*OFFICIAL* Denon AVR 391 / 591 / 1611 Owner's Thread - Page 139 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #4141 of 4923 Old 02-24-2012, 10:11 AM
jdsmoothie's Avatar
Quoted: 14555 Post(s)
Liked: 6911
The purpose of Dyn EQ is to boost the bass and surround audio at volume levels below 0db. If you prefer to reduce that effect, you can set the Reference Level Offset setting to either 5db, 10db, or 15db for that particular source. The purpose of Dyn Vol is to equalize the volume so that not only loud explosions are tamed but also so that softer dialog is increased as well.
Additionally, if neither of these settings suits your needs, you're always free to just lower the surround channel volume using the button on the remote to better suit your preference without effecting the Audyssey filters.
jdsmoothie is offline
post #4142 of 4923 Old 02-24-2012, 10:47 AM
Bob Loblaw2's Avatar
Ok, just read the last response, yes, that's what I thought it did but didn't know how to express it exactly. I only use it when my wife is trying to sleep and I'm playing a game that goes from quiet conversation to loud firefights. And I don't use it otherwise because I felt it probably was at odds with whatever the creators of the content intended.
Bob Loblaw2 is offline
post #4143 of 4923 Old 02-28-2012, 06:06 PM
euphoriapt's Avatar
When i did the auto setup at the end .. appears me a message saying Cation .. Front L/R Phase .. Center Phase .. Surround L/R Phase.
What does it mean
euphoriapt is offline
post #4144 of 4923 Old 02-28-2012, 06:06 PM
euphoriapt's Avatar
What does it mean
post #4145 of 4923 Old 02-28-2012, 07:11 PM
jdsmoothie's Avatar
Liked: 6911
It means you need to check your speaker wires to ensure that they are wired correctly ... +/+ and -/- and once confirmed, you can ignore that message.
post #4146 of 4923 Old 02-28-2012, 07:28 PM
mekkerl's Avatar
Yes, these settings are remembered by input. Also note that Dyn EQ MUST be set to ON in order for Dyn Vol to be enabled as well.
Jd...are the channel level settings saved by input as well? Or do I have to save my channel level settings as a quick select?
I need my center and sub raised +4db or so, and my surrounds lowered -1 about. I thought these were saved as I watch a movie. But it seems the next time I watch a movie, like tonight, I had to go back in and make the changes.
I guess I could have my harmony remote auto hit a quick select button upon start-up if that's the only way?
mekkerl is offline
post #4147 of 4923 Old 02-28-2012, 10:07 PM - Thread Starter
batpig's Avatar
Quoted: 3693 Post(s)
Liked: 3544
yes, channel levels are global unless you use a quick select to memorize different "states".
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #4148 of 4923 Old 02-29-2012, 12:57 AM
jdsmoothie's Avatar
Liked: 6911
In addition to using a Quick Select, note you can also try adjusting the Reference Level Offset for that source to 10db to reduce the Audyssey Dyn EQ bass/surround boost which will also improve the center channel dialog.
post #4149 of 4923 Old 02-29-2012, 04:32 AM
mekkerl's Avatar
Okay, I'll re-run the auto set-up tonight, and then try the reference offset as you mentioned.
mekkerl is offline
post #4150 of 4923 Old 02-29-2012, 09:14 AM
upstate-avfan-da's Avatar
Quoted: 83 Post(s)
Liked: 41
Odd issue, this morning my wife calls to say our 55D8000 is broke
Connection is:
Scientific Atlanta DVR/CBL (TWC)
to
Denon 591
to
TV
Audio comes in but fuzzy static for picture.. everything was fine last night.
Any ideas? Source is correct but not getting "no signal" and not getting cable feed. I am thinking something is screwy where its trying to feed image from "TV" input.
Bit by the upgrade bug, limited by the WAF
upstate-avfan-da is offline
post #4151 of 4923 Old 02-29-2012, 09:19 AM
jdsmoothie's Avatar
Liked: 6911
Could be a loose HDMI cable connection or an issue with the cable box. Have her reset the cable box either via the menu or simply unplug the power cord to the cable box.
post #4152 of 4923 Old 02-29-2012, 09:35 AM
petaylor's Avatar
You could try just pluging the cable box directly into the TV and see, if it's still fuzzy.
petaylor is offline
post #4153 of 4923 Old 02-29-2012, 12:01 PM
Quoted: 83 Post(s)
Liked: 41
Thanks! That worked.... not sure why it did it.
post #4154 of 4923 Old 02-29-2012, 12:11 PM
jdsmoothie's Avatar
Liked: 6911
Great! Gotta love those easy fixes for the wife ... keeps her in a good mood.
post #4155 of 4923 Old 02-29-2012, 08:02 PM
Quoted: 83 Post(s)
Liked: 41
+++++1 hahaha
post #4156 of 4923 Old 03-01-2012, 03:36 PM
bifftannen's Avatar
Originally Posted by bifftannen View Post
Appreciate the advice. I reset the receiver. nothing fixed.
Guess I learned my lesson and will research to find a better brand for my next purchase after tossing this 591 into the garbage.
Every brand has a few defective units that get by the QA folks. You're still within the 2 year warranty period on the 591, so check Denon's website for local repair facilities in your area where you can get it repaired.
