How to DIY ; TX-SR576/TX-SR606/etc HDMI daughterboard repair (for dummies?) - Page 29 - AVS Forum
post #841 of 857 Old 06-26-2014, 12:25 AM
Liked: 0
Quick update... I left the receiver switched on whilst I went out for a few hours. I came back to find the hdmi working. After watching a film for a few hours, I had problems with the picture showing lines and snow, going black, then the picture coming back ok. Any ideas?
Paul
edit: Oh something else I noticed, was when plugging in the hdmi cable and the metal part of the hdmi connector touches the receiver casing it arcs slightly. I'm guessing this isn't normal?
A[L]C is offline
post #842 of 857 Old 06-26-2014, 08:09 AM
crakarjax's Avatar
Quoted: 37 Post(s)
Paul
The arcing is not normal, did you forget to connect a ground wire or something? I would take the HDMI card out again and reseat it, making sure everything is connected properly.
crakarjax is offline
post #843 of 857 Old 06-30-2014, 07:43 PM
Liked: 0
Hi folks, I just did this repair to a TX-sr706 hdmi board by replacing (most) of the capacitors on the hdmi daughter board and would like to report (what appears to be) a full recovery of audio hardware and a 95% recovery of the video hardware. For your reference, here are images of the repair (high rez):
https://www.dropbox.com/s/j0qwst3e3cdk0si/2014-06-29%2012.49.18.png
https://www.dropbox.com/s/mliut2o9a3...2012.49.33.png
Due to stock issues at my local Fry's, I was only able to obtain 10 100uF (105C) capacitors this time (a mix of 25 and 35V), so I had to decide which two capacitors skip. I'm not sure if my logic is totally sound, but I chose to replace all capacitors that were associated with voltage regulators, and then work out from the HDMI output jack. Can anyone comment on the functionality of the capacitors that I did not replace (C3502 and C3402)? They both seem to be associted with a +3.3V power supply, but I'm not savvy enough to go any further than that. The nearest IC is marked ISSI in both cases.
The only remaining issue with the receiver at this point is that some deep blacks will show up as blues, which prevents me from passing HDMI through the device.
Many thanks to you all for this thread, I've found it most informative.
mtaylor6 is offline
post #844 of 857 Old 07-02-2014, 02:15 PM
SomethingMore's Avatar
Originally Posted by CZ_the_DAY View Post
Apparently, as per the manufacturer datasheets, the 'lifespan' of a given Cap is typically only a couple thousand hours when at the rated temperature. Hence my push to use top notch stuff in case heat build-up isn't reduced. Other variables like materials or size (result of voltage rating,etc) may have unknown subtle effects in sensitive circumstances (rocket science alert!).
Bottom line: thankfully this repair has been proven to be somewhat flexible.
Well... I should have opted for the better caps. My 606 is exhibiting the same problem as before. It's taking about 30 minutes to get a signal from the HDMI ports. I'm going to bust this thing open and get a co-worker (the same as 4 years ago!) to do the fix for me again.
Does anyone have specific caps that they used without any problems?
Here's what I found based on the OP:
APSA100ELL101MFA5G
Capacitance 100µF
Voltage Rating 10V
Tolerance ±20%
ESR (Equivalent Series Resistance) 25 mOhm
Lifetime @ Temp. 2000 Hrs @ 105°C
Operating Temperature -55°C ~ 105°C
SomethingMore is offline
post #845 of 857 Old 07-02-2014, 05:21 PM
DBacksFan5205's Avatar
SomethingMore,
Rubycon caps seem to work well.
The YXF series.
100uF
50V
105C
Typical ESR = 0.15 Ohms
Cheers!
