*Official* Denon AVR-1911/791 & AVR-2311CI/891 Owner's Thread - Page 169 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #5041 of 5168 Old 05-03-2014, 04:25 PM
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
Help please. I turned on the system today but the sub didn't. Last night the wife was bitching so I turned the sw level all the way down.
Today when I hit ch level on the remote it doesn't even show the sub. But I checked the setting and it says sub yes. What did I do?
Denon X3100W
Klipsch RB-61 II (Fronts), Klipsch RC-52 II (Center)
Deftech StudioMonitor 350 (surrounds)
Klipsch SW-115 (sub)
LG 50LB5900
TiVo Roamio
jpcamaro70 is offline
post #5042 of 5168 Old 05-03-2014, 04:53 PM
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
My fronts were set to large so it's on again but all my custom settings are screwed. It took nee forever to get it the way I like it.
Denon X3100W
LG 50LB5900
TiVo Roamio
post #5043 of 5168 Old 05-03-2014, 06:18 PM
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
Man this sucks
Denon X3100W
LG 50LB5900
TiVo Roamio
post #5044 of 5168 Old 05-16-2014, 08:56 PM
jrod9707's Avatar
Quoted: 78 Post(s)
Liked: 35
I have had this receivers for several years and am in the Dallas area now where almost every station has an hd radio signal. Is there something I need to turn on in the menus to receive the stations. I never realized this receiver had a HD TUNER.
I drive a Dodge Stratus.
jrod9707 is offline
post #5045 of 5168 Old 05-16-2014, 11:42 PM
jrod9707's Avatar
Quoted: 78 Post(s)
Liked: 35
Never mind found this in the manual.
Press TUNER to switch the input
source to “HD Radio”.
2 Press BAND to select “FM” or “AM”.
FM When listening to an FM broadcast. AM When listening to an AM broadcast.
3Tune in the desired broadcast
station.
q To tune in automatically
(Auto tuning)
Press MODE to light the “HD-AUTO” or “AUTO” indicator on the display, then use TUNING d or TUNING f to select the station you want to hear.
•The indicator lights on the display when an HD Radio
station is tuned in.
• When “HD-AUTO” (tuning mode) is selected, only HD Radio
stations are tuned in.
• If “AUTO” (tuning mode) is selected, both HD Radio and analog
w To tune in manually (Manual tuning)
Press MODE to turn off the display’s “AUTO” indicator, then use TUNING d or TUNING f to select the station you want to hear.
jrod9707 is offline
post #5046 of 5168 Old 05-17-2014, 01:44 PM
jrod9707's Avatar
Quoted: 78 Post(s)
Liked: 35
Well I tried following the directions and it does not turn the HD RADIO ON. ANY SUGGESTIONS?
jrod9707 is offline
post #5047 of 5168 Old 05-17-2014, 02:42 PM
jdsmoothie's Avatar
Quoted: 12881 Post(s)
Liked: 5941
Are you able to get any FM or AM stations? Do you have the FM and AM antenna's that came with the AVR connected? HD broadcasts are limited in distance so if you are not close enough to the radio station, the signal will simply fall back to the analog FM/AM signal.
jdsmoothie is online now
post #5048 of 5168 Old 05-18-2014, 03:50 PM
jrod9707's Avatar
Quoted: 78 Post(s)
Liked: 35
I only have the FM antenna connected. I have no problems getting signal and my cx5 has a hd radio and it has no problem getting signal when it's in the garage. The radio just switches back and forth from manual and auto but doesn't show the HD AUTO. Any ideas?
jrod9707 is offline
post #5049 of 5168 Old 05-18-2014, 06:15 PM
jdsmoothie's Avatar
Liked: 5941
If digital signal isn't strong enough at the AVR, it reverts to the analog signal. You might want to try a more powerful FM antenna.
post #5050 of 5168 Old 05-19-2014, 10:49 AM
jrod9707's Avatar
Quoted: 78 Post(s)
Liked: 35
Great suggestion. I'll try that. Thankyou!
jrod9707 is offline
post #5051 of 5168 Old 06-03-2014, 11:38 AM
JJMONIE's Avatar
I am in thr Toronto area and my 2311CI has horrible reception. It is in the basement but my older Sony mini system worked great. I posted about this a few years back and the general response was that reception on newer recvievers is horrible.
I now listen to either the radio stations through my cable box or stream fromone of my media players.
