HDMI 1920x1200 receiver support? (Sony STR-DH810) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 04-06-2010, 12:48 AM - Thread Starter
MyDogHasFleas's Avatar
Just picked up a new 2010 model Sony receiver STR-DH810. I connect my PC which has HDMI output to the receiver's HDMI input. Then I connect my receiver's HDMI output to my 1920x1200 LCD monitor.
Lo and behold, the computer's display settings show the display as a "SONY AVAMP" rather than what it actually is, and limit me to setting 1920x1080 resolution. This happens even when I turn pass-thru on and put the receiver in standby mode.
If I connect the PC directly to the monitor via HDMI cable, all is well video-wise. Unfortunately then I have to listen to sound over the monitor's speakers instead of my home theater speakers.
I think I'm going to need to return this receiver as it does not do what I want, that is, to pipe the sound from the PC over HDMI to the receiver for processing, yet pass through full 1920x1200 to the monitor.
Are there any HDMI receivers which support 1920x1200? Or is there a different solution to my problem? I've also thought about using an HDMI splitter, I wonder if that would work. They're kind of expensive though.
MyDogHasFleas is offline
post #2 of 19 Old 04-06-2010, 10:27 AM
DaveHCYJ's Avatar
hdmi 1.4 supports resolutions greater than 1080p, so it should be able to do it. If you set the output from your computer to 1920x1200 then the receiver should be able to pass it through.
You might try contacting your graphics card manufacture, or checking their forums. Its been years since I've done it, but with one of my old video cards, I had to get 3rd party drivers to get it to work.
Basically whats happening is your video card is trying to make things "easy" for you by limiting you to the resolutions that the Sony is reporting, even though you know better than the video card.
DaveHCYJ is offline
post #3 of 19 Old 04-06-2010, 10:32 AM
ccotenj's Avatar
Liked: 101
- yup, "sony avamp" is what it is... the pc is getting that from the edid information provided by the avr...
- it's likely that when the pc is handshaking with the avr, the avr is telling it "i can only accept up to 1920 X 1080, so please send that"...
- an hdmi switch is unlikely to buy you much, as the pc won't be able to complete a handshake with two different output resolutions...
i don't know which (if any) avr's will pass 1920 X 1200...
- chris
ccotenj is offline
post #4 of 19 Old 04-06-2010, 10:35 AM - Thread Starter
I've done some more research. I think the bottom line is that the receiver just doesn't support anything more than 1080p (1920x1080). The Onkyo TX-SR607 is also reported to have exactly the same problem, right here on AVS in the "official thread".
Some users who have fooled the HTPC into sending 1920x1200 report that the receiver no longer processes the audio over HDMI, which kind of defeats the whole purpose.
I wonder if the newer HDMI 1.4 supporting receivers will handle my situation.
I think what I will do is return the Sony receiver and wait a bit until the newer receivers get some experience. I think the receiver designers just didn't allow for HTPCs and HDMI -supporting video cards going to LCD displays very well.
post #5 of 19 Old 04-06-2010, 10:37 AM
ccotenj's Avatar
Liked: 101
@dave...
all flavors of hdmi (right from version 1.0) will support 1920X1200p60...
that doesn't mean that the ce implemented that support...
- chris
ccotenj is offline
post #6 of 19 Old 04-06-2010, 10:42 AM - Thread Starter
I think you meant "splitter" but yes I agree, on 2nd thought, stupid idea, will not work
me neither but if I find out I will post here. I'm hoping that the newer HDMI 1.4-supporting receivers will do the trick. Like the Onkyo TX-SR608 or Sony STR-DN1010, which will be available in the next couple of months.
post #7 of 19 Old 04-06-2010, 10:57 AM
ccotenj's Avatar
Liked: 101
yea, splitter... that's what i get for trying eat and post at the same time...
it'll be interesting to see what ends up supporting computer resolutions... a lot of displays do...
i'm wondering if the cem's are even really considering the htpc marketplace when designing avr's...
now i'm also curious to see what happens if i feed my avr a wuxga signal... gonna try it tonight and see what happens...
- chris
ccotenj is offline
post #8 of 19 Old 04-06-2010, 11:09 AM
DaveHCYJ's Avatar
The Onkyo 608 has a vga input, so maybe the marketplace is moving more towards support for htpc's. We'll have to wait and see if it supports any higher resolutions though...
Also, the OP's receiver is a 1.4 receiver, so it seems that rules out 1.4 making this work. But who knows, it could actually work -- we still don't know if he has tried forcing it to do 1920x1200 yet.
