*Official* Denon AVR-1911/791 & AVR-2311CI/891 Owner's Thread - AVS Forum
post #1 of 5105 Old 05-26-2010, 01:08 PM - Thread Starter
GotHDTV?'s Avatar
Denon finally posted information on their website for their new HDMI 1.4 receivers.
AVR-1911
http://www.usa.denon.com/ProductDetails/5330.asp
Product Sheet
http://www.usa.denon.com/AVR-1911_Lit521.pdf
Owner’s Manual (English)
http://www.usa.denon.com/AVR-1911-OM-E_006.pdf
Owner’s Manual (Spanish)
http://www.usa.denon.com/AVR-1911-OM-S_006.pdf
AVR-1911
$599.00
Thrilling Surround Sound Performance
Featuring the latest high resolution audio decoders, including Dolby TrueHD and DTS-HD Master Audio, formats found on Blu-ray discs, the AVR-1911 is also equipped with Dolby Pro Logic IIz, which provides the option of front height effects channels, for a dramatically expanded front soundstage. Pro Logic IIz also breathes new life with your stereo audio sources, providing enveloping surround sound.
Equipped With HD Radio
In addition to conventional AM and FM tuning, the AVR-1911 also features HD Radio. With HD AM radio sounds like FM, and HD FM radio sounds like CD.
HDMI 1.4a Includes 3D Blu-ray Compatibility
The AVR-1911 includes the latest HDMI 1.4a specification, which provides 3D Blu-ray pass-through (Broadcast and Blu-ray) capability, as well as providing Audio Return Channel. There are 4 HDMI inputs, along with standard definition and component video inputs. Standard definition video sources such as VCR and DVD are upconverted to HDMI, which allows for a single HDMI cable run to the TV, avoiding the expense and hassle of multiple cable runs.
Easy Setup With Automatic Room Acoustic Correction
Audyssey MultEQ dynamic room acoustic correction system features a microphone (included) to automatically measure the speaker configuration and provide acoustic tailoring for the best surround sound experience, and provides quick and easy setup. Dynamic Volume minimizes jarring volume jumps during commercial breaks, and Dynamic EQ provides a natural tonal balance even at very low volume levels.
AVR-791
(Basically same as the AVR-1911, but without HD Radio, see FAQ below for more info)
http://www.usa.denon.com/ProductDetails/5308.asp
$499.00 MSRP
Product Sheet
http://www.usa.denon.com/AVR-791_Lit517.pdf
http://www.usa.denon.com/AVR-791-OM-E_009.pdf
http://www.usa.denon.com/AVR-791-OM-S_009.pdf
ooofest likes this.
GotHDTV? is offline
post #2 of 5105 Old 05-26-2010, 01:16 PM - Thread Starter
GotHDTV?'s Avatar
AVR-2311CI
http://www.usa.denon.com/ProductDetails/5335.asp
Product Sheet
http://www.usa.denon.com/AVR-2311CI_Lit521.pdf
http://www.usa.denon.com/AVR-2311CI-OM-E_001.pdf
http://www.usa.denon.com/AVR-2311CI-OM-S_001.pdf
AVR-2311CI
$899.00
Equipped With The Latest Surround Sound Decoders
The AVR-2311CI features high resolution audio decoders, including Dolby TrueHD and DTS-HD Master Audio. It also comes equipped with Dolby’s Pro Logic IIz decoder, which provides superb surround sound from conventional stereo audio sources such as CD. The Pro Logic IIz decoder also features the ability to produce two additional front height effect channels, which provides a dramatically expanded front soundstage.
HD Radio
In addition to conventional AM and FM tuning, the AVR-2311CI also features HD Radio. With HD Radio AM sounds like FM, and FM HD radio sounds like CD.
Featuring 6 HDMI inputs, the AVR-2311CI is also equipped with Denon’s high resolution video processor, which accepts standard definition video sources and upconverts them to HDMI. The latest HDMI 1.4a standard is supported, which provides 3D pass-through (Broadcast and Blu-ray), and also supports Audio Return Channel. The HDMI upconversion allows for a single HDMI cable run to the TV, avoiding the expense and hassle of multiple cable runs.
