The "Official" Pioneer VSX-1020-K Owner's Thread - Page 154 - AVS Forum | Home Theater Discussions And Reviews
Old 04-05-2015, 08:44 AM
Lynn Shaver's Avatar
Originally Posted by Terry Buda View Post
Anyone who can, please help.
My VSX-1021 has worked fine since I got it in 2011. A few days ago, after I switched off and on again, it failed to produce audio. All of the various features still work fine (video, source switching, network, iPad app, etc,). I was able to perform a normal system reset (Enter button and Standby/On button press). I tried to flash the latest system update, however, it fails at 20% complete, displaying the message: "Update Error 1".
I emailed Pioneer support. 'Rocky' gave me a few cursory check steps and the advice that the unit needs to go to a qualified service center, for which he provided the nearest locations. Having called them both, I learned that this problem is common with this model, and they expect the part to cost $260 + approximately $95 labor. (In excess of the cost to replace it)
Does anyone have experience with this issue? I believe I could replace the part myself, if I could find out which circuit board needs replacement. I hate to trash the unit, when it otherwise works fine.
Thanks in advance for any help!!
I had a similar problem. The sound stopped working, but the video functioned normally. I found a similar problem (Post # 4189, Page 140 of this forum) regarding using the headphone jack. So I found an old 1/4 headphone jack and plugged in a pair of headphones. My missing sound was being directed to the headphone jack. Once I unplugged the headphones, the receiver functioned normally. Hopefully this will help.
Lynn Shaver is offline
Old 04-10-2015, 03:02 PM
ItzMe's Avatar
I'm just curious... I have a Fire TV Stick plugged into to the front HDMI of my Pioneer. I was impressed to discover my IPad and IPhone Fire TV App had a single touch command that switched my 1020 to the correct input for the Fire TV. Now I realize that's done with and IP command, since all the devices involved are own my network, and that HDMI CEC may not me involved (not sure). I'm wondering if theres anyway to replicate that command using the Pioneer remote?
ItzMe is offline
Old 04-17-2015, 11:50 PM
Commander Dan's Avatar
Okay. I am having a problem with my VSX-1020 as it relates to the right/front speaker channel. The other day after powering up, I realized there was no sound coming from the right speaker. I pulled the receiver out to the check the speaker connections and afterwards it began to work. I assumed at that point it must be a short in the speaker wiring.
However, a few days later, the channel was once again out after powering up. I soon began to realize that simply "moving" or even "bumping" the receiver would cause the channel to start working, although to varying degrees of volume. Sometimes I can "bump" it to get the channel to come on, though not at full volume, and then bump it a couple of more times to get to full volume.
Anyone have any theories as to what has happened to my receiver, or what it might take to have it repaired? It is long since out of warranty...
Many thanks...
Commander Dan is offline
Old 04-18-2015, 05:22 AM
gregoryperkins's Avatar
Quoted: 103 Post(s)
Liked: 42
Have you replaced the wire?
gregoryperkins is offline
Old 04-18-2015, 07:43 AM
Yes indeed...
Old 04-18-2015, 08:04 AM
pip11's Avatar
Many thanks...
There are relays on every channel, it's the last step for the signal before it gets to the speaker outputs. Since they're electromechanical (they're the loud things you hear clicking) it makes sense that bumping the receiver could make it start working.
I had a bad one on a 1020 I bought for parts. Luckily there's one for every channel, so if you aren't using any channels (like surround backs) you could swap the relay from that and avoid having to buy one.
Or, if it's possible to assign the right-front output to a different connector (bi-wiring/bi-amping?) that would be a workaround.
pip11 is offline
Old 04-29-2015, 09:23 PM
Steelman99's Avatar
Quoted: 65 Post(s)
I have a question about this receiver , maybe someone can help. Is it possible to have custom mcacc settings for different source imputs , such as HDMI 1, 2, 3?
Steelman99 is offline
Old 04-30-2015, 07:31 AM
Quoted: 103 Post(s)
Liked: 42
Just curious, why would you want that?
Old 04-30-2015, 06:42 PM
Steelman99's Avatar
Quoted: 65 Post(s)
Well I am having a difficult time trying to tune in the music streaming service Rdio via HDMI and a PC. I can't get it to sound very good. The MCACC settings I use for my Roku and Directv DVR are fine. But streaming music sounds a bit muffled, using the same MCACC settings.I was using a PS3 with their music service "Music Unlimited", and It was sounding very good,but the service was discontinued. So now I am back to finding a good solution. I am wondering if a DAC would help.
Old 05-01-2015, 06:27 AM
Quoted: 103 Post(s)
Liked: 42
How does it sound using headphones? Maybe it's just a low bitrate stream. I know Pandora free is low quality, not sure about rdio.
Old 05-01-2015, 09:55 AM
Steelman99's Avatar
Quoted: 65 Post(s)
I set it to 320 (high quality) on my PC. I was using HP Stream Mini with eithernet ,that I just got using HDMI . I don't think it will work very well, so I intend to send it back. I am having better results streaming with a Chromecast, and optimizing my 1020's EQ for that input. I might have to try buying a PC with a better soundcard or maybe use a DAC in addition. Or possibly buy a Sonos connect. Rdio support told me the Chromecast Rdio app streams at whatever quality setting is on my casting PC.
So if each input on my 1020 can't have a custom EQ I may be able to switch things automatically with my Harmony remote as a work around.
Old 05-20-2015, 01:48 PM
Steelman99's Avatar
Quoted: 65 Post(s)
I was using a V90 Dac today streaming Beats Music on a Apple 3 via optical ,and I noticed the Sound Retriever "Over" light would come on every so often. Everything sounder pretty good. Any problems I should be aware of?
Old 05-23-2015, 01:35 PM
Steelman99's Avatar
Quoted: 65 Post(s)
Bump
Old 06-10-2015, 11:37 AM
weberlajes's Avatar
I just switch from 5.1 to a soundbar. New kid, wires, dog, etc. Whatever. Anyway, I have everything working fine except for audio-only sources: radio and optical-in. I have HDMI Through enabled, but I can't figure out why those sources won't pass through.
Any thoughts?
weberlajes is offline
Old 06-27-2015, 11:56 AM
Bails52's Avatar
I'm trying to get a fuller sound where the entire room seems involved, not just the front. I thought I'd try the Panorama setting, but when I scroll through the Audio Parameter settings, a number of the options mentioned in the owners manual aren't there, including Panorama. Others are Dimension, C. Image, Effect, H. Gain and V.SB.
Does anyone know why I'm missing those options?
Bails52 is offline
