Pioneer VSX-1120 TXH HDMI V1.4 Receiver Owners' Thread - Page 169 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #5041 of 5052 Old 11-29-2014, 01:09 PM
ToomeyK's Avatar
Connecting receiver to network
Hello,
I'm trying to connect my receiver to my home network which requires a password. When I go through the system setup menu, to network settings, the default selection is to use DHCP which i fine since my router supports that. There's no place to input a password and naturally, my receiver isn't connected my network.
What am I missing?
Kevin
ToomeyK is offline
post #5042 of 5052 Old 11-30-2014, 08:23 AM
mogrub's Avatar
Quoted: 202 Post(s)
Liked: 172
Check your ethernet cable. Are you sure your home network requires a password for wired connections? That's usually reserved for wireless.
Every once in a while, quite inexplicably, things actually go according to plan.
mogrub is offline
post #5043 of 5052 Old 02-28-2015, 02:17 AM
vath's Avatar
Originally Posted by howzz1854 View Post
my guess is your center is colored to begin with. if your main L/R are less colored, you can tell MCACC to calibrate according to FRONTS. there're three options of auto calibration. "all channel", "FRONTS", or "opposites". in this case if your fronts are less colored, i would calibrate to the fronts. all channel in this case will just make your fronts sound tinier and more shrilling.
try that and report back.
I'm gonna have to try this too....
vath is offline
post #5044 of 5052 Old 02-28-2015, 02:28 AM
ki11abee's Avatar
had this receiver for like 3 years or so working flawlessly. Just bought a TV that supports ARC and decided to use it. Now when my harmony one starts the sequence of powering on everything like it used to, the receiver always goes to the display selection instead of the HDMI 1 that it needs to be at. Why does it keep doing it, when i shut it off it neevr was on that source of display, it was on what it was supposed to be on. I hit help on remote and redoes the whole sequence and then it works. Why?
ki11abee is offline
post #5045 of 5052 Old 06-12-2015, 01:28 PM
Danabw's Avatar
Quoted: 58 Post(s)
Liked: 39
I've just purchased a 4K TV.
Currently I'm running all inputs into the receiver and feeding out to my current TV via a single HDMI cable into the TV's primary HDMI port.
As far as I can tell there isn't very much 4K content, other than some streaming from Netflix or YouTube. We connect our Roku to the receiver via HDMI and then route from the receiver to the TV.
Will the receiver be able to passthrough 4K signals unaltered?
Appreciate any help on this.
Thanks, still loving this little receiver that could.
Danabw is offline
post #5046 of 5052 Old 06-12-2015, 07:25 PM
hernanu's Avatar
Quoted: 323 Post(s)
Liked: 715
It won't pass 4K signals at all.
It's not an issue now, though, since there are no signal sources that produce it. Once 4K bluray players come out, as an example, then you may need a new AVR with 4K processing.
Alternatively, if a 4K bluray has two HDMI Outputs, you could have one go directly to the screen for video, and another HDMI connector to the AVR just for sound.
As far as 4K streaming, which is the only way to get 4K now, just run a digital SPDIF cable (optical or coax) from the TV to the AVR to get the sound.
Danabw likes this.
hernanu is offline
post #5047 of 5052 Old 06-12-2015, 09:12 PM
Danabw's Avatar
Quoted: 58 Post(s)
Liked: 39
So you're saying that I should stream Netflix via the built-in TV app, and send the audio from the TV to the receiver, rather than using the Roku. Thank you.
Sent from my SCH-I545 using Tapatalk
Danabw is offline
post #5048 of 5052 Old 06-15-2015, 09:22 AM
hernanu's Avatar
Quoted: 323 Post(s)
Liked: 715
I would unless you have two HDMI outputs on the Roku: one a reliable HDMI 2.0 output to go to the display, another to go the the AVR for sound.
hernanu is offline
post #5049 of 5052 Old Yesterday, 05:27 PM
curtishd's Avatar
Quoted: 39 Post(s)
I am trying to do a few thing but am having some difficulty so any advise would help.
I have a 7.1 set up.
Questions:
1. How do I get the back 2 rear surround speakers to play from a 5.1 source? When I push the THX button I only get THX cinema, THX music or THX game and NOT the setting THX Surround EX which is what I need (I think) to play 5.1 up to 7.1
2. What does the THX audio setting for: SBch Processing do? The choices are Auto or Manual. I assume it's for the surround back channels but I'm unsure as to what each setting does. I have tried both setting and it doesn't seem to change anything (and I still don't get the option of THX Surround EX).
3. If I were to add the two front height speakers is there a setting that plays all 9.1 speakers at the same time in the mix?
curtishd is online now
post #5050 of 5052 Old Yesterday, 07:31 PM
HopefulFred's Avatar
Quoted: 350 Post(s)
Liked: 303
1 - engage PLIIx http://www.dolby.com/us/en/technolog...logic-iix.html
2 - I don't know. Probably just forces the second order 80Hz crossover.
3 - Nope. There are only 7 amps and 8 (7 plus sub) processing channels in the box.
HopefulFred is online now
post #5051 of 5052 Old Yesterday, 09:04 PM
curtishd's Avatar
Quoted: 39 Post(s)
I can't even get PLIIx... I just get options like sci-fi, music, hall and so on and for THX I get cinema, music or game but thats it. I have my system set to "B" for the 7.1 set up according to the on screen graphic.
post #5052 of 5052 Old Today, 02:45 PM
Quoted: 350 Post(s)
Liked: 303
I don't use those features in my setup, so I had to look it up. You're pressing the wrong button. http://www.pioneerelectronics.com/St...ctions1015.pdf (scroll to pg 48 and 49.)
While listening to a multichannel source, press "RECEIVER" then "STANDARD (STANDARD SURROUND)" If necessary, press repeatedly to select a surround mode. (That means, press standard multiple times to scroll through the options.) If you press "ADV SURR" you get "Action" Drama" "Sci-Fi" etc.
