*Official* Denon AVR-1911/791 & AVR-2311CI/891 Owner's Thread - Page 170 - AVS Forum
post #5071 of 5095 Old 09-19-2014, 03:01 PM
kushum's Avatar
alright guys need some help. last week i fried my hdmi board on a 891 switching inputs without turning off the receiver, I know my dumba$$. well last night i decided to bring it out to play with it before actually going out and deciding on a new avr. So long story short i got everything to work connecting my pc>fiio e18>891 cd rca input but the sub isn't working. Is there a way of getting my sub to work and a way to adjust the sound? My headphones sound good coming out of the receiver but my speakers sound like trash.
kushum is offline
post #5072 of 5095 Old 09-19-2014, 03:49 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 1377 Post(s)
Liked: 1598
Set the speakers to SMALL/80Hz.
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer for AVRs, Speakers, etc.
Daily 8am – 8pm EST (Sat/Sun too if you leave message)
Call for pricing on Denon, Marantz, Yamaha, Pioneer Elite, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #5073 of 5095 Old 09-19-2014, 05:24 PM
kushum's Avatar
thats the thing i cant get a image up on the monitor since the board is fried and nothing is popping up on the display on the receiver
kushum is offline
post #5074 of 5095 Old 09-19-2014, 11:48 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1598
Time for a new AVR.
post #5075 of 5095 Old 09-22-2014, 06:04 PM
Liked: 0
Hey guys, new to all this and any help will be great! I have a Denon AVR-891 and it will turn on for about 5 seconds, display "main zone on" on the screen then turns it's self off. A flashing red light then displays around the on/standby button. Any ideas how to fix this? Cheers
Jedos is offline
post #5076 of 5095 Old 09-22-2014, 08:01 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1598
The most common problem is a loose speaker wire from one post touching another post. Is the red light flashing quickly (eg. 2x/sec) or more slowly (eg. every 2 sec)?
post #5077 of 5095 Old 09-22-2014, 11:06 PM
Liked: 0
That's sounds pretty feasible. Haven't had the chance to check the speaker wires and don't really know what I'm looking at but there is definitely a short there somewhere as it will run without fail when I have the outer cover off but as soon as I put it back on it shorts out. That red light flashes slowly. About once every 2 seconds. Sounds like an easy fix if I can locate the loose wire. Will keep tinkering with it and see how I go. Thanks heaps!
Jedos is offline
post #5078 of 5095 Old 09-23-2014, 02:03 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1598
A slow flashing light generally means a "poor ventilation" issue causing the unit to heat up. Is there sufficient open room around the AVR (eg. at least 3-4") and not inside an enclosed cabinet?
post #5079 of 5095 Old 09-23-2014, 04:40 AM
Liked: 0
Yeh I got it given to me off a mate because he was having issues with ventilation and tripping out. He tried running it in the open and ontop of a fan forced pad for laptops to push cool air through it but that didn't work. When I run it without the cover off in an open space it works perfect but as soon as I put the cover back on it trips. I'm guessing there is a loose wire that is shorting out.
Jedos is offline
post #5080 of 5095 Old 10-02-2014, 08:25 AM
Eben's Avatar
Will This Work?
Connect DirecTV HD box with component to AVR1911; assign component to V. AUX; associate V. AUX with HD Radio -- all this so when I select HD Radio on the AVR I will get audio from the radio but video from the sat. receiver. Will it work (especially for HD video sources, i.e., sports)?
Eben is offline
post #5081 of 5095 Old 10-02-2014, 08:55 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1598
The feature you want does exist. With the HD Radio playing, set the Video Select setting (p. 47 Owner's manual) to the component video input.
post #5082 of 5095 Old 10-03-2014, 07:27 AM
himebaughdn's Avatar
I have what is hopefully a simple question.
I have connected my Denon AVR 1911 to a Dish receiver, TV, surround sound bar and sub woofer. All works fine when using the main zone, but I am trying to connect two outside speakers on to Zone 2 and nothing works. I have checked many things and it seems like I have covered everything, but no luck. I would like to listen to the Sirius radio that comes through the Dish receiver on my outside deck. I'm a novice at this and would appreciate some help.
himebaughdn is offline
post #5083 of 5095 Old 10-03-2014, 08:09 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1598
Only analog sources will pass to Zone 2, so you must also connect an analog (red/white) cable from the Dish receiver and connect it to the analog inputs with the same name being used for the HDMI input (eg. CBL/SAT).
post #5084 of 5095 Old 10-03-2014, 12:38 PM
Thank you! I will try it.
post #5085 of 5095 Old 10-07-2014, 08:58 AM
Eben's Avatar
OK, tried this but I'm sure I did something wrong. I connected DirectTV receiver to AVR using component. I assigned the component to V.AUX. When I selected V.AUX I got a picture (no sound, as expected)! However, when I selected HDRadio and then set the Video Select to V.AUX, I got sound but no video.
Eben is offline
post #5086 of 5095 Old 10-07-2014, 09:09 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1598
Ensure V.Aux doesn't also have HDMI assigned.
post #5087 of 5095 Old 10-07-2014, 03:00 PM
Eben's Avatar
At work now, will check tonight, thanks.
Eben is offline
post #5088 of 5095 Old 10-08-2014, 09:08 AM
Eben's Avatar
I checked last night and V.AUX had only COM assigned.
Eben is offline
post #5089 of 5095 Old 10-08-2014, 09:33 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1598
Try doing a soft reset by unplugging the power to the 1911 for 10 minutes. Also try using a different source name.
post #5090 of 5095 Old 10-08-2014, 01:07 PM
Eben's Avatar
If these don't work, is the next step a full reset? No big deal because I added new speakers recently and haven't yet rerun Audyssey.
Eben is offline
post #5091 of 5095 Old 10-08-2014, 01:09 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1598
Yup.
post #5092 of 5095 Old 10-08-2014, 02:33 PM
Eben's Avatar
Yup.
Cool. Appreciate the assistance.
Eben is offline
post #5093 of 5095 Old 10-15-2014, 04:47 AM
dsubra's Avatar
Stereo mode / surround not working
Hi,
After cleaning my set , suddenly only Direct mode working in main (zone 1).In stereo mode no sound from amp, so any surround eg PLII, Dolby Digital, any simulation no sound , only Direct source, why? Zone 2 working as usual. Pls help. Tq.
dsubra is offline
post #5094 of 5095 Old 10-15-2014, 05:35 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1598
Refer to your Owner's manual and do a microprocessor reset.
post #5095 of 5095 Old 10-15-2014, 06:06 AM
dsubra's Avatar
Thumbs up
Thanks for the prompt reply, i thought so.....but 'off'ing the set for 10mins rectify the problem already.
Tq again.
dsubra is offline
Denon Avr 791 Receiver , Denon Avr 1911 Receiver , Denon Avr 891 Receiver , Denon Avr 2311ci Receiver
