How to DIY ; TX-SR576/TX-SR606/etc HDMI daughterboard repair (for dummies?) - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
post #901 of 1085 Old 12-20-2014, 07:02 AM
Liked: 0
Quick status update, I have replaced the cheap 100uF caps with Panasonic FR caps as suggested by MikeMartell, now everything works incl. OSD...no clue if there was a bad cap or soldering was not 100%, at least the polarity was OK from the beginning. Now I have a small stock of various caps I hopefully don't have to replace
PigBag is offline
post #902 of 1085 Old 12-20-2014, 09:42 AM
MikeMartell's Avatar
Good job. Enjoy your "new" receiver lol.
MikeMartell is offline
post #903 of 1085 Old 12-24-2014, 10:49 PM
Liked: 0
Replacement Board Question
I tried my hand at replacing the capacitors on the BCHDM-0132(25140132B) board for the Onkyo HT-RC-140 (picture attached), but it turns out I am really bad at soldering to flat surfaces.
Anyhow, I am looking to buy a replacement board but I want to make sure that it is not going to fail after a few months. Is there a way to find a place that sells this board that uses better capacitors?
I'm looking at some on Ebay, but again I can't tell if is an old model that uses the bad capacitors or something newer that hopefully does not.
Thanks in advance
zshelley is offline
post #904 of 1085 Old 12-24-2014, 10:55 PM
Liked: 0
Ht-rc-180*
zshelley is offline
post #905 of 1085 Old 12-31-2014, 04:50 AM
Liked: 1
Smile
Originally Posted by punjabby View Post
Hi I have an onkyo tx-sr608 with no sound coming from speakers when using hdmi. I feel I have the infamous hdmi board failure... Has anyone else with a sr608 tried this fix? I feel like I should go ahead and try it anyway...any suggestions?
I've just completed this with a TX-SR608 and it works fine again. It's the same general approach as in other tutorials and videos out there for different models but there are a few minor differences.
There are three 16v 100μF capacitors on the top of the board and one 50v 4.7μF capacitor on the underside. There are extra HDMI connections including one internal one linked to the front panel. I've uploaded a few pictures from the process to Imgur http: //imgur.com/a/F0JIz.
bryan.lynch likes this.
mitchellrj is offline
post #906 of 1085 Old 01-03-2015, 02:24 PM
umenon's Avatar
Quoted: 669 Post(s)
Liked: 233
Quick question ... on the 606 receiver ... does the front HDMI input also fall victim to the board problem.
In other words - can this receiver be used just to process HDMI audio (i.e. no HDMI out needed) by using the front HDMI input?
umenon is offline
post #907 of 1085 Old 01-04-2015, 04:01 PM
graham_b's Avatar
Liked: 0
Thanks all, this information is great. Crazy that this thread almost has 1000 posts, and a video on how to fix it has 88k views, but Onkyo didn't recall these receivers.
I'm having a problem in my setup, that may be related, but I just want to make sure before I crack it open and start soldering.
My TX SR-606 starts up fine, but the audio and video, supplied via HDMI, cuts out intermittently. It can be fine for 30 minutes, then it cuts out for 3 seconds or so, then comes back. Sometimes this happens several times in a span of ten minutes. Sometimes it doesn't happen for 45 minutes.
Does this sound like a capacitor issue?
EDIT - is that the longest time span between join date and first post ever??
graham_b is offline
post #908 of 1085 Old 01-09-2015, 09:40 PM
CherylJosie's Avatar
Quoted: 729 Post(s)
Liked: 295
Originally Posted by CZ_the_DAY View Post
Many have observed how temperature affects the faulty ONKYO but I can elaborate. While my unit would be on the verge of instability with artifacts in the video, I'd barely cool* the chip SiI9185' (3to1 HDMI switch) and the signal disappeared until it warmed. Same conditions, cooling* neighbouring chip SiI9013' (HDMI receiver) and the signal became flawless temporarily. IOW change a chip's tolerance to noisy power by means of temperature. (Initially I feared faulty chips!) This helps explain the commonly reported wait times after first powering on.
Sorry for dredging this old thread up, but just in case someone was wondering, there is a sort of technical explanation that might explain this weird temperature sensitivity.
I am assuming for the purposes of this discussion that the HDMI receiver IC connects between the HDMI input connector and the HDMI 3-to-1 switching IC on this receiver.
CMOS transistors are sensitive to temperature. When they are cool, they switch faster, causing the output transitions of its internal logic gates or its external output buffers (output pin drivers) to be sharper and the IC draws more current as a result.
