The "Official" Pioneer VSX-1020-K Owner's Thread - Page 103 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #3061 of 4704 Old 03-05-2011, 01:34 PM
Millerca2's Avatar
Originally Posted by ChristianZane View Post
I just bought an Onkyo and it displays a huge graphical banner at the bottom of my screen everytime I mute or change the volume which covers up my DTV banners, there is no way to turn this off, is there an option on the VSX-1020 to turn the OSD off when changing the volume or muting? Thanks I'd appreciate the assistance before I purchase this receiver.
There is no OSD with the 1020, so it isn't an issue.
Millerca2 is offline
post #3062 of 4704 Old 03-05-2011, 02:10 PM
ChristianZane's Avatar
It says "A full-color GUI to control your home theater experience"... so when you change the volume or mute, you don't get a graphic on your TV? Is there an option to turn that ON if you wanted it? Thanks!
ChristianZane is offline
post #3063 of 4704 Old 03-05-2011, 03:04 PM
LastButNotLeast's Avatar
Quoted: 1492 Post(s)
Liked: 1091
Originally Posted by ItzMe View Post
Regarding Page 10 of the manual, is there an audio or video file somewhere that I can download to test all the digital formats (DTS-HD, DTS, MSTR, etc). I also want to see when my "XC" speaker lights up and when it doesn't.
These:
http://www.avsforum.com/avs-vb/showthread.php?t=1181902
and here:
http://www.demo-world.eu/trailers/hi...n-trailers.php
Have fun!
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #3064 of 4704 Old 03-05-2011, 03:14 PM
Liked: 1091
I was going to suggest downloading the manual, but Pioneer's site seems to be down, so I found it here:
http://www.retrevo.com/support/Pione...3658ag511/t/2/
And, no, AFAIK.
post #3065 of 4704 Old 03-05-2011, 03:26 PM
Millerca2's Avatar
To clarify. When you do the mcacc or setup there is an on screen GUI and it is very nice. Once the setup is completed you will no longer have any display on the screen. No way to turn it on even if you wanted to. Some people like it, some that have their receivers tucked away don't.
post #3066 of 4704 Old 03-05-2011, 03:39 PM
Great thanks, Pioneer site has been down all day which is why I couldn't get this info in their manual, cheers.
post #3067 of 4704 Old 03-05-2011, 03:40 PM
Flash711's Avatar
I'm having audio issues. Running a Sumsung BD-c5900 to the 1020. The last few movies I've watched I'm having audio cut outs using DTS-HDMA. Switched HDMI cables around same result. Tried one of the movies at a neighbors audio was flawless. Samsung said it's an issue with the receiver, that there might be a setting to correct this. Any thoughts would be appreciated.
Flash711 is offline
post #3068 of 4704 Old 03-05-2011, 05:58 PM
lsilvest's Avatar
I'm assuming the XC represents the extra rear center speaker added to my 5.1 speaker set.
Here's what the manual says about that, but I find that hard to understand:
XC - Either one channel other than the ones above, the mono surround channel or matrix encode flag
The rear center speaker in a 6.1 setup will play the same as one of the other rear speakers. Essentially it just gives you a little more volume or depth from the rear.
lsilvest is offline
post #3069 of 4704 Old 03-05-2011, 09:55 PM
Draconian1's Avatar
I just picked up a pair of mission 702e speakers, and they support bi wiring. the recommended power is 20-100wpc. Am I able to bi-wire with the 1020-k or would I end up over powering the speaker?
Draconian1 is offline
post #3070 of 4704 Old 03-05-2011, 10:21 PM
airtimehocutt's Avatar
i am lookin at getting the 1020 also. i am worried that this unit will not handle my 2 front left/right spreakers. they are a full range speaker with 15" subs. i have a powered sub also but i want to have plenty of power during stereo mode. i had an older yamaha reciever that beat the crap out of my current denom reciever as far as power goes. bass was a big difference. i read i could connect the extra 2 channells on the 7.1 to give extra power to the fronts (only have 5.1). this is in a dedicated home theatre room. 15 by 26 thanks
airtimehocutt is offline
post #3071 of 4704 Old 03-06-2011, 08:57 AM
nickachambers's Avatar
I have hooked up speakers in my kitchen to zone 2 and they work. The only problem is they sound flat. I need to boost the treble and bass but i cant figure out how to do this. Right now they don't sound good at all.
Please someone help me
nickachambers is offline
post #3072 of 4704 Old 03-06-2011, 09:26 AM
ItzMe's Avatar
Quoted: 28 Post(s)
I tried the test files via usb into both the brp (which is connected HDMI thru the 1020 and has 3d 7.1 encoding) and the tv (toslink to the 1020). Not all the files played. But no files ever caused the pioneer's indicators to light up more than the 5 speaker LEDs as I'd hoped. I thought it did, but on closer inspection it was the low frequency LED that was lighting up. I cant seem to get the extra speaker to ever indicate.
