"Official" Yamaha RX-V467/RX-567 Thread - Page 20 - AVS Forum | Home Theater Discussions And Reviews
post #571 of 600 Old 12-25-2012, 10:13 PM
jtb50's Avatar
I have a rx-v567 with firmware version e017. Been thinking about purchasing a 3d tv. Will i need to upgrade the firmware to 018, or is 017 ok to pass through the 3d signal. Thanks.
jtb50 is offline
post #572 of 600 Old 04-13-2013, 03:25 PM
Jeff Nussbaum's Avatar
I know this is a late question on this receiver but can I hook up a sacd player via analog jacks? I'm not sure but I don't think this receiver (RX-567) supports it
Jeff Nussbaum is offline
post #573 of 600 Old 04-13-2013, 07:18 PM
kriktsemaj99's Avatar
Quoted: 628 Post(s)
Liked: 344
For multi-channel SACD you can use HDMI if your player supports it (either for PCM or DSD). Only the 667 and higher have multi-channel analog inputs.
Jeff Nussbaum likes this.
kriktsemaj99 is offline
post #574 of 600 Old 04-14-2013, 08:46 PM
Thanks for answering going with good old HDMI
post #575 of 600 Old 04-28-2013, 11:39 AM
ThurstonX's Avatar
Hi,all.
Hoping someone has some insight into this problem.
I just moved my old Kenwood 5.1 AVR out, and put the RX-V467 in its place. The Kenwood could only handle 24-bit 96KHz PCM over SPDIF, but at least it handled it. The RX-V467 claims to support 24-bit 192KHz, and as I have a few hi-res albums in that format, I wanted to be able to stream them from a PC (M-Audio Delta 192 card) to the AVR. The files are FLAC and play fine on a laptop with a Realtek chip that supports that format. And the Kenwood could handle 24-bit 96KHz FLACs via SPDIF.
The RX-V467 doesn't even show speaker icons when I set the M-Audio card to 192,000 Hz. If I go down to 176400, the front speaker lights come on, and stay on for lower samplerates. BUT, when playing back a 24-bit 96KHz FLAC from Winamp (using either the default DirectSound output plug-in, or the Maiko WASAPI output plug-in set to Shared or Exclusive mode), I get no sound. Both output plug-ins' status shows the proper format being output, and the Kenwood could handle this. All this with the M-Audio set to the correct samplerate (96000), and Winamp allowing 24-bit playback.
I've got the M-Audio hooked up to a pass-through SPDIF switch (coax in, optical out; the switch handles this fine, per the above Kenwood example), and the switch to the AVR, so that's not the problem. I do get sound if I play a "normal" CD quality FLAC, or if I play a 24-bit 96KHz FLAC (via DirectSound), but set the M-Audio to 44100 or 48000. If I go beyond 48000, I get nothing. I confirmed this by connecting the M-Audio directly to the RX-V467 via coax. The exact same results as above: no playback above 48000.
I've also tried AV3 and AV4 inputs, but of course there's no difference in test results.
If I play a DTS DVD (or audio ripped from one, played in MPC-HC via LAV Audio), where the samplerate reads 96/48, the M-Audio automatically goes to 48000, even if I had it set to 96000, but the RX-V467's Audio Decoder info says "DTS 96/24." That's just more confusing. At least all five speakers light up on the front ;-)
Another thing I notice is that the "Audio Decoder" for AV1 (Optical IN) says "Analog." Not sure if that's relevant. If I try to play a 16/44.1 FLAC with "Stereo" I get nothing. Works with Direct and Straight, and various other enhancements. Decoder always reads Analog.
So my question is, am I misinterpreting the manual? Does the RX-V467 not support PCM over SPDIF beyond 48KHz? I've tried Direct mode, Straight, Stereo, Stereo and then Direct (doubt that matters, as Direct should override all other settings). No joy.
So, guessing I've misinterpreted the manual, can anyone recommend a decent AVR that will handle 24-bit 192KHz FLACs via SPDIF?
