Pioneer 1020k Internet Radio List plus More - AVS Forum | Home Theater Discussions And Reviews
post #1 of 39 Old 05-06-2010, 07:49 PM - Thread Starter
Theheadsn's Avatar
Hey guys and gals. I finally got around to resetting the internet radio links on my Pioneer; and it took me a few minutes to copy and paste, but heres the list that comes factory stock with the reciever. In case anyone wants to put it back to the way it was, or really likes the normal stations.
Also heres a link to a website that will give you the URL of most any local radio stations by you, so you can add it to the receiver I know Im happy about it haha
The Streamm Center
(heres the list, but its backwords. Copied and pasted from bottom to top lol sorry)
FM Nirai
http://www.simulradio.jp/asx/fm-nirai.asx
MIYAZAKI Sunshine FM
http://www.simulradio.jp/asx/sunshinefm.asx
NOAS FM
http://www.simulradio.jp/asx/fmnakatsu.asx
Shonan Beach FM
http://www.simulradio.jp/asx/shonanbeachfma.asx
REDS WAVE
http://www.simulradio.jp/asx/reds-wave.asx
OTTAVA
http://ottava.jp/live/frame/ottava_live.php
Mumix Radio Live
http://www.mumix.net/radio/m3u/mumixradio.m3u
Relax
http://www.mumix.net/radio/m3u/relax.m3u
NME
http://edge31.proradiostreaming.com:80/;stream.mp3
BBC Radio 1
http://bbc.co.uk/radio/listen/live_wmt/r1.asx
AVRO Baroque
http://shoutcast.omroep.nl:8068/listen.pls
Venice Classic Radio
http://www.veniceclassicradio.eu/live1/128.pls
Classic & Jazz
http://www.laradiodesebb.com/stream/classicandjazz.pls
RauteMusik - Lounge
http://lounge-high.rautemusik.fm/listen.pls
Swiss Groove
http://www.swissgroove.ch/listen128.pls
RauteMusik - Goldies
http://goldies-high.rautemusik.fm/listen.pls
KVSC 88.1 FM
http://www.kvsc.org/listen/broadband.m3u
Snake Net Metal Radio
http://www.snakenetmetalradio.com/snakenet96.pls
Hot 108 Jamz
http://www.hot108.com/hot108.pls
Technicolor Web of So.
http://www.techwebsound.com/TWOS.pls
Classical Music Archi.
http://radio.classicalarchives.com:8002/listen.pls
Smoothchoice.com
http://www.smoothchoice.com/128.pls
Powerhitz.com
http://www.powerhitz.com/powerhitz_dot_com.asx
1.fm Top 40
http://www.1.fm/wm/energytop40128k.asx
Theheadsn is offline
post #2 of 39 Old 05-08-2010, 06:31 PM
aeitingon's Avatar
Thanks for setting this up! I am having pretty good luck copying links from the site you provided - now I can listen to radio stations that I miss from other cities. Very cool feature once you get it set up.
aeitingon is offline
post #3 of 39 Old 05-10-2010, 01:27 AM
vaix77's Avatar
thanks for the post. not sure if i will ever change them back to these stations but great information to have.
vaix77 is offline
post #4 of 39 Old 05-10-2010, 01:27 AM
vaix77's Avatar
I wish i would have checked the forum before trying to hunt down the URL's on my own. The Streamm Center is a great place to get URL's. I also used http://www.usliveradio.com/
This is one of the great features from the 1020.
vaix77 is offline
post #5 of 39 Old 05-19-2010, 11:21 AM
happyhour1973's Avatar
This is great! Thanks!!
happyhour1973 is offline
post #6 of 39 Old 05-19-2010, 12:04 PM
winston9332's Avatar
Liked: 31
would be a lot easier (better) if it just had pandora!
winston9332 is offline
post #7 of 39 Old 06-01-2010, 04:11 PM
JOgden's Avatar
Is it possible to get K-Love to stream from this? They have a streaming radio page however, I can't get it to work on the player.
http://www.klove.com/broadcast/playn...a=listen&bt=1&
JOgden is offline
post #8 of 39 Old 06-05-2010, 12:22 PM
jjscheid's Avatar
Hi - I've found a couple issues with my internet radio source, and was looking for any help:
1. I am able to play any of the stations that came with the 1020, but when I try to add others (via my laptop), I normally get "Connection NG" (no good). I think I've tried adding about 6-7, and I've only succeeded with 2. I've tried adding ones with pls or asx - seems to not make a difference.
2. Have you had any problems with stations just stopping playing? the station info is still scrolling on the display, but they stop playing thru the speakers (a or b). This has happened consistently with one station, wondering if anybody else has had the same happen to them?
any ideas? i connect via at&t dsl modem - not the fastest, but still decent speed. I am able to connect via my laptop and either media player or Itunes to every one of those same stations (same URL also), so I know it's the right URL.
Help! Thanks in advance.
jjscheid is offline
post #9 of 39 Old 06-07-2010, 06:20 AM
JOgden's Avatar
I was able to find the station: http://klove.com/listen/klove_mp3live_high.pls
Try switching the receiver to HDMI or DVD or anything other than the radio and then add your stations as this worked for me. Try enabling UPNP on your router if you have the option, I thought while looking through my NAT traffic that my receiver had opened ports via UPNP for streaming radio.