AVR-891
(Basically same as the AVR-2311CI, but without HD Radio, see FAQ below for more info)
http://www.usa.denon.com/ProductDetails/5319.asp
$799.00 MSRP
Product Sheet
http://www.usa.denon.com/AVR-891_Lit517.pdf
http://www.usa.denon.com/AVR-891_OM_E_004.pdf
http://www.usa.denon.com/AVR-891_OM_S_004.pdf
ooofest likes this.
GotHDTV? is offline
post #3 of 5105 Old 05-26-2010, 04:47 PM
batpig's Avatar
Quoted: 1097 Post(s)
Liked: 1555
FREQUENTLY ASKED QUESTIONS
Q. What is the difference between the three-digit models (e.g. AVR 791) and the four-digit models (e.g. AVR 1911)?
A: In general, NOTHING. Denon puts out two parallel receiver lineups, with four-digit and three-digit model numbers. The four-digit models are generally sold by high end stereo shops and custom installers, and the three-digit models are the "consumer" version sold in retail outlets like Best Buy and Fry's.
However, there is ZERO difference in terms of power, specs, sound quality, build quality, etc. between the two lines. Denon has been doing this for years, it is exactly analogous to the Yamaha HTR and RX-V parallel receiver lines.
There will usually be one or two minor differences to differentiate the three-digit and four-digit models. There is typically a slight cosmetic difference between the two lines, and different remotes.
For more info, please see the Denon Model Numbers page at batpigworld:
http://batpigworld.com/models.html
Q. OK, what are the specific differences?
A: see the listing below for specific differences between the "twin" models --
The AVR 791 and AVR 1911 are "twin" models. The only differences between the two (beyond cosmetics) are:
(1) The AVR 1911 adds HD radio
(2) The AVR 1911 has Zone 2 pre-outs (so you are not required to use the "amp assign" to power Zone 2). This means that, with the additional of an external 2-channel amp, the 1911 can run 7.1 + Zone 2 (whereas the 791 can only do 5.1 + Zone 2).
(3) The AVR 1911 has a "Room-to-room" remote control jack so you can hard-wire an infrared remote extender for your 2nd zone
IN ALL OTHER RESPECTS, THE AVR 791 AND 1911 ARE IDENTICAL!
The AVR 891 and AVR 2311 are "twin" models. The 2311, being the "CI" model, adds a few features; the differences between the two (beyond cosmetics) are:
(1) The AVR 2311 adds HD radio
(2) The AVR 2311 has Zone 2 pre-outs (so you are not required to use the "amp assign" to power Zone 2). This means that, with the additional of an external 2-channel amp, the 2311 can run 7.1 + Zone 2 (whereas the 891 can only do 5.1 + Zone 2).
(3) The AVR 2311 has expanded Zone 2 setup options, including bass/treble controls and optional HPF (high-pass filter) for Zone 2 speakers, the ability to switch Zone 2 between stereo and mono, and variable volume output for the Zone 2 pre-outs
(4) The AVR 2311 has a "Room-to-room" remote control jack so you can hard-wire an infrared remote extender for your 2nd zone
(5) The AVR 2311 has the "CI" features: RS-232 control port, 12V trigger output
IN ALL OTHER RESPECTS, THE AVR 891 AND 2311 ARE IDENTICAL!
Q. Does the AVR 791 have more power than the 1911? And 891 vs 2311??
A: NO!!! This is pure marketing gimmickry!!
The AVR 791 and 1911 have IDENTICAL amplifier sections!!!
The AVR 891 and 2311 have IDENTICAL amplifier sections!!!
Denon decided to quote the "6-ohm" wattage spec instead of the "8-ohm" spec purely to make the 3-digit models look more impressive on the shelves of Best Buy, Fry's, etc. If you look at the actual manuals / product sheets, you will see that the amplifier specs are actually identical among these models!
Q. Should I get one of these new models, or buy a cheaper xx10 model on closeout??
A: This is what's NEW on the xx11 models:
- HDMI 1.4, which supports 3D video, ARC (audio return channel) and ethernet over HDMI
- a front-panel USB port that is compatible with iPod/iPhone direct play and control (also music off USB drives)
- a new, improved remote (all the buttons are on one side!)
- HD radio (4-digit models only!)
