
- What were the settings before you added the amplifier?
- What speakers are you using, and how far away from them do you sit?
I would check to see if there is another gain or trim setting someplace in the AVR to reduce the volume.
You can buy inline attenuators to reduce the signal level to the amplifier, something like these: http://www.parts-express.com/Search....itesearch=true I would try the 12 dB version since you are all the way down, or maybe 6 dB if you want room to turn up the trims after Audyssey does its thing. There are probably cheaper versions around, I found these after a quick search of Parts Express.
DonH50 is offline
post #2586 of 2597 Old 09-05-2016, 11:36 AM
lovingdvd's Avatar
Quoted: 2838 Post(s)
Liked: 597
Interesting. What is the concern about having his trims set where they are? In the Marantz 8802a thread I think it is pretty common for people to report around -8 to -10 dB levels as set by Audyssey. In my case I am using an 8802a with a Emotiva gen3 and speakers with 90 dB sensitivity and Audyssey sets my trims at around -9 dB. Are there any potential issue running it like that?
lovingdvd is offline
post #2587 of 2597 Old 09-05-2016, 12:15 PM
DonH50's Avatar
Liked: 1751
I thought the lower trim limit was -12 dB but I may be wrong. My concern is that, if the "real" value required is say -15 dB, then correct amplitude balance cannot be achieved among the speakers because the attenuation limits at -12 dB, and there is no way for the user to know how far off from ideal the gain is in the system. If the limit of the AVR is -12.1 dB then there is no concern (except very little margin). I am also concerned about the implications for the internal filters with respect to gain and amplitude optimization through the filter chain but have no way of knowing exactly how Audyssey handles that internal. Optimization of signal levels through a cascade of filters gets complicated.
I would not be concerned about a -9 dB trim level if the limit is -12 dB.
I would have the same concerns if Audyssey set the level to +12 dB, implying the amplifier did not have enough gain to balance levels among the speakers. Similar analogy; if a channel needs +15 dB, and the limit is 12 dB, that channel will be be loud enough relative to the other channels,and there is no way to know how far off it is.
HTH - Don
DonH50 is offline
post #2588 of 2597 Old 09-05-2016, 03:11 PM
sassuki's Avatar
Quoted: 12 Post(s)
Originally Posted by SOWK View Post
Someone sell me their mint condition/100% working perfect XPA5-GEN2 AMP please...
I have one that I might not use now. I went with elusive 1099s for the lcr duties and I am afraid I won't gain any benefit by using the xpa5 instead of the avr amp since they are so efficient. PM me if you're interested.
sassuki is offline
post #2589 of 2597 Old 09-05-2016, 09:40 PM
sassuki's Avatar
Quoted: 12 Post(s)
Sorry... Just realized mine is actually a gen1
sassuki is offline
post #2590 of 2597 Old 01-17-2017, 03:11 PM
rochesterboy's Avatar
I am new AMPs and XPA-5. Is there a break-in period for this?
rochesterboy is offline
post #2591 of 2597 Old 01-17-2017, 03:13 PM
Secret Squirrel's Avatar
Quoted: 44 Post(s)
Liked: 40
No
Sent from my SM-T230NU using Tapatalk
Secret Squirrel is offline
post #2592 of 2597 Old 01-17-2017, 04:09 PM
Rabid 3-D Aficionado
marcuslaw's Avatar
Quoted: 702 Post(s)
Liked: 598
Not according to Emotiva.
Sent from my SM-G900V using Tapatalk
marcuslaw is offline
post #2593 of 2597 Old 01-17-2017, 05:56 PM
ALtlOff's Avatar
Quoted: 1182 Post(s)
Liked: 589
Nope, Fire-It-Up, it's not like it was back in the Tube days....
*Warning* None of my suggestions, ideas or even thoughts have any WAF, in any way!
My Build Thread:
http://www.avsforum.com/forum/15-gen...formation.html
ALtlOff is offline
post #2594 of 2597 Old 01-31-2017, 02:54 PM
TommyTom83's Avatar
Quoted: 34 Post(s)
Liked: 27
Woohoo just got my tracking number for my XPA 5. Supposed to come in on Thursday
TommyTom83 is offline
post #2595 of 2597 Old 01-31-2017, 08:41 PM
pacman9270's Avatar
Quoted: 94 Post(s)
Liked: 54
Congrats! Still enjoying mine.
Theater Setup: 5.2.5 (10.1 Auro3D) / ~3100 cu.ft. / Vaulted Ceiling
Projector:JVC DLA-X570R Screen:SI Performance Series 16:9 100" Source Player:Oppo BDP-103D/UDP-203 Pre/Pro:Marantz AV8802A Amps:Emotiva XPA-5(Fronts/Surrounds) and BasX A500(Heights) Fronts/Surrounds:Sonus Faber Venere 2.0 Center:Sonus Faber Venere Center Front/Rear Heights:Definitive Technology PM1000 / ProCenter1000(VOG) Subwoofer:Dual SVS SB-2000 Speaker Wire:Monoprice CL2 12-AWG w/Bananas ICs:BlueJeanCables/Mediabridge
pacman9270 is offline
post #2596 of 2597 Old 01-31-2017, 11:57 PM
strindl's Avatar
Quoted: 56 Post(s)
Liked: 32
You'll love it. My gen 1 XPA-5 has been running great since 2009.
marcuslaw and pacman9270 like this.
Main system: Thiel 3.6 L/R speakers, Pair of Velodyne F1500r subs, B&W HTM center, Emotiva and Polk RTi 28 surrounds, Integra DHC 9.9 pre/proc, Pair of Emotiva XPA-1's, Emotiva XPA-5, Threshold SA/4e, pair of Threshold S/200's, Oracle Delphi TT w Magnepan Unitrac 1 arm and Shure V15 - Vmr, Logitech Squeezebox Touch, Oppo BDP 83 optical disc player, Threshold T2 preamp, Denon DR-M44HX cassette, Pioneer CLD-97 Laserdisc. LG PF1500 led projector,Elite 100"tab tension-ed motorized screen.
strindl is offline
post #2597 of 2597 Old 07-13-2017, 05:47 AM
Liked: 4
Hi guys, I'm deciding between (Denon X3300 + Emotiva A500) and Denon X6300/X7200. On paper it seems that X7200 and A500 have the same power ratings per channel, but I know that's not true. AV receiver tends to overstate their power ratings due to the wrong conditions. I want that extra head room, and I like how seperate power amp provides that airy and spacious sound. Not sure if it makes sense.
I use it for 2.0/2.1 stereo music and 5.2.2 Atmos movies. System: Monitor Audio Gold 100, C350, bronze fx, pro 65 inceilings, dual SVS SB2000.
Any inputs would be appreciated thanks (:
holyxiaoxin is offline
Emotiva Xpa 5 5 Channel Power Amplifier
