*OFFICIAL* Denon AVR 391 / 591 / 1611 Owner's Thread - Page 160 - AVS | Home Theater Discussions And Reviews
 4Likes
post #4771 of 4787 Old 02-26-2015, 01:52 AM
richeydog's Avatar
I'm having a problem with my Denon 591. I was purchased in 04/2011. A couple of weeks ago I noticed distortion(mostly dialogue) in the center channel while playing netflix movies with my Roku 3. I did a search and I stumbled upon this thread. I seem to be having the same problem as several other people. I know I can set the Roku to stereo but I'd rather have a permanent solution. Has anyone sent their receiver to a repair center and had the decoding bug fixed?
richeydog is offline
post #4772 of 4787 Old 02-26-2015, 02:07 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3479 Post(s)
Liked: 2115
AFAIK, a firmware update has not been released to resolve this issue in the models in this thread.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #4773 of 4787 Old 02-26-2015, 07:10 AM
elinter's Avatar
Does the 1611 output the OSD via HDMI as an overlay or does it require a separate composite connection to the TV?
elinter is offline
post #4774 of 4787 Old 02-26-2015, 07:25 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2115
OSD displayed on black background over HDMI. Overlay on source feature begins with 2311CI.
post #4775 of 4787 Old 02-26-2015, 12:59 PM
richeydog's Avatar
Thanks. Even if there were a firmware update we would have to send it in to a repair center, correct? I don't think this receiver has an ethernet connection.
post #4776 of 4787 Old 02-26-2015, 01:47 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2115
Correct.
post #4777 of 4787 Old 03-05-2015, 04:18 PM
abuhafsa's Avatar
Center channel cross over at 60Hz??
I’ve had a Denon 591 receiver for over 4 years without any issues. I recently upgraded to a set of NHT superzero 2.1 speakers (satellite and center) and an SVS SB12-NSD subwoofer. After calibrating with the auto-setup, my center speaker crossover is set to 60Hz, while the satellites are set to 110hz (front) and 120hz (rear). I performed the auto setup several times with the same results. The center speaker itself sounds okay, and when I spoke to the NHT customer rep he thought the problem may be with the receiver. He suggested I manually set the cross over to 85-90 hz.
I’ve never experienced such a low center cross-over with my other speakers (Boston Acoustics and Energy Take classics).
Does anyone have any idea what’s going on? Is the receiver trying to ‘blend in’ with the better sub that I now have? How can I figure out if the issue is with the speaker or the receiver?
Any ideas or tips appreciated. Thx.
abuhafsa is offline
post #4778 of 4787 Old 03-05-2015, 04:23 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2115
What is it you think is wrong about the center speaker crossover?
post #4779 of 4787 Old 03-05-2015, 04:34 PM
abuhafsa's Avatar
Well, the speaker is rated at 85Hz - 20kHz at -3dB, so isn't it going to muddy the midrange if it tries to reproduce frequencies below 85Hz instead of the sub?
abuhafsa is offline
post #4780 of 4787 Old 03-05-2015, 04:47 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2115
How the speaker is rated in the mfr's environment and how it reacts in your room can be different. If you prefer to raise the crossover, then do so.
post #4781 of 4787 Old 03-15-2015, 01:15 AM
sk280's Avatar
Hello AVR591 owners,
I recently purchased an excellent condition AVR591 here in Australia with model# AVR1611. I seem to have a major issue with the volume. I have to raise the master volume to atleast 50 before I can hear any sound from the receiver. This seems to be case for HDMI and analog connections. I thought it was Audessey and did a microprocessor reset (off + surround buttons + on), still the same.
Having said this, when I increase the volume to 65, it does get loud and I can hear every detail. When using settings set by Audessey, its a lot better except for the volume which is too low. Any suggestions will be greatly appreciated.
sk280 is offline
post #4782 of 4787 Old 03-15-2015, 06:18 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2115
There's nothing wrong with your volume control. Denon AVRs use a logarithmic volume control such that average volume is 50-70.
post #4783 of 4787 Old 03-15-2015, 08:22 AM
JChin's Avatar
Quoted: 176 Post(s)
Liked: 150
Hi sk280, maybe you selected "no" to Dynamic Volume at end of setup. Try changing Dynamic Volume to Evening and set Reference Level Offset to 10 or 15 dB.
Dynamic Volume and Reference Level Offset can be found under Audyssey Settings in Audio Adjust menu.
120inna55 likes this.
JChin is offline
post #4784 of 4787 Old 03-16-2015, 12:09 AM
sk280's Avatar
Thanks jdsmoothie. I googled logarithmic volume and found this to be the case.
I have decent floor standing speakers, 91dB sensitivity. Music is not great with this Denon 591.
However, identical speakers when played using my Vintage denon legacy stereo amplifier with cd played from my vintage Akai cd player in cd direct mode sounds fantastic. More detail, effortless, joy to hear.
I can't believe there is so much difference in clarity. All along, I thought all Amps sound the same. Time to sell the 591.
Regards
sk280 is offline
post #4785 of 4787 Old 03-16-2015, 12:11 AM
sk280's Avatar
Thanks jchin. I will reset the microprocessor, rerun audessey and try this again.
sk280 is offline
post #4786 of 4787 Old Today, 05:55 PM
dpeters11's Avatar
I'm not sure when or how this happened, but I noticed that I'm no longer getting a display on my 591, on the receiver itself. If I do anything like changing the volume it comes up for a few seconds, then goes off.
I'm assuming it's a setting that got modified, but not sure what.
dpeters11 is online now
post #4787 of 4787 Old Today, 06:15 PM
585-645-1006
jdsmoothie's Avatar
Liked: 2115
On a higher level model, this issue would be caused by selecting the PURE DIRECT mode, but the 591 doesn't have this feature, rather the front panel is either ON or OFF. Check the Display setting (p. 50) and try a different setting.