Tried resetting yet again and the problem persists. Unfortunately the closest repair shop is very far away. Not worth the drive....I'll use the defective 591 for my bedroom receiver and take this as an "opportunity" to upgrade.
I do like Denon - what's the step up for a 5.1 system Denon AVR that you guys would recommend over the 591? I'd say price max is about $500.
bifftannen is offline
post #4157 of 4923 Old 03-01-2012, 04:02 PM - Thread Starter
batpig's Avatar
Liked: 3544
at $500 the Denon 2112ci is the best current option. If you don't need the network features or analog>digital video conversion then you can save money by getting the 1712 model, which has the same audio quality (both have MultEQ XT processing).
see the xx12 thread and read through the first few posts for model comparisons and other info: http://www.avsforum.com/avs-vb/showthread.php?t=1334369
Setup Guide and FAQ
batpig is offline
post #4158 of 4923 Old 03-01-2012, 04:56 PM
bifftannen's Avatar
Thanks batpig. I'm also looking at the Onkyo TX-NR709 but this will give me a good Denon comparison point.
post #4159 of 4923 Old 03-01-2012, 05:39 PM
mekkerl's Avatar
So if I want to change the ch. level settings, and want them to stick, how do I do that?
mekkerl is offline
post #4160 of 4923 Old 03-01-2012, 06:52 PM
Quoted: 83 Post(s)
Liked: 41
Press and hold the quick select button to save everything as-is at that moment (ch level, volume, etc)
post #4161 of 4923 Old 03-01-2012, 07:06 PM
mekkerl's Avatar
Yeah, but is there a way to set these for all inputs, globally as batpig indicated?
I'd prefer not to have to hit the quick select button.
mekkerl is offline
post #4162 of 4923 Old 03-01-2012, 07:50 PM - Thread Starter
batpig's Avatar
Liked: 3544
like I said above, ch level changes ARE global unless your are using Quick Selects.
so if you don't use the quick selects, then changes you make will be retained for ALL inputs.
Setup Guide and FAQ
batpig is offline
post #4163 of 4923 Old 03-02-2012, 05:18 AM
jdsmoothie's Avatar
Liked: 6911
Yes. Ensure the "Auto Surround Mode" setting is set to ON (p. 52).
post #4164 of 4923 Old 03-03-2012, 09:49 AM
Herman Trivilino's Avatar
You have to do both. Use menu page 4-1-5. Channel Level.
Herman Trivilino is offline
post #4165 of 4923 Old 03-04-2012, 05:29 PM
col2k3's Avatar
So, I have a 1611. got it hooked to directv and a bd player and using a 5.1 system; used audyssey to set it up and got everything going, but so far I've had it turn itself off twice in 2 days; once while watching directv and once in a bdmovie. First time it happened after 45 minutes, the second one after just 5, both times I ended up with no signal on tv and I couldn't just turn it back on, but had to turn everything else off and then back in order to get it going, and both times after it happened It went back to working normally after I decided to turn it off.
What could be causing this? What should I do to troubleshoot?
For the past 3 months I had been using it in a different room just for radio and ipod with no issues
col2k3 is offline
post #4166 of 4923 Old 03-04-2012, 05:42 PM
JChin's Avatar
Quoted: 367 Post(s)
Liked: 210
Hi col2k3, suggest to check all speaker wire connections (at receiver and at speakers).
JChin is online now
post #4167 of 4923 Old 03-05-2012, 06:11 AM
col2k3's Avatar
Thanks, I just did that but found nothing wrong; and it happened again; when it happens the receiver ends up with blinking red lights.
I tried checking on the manual but couldn't find how to set the receiver to pass through all video untouched on this model (1611) could anyone help me out? want to set that in case it's something like too much bandwith for the hdmi cables I'm using or whatever, but couldn't tell what option it would be on the receiver menu.
I also tried unplugging everything for 3 minutes, and then turning everything back on, having the directv receiverreset itself and all.
So with the speaker wire connections all good, what else could be causing this.
col2k3 is offline
post #4168 of 4923 Old 03-05-2012, 07:26 PM
fhschellenberg's Avatar
Quoted: 16 Post(s)
The 1611 has no video processing cababilities, so it is always passed through untouched.
Fred
LG OLED65E6P calibrated by Chad B
Panasonic TCP-65VT25 ISF calibrated by Chad B
fhschellenberg is online now
post #4169 of 4923 Old 03-05-2012, 07:35 PM
noodleNT's Avatar
I have had the Denon AVR-591 since May 2011 and have had off and on issues with audio quality. Currently I use the AVR with my TV speakers. On day I will add surround sound but for now the TV speakers are good enough. However every now and then the audio will get very tinny and get this digital garble to it. If I power off the receiver and turn it back on the issue will stop and may not happen again for a week or more.
I have re-cabled everything with new HDMi cables but no luck. I have 3 HDMi devices going to the AVR and they all seem to do it. However, some more than others. The TV is a Panasonic TC-P54G25.
noodleNT is offline
post #4170 of 4923 Old 03-06-2012, 04:55 AM
jdsmoothie's Avatar
Liked: 6911
Not sure why you have an AVR if you're not using surround speakers? Why connect to the AVR at all when you can connect directly to the TV or an HDMI switch?
