"Official" Yamaha RX-V467/RX-567 Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 603 Old 02-27-2011, 01:38 PM
marmyk1's Avatar
Originally Posted by kriktsemaj99 View Post
The disc might be OK, it could be the player that's the problem. The older the player the more likely it will work. PS2 is known to work. PS3 will work if you set the audio output options correctly.
If you take the disc you burned and rip it losslessly (back to WAV format) I can tell you if it's a valid firmware file (by verifying all the checksums). That will at least tell you if the disc or the player is the problem.
Also, with the right player people have been able to play the original WAV file directly from a USB memory stick, and skip the CD burning stage altogether.
I would like to thank everyone for their input on my RX-V467 firmware problems. I finally got back to it this morning after being rudely interrupted by life. I successfully installed it this morning using NTi to burn the cd. my problem was stubbornly trying to get windows media player to do it. after several attempts without success, then wasting time trying every player in the house to do what cant be done. the first burn with NTi then using a PS2, thanks to kirktsemaj99 for that one, it was done without a hitch. when the sony EX720 arrives i will see how it all works. and now we wait.
marmyk1 is offline
post #272 of 603 Old 02-28-2011, 04:50 AM
Lordlindsey's Avatar
What does the firmware do for the 467?
Is it fixing a problem or giving additional features?
Lordlindsey is offline
post #273 of 603 Old 02-28-2011, 11:43 AM
marmyk1's Avatar
the firmware allows 3D video pass-through capability for the HDMI connections
marmyk1 is offline
post #274 of 603 Old 02-28-2011, 12:19 PM
Ah, ok.
post #275 of 603 Old 02-28-2011, 03:33 PM
tonedef407's Avatar
I've got the 467 running with two fronts and am going to be adding a matching center tomorrow. What is going to be the best way to set this up with the receiver. I know to tell the receiver that those 3 are all that's hooked up. Will that automatically downmix the multi-channel audio into the 3 speakers?
tonedef407 is offline
post #276 of 603 Old 02-28-2011, 09:39 PM
zlaneb's Avatar
Any help appreciated.
Straight forward setup - Time Warner Cable box to 567 HDMI1 In.
567 HDMI Out to Sony Bravia HD TV.
Standard Setup of Surround Speakers.
During playback from TW Cable box, video and audio cuts out on TV and speakers. I have noticed the Cinema DSP indicator flashes on the 567 when this occurs. DRIVING ME BATS! Anyone else experience this issue? Any help definitely appreciated.
Thanks in advance!
zlaneb
zlaneb is offline
post #277 of 603 Old 03-01-2011, 04:10 AM
Good question for a 3-speaker setup.
I think it will.
post #278 of 603 Old 03-01-2011, 04:11 AM
Thanks in advance!
zlaneb
Need to narrow down, whether it's the TW box or AVR.
Try plugging directly from TW box to TV and see if the issure pops up.
post #279 of 603 Old 03-01-2011, 04:45 AM
Ticmxman's Avatar
Thanks in advance!
zlaneb
HDMI cable possibly.
Ticmxman is offline
post #280 of 603 Old 03-02-2011, 02:45 PM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
What did I do wrong???
I got this receiver about month ago. Hooked up my Comcast cable box by running coax to the receiver for audio and component straight to the TV for video. I have a 5.1 setup and it worked great. I got a lot of activity in the surrounds that was missing from my old receiver. I listened to pretty much everything in direct mode. Recently, I got an HDMI TV. I unplugged everything, removed the component cables and installed HDMI from the cable box to the TV. I made no changes to the audio feed. Now, when I watch cable I get no activity in the surrounds. Surrounds work fine from my blu-ray player.
What do I need to do to fix this???
David
crussader is offline
post #281 of 603 Old 03-02-2011, 10:42 PM
frankz1's Avatar
Sounds like your setting in the cable box got switched from Surround to Stereo (PCM).
frankz1 is offline
post #282 of 603 Old 03-03-2011, 07:03 AM
caper_1's Avatar
Liked: 26
Yeah, check audio settings in cable box...something like HDMI audio or something. Also, may need to select some sort of matrix, like PLIIx in the receiver. Could be so may things. Start with the cable box first. Maybe HDMI audio is set to stereo or something?
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
post #283 of 603 Old 03-03-2011, 10:46 AM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
Thanks. Will check the cable box settings.