DBacksFan5205 is offline
post #846 of 857 Old 07-03-2014, 08:37 AM
crakarjax's Avatar
Quoted: 37 Post(s)
I think the brand doesn't matter so much as the specs. The higher the temp rating the better -- and higher voltage rating doesn't hurt at all.
post #847 of 857 Old 07-03-2014, 10:06 AM
Thanks guys. I think I'll go with something very similar to DBacks' suggestion. A local shop seems to have a different brand, but with the same specs.
post #848 of 857 Old 07-04-2014, 06:27 AM
Scottie2's Avatar
Part ID
Hey guys, started having problems with my HDMI signal again, and while removing the board i managed to break one of the leads for this part. I desoldered the other side, but i cannot repair the connection because it pulled some small wire from inside the housing that i cannot access. I have no idea what this part is called, and have no luck so far searching the "470 M80" markings. thanks for the help
Scottie2 is offline
post #849 of 857 Old 07-05-2014, 05:46 PM
Scottie2,
That part is an inductor (or choke coil). It is circuit part L8954, PN RCP1317NP-470M.
Check availability at: http://www.findchips.com/search/RCP1317NP-470M
Apparently they are available at Avnet Express, Mouser Electronics, Digi-key, etc.
Good Luck!
post #850 of 857 Old 07-08-2014, 07:46 PM
ebo
ebo's Avatar
Originally Posted by kylejn View Post
And a shot of one of the new capacitors soldered to the board. Not the cleanest solder but it's not too bad for a beginner, I think!
I'm not sure, but it looks as if the negative lead of the cap (the white stripe down the side) is going to the positive pad (with beveled corners on the outline). Or maybe a reflection off the cap just looks like a white stripe.
If the polarity is reversed the cap would probably work for a while but eventually the dielectric would break down and the cap would short.
ebo is online now
post #851 of 857 Old 07-20-2014, 08:15 AM
LilJayV10's Avatar
First off I wanted to say thanks to CZ_the_day for making this thread. I've owned a TX-SR706 for the past eight years and apparently I've one of the few lucky ones that haven't had any problems out of it. I had to do a hard reset on it once about seven years ago for a HDMI problem but that's it.
About a month ago lighting struck a utility pole across the road and took out a bunch of things in the house, cable modem, PS3, lights and unfortunately my Onkyo receiver. Everything except the lights were on surge protectors but with the lighting striking so close and the transformer arcing for so long it didn't seem to matter.
Everything on the receiver still works correctly except the HDMI part. I have audio but no video and the setup menu screen will not display.
After searching Google I found this thread and have been reading it on and off for the past week.
My symptoms match those listed in this thread. I'm going to attempt to source the caps locally this evening. While I'm in the receiver is there anything else I should look for or test? I have an extensive background in automotive wiring and diagnostics but none with this.
Thanks for any help and great thread!
Jason
LilJayV10 is offline
post #852 of 857 Old 07-21-2014, 11:18 PM
LilJayV10's Avatar
I replaced all the caps tonight and still no picture. Is there anything else to check or am I stuck replacing the receiver or replacing the hdmi board and hopes that fixes it?
post #853 of 857 Old 07-22-2014, 06:57 AM
crakarjax's Avatar
Quoted: 37 Post(s)
The cheapest route for you I think is to buy a working used 706 and swap parts/boards into your old one until it works. If you can fix that part, great -- do so and re-sell that 706. If not, you now have a working receiver anyway, and likely for less than a repair center would cost you.
post #854 of 857 Old 07-22-2014, 05:44 PM
eaayoung's Avatar
Quoted: 23 Post(s)
Liked: 50
Or, pick up a newer used receiver with newer technology. Dread when I have to make the decision with my 876. Still going strong but only really use it when watching movies.
eaayoung is online now
post #855 of 857 Old 07-23-2014, 06:19 AM
crakarjax's Avatar
Quoted: 37 Post(s)
IDK, I bought a used 876 about 4 months ago and love it. Doesn't lack any feature that I would use, and sounds amazing. Audio fidelity doesn't change over time, only technologies do -- and a lot of the newer technologies are useless, for me.
post #856 of 857 Old Yesterday, 03:50 AM
Liked: 0
Another Onkyo fixed
Just wanted to say thank you. Fixed my receiver last night using the information in this thread. Plainview, NY.
santiagovm is offline
post #857 of 857 Old Yesterday, 04:35 AM
Liked: 0
Another Onkyo fixed
Thank you for the information. Fixed my receiver yesterday. Plainview, NY.
Onkyo Tx Nr807 , Onkyo Tx Sr606 Receiver