JJ
JJ
JJMONIE is offline
post #5052 of 5168 Old 06-22-2014, 04:40 AM
JJMONIE's Avatar
Did my 2311 blow up?
Well, this was embarrassing, a friend came over to the house for the first time last night and I wanted to show him how my HT system was. Start streaming a BR rip of Fast & Furious 6, the first scene with the car race and pop! After 30 seconds, the front panel of my Denon goes blank and I lose all sound but still had picture.
I feel like an idiot now for showing off so to speak and then blowing my amp but it wasn't at 100%, maybe 85% and for only 30 seconds max.
Any idea what happened? Am a better off sending it to Denon or is there a local guy in the GTA that can help me out? Thanks guys.
JJ
JJ
JJMONIE is offline
post #5053 of 5168 Old 06-22-2014, 06:12 AM
jdsmoothie's Avatar
Liked: 5941
The AVR will generally go into protection mode well before 100% which is why a rule of thumb is to never go above 80 or 0db depending on which volume scale is being used. Try resetting the microprocessor per the instructions listed in the Owner's manual and if still no joy, then check Denon's website below for the closest repair shops. Note however, that unlike in the USA, the warranty on the 2311CI in Canada is only 2 years. If you purchased with a credit card, the issuer may add a 3rd year. If you are out of warranty, you may want to consider a newer model if the repair estimate is $200-$300.
http://ca.denon.com/ca/support/pages...tersearch.aspx
post #5054 of 5168 Old 06-24-2014, 08:27 AM
JJMONIE's Avatar
Good news! I opened up the receiver and found a blown fuse. Replaced it and all is good now. I think I went too much, too fast while the amp was cold. Thanks.
JJ
JJ
JJMONIE is offline
post #5055 of 5168 Old 07-03-2014, 01:43 PM
Cyberhog9's Avatar
Somehow I have lost audio from my AVR 791 to my speakers.Everything is how it's always been hooked up.I had audio this morning and now I can't get anything.Cable box,TV Phono and the reciever all work,but I must have hit a wrong button somehow.Denon's user manual is like wading thru War and Peace.
Any ideas?
Cyberhog9 is offline
post #5056 of 5168 Old 07-03-2014, 04:46 PM
jdsmoothie's Avatar
Liked: 5941
Check the front panel display of the 791. If it reads "H/P ON" then blow some compressed air into the headphone jack, otherwise if not, try resetting the microprocessor per the instructions on p. 78 in the Owner's manual.
post #5057 of 5168 Old 07-03-2014, 05:42 PM
Cyberhog9's Avatar
I tried resetting the microprocessor multiple times. I'm about to unhook and just kick the living **** out of overpriced crap electronics.Nothing I have done and I have read the Denon manual is working.I think the Auddessy part is broken.
post #5058 of 5168 Old 07-07-2014, 11:18 AM
yavuzalp's Avatar
AVR 791 No sound
OK guys here is my problem I had this AVR 791 for about 3 years now. My problem started about a year ago. I had my ps3, apple tv, sat box and another TV box installed. and working fine for quite a while. And one day I turned on sat/cable and there was no sound but picture was there. I checked the other equipment and i had the sound but sat/cab. So i switched the to another hdmi port and kept using but from that point on i have been keep loosing all the ports one by one every 3-4 months. As of Friday all my ports are gone and I have no sound but great picture . It doesn't say HP on the front display but I still sprayed it with compressed air no luck tried to reset the system no luck any idea? If i turn of the receiver but TV is on I can get the sound from TV.
I already went out bought a SONY STR DN850 but I want this to get fixed so i can use it on my basement or I can sell it on Craigslist but I can't do anything with it on its current condition any ideas what it can be or what should I do?
Thanks in advance for your inputs.
yavuzalp is offline
post #5059 of 5168 Old 07-07-2014, 11:31 AM
jdsmoothie's Avatar
Liked: 5941
From your description, sounds like the HDMI board has gone bad ... generally a $400 expense out of warranty.
yavuzalp likes this.
post #5060 of 5168 Old 07-07-2014, 08:11 PM
yavuzalp's Avatar
LOL $400 ...I guess that thing goes to trash that is what I was worried about I didn't want to spend diagnostic than find out this so i got the sony i hope this will be better than the Denon. Thanks for your reply.
yavuzalp is offline
post #5061 of 5168 Old 08-27-2014, 05:05 PM
rugmankc's Avatar
Guys, I need some help. Not a techy but this forum helped me get my 2311ci which has been great. I never set Dolby Vol to on when running Audyssey Auto Set Up. So, can not toggle thru the Day, Evening etc toggles to control commercial volume. I know I can go back and redo everything until I get to last step where Dolby Vol on/off is. I don't have a mic and can't get past step 2 w/o it. Plus I would hate to screw things up when working so well. Is there a way to get to turning Dolby Vol on w/o going thru entire setup or a way to skip step 2. This info is on pages 55 and 9 in my manual.