If the HDMI switching IC is cooled, it might have faster internal logic edge rates and draw more current from its supply, increasing its sensitivity to local regulator power supply ripple from failing capacitors and causing internal data corruption, particularly at the input buffers where the effective input voltage high and low levels might vary due to power supply ripple shifting the input switching threshold voltages.
If the HDMI receiving IC is cooled, it might also start switching faster and create sharper transitions on its output, increasing the edge rate and improving the apparent signal-to-noise ratio seen at the input pins of the HDMI switching IC that is experiencing excessive power supply ripple and having input threshold issues.
This is just an educated guess, but I have personally debugged similar issues with digital interfaces in the past by using various methods to modify the buffer output switching speeds, or modify the internal switching speeds, to affect the edge rate and power consumption of similar devices.
I currently own 6 various models of used Onkyo receivers that I purchased from private parties for a project. Every single one of them turned out to be in the early stages of HDMI failure or already failed when I got them. They do not qualify under Onkyo's recent recall because I do not have an original receipt and they were not purchased from an authorized reseller, so I am in the process of repairing them myself using information similar to this thread.
CherylJosie is offline
post #909 of 1085 Old 01-09-2015, 09:56 PM
Quoted: 729 Post(s)
Liked: 295
If I understand you correctly, you want to use the HDMI front panel input to get audio only from the receiver.
First off, if you are using an AV source such as a blu-ray player, you will still need both audio and video connections anyway.
Secondly, this failure mode eventually worsens and takes the whole HDMI functionality with it, including audio.
If you want to use your receiver as audio-only device, use the optical or RCA digital audio inputs on the back panel, or the analog inputs. None of these signals require the HDMI function to work.
There are some network-capable receivers that apparently have issues with the network chip solder balls. Onkyo claims the chips are defective but IMO there is also the possibility that the high temperatures on the HDMI board are partly responsible for the solder ball failures due to thermal expansion and contractions over many power cycles.
The (claimed) network chip symptom is audio dropouts that can eventually become permanent, but my TX-NR929 is having both audio and video dropouts so YMMV, especially if your receiver is experiencing both failed capacitors and failed solder balls.
I recommend to everyone with a failed Onkyo HDMI board to call the service department and ask for a free repair regardless of warranty due to the ridiculous failure rate of these boards. My guess is, if you make enough noise they will repair it no matter whether it 'qualifies' under the terms of the limited recall or not. If they refuse to repair it I would demand they buy it back from you so you can purchase another receiver and I would recommend buying a different brand also, at least until Onkyo reliability improves, especially if they left you holding a receiver with a broken HDMI.
post #910 of 1085 Old 01-11-2015, 12:24 PM
danalmasy's Avatar
UPDATE: About 6 months after replacing my capacitors my unit finally bit the dust - for good.
I opted to go out and buy a new Sony DN-1040 and I've been really happy with it. Thanks for the thread guys!
Panasonic TC-P50S30 • Sony STR-DN1040 • Polk RM6750 • PS3 + PS4 • XBOX 360 + ONE • AppleTV • Logitech Harmony 700
danalmasy is offline
post #911 of 1085 Old 01-14-2015, 09:58 PM - Thread Starter
CZ_the_DAY's Avatar
I really wish I could devote the concentration required to do a refresh of the front page of this thread - all that has been expressed, spanning so many models, may be further unified to spare those just tuning in from reading all of the nearly *1000 posts (*noted by graham_b) - don't get me wrong, it's not without entertainment value - CherylJosie even contributed a hypothesis that expanded on my silicon observations and musings , plus gives me visions of peoples baking their receivers in ovens, with hopeful stares and fingers crossed - sorry but these aren't xboxz - perhaps the majority of the nearly 300,000 'views' of this thread to date were those expecting a fix truly fit for a dummy - sorry to disappoint - my admiration goes out to all who tried and shared, whether successful or not
CZ_the_DAY is offline
post #912 of 1085 Old 01-24-2015, 11:57 PM
serafis's Avatar
Liked: 0
TX-SR606 Permanent Cooling Solution
Thanks to the contributors to this & other threads, I've now successfully fixed three TX-SR606 receivers that I bought very cheaply because of HDMI switching / upscaling / OSD problems. I've kept one for the lounge, one for the music room and I've given the third to my brother-in-law who's thrilled with it.
What's worked for me is replacing ALL the 100uF and 220uF electrolytics on the top and bottom of the HDMI board with 105C 16V or 25V electrolytics (depending on what I could get), also a 22uF on the top of the board near the HDMI-out with a 22uF 16V, and putting 1uF film capacitors across some of regulators as advised earlier in the thread. Photos of the finished board attached.
