*OFFICIAL* Denon AVR 391 / 591 / 1611 Owner's Thread - Page 163 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #4861 of 4887 Old 09-23-2015, 09:46 AM
Adult Beverage's Avatar
Quoted: 38 Post(s)
Liked: 26
Also try powering off and unplugging the 591 for about 10 minutes. Then power on the TV, wait 4-5 seconds, the 591, wait 4-5 seconds, then the cable box/BDP. Also ensure on the 591, the "Decode Mode" is set to "Auto" and not "PCM."
Thanks. Will try all that tonight as well. To add to my uncertainty, I found the following about the BR player I'm using. Hope it isn't trying to be too smart and causing the problem. If the 591 Input Mode and Decode Mode are both set to AUTO the player should be bitstreaming I believe.
Auto is Sony's way to indicate it will check the content, then check the destination and if they agree it sends the content as presented. So if you are plugged into a TV with 2ch audio, that is what the BD player sends. If the AVR accepts DTS-MA, it will send that. When sending PCM only, most devices get sent DD 2.0, but not always.
Infamous last words: "Hold my beer. Watch this!"
Adult Beverage is offline
post #4862 of 4887 Old 09-24-2015, 06:57 PM
Quoted: 38 Post(s)
Liked: 26
Since I had been through the settings on everything at least three times, I tried the above recommendation first. Everything was back to normal. Guess I can put the hammer away.........
b5fan001 likes this.
post #4863 of 4887 Old 09-30-2015, 02:59 PM
hikeskool's Avatar
Good afternoon all.
I am having what looks to be a rather common problem some other users are experiencing. I can hear audio when using “all HDMI” but I can’t see any picture when using this receiver. Here is my gear:
Samsung PN50C550 monitor
Denon AVR-591
Standard AT&T U-Verse DVR
Sony BDP-S570 BD player
Polk RTi A7 (x2)
Polk PSW125 subwoofer
Previously, I had used this Denon unit to pass audio from my PC via a 3.5mm minijack/RCA adapter to two Polk RTi A7s and the Polk PSW125 subwoofer. I have had no issues with the audio. However, I bought this receiver knowing one day I would like to use it to switch between multiple sources using audio AND video.
I have performed the “soft reset” by unplugging everything for ten minutes (overnight, actually) and have also reset the receiver by holding down the three face buttons. Neither worked. The cables I have used have worked fine in previous applications (I am using decent-quality Monoprice cables) but I tried other cables (which also work in other applications) and those do not work either. Of course, the U-Verse box and the BD player both work fine via HDMI when plugged directly into the Samsung TV. I have tried using multiple HDMI inputs on my TV as well as multiple inputs on the receiver, same story: I get audio but no video.
So what is the deal here, am I screwed? Is this some HDCP nonsense? I can’t blame JUST the Sony BD or JUST the U-Verse box because both exhibit the same symptoms: no video. Hell, I can’t even get any of the OSD stuff to display from the receiver to the TV since I simply can’t get ANY video output from the receiver to the TV using HDMI.
I am at a loss here. I have had this receiver for a while now and I know it was made in ~2010. I know I bought the BD player a couple years after I bought the receiver and surely the U-Verse box is newer than the receiver as well. Unfortunately, I have no other HDMI receivers to test with (or any other receivers at all, actually). So what do I do? Is there a way to pass video through this receiver using anything but HDMI?
I MIGHT be able to pass JUST audio from the U-Verse box and BD to the receiver and pipe separate video from these same components directly to the TV. But this is a huge PITA and complicates what SHOULD be a simple “plug-and-play” operation. My setup could not be any simpler.
Thank you for your help. This is incredibly frustrating. My setup is far from complicated (one TV, one receiver, two speakers, one subwoofer, a cable box, and a BD player; all HDMI, preferably). I thought as a community we gave up (had shoved down our throats; please pardon my cynicism) “a little bit” of freedom by accepting HDCP as an everyday thing but gained the convenience of “just using one plug” to hook everything up. At least in my case, it looks like it will not be that simple.
hikeskool is offline
post #4864 of 4887 Old 09-30-2015, 08:08 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 7311 Post(s)
Liked: 3365
Originally Posted by hikeskool View Post
Good afternoon all.
Denon AVR-591
Polk RTi A7 (x2)
Not sure what "3" buttons you held down, as there are only "2" buttons to hold down as noted in the Owner's manual and image below. The power button is simply depressed and released.