David
post #284 of 603 Old 03-04-2011, 12:30 PM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
I'm about to buy a 3D blu-ray player. I have to upgrade the frimware before it will work?
David
post #285 of 603 Old 03-05-2011, 03:10 PM
newfpw's Avatar
I just set up my RXV467 my fat PS3 is set in linearPCM and display shows it's playing DTS-HD receiver shows PCM not multi-ch pcm did I do something wrong
Panasonic VT-60,LG 55LW5700,Playstion TV, Fibe Pvr+wireless,YAMAHA RXV-467, .HARMONY 520,XBOX360#5+HD-DVD.PS4
newfpw is offline
post #286 of 603 Old 03-05-2011, 03:25 PM
kriktsemaj99's Avatar
Quoted: 636 Post(s)
Liked: 357
It depends when you bought the receiver, it's possible you already have the firmware that can pass 3D. You could go and download the latest firmware from the Yamaha web site, and it will contain instructions on how to check your current firmware version.
kriktsemaj99 is offline
post #287 of 603 Old 03-08-2011, 05:15 AM
caper_1's Avatar
Liked: 26
No, I think thats right.
caper_1 is offline
post #288 of 603 Old 03-08-2011, 07:36 PM
newfpw's Avatar
My 467 came with the firmware cd taped to the box
newfpw is offline
post #289 of 603 Old 03-10-2011, 11:44 AM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
Am trying to download the 467 firmware from the Yamaha site, but all it downloads is a pdf. Can somebody give me a good link?
David
post #290 of 603 Old 03-10-2011, 04:50 PM
caper_1's Avatar
Liked: 26
The PDF has a link to the WAV file inside it...try that.
caper_1 is offline
post #291 of 603 Old 03-10-2011, 07:50 PM
Starless's Avatar
Should it be possible to do the update using my airport express/itunes with an optical connection to the receiver? I tried it but had no luck so far. I don't actually have a disk player connected to the receiver...
Starless is offline
post #292 of 603 Old 03-10-2011, 07:51 PM
marmyk1's Avatar
your lucky, i had to make mine and it caused me grief
marmyk1 is offline
post #293 of 603 Old 03-11-2011, 01:11 PM
newfpw's Avatar
Should I do the update ,I have no 3D devices or ever intend to,is there any other fixes
newfpw is offline
post #294 of 603 Old 03-11-2011, 03:47 PM
newfpw's Avatar
just checked it all ready updated,lucky me
newfpw is offline
post #295 of 603 Old 03-11-2011, 04:22 PM
marmyk1's Avatar
my understanding of the firmware is for 3D pass-through on HDMI. I am not aware of any other benefits.
marmyk1 is offline
post #296 of 603 Old 03-11-2011, 08:20 PM
marmyk1's Avatar
just hooked up a pair or Axiom M22's to my Yamaha RX-V467. sweet,sweet,sweet.
marmyk1 is offline
post #297 of 603 Old 03-13-2011, 10:03 AM
layne123's Avatar
"l assume the answer is yes unless I hear otherwise and ask another question. I understand the 467/4063 does not upconvert but everything I'll be feeding through it does it's own upconverting. Is there any need for a second upconverting point? My philosophy is the simpler the better so long as it does the job"
I didn't see an answer to the question above and obviously I have the same question.
Also what's the HDMI standby pass through that people are mentioning?
Thanks for any assistance!
layne123 is offline
post #298 of 603 Old 03-13-2011, 01:58 PM
marmyk1's Avatar
the AVR will simply pass-through video. if your sending HD signals to your tv theres no need to up convert them. no up converting from this model. the HDMI standby pass-through allows audio/video signals to be sent to the tv buy HDMI without the AVR being turned on. this is usefull for late night viewing when others are asleep
marmyk1 is offline
post #299 of 603 Old 03-13-2011, 07:46 PM
layne123's Avatar
layne123 is offline
post #300 of 603 Old 03-14-2011, 05:25 AM
caper_1's Avatar
Liked: 26
I have the 565 which upconverts. Reason why is I wanted only ONE cable from AVR to TV: HDMI. It will 'upconvert' component video (Wii, DVD) to HDMI, so I never have to change input on my television.
caper_1 is offline
Yamaha Rx V467bl 525 Watt 5 1 Channel Av Receiver Each Black , Yamaha Rx V567 Receiver