But..... (and there's always a but, isn't there?).... I found that one of the receivers had actually already had all its capacitors replaced previously, but the new ones had gone bad. Replacing them fixed the problem and the receiver works well. But this led me to thinking about the HDMI heat problem generally, and whether an effective and unintrusive cooling solution is possible.
I found that there's easily room to fit a standard 120mm 12v computer case fan inside the receiver case, directly above the HDMI board. So I bought a cheap one with standard molex connectors and fitting screws from a local supplier (ebay has them too). I chose one with a current draw of around 0.2A, a rotation speed of around 1300rpm, and a noise factor of less than 20dB as I want it near-silent. (Note: my pictures show a sleeve-bearing fan, but a ball-bearing or hydro-bearing is better for longevity).
I removed the receiver cover and positioned the fan on the underside of the cover, where it would blow downwards onto the HDMI board - I thought this would be better than drawing the heat upwards onto the board. I marked where the mounting holes needed to be and carefully drilled (4.5mm) the top of the receiver cover and countersunk them. I then fitted the fan to the underside of receiver cover using the fitting screws - I used a couple of washers as spacers between the fan and the cover to avoid any chance of the blades rubbing against the cover in operation.
I snipped the spare molex connector and its wires off the end of the fan, leaving the other molex still attached to the fan's red & black leads. I snipped the red and black wires off the connector I'd just removed (as they're not needed), leaving just the yellow and black wires. I then cut the yellow wire in the middle, and soldered a 47 ohm 1 watt resistor in line with the yellow lead, to reduce the fan voltage from 12v to around 7v so it will run slower and near silent. I used heatshrink tubing to insulate the resistor and solder joints.
With the HDMI board removed, I carefully poked the yellow and black molex wires through the hole in the top of the HDMI board (next to the white connector with the black ribbon cable that carries 12v from the power supply to the HDMI board - you may need to slightly enlarge the hole depending on the thickness of the molex wires). I soldered the black molex lead to one of the 0V pins of the white connector on the underside of the HDMI board, and the yellow molex lead to one of the 12V pins as shown in the attached photo.
Lastly, I re-fitted the HDMI board and its connectors, and carefully replaced the receiver cover, plugging the fan's molex into the one I'd just fitted to the HDMI board. Plugged the receiver in and bingo, when it powers up, the fan spins almost silently. It draws only around 0.11A so won't be much of a burden on the power supply.
I've been running it like this for a few weeks now. in my closed hi-fi cabinet, the receiver used to run so hot that I could barely touch the case above the HDMI board. Now it runs warm to the touch, but not hot, and the cabinet seems cooler too because air is being circulated. I'm expecting that this will prevent any future HDMI failures due to heat. It looks great and runs silent and I've now made the same modifications to the other two SR606's that I've fixed. Planning the same modification to an TX-SR607 I've just purchased to fix up (bad caps on amp driver board, due to heat/age, causing protect mode).
Only thing I've found is that, if HDMI Control is turned on in Setup (Hardware / HDMI), the fan will run even when the receiver is on standby - this is because the HDMI board is still receiving 12v for the control circuits, so it's probably a good thing to keep it cool, although it will of course shorten the life of the fan. However, these fans typically run for years, and the way I've fitted it means that it's easily replaced if needed.
Photos of the modification attached - I hope this is useful to some other SR606 owners as it's it's a really excellent receiver when it works!
Name:	HDMI board (top).JPG
ID:	500841   Click image for larger version
Name:	HDMI board (bottom).JPG
ID:	500849   Click image for larger version
Name:	120mm Case Fan with Molex.JPG
ID:	500857   Click image for larger version
Name:	120mm Fan fitted to receiver cover (1).JPG
ID:	500865   Click image for larger version
Name:	Fan fitted to receiver cover (2).JPG
Name:	Fan fitted to receiver cover (3).JPG
ID:	500881   Click image for larger version
Name:	Molex and resistor fitted to HDMI board (top).JPG
ID:	500889   Click image for larger version
Name:	Molex and resistor fitted to HDMI board (bottom).JPG
ID:	500897   Click image for larger version
Name:	Fitting the receiver cover with fan.JPG
ID:	500905   Click image for larger version
serafis is offline
post #913 of 1085 Old 02-04-2015, 03:30 AM
Quoted: 729 Post(s)
Liked: 295
Please consider adding a permalink to the preceding uber comment on this thread in your initial thread-starting post, since it basically covers the repair and the cure for the design issues all in one succinct, excellent post. I really think a simple fan is the way to go for this failure mode, after repairing/replacing the HDMI board. Bravo.
post #914 of 1085 Old 02-06-2015, 01:29 PM
Liked: 0
wow this thread is 5 years old and might just save my bacon..