Thanks for reading!
ThurstonX is offline
post #576 of 600 Old 04-28-2013, 12:02 PM
Quoted: 628 Post(s)
Liked: 344
Originally Posted by ThurstonX View Post
The RX-V467 claims to support 24-bit 192KHz...
I think any claims of 192kHz apply to HDMI audio.
post #577 of 600 Old 04-30-2013, 09:35 AM
ThurstonX's Avatar
I think you're right. This, from Yamaha support:
It does not support FLAC file formats. For the Optical/Coaxial inputs you would have to set the output to 96 kHz. Or use HDMI which will support higher bit rate PCM signals.
Best Regards,
The Yamaha Customer Support Team
They are incorrect re: the Optical/Coaxial inputs. I output the same signal from the same PC to my old Kenwood VR-6060 and got 96 KHz. Just wasn't happening on the RX-V467.
I might try enabling the AMD Radeon's HDMI Out, and hook it up to the Yamaha to see if it'll take 24/96 and 24/192. The one thing I'd miss by swapping Yamaha for Kenwood is the Kenwood's 6-Ch. input. It's handy for video files that have, e.g., 5.1 AAC audio. That works great from the motherboard's onboard Realtek outs. Can't pass that over SPDIF. Re-encoding to AC3 on the fly works, though.
post #578 of 600 Old 04-30-2013, 01:16 PM
ThurstonX's Avatar
Sure enough, I can get 24/192 through my AMD Radeon HD 6670's HDMI Out, played via Winamp and the Maiko output plug-in in WASAPI Exclusive (Bit-copy) mode.
Now, do I sacrifice my 6-ch and dedicated Phono inputs for 24/192? Decisions decisions.
Thanks, kriktsemaj99, for the suggestion to try HDMI. I usually disable that device in Windows.
post #579 of 600 Old 09-21-2013, 09:04 AM
krisfnbs's Avatar
I own a 467 and I am having a hard time setting my floor standing speakers crossover points. I cant seem to locate it. I do have a sub, and I have that setting at 100hz in the receiver. However there is practically NO bass coming out of the floor standing. (Bic acoustech PL76) Any help would be appreciated.
Additionally, any guideline on setting the GEQ in this unit? Im not too familiar with setting up recieivers as you can tell.
krisfnbs is offline
post #580 of 600 Old 09-22-2013, 07:44 AM
Quoted: 628 Post(s)
Liked: 344
There's only a single crossover setting, which applies to the sub and all speakers set as SMALL.
If you set the fronts as as LARGE they will play all frequencies, but then you're putting more load on the 467 which doesn't have a lot of power. If set as SMALL they are only playing above 100Hz now, so you could lower the crossover to 80 (or even less), unless you have much smaller surround speakers that don't want a lower crossover.
If you've run YPAO then it has already set up the parametric equalizer, and changing to manual GEQ will override the YPAO settings.
post #581 of 600 Old 09-27-2013, 05:37 AM
caper_1's Avatar
Liked: 26
Those speakers should be set to "Large" which will allow them to play "regular" bass, but the receiver will still divert LFE channel of x.1 material to the sub, assuming the setting for LFE/BASS Out is either SWFR or Both.
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
post #582 of 600 Old 11-18-2013, 04:54 PM
SULLY12's Avatar
I have looked around and cant seem to find an answer. has any one with the 567 use a pro amp for thesre subs? I really need to know if it will work ok or if i need extra stuff to make it work. i am looking at the inuke 1000 or 3000. thanks
SULLY12 is offline
post #583 of 600 Old 12-16-2013, 08:03 AM
Howie21's Avatar
Hi,
I have a RX-V467 and have just updated the Firmware to 018 without issue. The update process worked fine.
Since doing this my remote has stopped working (I have changed the batteries and confirmed that it works with the TV)
Has anyone else experienced this or aware of a fix.
