Yamaha RX-V765 Won't stay on - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-05-2010, 11:58 AM - Thread Starter
jholst's Avatar
About a week ago my RX-V765 started to shut down about 5 seconds after pressing the power button. I checked the speaker wires for shorts and checked the speaker impedance setting per the manual. Also, I have tried disconnecting all the speaker, HDMI, other cables -- same result. After three attempts the receiver will not turn on at all until the receiver is unplugged from the outlet and plugged back in. The same problem still occurs.
When it first started happening, after a few attempts it would stay on. Once it stayed on everything worked fine and it would not shut down even after leaving on for a day. There were never any messages on the display to check something. As week went on, it took more attempts to get it to stay powered on. Now, it will not stay on no matter how many times you try to press the power button.
I have had this receiver less then a year and am surprised this is happening with a Yamaha product.
Has anyone had this problem and if so what was the fix?
jholst is offline
post #2 of 8 Old 06-05-2010, 12:01 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
If the AVR will not stay POWERED ON with NO loudspeakers connected then the problem is internal, needs to go to the service center..
Just my $0.00...
M Code is online now
post #3 of 8 Old 06-05-2010, 12:02 PM
rdgrimes's Avatar
Quoted: 1992 Post(s)
Liked: 1320
The fix is probably an RMA. But make sure that HDMI-Control or HDMI-CEC is turned off in each connected component.
rdgrimes is offline
post #4 of 8 Old 06-05-2010, 12:38 PM
RoboRay's Avatar
Yamaha is no different than other companies in that failures may occur. Failures in less than a year are why warranties exist.
RoboRay is offline
post #5 of 8 Old 07-07-2010, 09:26 AM
YoramFor's Avatar
I have exactly the same problem with an RX-V765 that I bought a year ago. I talked to Yamaha and they said that it may be a short in the speaker connections. They asked me to disconnect the speakers and try again, which I will do later today.
YoramFor is offline
post #6 of 8 Old 12-28-2010, 09:05 PM
fpalaia's Avatar
Having same problem.
Anyone know the solution.
thanks
fpalaia is offline
post #7 of 8 Old 12-28-2010, 09:09 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
The solution is to either fix your wiring, replace a defective speaker(s), or have it serviced far as I know. Did you do basic diagnostics, such as unhooking all speakers to see if the problem went away?
"But this one goes up to 11"
MichaelJHuman is offline
post #8 of 8 Old 11-23-2011, 08:15 AM
StereoSteveo's Avatar
Send for repair I think..
StereoSteveo is offline