ItzMe is offline
post #3073 of 4704 Old 03-06-2011, 10:47 AM
Liked: 1091
Anyone played with x-curve (manual page 103)?
post #3074 of 4704 Old 03-06-2011, 12:32 PM
Liked: 1091
Or you can try a very old trick: hook up the rear center to the positive of the left rear and the positive of the right rear. That gives a boost to whatever is playing in one OR the other, but not in both.
post #3075 of 4704 Old 03-06-2011, 05:05 PM
PeaveyAxe's Avatar
That's because the 1020's capabilities for Zone 2/Speaker B settings suck balls.
I'm dealing with the exact same issue. I finally came to the sad realization that this is as good as it gets without running your Zone 2 signal to an external amp. I assumed the capabilities would be a lot better before I purchased. NEVER ASSUME ANYTHING.
PeaveyAxe is offline
post #3076 of 4704 Old 03-06-2011, 07:34 PM
waynebrady's Avatar
I'm trying to hook up my laptop and I'm having a hell of a time getting my 1120k to take hdmi video and optical audio from my MacBook.
Did I just spend $500 for a receiver I can't hook up video and audio simultaneously?!
waynebrady is offline
post #3077 of 4704 Old 03-07-2011, 07:32 AM
bootman_head_fi's Avatar
Quoted: 535 Post(s)
Liked: 340
What are you getting exactly? (besides a hell of a time)
I assume you got this to work on another receiver since you think the laptop can't be at fault.
Are you really hearing a difference?
http://youtu.be/G-lN8vWm3m0
Set an example:
Treat everyone with kindness and respect, even those who are rude to you...
Not because they are nice, but because YOU are. :)
bootman_head_fi is offline
post #3078 of 4704 Old 03-07-2011, 07:47 AM
ccotenj's Avatar
Liked: 101
a) ensure the macbook is setup correctly...
b) use the "sigsel" button on the remote to tell the avr to get the audio from the optical, not the hdmi, input...
- chris
ccotenj is offline
post #3079 of 4704 Old 03-07-2011, 07:57 AM
looter's Avatar
You can't and that is a definite short coming of the 1020.
looter is offline
post #3080 of 4704 Old 03-07-2011, 08:05 AM
looter's Avatar
As someone else said use Signal Select. See post #1535 of the thread.
http://www.avsforum.com/avs-vb/showt...4#post19186714
looter is offline
post #3081 of 4704 Old 03-07-2011, 12:10 PM
Quoted: 535 Post(s)
Liked: 340
Go with separates or at least a AVR with pre-outs so you can use an external amp.
Set an example:
post #3082 of 4704 Old 03-07-2011, 12:13 PM
Quoted: 535 Post(s)
Liked: 340
Doth bother with bi-wiring.
Its nothing more than a marketing gimmick to get you to just buy more wires.
http://www.nousaine.com/pdfs/Wired%20Wisdom.pdf
Set an example:
post #3083 of 4704 Old 03-07-2011, 12:21 PM
doc420's Avatar
Just received my 1020. My old receiver didn't have any HDMI inputs so I connected everything(PS3, 360, DVR box) to my TV and used the optical out from the TV to the receiver just for sound.
Should I do this again or hook up everything to the 1020 and then output it to the TV?
doc420 is offline
post #3084 of 4704 Old 03-07-2011, 12:25 PM
Quoted: 535 Post(s)
Liked: 340
If your TV passes DD or DTS, then I guess this should work.
But more likely is that you will limit your self to just 2ch audio from the set's output.
Forget about hearing HD audio from a bluray player hooked up like that.
Set an example:
post #3085 of 4704 Old 03-07-2011, 12:27 PM
ccotenj's Avatar
Liked: 101
hook up everything to the 1020... it's designed to be a switcher... the tv is not...
- chris
ccotenj is offline
post #3086 of 4704 Old 03-07-2011, 12:29 PM
doc420's Avatar
So you are saying to hook up everything to the receiver? Does this downgrade the image quality from my devices(TV/DVR box, Ps3, 360) to my TV since it's not a straight connection(going through receiver to TV)?
Thanks!!!
doc420 is offline
post #3087 of 4704 Old 03-07-2011, 12:29 PM
doc420's Avatar
Well that answers my question. Thanks!
Edit: Which has better sound quality Optical or HDMI?
doc420 is offline
post #3088 of 4704 Old 03-07-2011, 01:28 PM
ccotenj's Avatar
Liked: 101
Thanks!!!
no, image quality will not suffer...
if both are passing the "same" data, neither... hdmi has the advantage of being able to handle the high bit codecs and multi-channel pcm... use hdmi if at all possible...
- chris
ccotenj is offline
post #3089 of 4704 Old 03-07-2011, 01:44 PM
Quoted: 535 Post(s)
Liked: 340
Unless you get that pesky device that doesn't like to HDMI handshake with an AVR.
Hooking it directly to the TV usually fixes those intermittent drop outs.
...and a TV is designed to be a switcher, a video one.
Set an example:
post #3090 of 4704 Old 03-07-2011, 04:20 PM
FM Fan's Avatar
Hello,
I am trying to program internet radio stations using my laptop. LAN connection has been made and we are connected. The Manual says to enter the Receiver's IP address in the Browser URL window...and it says the Receivers IP address is on page 103 of the Owner's Manual...but I do NOT see it there, or anywhere else.
Can someone tell me how to obtain the Receiver's IP address...and how to select my Internet Radio Stations using my laptop.
Thank you!
FM Fan is offline