Any help or advice greatly appreciated
Howie21 is offline
post #584 of 600 Old 12-18-2013, 10:57 AM
Howie21's Avatar
Originally Posted by Howie21 View Post
Hi,
Sorted.  I had to reset the Remote ID to 520
Howie21 is offline
post #585 of 600 Old 12-25-2013, 09:41 PM
Tyjb9x's Avatar
I recently acquired a RX-V467 along with a Bang & Olufsen Beogram RX (http://www.beoworld.org/prod_details.asp?pid=858). I have a couple quick questions and I'm not sure if this is the thread / forum to be posted these questions on, but here goes.
1) It's my understanding this turntable does not have a preamp, so I would need to purchase one like this? (http://www.phonopreamps.com/tc450pp.html)
2) The RX-V467 does not have a phono input, thus requiring a preamp, which I posted above (is this correct?)
3) The RX-V467 does have a pre-out, but no pre-in but again, would purchasing a preamp would solve this?
4) Would I need external amplifier or would running it through the RX-V467 bypassing the preout on the RX-V467 and just using an external preamp work? Would I need to use the "Pre Out" on the receiver at all?
So overall I'm assuming it would work like this, Turntable > IN External Phono Preamp > OUT External Phono Preamp > IN Audio 1 on RX-V467 > OUT Audio Out on RX-V467 (if I'm using component speakers. What if I was using speakers with normal speaker wire?
Sorry for all the questions and I'm hoping it's a simple solution.
Tyjb9x is offline
post #586 of 600 Old 12-26-2013, 06:11 PM
FrankH3rd's Avatar
Plug the turntable into one of the RX-V467 audio inputs and see what happens. Can't hurt anything and you might get outcome you want. If output volume too low or noisy when volume control at high level, then you need a preamp.
FrankH3rd is offline
post #587 of 600 Old 12-26-2013, 06:41 PM
Tyjb9x's Avatar
It is playing and the quality sounds pretty good, except the volume doesn't get very loud (which maybe the speaker) and the volume control on the RX-V467 does not do anything, even all the way down or up!
Tyjb9x is offline
post #588 of 600 Old 12-27-2013, 04:45 AM
FrankH3rd's Avatar
Lower volume and plug headphones into rx-467. See if volume changes and in normal range and good quality---> don't need preamp. (Do same test for regular speakers). If volume very low ---> do need preamp for turn table.
Regarding pre out, volume controls in general do not control line level (pre out) levels, only final amp in receiver, but might be software option setting, not sure.
post #589 of 600 Old 07-12-2014, 08:21 AM
renji1337's Avatar
Quoted: 70 Post(s)
Does it mattter if you have your speakers set to 8 or 6 ohm in sp imp? I have 6 ohm speakers but there connected as 8 ohm.
renji1337 is offline
post #590 of 600 Old 09-26-2014, 08:59 AM
Liked: 0
Question v467 Amp, cannot seem to update firmware
Hey All,
I wonder if you can give me some pointers. I have a UK RX-V467 amp (I am in the UK!) and I am trying to update the firmware for the 3D passthru and also to see if this improves ARC, however, this whole burn a CD and play it just does not seem to work at all.
Any pointers, I have tried anything from playstations to an old portable CD with no luck.
Any advice would be appreciated.
Vortal is offline
post #591 of 600 Old 09-26-2014, 09:53 AM
Quoted: 628 Post(s)
Liked: 344
^ if you've tried multiple players and they all fail, chances are it's the way you burned the CD. Do you see CDDA Upgrader on the display, but then nothing happens after you start playing the disc?
Some burning software modifies the data before writing to disc, unless you change the default settings. For example, I've used Windows Media Player successfully, but it won't work unless you go into burn settings and disable "Apply volume leveling across tracks".
So how exactly are you burning the CD?
post #592 of 600 Old 09-26-2014, 10:15 AM
Liked: 0
Yea I see the CDDA Upgrader on the display but nothing happens.
