*Official* Denon AVR-1911/791 & AVR-2311CI/891 Owner's Thread - Page 171 - AVS | Home Theater Discussions And Reviews
post #5101 of 5117 Old 11-22-2014, 04:31 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 3692 Post(s)
Liked: 2173
X2000 would be a nice choice.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #5102 of 5117 Old 11-23-2014, 04:48 AM
drhill's Avatar
Quoted: 20 Post(s)
drhill is offline
post #5103 of 5117 Old 11-23-2014, 03:35 PM
bisk's Avatar
Denon AVR-2311CI Optical Output Issues
I'm having an issue getting the optical output working on my AVR-2311CI so that I can use my Triton Headphones. I have all of my sources (Xbox One, HTPC, Wii U and Cable Box) hooked up via HDMI, but I can't seem to get the audio to output over the Optical Out. I can't seem to find the option to enable the optical output. I hooked an optical cable up to the optical out and I'm not seeing any light coming from the cable either. Any ideas how I can enable the output?
bisk is offline
post #5104 of 5117 Old 11-23-2014, 03:46 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2173
There is no HDMI --> optical down conversion, rather you must use OPT IN --> OPT OUT.
post #5105 of 5117 Old 11-23-2014, 05:11 PM
Liked: 0
Hello, I have the avr 791 and it doesn't seem to be detecting my speakers. I have tried hooking up through hdmi and component, I get video but no sound. Any help?
joshhud is offline
post #5106 of 5117 Old 01-03-2015, 07:22 PM
Quoted: 13 Post(s)
Liked: 0
I have a 1911, and have successfully set up my zone 2 on the deck, but can not figure out how to adjust/change the volume for zone 2. I can change the volume on my main/5.1 setup, but can't adjust it for zone 2. I have gone into the settings, and changed the startup volume, but am at a loss after that. Any help would be appreciated!!!!!! Thanks in advanced!!
BViz is offline
post #5107 of 5117 Old 01-04-2015, 06:43 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2173
If you are using the 1911 to power the speakers, you should be able to select Zone 2 and use the AVR remote for volume control. If using an external amp, volume control is via the external amp.
post #5108 of 5117 Old 01-04-2015, 08:54 AM
Quoted: 13 Post(s)
Liked: 0
Thanks for the reply. I forgot to add that I lost the original remote in a move. I have a Harmony 700. Any tips on programming it to control the Zone 2 volume, or would have to post in a different form? Thanks again for your quick reply.
BViz is offline
post #5109 of 5117 Old 01-04-2015, 12:15 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2173
Sorry no, as I don't use Harmony. However, if you have downloaded the 1911 remote codes from the Logitech website to the 700, you should be good to go.
post #5110 of 5117 Old 01-04-2015, 03:48 PM
Quoted: 13 Post(s)
Liked: 0
Thanks for the reply. I'm going to call Logitech customer support and see if they can help. Great thread, I have leaned lots. Keep it up!!! Thanks again.
BViz is offline
post #5111 of 5117 Old 02-21-2015, 06:26 AM
Liked: 0
AVR 2311 - RS-232 control port
Hi,
Does anyone know how to turn on the RS-232 control port on the AVR-2311?
I'm trying to connect it to my Control4 Controller.
mohi is offline
post #5112 of 5117 Old 02-21-2015, 07:41 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2173
It's always on ... you simply need to send it the proper serial control codes which Control4 should be able to provide.
post #5113 of 5117 Old 03-29-2015, 08:02 PM
ncrules23's Avatar
I have a 791, trying to connect headphones to it. But I'm only getting surround mix out of it. Can't hear any words. They are stereo headphones, what am I doing wrong?
ncrules23 is offline
post #5114 of 5117 Old 03-30-2015, 02:37 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2173
Insert and remove the headphone jack a few times as it may simply not be making a solid connection.
post #5115 of 5117 Old Today, 07:40 AM
**OptimusPrime**'s Avatar
Hello!
Bear with me here, I am possibly going to upgrade to a new tv and I have a question about 4k and my current receiver, the 2311CI.
I know my receiver can pass through 1080p and 3D. Question is, not that there is really is a true 4k source yet, but if there was, will my receiver simply pass it through to the tv?
Most 4k content I'd play would probably come from the tv itself...but if directv or any other streaming device/service were connected to the receiver, would it simply pass that signal to the tv?
Thanks in advance!
**OptimusPrime** is offline
post #5116 of 5117 Old Today, 08:03 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2173
No, it would not, rather the 4k signal would have to be connected directly to the TV with audio to the AVR.
post #5117 of 5117 Old Today, 09:51 AM
Great!! More cables!
Denon Avr 791 Receiver , Denon Avr 1911 Receiver , Denon Avr 891 Receiver , Denon Avr 2311ci Receiver
Gear in this thread - 2311ci by PriceGrabber.com