This is what you LOSE on the xx11 models:
- No more EXT IN multichannel analog inputs
- Fewer "legacy" inputs (e.g. component video, s-video, etc)
- No more "B" speaker posts (although you can reassign the surr.back amps to "Front B" if you want to use a dedicated pair of 2-ch music speakers)
- No more switched outlets
That is basically it -- if you don't care about 3D or the USB port for your iPod/iPhone, you can get the xx10 model without missing out on much.
Assume that sound quality is IDENTICAL! The xx10 and xx11 models have the same Audyssey MultEQ room processing, same audio codecs, etc.
Q. Should I go with the 791/1911 model or is it worth it to pay more for the 891/2311CI model?
A: That depends! Again, assume that sound quality is IDENTICAL! Do NOT buy the next model up with the expectation that you will get better sound quality. All "consumer" models, from the lowly AVR 391 to the AVR 2311CI, have the same basic amp section, DSP chips, and Audyssey processing. ONLY buy the next model up if you actually want the extra features!
The AVR 791 and 1911 are twin models -- see above for the specific differences. They provide:
- Four HDMI 1.4 inputs and one output
- Analog video inputs = one component video input and two composite video inputs
- Digital audio inputs = one coaxial and one optical digital audio input
- Analog audio inputs = four analog RCA audio inputs (the "CD" input is audio-only!)
- Front-panel USB input with iPod/iPhone direct play and control (can also play MP3/WMA/AAC off a USB drive)
- Audyssey MultEQ room correction with Dynamic EQ + Dynamic Volume
- Video conversion of any input (analog or digital) up to 1080p with ABT-1030 video processor chip
- Basic black/white OSD which CANNOT OVERLAY on top of video; when you call up the OSD, the video will blank out and the OSD will appear
The AVR 891 and 2311CI are twin models -- see above for the specific differences. They provide the following additional features beyond the 791/1911:
- 6 HDMI inputs (instead of 4)
- Greater selection of "legacy" inputs: two component video inputs, two each coaxial and optical digital audio inputs, two S-video inputs, three composite video inputs, and six RCA analog audio inputs.
- Better DAC's and ADC (again, making it a better choice if analog / legacy support is important)
- A component video monitor output (with GUI support)
- Dual subwoofer outputs (note that these are IDENTICAL mirrored outputs, they do not get separate distance/level/EQ settings)
- Upgraded video processing, including:
... (1) superior ABT-2015 video scaling chip (better HD processing and deinterlacing performance)
... (2) color GUI menus instead of basic black/white text OSD
... (3) the ability to OVERLAY volume, status, and GUI graphics on top of the video signal
... (4) picture adjustments (color, brightnes, contrast, etc) can be set separately for each input
... (5) the ability to convert analog video to component video output (and can still use GUI via component out)
- The AVR 2311CI also adds an RS-232 port (so you can do firmware updates at home without sending it into a repair center) and enhanced Zone 2 flexibility (stereo/mono switch, variable or fixed volume on RCA pre-outs, bass/treble control, and HPF control).
Q. Should I go with the 891/2311 model or is it worth it to pay a bit more to step up to the 991 model?
A: That still depends! The new AVR 991 (a slightly stripped-down version of the 3311CI) adds several features compared to the 2311/891 level for only $100-200 more msrp.
This is what you get stepping up to the AVR 991:
- slightly more power
- MultEQ XT (instead of regular MultEQ)
- Audyssey DSX
- Networking (including DLNA support, and Pandora, Rhapsody, Flickr streaming)
- It is a bit more of an "audiophile" unit too for critical 2ch music buffs, with a PHONO input, AL24+ processing on the front channels, and slightly better analog components.
If you are willing to spend all the way up to the 3311CI, you add:
- 3 zone support
- a second smaller remote for Zone 2/3 (IR only)
- dual 12V trigger outputs
- pre-outs for all channels
- 3 year "CI" warranty
ooofest likes this.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #4 of 5105 Old 05-26-2010, 04:58 PM
batpig's Avatar
Liked: 1555
Originally Posted by mcleanda View Post
Other than the HDMI 1.4 spec is there any other differences between the 2310 and 2311
there are many differences, some small, some large:
ADDITIONS:
- HDMI 1.4 inputs (with 3D support and ARC)
- 6 HDMI inputs instead of 5
- dual subwoofer outputs (although they are "mirrored" identical signals)
- USB port on front with ipod direct play (via built-in GUI), can also play MP3's off a USB drive
- new remote (finally abandoning the idiotic 2-sided remote with the secret panel on the back)
- HD radio
- slightly enhanced Zone 2 functionality (bass/treble control, can select mono vs stereo)
SUBTRACTIONS:
- no more EXT IN multichannel analog inputs
- no more PHONO input
- loss of "B" speaker posts (now must use "Amp Assign" terminals if you want "B" speakers)
- no more switched outlets
There are also some minor functional differences here and there in terms of operation.....