Stuck now for buring discs as switched to MBP's at home - will see if I can burn one at work
Vortal is offline
post #593 of 600 Old 01-25-2015, 07:58 AM
Cravit8's Avatar
Quoted: 1151 Post(s)
Liked: 610
I need a replacement HDMI board, does anyone know where I can find a vendor?
I have google searched all the numbers on the board and nothing comes up. I was expecting somewhere to have these in stock the way most TV brand boards can be had.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #594 of 600 Old 02-18-2015, 10:10 PM
IronHorse's Avatar
Is there an "Official" Yamaha HTR-5063 thread bouncing around? I'm in the process of tweaking/changing my speaker setup, so it would be helpful to have some dialogue with someone who can tell me more about my setup options especially the center and surround speakers. I also want a quickie lesson on using the microphone balance system. Thanks!
• If God had intended man to watch TV 24/7, he would have given him Rabbit Ears •
Mitsubishi WD-65737 DLP • Yamaha HTR-5063 • Panasonic BDT210 BDPlayer • DirecTVDVR • Chromecast • AppleTV/XMBC • Comcast HD
Speakers • Towers Polk Audio Monitor60B II • CC Polk Audio CS1B II • Rear Surround Klipsch S10s • Sub Velodyne EQ Max 8"
IronHorse is offline
post #595 of 600 Old 08-20-2015, 09:24 AM
Liked: 0
Question last US firmware
Hi,
Can i apply the last US firmware (F018) on my european (french) RX-V567 ? Because, it seems to be the only one avalaible. My 567 is running with the C015.
I've an heavy graphic issue with an intel igp on windows (with openelec, it works well). I unable to have 1920x1080@60 hz with my intel's NUC with any driver and the last bios. I hope this upgrade will resolve this issue.
thanks
dranerfr is offline
post #596 of 600 Old 08-20-2015, 08:06 PM
Quoted: 628 Post(s)
Liked: 344
Yes, the same firmware is used in all regions (US, Europe, etc.) so you can do the update. But the problem may be at the source rather than with the receiver.
post #597 of 600 Old 10-27-2015, 09:29 AM
Liked: 0
Direct Mode as standard
Is there a way to configure a source to always use "Direct Mode"? Right now I always have to manually set Direct Mode after turning the receiver on. This is especially painful, since there is no button for this on the receiver itself, only on the remote.
CHMiniMized is offline
post #598 of 600 Old 01-02-2016, 08:40 AM
LOTL's Avatar
Just lost my HDMI video. I have had the following setup working for a few years and now have just lost the video but still have sound.
I have my Comcast STB connected via HDMI to the AVR HDMI 1 input and then my HTPC connected via HDMI to AVR HDMI 2 input.
If i connect both devices to my TV directly using the same HDMI cables, i get both video and sound with no issues. I changed the HDMI output cable from the AVR with a known good working HDMI cable and still no luck.
None of the cables are longer than 8'.
Im open to suggestions on what to try next.
LOTL is offline
post #599 of 600 Old 01-05-2016, 07:34 AM
Cravit8's Avatar
Liked: 610
Sorry buddy you're outta luck.
I've had a unit sitting in my office for 18 months with the same problem because there are no parts resellers.
PSN: Cravit8
XBL: oOo_Crav_oOo
Cravit8 is offline
post #600 of 600 Old 07-23-2016, 01:51 PM
rastuso's Avatar
Audio only through HDMI?
I have an HTPC. I use HDMI to the receiver for movies fine. I just upgraded my motherboard, and it has no Optical out, which is getting to be the norm. But the HDMI out to the reciever only shows up if the Projector is on. I want to also just send audio out for music to the reciever, without my PJ being on. Is this possible?
Good Lord, after LOTS of looking, it was nothing but EXTENDING my desktop to the HDMI, not duplicating. WOW, that sure wasn't an easily found tidbit.
Jason
rastuso is offline
Yamaha Rx V467bl 525 Watt 5 1 Channel Av Receiver Each Black , Yamaha Rx V567 Receiver