My 576 Started to refuse to show an image from my PC (was always intermittent), but now on top of that it won't show a signal from my PS3 which was never an issue.
still ok with my stb at 1080i, so looks like it's a candidate for some DIY.
strangely enough it's not showing no signal on the display, but i'm not getting an image regardless..
will let you know how i get on.
thanks everyone for the information.
Marticus100 is offline
post #915 of 1085 Old 02-15-2015, 07:43 AM
Liked: 0
Thanks to Serafis for posting this detailed bugfix description. I had the same issue with my TX SR 606: HDMI inputs were showing up late, also the normal composite inputs
had only Audio and I had to turn on and off 1000x times to see the picture.
First I saw the video on Youtube, (cannot add the URL unfortunately) and later found this post on AVS.
I decided to exchange also all mentioned Caps. Ordered from Mouser for 10 bugs, replacement
was done in an hour, not so difficult. I also added two 80mm 0.2A fans to circulate out the heat, 50Ohm in series to tapped 12V to bring
it down to noiseless RPMs at ~7V. One is blowing on the HDMI board, the other one blowing out.
Everythings works perfect again!!
ID:	546921   Click image for larger version
ID:	546929   Click image for larger version
KKBuddy is offline
post #916 of 1085 Old 03-04-2015, 10:01 AM
Maverick0984's Avatar
Quoted: 319 Post(s)
Liked: 140
Originally Posted by mtaylor6 View Post
Hi folks, I just did this repair to a TX-sr706 hdmi board by replacing (most) of the capacitors on the hdmi daughter board and would like to report (what appears to be) a full recovery of audio hardware and a 95% recovery of the video hardware. For your reference, here are images of the repair (high rez):
https://www.dropbox.com/s/j0qwst3e3cdk0si/2014-06-29%2012.49.18.png
https://www.dropbox.com/s/mliut2o9a3...2012.49.33.png
Due to stock issues at my local Fry's, I was only able to obtain 10 100uF (105C) capacitors this time (a mix of 25 and 35V), so I had to decide which two capacitors skip. I'm not sure if my logic is totally sound, but I chose to replace all capacitors that were associated with voltage regulators, and then work out from the HDMI output jack. Can anyone comment on the functionality of the capacitors that I did not replace (C3502 and C3402)? They both seem to be associted with a +3.3V power supply, but I'm not savvy enough to go any further than that. The nearest IC is marked ISSI in both cases.
The only remaining issue with the receiver at this point is that some deep blacks will show up as blues, which prevents me from passing HDMI through the device.
Many thanks to you all for this thread, I've found it most informative.
I know your post was quite a while ago, but just incase you get notifications...I just completed this repair job on my TX-SR706 but replaced all 15 100uF capacitors on the board. The original 12 you're mentioning are the 4V types, and there are actually an additional 3 that are 16V but still 100uF. I replaced all 15 with 25V replacements and am happy to report functionality has been fully restored. I am not noticing any degraded performance or quality issues.
I'm still debating if I should replace all of the 220uF and add a fan in there...
Here are some images from my replacement job. Not the greatest quality, but it'll do.
ID:	583177   Click image for larger version
Maverick0984 is offline
post #917 of 1085 Old 03-05-2015, 12:40 PM
Liked: 0
I need help. I was starting the repair for my HDMI board and while i was removing it i accidentally bent and brokee one of the capacitors. The Capacitor that I broke is 470 M85 on it. I have been looking everywhere and can't seem to find a replacement one. Can anyone place direct me as to where I can order one?
Thank You
untouchablepl is offline
post #918 of 1085 Old 03-05-2015, 04:01 PM
Quoted: 30 Post(s)
Liked: 4
Hey guys, I would like to replace all the caps on my 706 receiver. Was wondering if anyone can share links to the proper caps I would need to buy preferably the Panasonic's? And how many of each I would need highly appreciate it thanks.
Sn95 is offline
post #919 of 1085 Old 03-05-2015, 10:52 PM
bryan.lynch's Avatar
Replaced four caps on the HDMI board on my TX-SR608 due to intermittent video loss issues. Seems to have fixed the problem so far. HDMI syncs up more quickly now when switching input sources too.
Parts were obtained from DigiKey...Rubycon YXJ series:
(1) 1189-1030-ND
4.7uF 100v 5,000 Hrs @ 105 deg C
(3) 1189-2195-ND
100uF 16v 5,000 Hrs @ 105 deg C
Best $3.63 I've ever spent!