DaveHCYJ is offline
post #9 of 19 Old 04-06-2010, 11:17 AM - Thread Starter
Are you sure it supports HDMI 1.4? Nothing that I have in the box says that. And HDMI 1.4 is listed as an "added capability" for the STR DN-1010 in this review.
From what I've read, people who force 1920x1200 lose the ability for the receiver to decode the audio portion of the signal, so it'd be moot anyway. I'm going to give up and return this thing, and wait a few months before I try again. I'm just going to use my old receiver which does not have HDMI and limp along sadly for a while.
post #10 of 19 Old 04-06-2010, 11:28 AM
DaveHCYJ's Avatar
My bad. I just skimmed that review the first time I read it -- I assumed it was like Onkyo's 2010 lineup, where every model all the way down into the home theater in a box ones are getting the full 1.4 implementation.
DaveHCYJ is offline
post #11 of 19 Old 04-06-2010, 11:52 AM
ccotenj's Avatar
Liked: 101
it'd be nice if they did... it would make some people real happy...
we'll find out in a couple hours what happens if you force it through mine...
- chris
ccotenj is offline
post #12 of 19 Old 04-06-2010, 04:05 PM
ccotenj's Avatar
Liked: 101
update:
no can do (re: force)... at least in the case of os/x... it will only allow me to set resolutions that the avr will accept according to it's edid info...
- chris
ccotenj is offline
post #13 of 19 Old 04-06-2010, 04:13 PM
JOHNnDENVER's Avatar
Did you expect this to work?
I would of said no before you even tried it.
I mean, I don't know of any that do x768 either for that matter.
JOHNnDENVER is offline
post #14 of 19 Old 04-06-2010, 04:21 PM
ccotenj's Avatar
Liked: 101
nope. i didn't. but i was curious, so i figured i'd try...
- chris
ccotenj is offline
post #15 of 19 Old 04-06-2010, 07:53 PM - Thread Starter
Another update, according to the Onkyo 608 manual (see page 75), 1920x1200 is not supported.
I guess I'll just have to make do with direct HDMI connections and sending the headphone audio to the receiver over RCA cable connections. Ah well.
What I'd really like is an HDMI mixer that can take 4 HDMI sources and output them to 3 HDMI screens in any manner I like, with any resolution I want, as well as processing the audio. I wonder how much money I'd have to spend to get this? Or how long I'd have to wait before this was available for under $1000?
post #16 of 19 Old 05-05-2010, 10:59 AM
FaKK's Avatar
found this side via google.
I'm looking for a new AV Reciver and had the hdmi 1.4 Sonys in mind, so i won't buy them. I just testet 1200p with my Panasonic SA-BX500 and had the very same result plus the monitor stays black while restricting higher resolutions.
What is a Solution? Got a ATI HD4xxx & HD5xxx with multichan. PCM + AC3/DTS HD Support and don't want to buy an additional HDMI Sound card.
Using 1st Port via DVI for the Monitor & 2nd one 'empty' via HDMI for a AV Reciver is nuts too:
- You can't use 2nd Monitor anymore unless it's resolution is <1080p plus its 16:9
- 2nd Monitor needs always to be turned on/at least clone mode.
FaKK is offline
post #17 of 19 Old 12-31-2014, 08:48 AM
Liked: 0
Hi,
I have a similar problem. I connect PC>Receiver>Monitor and for monitor resolution in settings on PC I can see 1080p recommended, while the monitor is showing maximum resolution as 1200p in its settings. I've spent ages googling, and cannot fix this....
But the weirdest part is, that with an older receiver, everything worked fine - I connected PC>AVR>Monitor and could set proper 1200p resolution for the monitor. However with newer AVR this 1200p disappeared. Could it be fault of new AVR? (It worked with Denon X2000, now I have Denon X2100, everything should be the same with them..).
phemark is offline
post #18 of 19 Old 12-31-2014, 11:39 AM
afrogt's Avatar
Quoted: 1055 Post(s)
Liked: 756
You should post that in the 2014 Denon xSeries Owners thread. JD may have the answer for you. The title of this thread is about the Sony DH810 and he may not see it.
The 'Official' 2014 Denon "S Series" / "X Series" AVR Model Owner's Thread & FAQ
Afro GT
afrogt is offline
post #19 of 19 Old 01-10-2015, 09:23 AM
Liked: 0
So spoke with Denon support, sent them EDID files, and they confirmed that X2100 doesnt support any resolutions in the range of 1080p-2k (they support those 2 though), so that is the reason it couldn't output to my 1200p monitor with that resolution.
They said it was because of stricter chip in X2100 (as I can do this fine in X2000).
phemark is offline
