*OFFICIAL* Denon AVR 391 / 591 / 1611 Owner's Thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #901 of 4911 Old 10-08-2010, 07:05 PM
mwok's Avatar
How would I tell the HTPC to just pass it/bitstream directly to the receiver? Is there a setting in the HDMI audio device?
mwok is offline
post #902 of 4911 Old 10-08-2010, 08:15 PM
jdsmoothie's Avatar
Quoted: 12214 Post(s)
Liked: 5561
You'll need to read your HTPC Owner's manual to learn what settings are even available on the video/audio card installed. It will either allow for bitstreaming or it won't (ie PCM setting only). Depending on the age of your HTPC, many older units cannot bitstream.
jdsmoothie is online now
post #903 of 4911 Old 10-08-2010, 08:25 PM
mwok's Avatar
Mine is a Intel DH57JG with Core i3 530 processor (onboard Intel IGP, audio, ethernet). These support bit-stream but how do I tell it to decode on the receiver side? With my old speakers (the sub had it's own controller dac), I can send the audio via digital (toslink) and the sub would decode it.
mwok is offline
post #904 of 4911 Old 10-08-2010, 08:39 PM
jdsmoothie's Avatar
Liked: 5561
Seems to still be a little confusion ..... compressed audio (ie DD, DTS, Dolby True HD, DTS-HD MA) must be uncompressed to PCM to play via the speakers. That uncompression either occurs at the component level (ie HTPC or BDP) or at the AVR. If it happens at the HTPC and is sent as PCM, the AVR simply plays it as is. If the HTPC sends it uncompressed, the AVR cannot play it and then must uncompress it to PCM at it's end first. Set your HTPC to "bitstream" and the AVR to STANDARD surround mode and you should be good to go.
post #905 of 4911 Old 10-08-2010, 09:21 PM
mwok's Avatar
Okay, setting the receiver in standard mode means pressing the "D/ST" button on the remote so it says "DIRECT" on the receiver right?
It sounds horrible compared to whatever surround encoding it was doing. "MULTI IN" mode sounds way better, so how come the direct signal sounds worse than the "equalized" one?
mwok is offline
post #906 of 4911 Old 10-08-2010, 09:29 PM
jdsmoothie's Avatar
Liked: 5561
Wow .. you're really making this more difficult then it needs to be ....
You set the STANDARD surround mode by pressing the "STANDARD" button on the remote. In this mode it will either play the decoded audio (ie PCM) or decode and play the bitstream audio.
Right next to that button is the D/ST button which stands for Direct/STEREO. In DIRECT mode there is no EQ processing which is why it doesn't sound as good as when you are using Audyssey. Now you know why it was better to get a model that included Audyssey rather than not, like the 391.
post #907 of 4911 Old 10-08-2010, 09:32 PM
Herman Trivilino's Avatar
Despite it being a bit dated, this article does a nice job of explaining the difference between PCM audio tracks and compressed bitstreams.
http://forum.ecoustics.com/bbs/messa...79/464956.html
Herman Trivilino is offline
post #908 of 4911 Old 10-09-2010, 07:00 AM
mwok's Avatar
Ah okay. Is there any true 5.1 music?
Also, can I leave my receiver on 24/7 (most of the time, it wil be idle)? Everytime I turned it off, there is a loud "click".
I'm now upto 5 remotes, time to invest in a harmony remote.
mwok is offline
post #909 of 4911 Old 10-09-2010, 08:52 AM
chris.woodard's Avatar
Hey guys,
So tried the switch with a known good hdmi on the blu ray and receiver still a no go, it is really strange if i put a blu ray in the player it will play but video will drop out. Any settings I need to change on the receiver?
Thanks again!
chris.woodard is offline
post #910 of 4911 Old 10-09-2010, 08:59 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Originally Posted by chris.woodard View Post
Hey guys,
Thanks again!
Hi Chris, check and make sure the BD player has the lastest firmware update.
JChin is offline
post #911 of 4911 Old 10-09-2010, 10:04 AM
Hey Jchin,
Thanks for the info, I will try that once I get home. Working all weekend is the pits.
post #912 of 4911 Old 10-09-2010, 03:58 PM
mwok's Avatar
When I run the audssey setup, why does it say this in the first step?
Caution
Center:Phase
Retry
Skip
Cancel
Also, where exactly is the IR sensor on the 591? I tried placing the IR repeater emitter at a variety of places on the LCD but it does not pick up when it is attached directly.
mwok is offline
post #913 of 4911 Old 10-09-2010, 05:29 PM
jdsmoothie's Avatar
Liked: 5561
The AVR is detecting your "Center" speaker is out of phase, which can occur when the speaker wires are reversed or sometimes it's just the way the speaker is mfr'd. Check to make sure you have connected the speaker wires correctly. If yes, then simply press "SKIP" and move on to the next speaker.
If you look on p. 60 of your Owner's manual, you'll note that the IR sensor is shown located in the upper left corner of the front panel display.
post #914 of 4911 Old 10-09-2010, 05:33 PM
mwok's Avatar
I double checked the wires and they are wired correctly. If they are manufactured this way, isn't that a defect? Will it affect the sound in any way?
mwok is offline
post #915 of 4911 Old 10-09-2010, 05:47 PM
jdsmoothie's Avatar
Liked: 5561
Possible, but not probable. Sometimes just moving the speaker to a new position will show it as out of phase. This reading is quite common. Simply press "SKIP" and move on.
post #916 of 4911 Old 10-09-2010, 06:17 PM
Okay so update, I have installed the latest firmware but still having issues. I connected the blu ray to my tv and reset it.