JOgden is offline
post #10 of 39 Old 06-07-2010, 03:56 PM
jjscheid's Avatar
Thanks for the reply! not sure if I know how to enable that or not.... but how could I add 1 or 2 stations, and also play the ones I have if that wasn't enabled already?
jjscheid is offline
post #11 of 39 Old 06-08-2010, 08:38 AM
JOgden's Avatar
My upnp suggestion was for the internet/connection drops while listening to the radio. Have you tried changing the receiver to DVD, then on your computer try changing/saving the stations?
JOgden is offline
post #12 of 39 Old 06-21-2010, 05:43 AM
LDukie's Avatar
When I try to change the internet stations, the receiver won't connect. I think it's because I don't have the URL ending in pls or asx like the ones that came with the receiver. How do you find that address? I can go to net radio stations and play them on my computer but not on the receiver. I'm sure I'm missing something in the address that the receiver needs, but how do I figure that out for each station that I want to add?
Thanks for any help, it would be much appreciated.
LDukie is offline
post #13 of 39 Old 06-21-2010, 09:33 AM
TornadoTJ's Avatar
Quoted: 1612 Post(s)
Liked: 510
That's the truth, I'd LOVE that!
TornadoTJ is online now
post #14 of 39 Old 06-21-2010, 12:39 PM
TornadoTJ's Avatar
Liked: 510
Hey, does anyone know how to extract the .pls URLs from Shoutcast? I had these in another application that I no longer use, it would be really cool if I could start entering some of the radio stations I used to listen to in that app. Stuff like .977 and Live365 have URLs you can access directly, but I can't find them.
post #15 of 39 Old 06-22-2010, 11:28 PM
TornadoTJ's Avatar
Liked: 510
Nobody knows how to find the streams???
post #16 of 39 Old 06-23-2010, 08:39 AM
LDukie's Avatar
One way that I have found that works, is to go to the internet radio station and see if you can play the station in media player. Media player then displays the correct link for some of the stations. This worked very well with SKY FM.
For 1.FM, a file is downloaded to your computer first and if you copy the link into a word file, you can then see the correct URL name ending in aspx.
I added a bunch to the receiver and they work.
LDukie is offline
post #17 of 39 Old 06-23-2010, 09:25 AM
TornadoTJ's Avatar
Liked: 510
For some reason I haven't been able to get media player to play the streams. I can get them to work in VLC and WinAMP, but not Media Player.
So the links don't have to be .PLS for the receiver to play them? It sounds like you are saying aspx works as well?
From Shoutcast, I did a "save as" and looked in the file, but was unable to find the link. I am going to try this again though, as it was really late last night when I was trying this and I may have overlooked the link.
post #18 of 39 Old 06-23-2010, 05:33 PM
LDukie's Avatar
They don't have to end in .pls, the ones from Sky FM end in .asx and they all work fine.
I just looked at shoutcast and those end in .pls, so media player won't play them.
LDukie is offline
post #19 of 39 Old 08-30-2010, 09:26 PM
CincyAudio's Avatar
Is there a way to stream Clear Channel stations on the Pioneer 1020/1120?
Here is an example: http://www.700wlw.com/mediaplayer/?station=WLW-AM
CincyAudio is offline
post #20 of 39 Old 08-30-2010, 10:07 PM
JeffK1234's Avatar
If you right click on a station on the Shoutcast radio directory website and hit properties, it will give you the url for the station in the pop up box that appears. That is how I got the urls for the stations I got from Shoutcast. They all worked. Don't know if this will help anybody.
JeffK1234 is offline
post #21 of 39 Old 09-05-2010, 09:07 PM
CincyAudio's Avatar
I have had no luck getting internet radio to work with the Pioneer 1120 from most of these stations that use flash. Let me know if you have any luck with this link:
post #22 of 39 Old 09-19-2010, 04:07 PM
heyyall's Avatar
I finally had some time to tinker with the internet radio on the 1120 (should be the same for the 1020). I learned a few tips that I haven't seen discussed, so I'm adding them here.
Cumulus Stations:
I was able to add Cumulus radio stations after reading some of the help information on Cumulus's website. I only tried this a couple of times, but it seems to work fine. Cumulus has the "Listen Live" link but this routes through a player on the computer. There is a more general link (given below) that seems to be the most flexible for the receiver (i.e., I couldn't get the "Listen Live" link to work with the 1120, but the link below did).
Root string for adding to the AVR through a web browser:
http://player.cumulusstreaming.com/stations/{Capital Call Letters - AM or FM}/PubPoint.asx
The station list can be found here by market:
http://www.cumulusstreaming.com/
Use:
Take my root string and sub in the call letters.