Thanks for any help, worst case may have to buy mic and redo everything. Must be an easier way. Commercial volume is driving my wife nuts at night.
Ken
rugmankc is offline
post #5062 of 5168 Old 08-27-2014, 05:18 PM
batpig's Avatar
Quoted: 3619 Post(s)
Liked: 3466
You are confused on several fronts.
1. Your 2311CI does NOT have Dolby Volume. It has Audyssey Dynamic Volume (Dolby Volume is a similar, competitor product from Dolby).
2. You do NOT have to re-run Audyssey calibration to turn Dynamic Volume on/off. When it asks you if you want to turn it on after running auto setup, it's just setting the default state for all inputs. But after that point, you can always turn it on/off as you wish, and it will memorize your setting by input (same for Dynamic EQ).
See that button on your remote that says "DYN EQ/VOL"? Just push it
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #5063 of 5168 Old 08-27-2014, 05:20 PM
jdsmoothie's Avatar
Liked: 5941
If Audyssey has been run, then you simply need to set the Dyn EQ and Dyn Volume settings to ON. You don't need to run Audyssey again just because you didn't set it up when initially running Audyssey. If you need a mic, you can buy one on eBay for about $25.
rugmankc likes this.
post #5064 of 5168 Old 08-27-2014, 05:43 PM
rugmankc's Avatar
Thanks for quick reply guys,
Sorry on the wrong name, I was reading on internet also. Saw Dolby Vol there.
I did press the DynEq/Vol button but it does nothing. Just pops up "Run Audyssey" on screen. Which I did when I first got receiver. Manual says I should see the modes on receiver display, I don't.
Must be missing something--
rugmankc is offline
post #5065 of 5168 Old 08-27-2014, 06:00 PM
batpig's Avatar
Liked: 3466
If it says "run audyssey" that means your calibration got erased. You can't use DEQ/DV without first completing calibration. So somehow you need to get a mic and recalibrate.
batpig is offline
post #5066 of 5168 Old 08-27-2014, 06:14 PM
rugmankc's Avatar
Thanks batpig,
I came to that realization after your and jd's replies.
I did it initially with the mic and thought I ran thru all of it. Thought the mic came with receiver, but can't find it anymore. Am sure Radio Shack will have one.
Not sure how it got erased, but that is what must have happened.
Just thought there might be a way to skip the mic setup (step 2) as step 1 had a skip option. Guess not.
Anyway just happy I researched and found out the receiver has this feature. Will get it working.
Thanks--
rugmankc is offline
post #5067 of 5168 Old 08-27-2014, 06:43 PM
batpig's Avatar
Liked: 3466
As an FYI, it you need to clamp down on volume in the meantime (eg late night listening) with Dolby digital tracks there is a DRC feature (dynamic range compression) which automatically restricts the loudest sounds.
But yes get a mic.
Settings can be erased either from power surges or perhaps leaving the receiver unplugged for more than a week or so. It could have also been erased when you tried to rerun Audyssey (although if I remember correctly it only erases the previous calibration when you complete and store the new calibration).
Setup Guide and FAQ
batpig is offline
post #5068 of 5168 Old 08-27-2014, 07:21 PM
rugmankc's Avatar
Thanks batpig, will check it out--
rugmankc is offline
post #5069 of 5168 Old 08-28-2014, 02:40 AM
jdsmoothie's Avatar
Liked: 5941
Originally Posted by rugmankc View Post
Thanks batpig,
I seriously doubt it as you must use a specific Audyssey mic either DM-A409, ACM1H or ACM1HB.
http://www.ebay.com/itm/Brand-New-Or...item519faa46c2
post #5070 of 5168 Old 08-28-2014, 05:53 AM
rugmankc's Avatar
Thanks jd
Thought I had a Denon mic. Can't believe I threw it away. Will look around house and check out your link.
rugmankc is offline
Denon Avr 791 Receiver , Denon Avr 1911 Receiver , Denon Avr 891 Receiver , Denon Avr 2311ci Receiver
