The "Official" Pioneer VSX-1020-K Owner's Thread - Page 152 - AVS Forum
post #4531 of 4546 Old 04-26-2014, 09:01 PM
dmann304's Avatar
Does anyone know why mine would power off and on with Ethernet cable hooked up to it?
it was working and now for some reason when Ethernet is hooked up it powers off and on and freezes.
dmann304 is offline
post #4532 of 4546 Old 04-27-2014, 05:41 AM
gregoryperkins's Avatar
Did you try a new cable? The only thing I could think is some kind of short.
gregoryperkins is offline
post #4533 of 4546 Old 06-01-2014, 05:47 PM
pcguy07's Avatar
Guys, I could use some help configuring the sound setting for my 1022-k. My speakers are the following: FRONTS - Polk Audio Monitor Series II and CENTER - Polk Audio CS1 Series II (3.0, might go 3.1 later with a sub). We watch a wide range of shows, including kids shows in SD and HD, reality, lots of dramas in HD and some HBO movies.
My issue is that I have trouble hearing voices/speaking parts (mostly the Dramas and movies in HD). Background noises and action sequences don't help, so we leave closed caption on all the time (which I hate).
When I use my PS3 to watch a movie, Netflix or play a game, it's auto changed to PCM which I'm fine with (I think).
Can you help me find a setting I can set and forget? Or at least 2-3 settings for the different types of shows we watch?
Your professional opinions are appreciated.
pcguy07 is offline
post #4534 of 4546 Old 06-02-2014, 08:30 PM
spidiracer's Avatar
Hi all I need your help.
I have a VSX1020K that likes to shut down due to overheating. I've checked all the speaker wires and they are good, tested the speakers, replaced the connections on the back with banana plug wires. The receiver is in a large cabinet with no other electronics in the cabinet running.
I've done a reset and that didn't help.
If I place a large fan in front of the receiver i can usually run it as long as i want but it will occasionally shut off even with that. I checked the OHMS of the posistor as described in this thread. The number was out of spec so i ordered a new cable and installed that today. Listening to music and after about 20 minutes it dies on me again. Now I have the fan in front it and its running just fine. There is no dust on the inside of it, the top never feels hot or even warm....
I dont know what else to do... Any idea's? I would really appreciate your help!
OH... so the OHMS on my new cable came out to 255 OHMS... my original was 280 OHMS... Spec is 310 OHMS right? How is a brand new $30 cable worse than the original???
spidiracer is offline
post #4535 of 4546 Old 06-03-2014, 10:56 AM
LastButNotLeast's Avatar
Quoted: 74 Post(s)
Liked: 211
Go to manual MCACC and increase the center channel 1kHz by 3dB or more. You might want to do the L and R, too, but that won't help as much.
Downloadable FREE demo discs:
http://www.avsforum.com/t/1475769/de...ently-authored
Did you really need to quote that entire post in your reply?
LastButNotLeast is offline
post #4536 of 4546 Old 06-03-2014, 11:07 AM
pcguy07's Avatar
Is there also a specific sound setting that I should be using? If not one, then which one for which situation?
pcguy07 is offline
post #4537 of 4546 Old 06-03-2014, 11:15 AM
Quoted: 74 Post(s)
Liked: 211
No, you can keep the effects coming from the surrounds, you just want some help with the dialog, most of which comes from the center. You may also want to increase the center's trim (volume) a little, but not too much, or it will "stick out," which you don't want.
post #4538 of 4546 Old 06-03-2014, 11:25 AM
pcguy07's Avatar
OK, so what sound effect settings would you choose?
pcguy07 is offline
post #4539 of 4546 Old 06-03-2014, 12:02 PM
Quoted: 74 Post(s)
Liked: 211
Auto.
post #4540 of 4546 Old 06-03-2014, 02:08 PM
pcguy07's Avatar
Auto.
HAHA, that would make sense. Thanks for the help LastButNotLeast. I very much appreciate it.
I will make these changes soon and let you know how it worked out.
pcguy07 is offline
post #4541 of 4546 Old 06-07-2014, 05:28 PM
pcguy07's Avatar
Im not sure you saw my speaker setup explained in my original post, but I have a 3.1 speaker configuration. No Surrounds. Its not an option due to living room setup and my two young crazy boys!
pcguy07 is offline
post #4542 of 4546 Old 06-07-2014, 08:56 PM
Quoted: 74 Post(s)
Liked: 211
Doesn't change my suggestions at all.
Have you tried them?
Sorry, can't help with the kids (though I have in-walls for surrounds, which you might consider).
post #4543 of 4546 Old 06-11-2014, 03:52 AM
Diam0n's Avatar
Hi,
Can please anyone photo the D-main board?
I bought used receiver, when I switch it on, LCD on and switching working, But no sound and video. When I disassembled upper case I  see that HDMI transmitter chip is missed. So I need know which model is it. In datasheet only this chip not marked (sad). Can anyone help me please?
P.S. Sorry for my English
Diam0n is offline
post #4544 of 4546 Old 07-10-2014, 03:34 PM
Steelman99's Avatar
Sound Retriever not available with Dolby Digital Plus?
My Sound Retriever function is not available when watching Netflix Via PS3 with DD +. Audio sounds a little muffled.
The Sound Retriever seems to work with other audio settings though.
Would anyone have any insight into this issue?
Steelman99 is offline
post #4545 of 4546 Old 07-11-2014, 11:46 AM
Steelman99's Avatar
I found another thread that maybe explains this issue. My fix was to disable DD+.
Dolby Digital Plus and Netflix on Various AVRs
post #4546 of 4546 Old 07-12-2014, 01:11 AM
Justin Coleman's Avatar
IP Address problem
I had the same problem would not complete MCACC.
Disconnect the cable and give it an IP address, gateway, subnetmask. This should work. Turn off DHCP.
Justin Coleman is offline
User Tag List