Setup Guide and FAQ
post #5 of 5105 Old 05-26-2010, 05:06 PM
lazydesi's Avatar
AVR 791 aka 1911 is in Stock
Via Amazon for $430.10
http://www.amazon.com/Denon-AVR-791-...4915062&sr=1-6
lazydesi is offline
post #6 of 5105 Old 05-26-2010, 10:56 PM
TVbc's Avatar
batpig... thanks for the quick rundown of the differences 'tween 2310 and 2311.
personally i'm fine to see the 12V outlets being dropped, the extension cord to the car in the garage was too long anyway....
will you elaborate? you who have the intimate knowledge of these things denon can spot the differences so much easier.
and while we're at it:
can you explain ARC Audio Return Channel feature of HDMI 1.4a ? i've read the explanation on HDMI page and on wikipedia, but i'm not getting the significance.
and, about the remote. the appearance seems to be more conventional and perhaps more straight forward and less exotic. which will translate to easier operation in actual use. is that your take?
finally, how dramatic can things get? first simon cowell leaves american idol and then someone other than batpig starts an official denon thread. what will become of us?
thanks
bc
iirc afaik fwiw imo
TVbc is offline
post #7 of 5105 Old 05-27-2010, 12:12 AM
batpig's Avatar
Liked: 1555
oops I was thinking about 12V triggers
the significance is that you don't have to run a separate digital audio cable back to the AVR to hear audio from any content that is tuned in the TV itself.
for example, if you run the coaxial cable straight into the TV and use the TV's internal tuner (as opposed to an external cable box), or if you rent a Netflix movie straight from the TV, or you access other web content, video off a USB drive, whatever it is.... the audio can pipe back to the receiver via the HDMI cable. In other words, that HDMI cable from the AVR to the TV is a 2-way street, allowing audio FROM the TV to flow back to the receiver.
Without that ARC, you have to run a digital audio cable from the TV and use up another input on the receiver...
is it a big deal? I don't think so just a minor convenience thing, but becoming more useful as TV's have more and more content accessible via web / network interfaces.
yes, pretty much. the two-sided remote was a horrid design and difficult for most people to use...
I will elaborate a little more on the "minor functional differences" when I comb through the manuals a bit more... but it's subtle things, like for example the DYN EQ/VOL button on the new remote now cycles between the Day/Evening/Midnight settings for Dynamic Volume, whereas on the older units you could only change this setting by entering the OSD/GUI.
Setup Guide and FAQ
post #8 of 5105 Old 05-27-2010, 06:01 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 1798 Post(s)
Liked: 1705
In summary, the single HDMI cable that folks currently have going from the AVR to the TV is all you would need for audio to return from the TV back to the AVR, however, both the AVR and the TV must be HDMI 1.4 compliant for the ARC feature to work correctly.
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer for AVRs, Speakers, etc.
Daily 8am – 8pm EST (Sat/Sun too if you leave message)
Call for pricing - Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is offline
post #9 of 5105 Old 05-27-2010, 07:41 AM - Thread Starter
GotHDTV?'s Avatar
Originally Posted by Jason@C&C View Post
Not to rain on your efforts here, but I think this should probably be two different threads.
Yeah, I initally started this because these were the only HD radio receivers, but it may be too late now to separate.....so I made it worse by add the other models (as other have suggested).
GotHDTV? is offline
post #10 of 5105 Old 05-27-2010, 07:45 AM - Thread Starter
GotHDTV?'s Avatar
ADDITIONS:
SUBTRACTIONS:
Also looks like the AVR-2310ci does NOT have HD Radio like the AVR-2311ci does, but maybe you think that is minor. It is the reason why I'm upgrading (besides needing a TrueHD and DTSHDMA receiver) and I finally get my all in one unit.