Examples:
For example, KROC in Rochester MN is
http://player.cumulusstreaming.com/stations/KROC-FM/PubPoint.asx
ESPN out of Eugene, OR is
http://player.cumulusstreaming.com/stations/KSCR-AM/PubPoint.asx
Some limitations, "Disney" is listed on some of the Cumulus stations. I couldn't get them to work either on the 1120 or directly on the "Listen Live" on the Cumulus website. I suspect programs that are syndicated may not be readily available.
heyyall is offline
post #23 of 39 Old 10-09-2010, 02:13 PM
MMD3's Avatar
I'm trying to set up KEXP (seattle indie station) and the URL I'm using connects but then it just plays the station identification and exits back to the menu.
I'm guessing I'm doing something wrong?
MMD3 is offline
post #24 of 39 Old 10-10-2010, 05:07 PM
MMD3's Avatar
still trying to figure out how to add KEXP, has anybody gotten their stream to work?
MMD3 is offline
post #25 of 39 Old 10-14-2010, 03:48 PM
heyyall's Avatar
Did you try this link?
http://kexp.org/audio/kexp-uncomp.asx [edit URL doesn't work-see below]
Seems like the *.asx streams will work. It works on my desktop and will try to test it on the receiver later.
Edit: Turns out the Pioneer will not play this stream (its uncompressed and at 1.4mps). This URL seems to play just fine,
http://kexp-mp3-1.cac.washington.edu:8000/listen.pls
heyyall is offline
post #26 of 39 Old 10-21-2010, 03:54 PM
MMD3's Avatar
aha!
thanks, I'll give the pls file a go... I was indeed trying to play the .asx
so it's just because it was too high of a bitrate you think?
MMD3 is offline
post #27 of 39 Old 10-21-2010, 05:50 PM
HighEndWire's Avatar
Liked: 26
I did exactly the same for most of my stations I put in a few of the Linn radio stations too which are high quality. Here's what I set-up on my rec'r:
Linn Radio http://89.16.185.174:8003/stream
Linn Jazz http://89.16.185.174:8000/stream
Linn Classical http://89.16.185.174:8004/stream
http://yp.shoutcast.com/sbin/tunein-...pls?id=1104998
~bEE Jazz
http://yp.shoutcast.com/sbin/tunein-....pls?id=297075
Raritan Bay Oldies
http://yp.shoutcast.com/sbin/tunein-...pls?id=1473791
SEOUL FM!
http://yp.shoutcast.com/sbin/tunein-station.pls?id=154
Happy Rock Radio
http://yp.shoutcast.com/sbin/tunein-....pls?id=148269
Raven Radio Mix
http://yp.shoutcast.com/sbin/tunein-...pls?id=1450622
Freebird Classic Rock
http://yp.shoutcast.com/sbin/tunein-...pls?id=1423118
FM 101 Country
http://yp.shoutcast.com/sbin/tunein-...pls?id=1088332
Delmondo Alternative
http://yp.shoutcast.com/sbin/tunein-....pls?id=925018
CharlesRadio Rock
http://yp.shoutcast.com/sbin/tunein-....pls?id=602507
Master Baker Rock
http://yp.shoutcast.com/sbin/tunein-....pls?id=488461
4 Noises Pop
http://yp.shoutcast.com/sbin/tunein-....pls?id=237552
Sunny Radio Classic Rock
http://yp.shoutcast.com/sbin/tunein-....pls?id=165878
New England Jazz Express
http://yp.shoutcast.com/sbin/tunein-...n.pls?id=76546
RTi FM Top 40
http://yp.shoutcast.com/sbin/tunein-...n.pls?id=38991
CruiseOne Pop/Rock
HighEndWire is offline
post #28 of 39 Old 10-31-2010, 12:40 PM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
Setting up my 1120 and not really familiar with internet radio. I've found urls for some stations and successfully updated via the web interface and listened on the receiver.
One of the local stations I listen to (929Dave FM) advertises an HDRadio station they call Dave Roots (the Roots of Dave FM) It's WZGC-HD2
I can't find a link to copy into the receiver. Do you all suppose that HDRadio stations don't have normal internet streams or have I just not looked in the right places? They have a way to listen on the internet via a flash player, but I can't get Flash to give up a good url. Help?
Update: Looks like there is no specific restriction on internet streams for HDRadio or anything like that. Seems that the particular station I wanted to check out is not available. I still haven't been able to find one, to be sure. And this website seems to be pretty comprehensive and does not include the station I wanted, but does include HD2 stations... oh well.
HopefulFred is offline
post #29 of 39 Old 12-15-2010, 01:14 PM
rdetoma's Avatar
I can't get properties on Shoutcast in Safari on my Mac. How would I get the info for the Disney Theme Park stations?
rdetoma is offline
post #30 of 39 Old 12-27-2010, 10:21 AM
tvotta's Avatar
Reading through the threads for help about internet radio stopping. I can play lots of stations but after a few minutes it stops for no apparent reason. I thought it could have been a DHCP renew issue so I gave all my devices static addresses.
Anybody have any ideas about troubleshooting internet radio stopping? I have a Panasonic blue ray and tv that I can get veracast and pandora plays all day via viracast, but when I play through my Pioneer vsx-32 internet radio mysteriously stops. Any ideas welcome!
tvotta is offline
