Just received my new Pioneer VSX-1020 receiver (pre-ordered direct from Pioneer)
Here are a few pics of the exterior:
After spending an hour or so with the unit, I've noticed the following:
Positives
Gorgeous GUI for main menu (After Denon AVR1909, this is appreciated!)
Very detailed auto-calibration using multiple patterns
Very granular adjustments (overall)
Negatives
Awful remote
Input switching takes longer than Denon it replaced
(So far) Don't see any way to control crossover for individual channels
Although it isn't fair to compare the sound of the Denon AVR-1909 and this unit yet as I spent a TON of time calibrating and adjusting the Denon and have only played with this unit an hour, I did notice a few things after the initial auto calibration:
MCACC has odd distances for my wall-mounted rear surrounds. They're about 2ft away, but MCACC sees as ~6ft
MCACC dials the sub level much lower than Denon's Audyssey
A filter of some sort is being applied to LFE channel as the Rythmik F12 sounds very different (lacking detail) than when I used the Denon. This is 110% a setting someplace I just haven't seen.
After going through the manual, I now see there's an Advanced MCACC (Manual) mode that has a TON of adjustments. More importantly, there seem to be some incredible tools at your disposal. I'll be playing with this soon and will post some images/results.
So I've just connected everything and ran a quick calibration. Compared to the Audyssey calibration on my previous Denon unit, this new Pioneer was incredible. Rather than one pass of "blips" through each channel, the Pioneer has several different patterns and steps.
You can also output the results to USB which I found to be pretty slick.
Overall, a few hangups but overall extremely impressed.
Remote was a non-issue as I was able to just use the "learn" function to grab the necessary codes for the AVR.
The first screen you see when you enter the menu or hook up the mic is:
One of my biggest negatives (so far, still researching) is the lack of control over the crossover for each individual channel. Instead, you have one "blanket" crossover setting as seen here:
(Again, the setting is likely there - just haven't seen yet. Time to read the manual)
Once the calibration is done, you get a TON of cool info to help you see what you're dealing with. Check this out!
The GUI looks similar to last year's models. And Pioneer does employ a global crossover. There are no individual crossovers for different sets of speakers.
EDIT: 2 things I noticed in the first photo and did not like, 245W power input and the "Made in China" tag. My last year's model, the VSX-919 is 350W and "Made in Malaysia". Pioneer cost-cutting? Although, if the unit sounds great, then those two factors bear no weight.
I'm waiting on delivery as well, but after reading the new Denon receivers press release, I realized I overlooked one feature that would be really nice to have...
Does the 1020 provide some sort of video volume level overlay graphic via hdmi to the so if the unit is hidden you can still see representation of the level? I'm not seeing anything in the manual as far as I can tell.
Older Pioneers had a universal crossover setting. Moreover, they apparently cutoff LFE info at that same point. I'd be interested to know if Pioneer changed the basic design here, although footnote 2 to page 102 of the 1020 manual suggests otherwise:
"This setting decides the cutoff between bass sounds playing back from the speakers selected as LARGE, or the subwoofer, and bass sounds playing back from those selected as SMALL. It also decides where the cutoff will be for bass sounds in the LFE channel."
Can anyone tell me if there's any reason why I shouldn't or couldn't send my front three channels (L/C/R) and send them to an external amp via the pre-amp outputs, and then power my two surround channels with the receiver's build in amp? I know the Pioneer doesn't put out nearly as much power as my dedicated amp but I'm hoping that since they're just surround channels they'll get plenty of power. Plus since I'm guessing Pioneer designs their amps to 'share' power among channels, the surround channels will have plenty of juice to play with since the L/C/R will not be used.
Basically what I want to do is take the Zone 2 preamp outputs from the 1020 and send them to the 4th and 5th channels on my HT amp so that I can power my 'whole house' (multiple pairs of speakers) system using my amp, rather than the receiver.
So can you or can you not change the cross-over point Fronts vs center vs surrounds separately? It seemed your initial impression was the crossover setting was universal, but then you followed up with this comment.
Is this something they've allowed to be adjustable on the Elite models in the past? Or are Pioneers in general basically not capable of this?
i don't see why you couldn't... that being said, i'd probably try it with just the avr first... fwiw, the amplifiers share a power supply, yes... which would likely give you "more power available" with the avr driving only 2 channels vs. 5, as only 2 amplifiers are drawing from the "current bank" (so to speak)...
see the two posts right before yours in reference to the xover... pioneer has never had anything but a global xover, regardless of elite or non-elite...
Wait a darn second... I just noticed when looking at the manual for the 1020 that there are no pre-amp outputs for an external amp!?
How is it that in all the reading I did about this comparing the 1020 and 1120... including articles from engadget, cnet, and long threads here, that I never noticed anyone mentioning the 1020 would not work with an external amp whereas the 1120 would?
It's pretty amazing to me that a receiver with such crazy advanced audio calibration capabilities such as advanced MCACC and the ability to output detailed graphs to USB, etc, etc... still employs a universal crossover point for all speakers.
It's not an absolute deal breaker for me since my fronts ideally would cross over at 65, center at 75 and rears at 85... I'll just cross them all over at 75 and that's good enough. But still, that does surprise me.
well, that would be a reason why you wouldn't be able to do what you asked about...
you aren't going to cross them at 75 on a pioneer avr... 80 will be the closest you get...
there's darn good reasons for using a global xover... regardless of calibration abilities... if you search in the sc-09 thread (and the 05/07 thread, for that matter), we've discussed this at length... others may feel differently of course, and i won't tell them they are wrong...
you are a better man than i if you can xover your speakers at 3 different points and still integrate the sub correctly... i'd pull out my (non-existent) hair trying to do that...
Hah... yeah. But I guess the same question now applies to the 1120.
Would you mind giving me a quick recap on what issues using non global crossovers can cause?
I think your last paragraph may hint to at least part of the issue.
If I set my center to crossover at 80Hz and L/R at 60Hz, the bass management is going to route everything below 80 from the center to my sub and everything below 60 from my front L/R to my sub. I'm guessing the issue is in that 60 to 80 range where my sub is playing the 60 to 80 range of my center and my L/R fronts are playing the 60 to 80 range themselves, which is very unlikely to 'match'.
Haven't seen an option for this and doesn't have by default. I'll try poking around more today.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