GotHDTV? is offline
post #11 of 5105 Old 05-27-2010, 07:49 AM - Thread Starter
GotHDTV?'s Avatar
if it's going to be the official thread, the 791 (twin to the 1911) and 891 (twin to the 2311) need to be added.
I'm OK with combining several Denon models into one "official" thread as there isn't THAT much functional difference among the low level models... it would be better in sense to consolidate the information and questions. Frankly, I'd be fine having one thread for ALL non-networked models (2311 and down) just to keep the info consolidated....
GotHDTV? - are you OK with the "thread starter" responsibility? you should be prepared to update your first post (e.g. including 791 and 891) with updated info as time rolls on.... I can reserve this post for a FAQ and stuff....
I like said, I was initally just putting the HD radio receivers together (I though those were the same, but one was higher end), but you convinced be to add the other too. Great, now I have to watch over 4 receivers.
GotHDTV? is offline
post #12 of 5105 Old 05-27-2010, 07:53 AM - Thread Starter
GotHDTV?'s Avatar
Not quite. Did I mention HD Radio which the AVR-1911 has? Unfortunately, the AVR-1911 has lower wattage then the AVR-791.
GotHDTV? is offline
post #13 of 5105 Old 05-27-2010, 08:07 AM
Buck1320's Avatar
I noticed on the Denon website that the wattage ratings are specified at different ohms, one at 6 ohms and the other at 8. Does anyone know why? Is that normal?
Buck1320 is offline
post #14 of 5105 Old 05-27-2010, 08:34 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1705
They both have the same wattage, it's just that the 4 digit model is posted at 8 ohm and .08 THD and the 3 digit models are posted at 6 ohm and .70 THD which results in higher wattage. As the 3 digit models are generally considered the "consumer" versions, by using the 6 ohm spec it appears to the average consumer that it has a higher total wattage. This is why if this thread is to be the "official" thread it would be better if you posted the differences between the 3 and 4 digit models as well as differences from their predecessors from last year in your 1st post. See bp's threads from last year's models for a good layout of questions and answers.
In the Denon Owner manuals, both the 8 ohm and 6 ohm specs are posted and in the past Denon has used the 8 ohm number for total wattage on both the 4 digit and 3 digit models for marketing purposes. Using the 6 ohm number is simply a marketing ploy to selling more "consumer" branded 3 digit models (which Best Buy now also posts on their website). AFAIK, there has been no change in actual wattage from last year's models to the 2011 models (ie 1610/590/1611/591 = 75W; 1910/790/1911/791 = 90W; 2310/890/2311/891 = 105W; 3310/990/3311/991 = 120W).
post #15 of 5105 Old 05-27-2010, 09:53 AM
Buck1320's Avatar
The more traditional is 8 ohms, however, using the 6 ohm number allows them to print a higher wattage (the lower the impedance, the higher the wattage) .... it's a marketing gimmick. AFAIK there has been no change in actual wattage from last year's models to the 2011 models.
I don't mean to dwell on this, but does anyone know why they would measure the wattage differently, thus making the three digit model appear to have more power than the four digit model at first glance? I would think it would be the other way around...
Also, is there a simple conversion to find out what an amplifier's output will be when impedance changes? Something to the effect of, "If an amp puts out 90 watts at 8 ohms, it's output at 6 ohms would be 'x' watts," or is the conversion more complicated than I'm making it seem?
Buck1320 is offline
post #16 of 5105 Old 05-27-2010, 10:05 AM
batpig's Avatar
Liked: 1555
the second I saw that they were using that 6ohm spec for the 3-digit models I had a vision of how many times we are now going to have to answer the exact same question from people wondering why one has more power than the other
MARKETING GIMMICK. period.
the key is distribution channels -- the 3-digit models are the ones sold in big box stores alongside Yamaha, which started this "game" earlier, now Denon wants to play catch-up. Basically, the 3-digit model is more likely to be seen by "ignorant" buyers who are going to be fooled by the B.S. spec, and are wondering why the $299 Yamaha has 110 watts/channel whereas the $599 Denon only has 90 w/ch and the $699 Harman Kardon has 50!
Yes, there are many electrical formulas, no need to get into that here.
I want to dampen any potential hysteria right now:
THE AMP SECTIONS ARE IDENTICAL. THE WATTAGE DIFFERENCE IS PURE MARKETING TRICKERY.