I can get it to display 1080i but not 1080p, when hitting 1080p for test setup. the screen will flash to the test page then drop out. I can get it to do 1080p on the tv ( sony bravia 55inch 240hz)
So back to the drawing board, should i reset the denon?
post #917 of 4911 Old 10-09-2010, 06:22 PM
iliabol's Avatar
I just hooked up avr-591 to all my HDMI sources and output to TV, but no video shows on TV, no menues, nothing. Anybody know what the problem could be?
iliabol is offline
post #918 of 4911 Old 10-09-2010, 06:36 PM
mwok's Avatar
1) When I set the input to HTPC or XBOX, how do I get the volume to show up on the display?
2) Is there some sort of third party display module I can plugin that will display the info from the receiver (like volume info etc)?
3) I can't bring up the menu without pressing Source Select first? Why is this?
4) I'm having some terrible interference from the TV with the IR repeater. I turned off the TV energy saving feature and it immediately starts to work HOWEVER, during commercials, the IR repeater gets "stuck" again due to interference. Why can't they use some other type of technology like bluetooth!
mwok is offline
post #919 of 4911 Old 10-09-2010, 07:18 PM
jdsmoothie's Avatar
Liked: 5561
I would suggest you both Reset the microprocessor (p. 70).
post #920 of 4911 Old 10-09-2010, 07:23 PM
jdsmoothie's Avatar
Liked: 5561
1. Unless it's a feature of your TV, the lowest level model that displays volume over HDMI is the 2311 or 891.
2. Not that I am aware of.
3. You should be able to bring it up by pressing AMP first, then MENU, otherwise the AVR thinks you are trying to bring up the menu of the component you have selected.
4. Unfortunately this can be a problem with some HDTVs. You might want to try a different remote.
post #921 of 4911 Old 10-09-2010, 07:57 PM
mwok's Avatar
The thing is that it displays the volume on TV IF I select the Squeezebox (only output digital coax) but it does not display volume if I select XBOX or HTPC.
Since my receiver is out of sight, I guess I have to set the individual volume settings on over 5 devices and pray that someone doesn't accidentally set the volume to 100%. This is pure bs by Denon.
mwok is offline
post #922 of 4911 Old 10-09-2010, 08:20 PM
jdsmoothie's Avatar
Liked: 5561
Most buyers with a volume display requirement generally just upgrade to the 2311 or 891.
post #923 of 4911 Old 10-09-2010, 08:56 PM
Is the input set correctly on the TV?
post #924 of 4911 Old 10-09-2010, 09:09 PM
Huhh?! I've debated placing my receiver out of sight, but decided against it. The information displayed on the front panel is just too valuable to me to hide from my sight. I want to be able to tell at a glance what my receiver is doing.
I used to have it positioned on a shelf below my TV, but had to move it recently to make room for a new center channel speaker. There was a huge WAF issue when I placed it on top of the entertainment center, but it is now surrounded by appropriate decor restoring peace to the household.
post #925 of 4911 Old 10-09-2010, 09:18 PM
I've never understood the value of a volume display. I can tell how loud it is without looking.
post #926 of 4911 Old 10-10-2010, 12:48 AM
bsevern's Avatar
I'm having a difficult time deciding between the Onkyo TX-SR606 or the Denon AVR-1611.
I've read so much about both units that analysis paralysis is sinking in
I'm planning to run the AVR to a Mitsubishi 65" 3D HD DLP, and use either a PS3 or a LG BX580 for my BD & 3D source. I have a set of Atlantic Technology speakers. It seems that the Denon would be a more then capable AVR for my needs.
I read a lot of complaints that the Onkyo degrades the HDMI video output, due to "video processing" but I assume since there's no video processing on the Denon this would never be the case?
Anything else that would make the Denon stand out from the Onkyo?
TIA,
Brian
bsevern is offline
post #927 of 4911 Old 10-10-2010, 01:24 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
TIA,
Brian
Hi Brian, I think it's sinking in .
The big advantage Denon over Onkyo is it handles 3D video and it does Audyssey MultEQ (6 position instead of 3 - 2EQ).
Maybe its a misprint and you meant Onkyo TX-SR608.
JChin is offline
post #928 of 4911 Old 10-10-2010, 07:40 AM
iliabol's Avatar
Yes, I set one of the HDMI inputs on TV to receiver, and I tried to reset microprocessor on avr - doesn't help either.
iliabol is offline
post #929 of 4911 Old 10-10-2010, 08:29 AM
jdsmoothie's Avatar
Liked: 5561
Try unplugging the AVR for about 30 minutes and then do the reset the microprocessor procedure again after plugging it back in. You also might want to try different HDMI cables. If still no joy, give the vendor a call for an exchange.
post #930 of 4911 Old 10-10-2010, 09:02 AM
mwok's Avatar
Even though the input is set correctly, are you sure the input is ASSIGNED correctly? For an example, you could have connected an HDMI cable to DVD port BUT the actual DVD input signal assigned could be from Game port.
mwok is offline
