The "Official" Pioneer VSX-1020-K Owner's Thread - Page 156 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #4651 of 4653 Old 05-12-2016, 10:16 AM
drdass's Avatar
hi pls help in connecting my pc windows 10 os i3 4gb ram 64 bit geforce gt 210 graphic card
connected with pioneer vsx 1020k thru hdmi port. the issues are
1. am not getting dts hd ma 7.1 and dd tru hd audio
2. can i connect any hdmi port in the receiver for pc? at present hdmi 1 only display pc. no other hdmi ports. is ther any setups for this?
3. graphic card supported sound formats are not shown dts hd ma and dd tru hd
pls help friends
drdass is offline
post #4652 of 4653 Old 06-08-2016, 08:06 PM
perfectly_circle's Avatar
VSX-1020 receiver stuck on PCM setting when using PS4
I have had this unit for several years, but I'm having a recent issue since I have acquired a new roommate. I've noticed that when using my PS4 recently, I cannot change from the "PCM" setting when I press the "Standard" button on the front of the VSX-1020 receiver. In the past I could. When I switch to my DirecTV receiver, I can switch through the settings normally when pressing "Standard". In the past, I have typically used Neural Surround. I think she has accidentally changed something recently, but I do not know what it is.
Any thoughts?
perfectly_circle is offline
post #4653 of 4653 Old 06-08-2016, 08:40 PM
tylerh's Avatar
pls help friends
I have a vsx 1121 and a GTS 250 video card in my desktop-similar but not exactly the same.I assume you are saying that you cannot get Dolby Digital or anything better over hdmi.If so-I feel your pain.After much research I found that the card did not support DD over hdmi and Nividia had no plans for an update.I assume it was either a DRM or licensing issue.In any case I then ran a separate optical cable.Matching that input up to the hdmi was a chore but luckily I found a post on AVS that pointed the way.
Now I have a roku box and plex so I don't have to use that set up as much.
I would like to know if newer cards support DD and better over hdmi.Anyone know?
tylerh is offline