If still no joy, I would suggest connecting the AVR to another TV (take it to a neighbor's house if you have to connecting to ideally other than a Samsung TV) to see if the issue is with the Samsung TV.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
Authorized dealer: Denon, Marantz, Yamaha, Onkyo, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is offline
post #4865 of 4887 Old 09-30-2015, 08:15 PM
hikeskool's Avatar
Yes, thank you. I went through that process and nothing helped. I will try to find another television to test the receiver.
Assuming I have no success with another television, what might be the problem? Thanks again.
post #4866 of 4887 Old 09-30-2015, 08:18 PM
585-645-1006
jdsmoothie's Avatar
Liked: 3365
Possibly the HDMI board went bad. Hard to say.
post #4867 of 4887 Old 09-30-2015, 08:20 PM
hikeskool's Avatar
HDMI board? On the receiver, I assume?
post #4868 of 4887 Old 09-30-2015, 08:22 PM
585-645-1006
jdsmoothie's Avatar
Liked: 3365
Yes.
post #4869 of 4887 Old 09-30-2015, 08:27 PM
hikeskool's Avatar
Yes.
There is probably no way to economically get this diagnosed or repaired, I assume.
post #4870 of 4887 Old 10-01-2015, 07:35 PM
585-645-1006
jdsmoothie's Avatar
Liked: 3365
Correct. Replacing the HDMI board (if available) would likely cost as much as what you paid for the AVR.
post #4871 of 4887 Old 10-05-2015, 02:53 PM
Liked: 0
1611 Display Not Working
The display on my 1611 stopped working the other day. The green light still turns on when I power it up. I have tried the dimmer feature and resetting the motherboard and no luck.
Is the screen shot? Did it over heat and cause some solder to melt? or is there a fuse for the display somewhere? Thanks in advance for the help!!
weiss21 is offline
post #4872 of 4887 Old 10-05-2015, 03:00 PM
Liked: 0
sorry, Microprocessor not motherboard
weiss21 is offline
post #4873 of 4887 Old 10-05-2015, 03:12 PM
585-645-1006
jdsmoothie's Avatar
Liked: 3365
The issue has cropped up on a few other models requiring repair.
post #4874 of 4887 Old 10-28-2015, 04:10 PM
sometown's Avatar
Question Replacing My MCS 95 Sub from this system
I loved this system until the Sub stopped working. I'm looking to buy a simple replacement for it, and I was wondering if this would work:
http://www.parts-express.com/dayton-...oofer--300-628
With a splitter, I could still run from the the Sub Pre-out on the 591 to the RCA Line In on the Dayton, right? Would it still work with the Audyssey set-up?
Any thoughts welcome. Thanks in Advance.
sometown is offline
post #4875 of 4887 Old 10-28-2015, 09:43 PM
Herman Trivilino's Avatar
Have you checked to see if the problem is with the sub or with the receiver?
My sub has the same RCA input jacks and it works just fine hooked up that way. Set the level at 50% on the sub and then after running Audyssey check to make sure the level didn't max out at 10 on the Denon. If it did, raise level on sub and run Audyssey again.
Herman Trivilino is offline
post #4876 of 4887 Old 10-29-2015, 04:46 AM
585-645-1006
jdsmoothie's Avatar
Liked: 3365
Before replacing your sub ... what have you done to determine if the issue is really with the sub? With the sub powered on, remove the cable from the 591 sub pre-out and rub your finger over the tip. Hear static? If not, then either the sub or the cable itself has gone bad. Try replacing the cable (you can use a regular rca red/white cable as a test). Still hear no static? Then it is the sub.
Before replacing the sub, the article below seems to describe a possible way to fix the sub if your issue is similar ...
http://www.fixya.com/support/t107541...won_39_t_power
If the above does not work for you, then the Dayton sub should work, however read the Owner's manual to determine if you need to use a splitter or can simply connect to the "L" input on the Dayton which is true with many subs (ie. dual input may not be required). Also no reason it shouldn't work any different than your current sub regarding Audyssey setup. Set the gain on the sub to about 10 o'clock prior to running Audyssey. As long as the sub isn't set to -12db, you're good to go, otherwise, if set to -12db, lower the sub gain to about 8 or 9 o'clock and run Audyssey again until the sub level results in < -12db. Once the Audyssey settings have been stored, most find the sub to be a little weak, so you'll want to go into Manual Setup - Test Tones and bump the sub up about +5db (eg. if set to -7db after Audyssey, raise to -2db).