Setup Guide and FAQ
post #17 of 5105 Old 05-27-2010, 10:06 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1705
Sure ... to sell more 3 digit consumer branded models. See my edited post above.
post #18 of 5105 Old 05-27-2010, 10:08 AM
batpig's Avatar
Liked: 1555
you don't have to do the "watching over" we will take care of that.
you just have to be willing to update the first post occasionally. I will put the FAQ in post #3.
Setup Guide and FAQ
post #19 of 5105 Old 05-27-2010, 10:09 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1705
So the sooner the 1st and 2nd posts are updated with the correct information the less often we have to answer it.
post #20 of 5105 Old 05-27-2010, 12:38 PM
TVbc's Avatar
FWIW
i think the previous socalled official denon threads have been great.
ontheotherhand, new blood, different approach is welcome.
let's see what it brings. more involvement sounds good to me.
bc
iirc afaik fwiw imo
TVbc is offline
post #21 of 5105 Old 05-27-2010, 12:43 PM
TVbc's Avatar
aha, thanks. that's real important, isn't it...
thanks for the direct explanation (and thanks to batpig, too).
bc
iirc afaik fwiw imo
TVbc is offline
post #22 of 5105 Old 05-27-2010, 12:51 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1705
Yup .. there's already been one poster who picked up a new HDMI 1.4 AVR wondering why the ARC feature wouldn't work with his HDMI 1.3 TV.
post #23 of 5105 Old 05-27-2010, 01:51 PM
Sandiar's Avatar
ftw
Sandiar is offline
post #24 of 5105 Old 05-27-2010, 02:01 PM - Thread Starter
GotHDTV?'s Avatar
Thanks for creating the FAQ. I cleaned up the first post up a bit (I know you said to remove the marketing, but it looks nice). I did remove wattage reference since you all point out that they are the same with different numbers).
Yes, I'm a newbie on audio equipment, but I do plan on buying this (undecided on 1911 or 2311ci, but probably the 1911 since it's more affordable) and am excited for it. How else I'm going to learn? I'll be switching out my 10 year old HTIB Kenwood receiver for this (yeah I know you all are probably frowning on me for that equipment).
GotHDTV? is offline
post #25 of 5105 Old 05-27-2010, 02:30 PM
batpig's Avatar
Liked: 1555
we don't judge we are just here to help!
Setup Guide and FAQ
post #26 of 5105 Old 05-30-2010, 07:00 AM
molezy's Avatar
Hi everyone. Just wondering what type of speaker cable I should use when I get the denon avd 1911. I was thinking of getting the chord carnival silverscreen. I will be connecting it to a q acoustics 2000 5.1 speaker pack.
Also what kind of termination will I need to connect to the denon avr? Is it bananna plugs?
molezy is offline
post #27 of 5105 Old 05-30-2010, 07:10 AM
John McCutcheon's Avatar
I'm sure you could get something from Monoprice for much less money.
John McCutcheon is offline
post #28 of 5105 Old 05-30-2010, 09:47 AM
Cyberhog9's Avatar
Looking at the 791 with the USB port. Would I be able to plug in an external hard drive and play mp3's through the reciever? I'm way behind on all this stuff.
My old DRA 375 is being sent to the garage.
I have zero experience with newer a/v recievers.
Sorry if this is a dumb question.
Cyberhog9 is offline
post #29 of 5105 Old 05-30-2010, 01:54 PM
batpig's Avatar
Liked: 1555
there is no "special" speaker wire you need, just get the cheap stuff from monoprice.
banana plugs are strongly recommended for connecting to the back of the unit. The speaker terminals will take bare wire but it is so much easier with banana plugs; you can get those from monoprice also: http://www.monoprice.com/products/pr...seq=1&format=2
Setup Guide and FAQ
post #30 of 5105 Old 05-30-2010, 02:01 PM
batpig's Avatar
Liked: 1555
in the manual it claims that it can play music files from a connected USB drive. See pg 27 of the 1911 manual -- it will support MP3, WMA, and AAC from USB drives formatted with FAT16 or FAT32 file structures.
Setup Guide and FAQ
Denon Avr 791 Receiver , Denon Avr 1911 Receiver , Denon Avr 891 Receiver , Denon Avr 2311ci Receiver