ID:	586433   Click image for larger version
ID:	586441   Click image for larger version
ID:	586449   Click image for larger version
ID:	586473   Click image for larger version
bryan.lynch is offline
post #920 of 1085 Old 03-08-2015, 10:59 AM
Liked: 0
has Anyone run intp such issue as "E2PROM ERROR", i founded a old thread from AVS and wroted to starter.
i have to write over eeprom or what ?
wordmc9 is offline
post #921 of 1085 Old 03-10-2015, 08:25 AM
Liked: 0
asked my self and answered:
Q705 eeprom is corrupted, tooked old one out , readed info to computer and tooked new one similar to old one, reporgrammed it and presto no issues e2prom error
loud and proud :P
wordmc9 is offline
post #922 of 1085 Old 03-10-2015, 02:50 PM
Jon S's Avatar
Quoted: 907 Post(s)
Liked: 283
After upgrading the caps on a 905, the receiver no longer has any audio output... Any ideas?
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #923 of 1085 Old 03-10-2015, 04:07 PM
loud and proud :P
Not that I hope you haven't fixed it but many seem to say they think they fixed it in other ways before the issue comes back.
Please report back how this holds up to see if it IS the permanent fix.
Sent from my SGH-I317M using Tapatalk 2
post #924 of 1085 Old 03-10-2015, 05:49 PM
DBacksFan5205's Avatar
Thank You
untouchablepl,
What model is your Onkyo?
The item in your picture is an inductor (or choke coil). It is circuit part L8954, PN RCP1317NP-470M.
Check availability at: http://www.findchips.com/search/RCP1317NP-470M
Apparently, they are available at Avnet Express, Mouser Electronics, Digi-key, etc.
Note: This information applies to HDMI card NCHDM-9114 and models 875, 876, 906, etc. It may help you find the required part. Look for the reference designator of the part (Lxxxx) silkscreened on the board and then I could check the parts list for you if I have one for your model.
Good Luck!
DBacksFan5205 is offline
post #925 of 1085 Old 03-14-2015, 03:27 PM
sandworms's Avatar
Quoted: 17 Post(s)
I don't know if this has been asked before but if anyone here is interested in fixing my 706 board, please pm me. I don't feel I should attempt it and I can send you my board + a service fee $$
sandworms is offline
post #926 of 1085 Old 04-02-2015, 08:25 AM
Liked: 0
Question Sound cuts
Hi all, many thanks to those who contributed to this great thread.
I've successfully changed the 6 100uf capacitors in my tx SR-576 and it has solved the handshaking issues with HDMI. I was never be able to get 1080p and now is working fine.
But... I've started to suffer same symptoms that graham b has described:
Random audio cuts, sometimes two or three in a couple of minutes, sometimes nothing for a long period. In my case, the audio cuts always are of less than a second long.
Someone knows where could be the problem? Maybe 220uf capacitors? Any help will be greatly appreciated.
andycor is offline
post #927 of 1085 Old 04-17-2015, 04:09 PM
sandworms's Avatar
Quoted: 17 Post(s)
Guys, someone please help me!, you will be compensated
post #928 of 1085 Old 04-17-2015, 05:30 PM
TX-SR706 HDMI Card Repair
sandworms,
You might want to check out eBay Listing #150664829211
or just do a search for "ONKYO HDMI REPAIR SERVICE"
post #929 of 1085 Old 04-19-2015, 07:30 PM
Liked: 0
Thanks for the info. The channel associated with the caps I skipped has finally given up the ghost, so I guess I'll go in and replace the last few.
mtaylor6 is offline
post #930 of 1085 Old 04-20-2015, 08:51 PM
Liked: 0
This is what happened when I went to replace the remaining 100 uF capacitors:
1. I almost broke an inductor off the hdmi board top (looks like the plastic on the bottom of the inductor is cracked).
2. I thought at first that it was a 470 uF capacitor and since I've got plenty of those, I figured on replacing it, so started trying to fatigue the contacts... didn't work. Then I realized it was a "L" part, which would mean inductor. do'h!
3. I tried to de-solder the inductor to get a better look at it. I almost got it out (raised up about 5 mm)... got scared of destroying the PCB.
4. Gave up on the inductor, replaced the capacitors I was here for in the first place.
5. Profit. (Full board recovery and I didn't actually break the inductor enough).
So any blue artifacting I had before is now totally gone on all channels. The one channel that conked out on me is back 100%.
mtaylor6 is offline
Onkyo Tx Nr807 , Onkyo Tx Sr606 Receiver