post #4877 of 4887 Old 10-29-2015, 10:26 AM
sometown's Avatar
So, I had already removed the panel and determined that the Z3 diode is fried, but I don't have any soldering tools and probably not enough patience! That's why I'm thinking of going with replacement. Thanks!
sometown is offline
post #4878 of 4887 Old 10-29-2015, 10:35 AM
sometown's Avatar
Thanks for this, yeah, the sub won't power on, so I removed the rear panel and could see brownish (burn?) marks under the Z3 diode.
sometown is offline
post #4879 of 4887 Old 10-29-2015, 05:51 PM
Call the place you're buying the sub from. They have excellent customer service and may be able to sell you a replacement amplifier for your sub. Perhaps no soldering is required to replace it. Unless the sub is old and the foam surround is failing.
post #4880 of 4887 Old 11-07-2015, 09:38 AM
pawel.brajczewsk's Avatar
Liked: 0
Hello. I was reading this tread find some answers but still I have some doubs about my system. I Have an denon AVR1611 I have connected an 2 main 4 ohm speakers (Jamo classic 6) and and center 8 ohm. I’m have a small room and maximum loudness I have used is around 40% of volume . Is this configuration is safe the for my avr and speakers. I’m thinking about connecting surrounds with will hav the also 8 ohm. What do you think about my system? Thanks in advance
Wysłane z mojego SM-N910F przy użyciu Tapatalka
pawel.brajczewsk is offline
post #4881 of 4887 Old 11-07-2015, 10:03 PM
585-645-1006
jdsmoothie's Avatar
Liked: 3365
If the 1611 isn't shutting down in protection mode, then yes, it is safe.
pawel.brajczewsk likes this.
post #4882 of 4887 Old 11-08-2015, 01:01 AM
Liked: 0
Denon is working sometimes 4-8 h daily. I watch TV and films from PC in mkv(DD and DTS). I have run this configuration about 3 weeks from now. So do you think that could something wrong with Avr or the speakers are no 100% of 4 ohm?
post #4883 of 4887 Old 11-09-2015, 06:28 AM
585-645-1006
jdsmoothie's Avatar
Liked: 3365
There should be no problem mixing 4-ohm speakers with 8-ohm speakers.
post #4884 of 4887 Old 11-10-2015, 02:43 PM
Liked: 0
Thanks for your opinion
post #4885 of 4887 Old 11-20-2015, 09:50 PM
abuhafsa's Avatar
Farewell
I ended up selling my Denon 591 today that I've loved and enjoyed for 4+ years, and upgraded to a Yamaha Aventage RX-A750 for an amazing price of $399. I'll be getting it on Monday 11/23.
I'm curious how the YPAO compared to Audessey.
Thanks to everyone on this thread for their tips, help, and advice!
abuhafsa is offline
post #4886 of 4887 Old 11-25-2015, 06:54 AM
abuhafsa's Avatar
Update:
I ended up absolutely hating the Yamaha RX-A750BL. Sounded dull with poor imaging. Dialog came out unnatural and 'metallic'. Calibrated using YPAO and tried all of their settings including Cinema DSP 3D but sounded worse than the 591 to my ears.
So I ended up exchanging it for a Denon X1200W for $29 more - and Wow! The difference is like night and day. The Audyssey XT did a really good job. Now the dialog is crisp and natural and the bass is smooth and punchy!
I'd always wondered if Audyssey was a gimmick but this experience confirms it isn't. The Denon + Audyssey combo is a differentiator in my book. I plan to stick with Denon from now on.
abuhafsa is offline
post #4887 of 4887 Old 11-25-2015, 10:39 AM
dsskid's Avatar
Quoted: 239 Post(s)
Liked: 251
Update:
goodbye....and welcome back.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #4888 of 4887 Old 11-26-2015, 12:29 PM
Liked: 0
Hi everyone !!!
Does anyone knows what are the difference between modes 1, 2 and 3 in RESTORE mode for Denos AVR 1611??
Same for Dynamic Volume modes Day, Night ane Evening.
I am looking for some sort of frequency response,explanation ot whatever help me understand how to use these functions.
I used to set ON both Dynamic volume and RESTORE as well, but I have finally realizad that it was better to use only RESTORER. Al leas for my personal like , it was the best way to use my AVR1611.
Thank you !!!
Osvaldopeni is offline
