Reference quality 7.1 preamp/processor on a budget - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 06-18-2010, 05:47 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Their prices are ok, but there are cheaper cables which work just as well.
"But this one goes up to 11"
MichaelJHuman is offline
Old 06-18-2010, 05:55 PM - Thread Starter
mjbuoni's Avatar
Originally Posted by Bill Mac View Post
Have you thought about keeping the 885 and adding a 2 CH preamp with HT Bypass? I have had several in my system and I feel it gives you the best of both worlds. I currently have a Parasound 2100 which is far from reference but sounds great to me. I think the Parasound P7 would work quite well with 2 7.1 M/C inputs and HT Bypass. I have seen them as factory refreshed at Audio Advisor for $1499.00. I bought my 2100 from AA as an open box which was actually never opened.
http://www.audioadvisor.com/prodinfo.asp?number=2PAHAP7
Bill
Thanks for your comments, Bill. I do have a 2 CH preamp with HT Bypass (Wyred 4 Sound STP-SE). It is excellent and what made me think to change from the 885. Even though I use it primarily for music, I sometimes prefer playing movies through the STP in stereo rather than 7.1 b/c the sound quality is noticeably more transparent.
I considered the Parasound P7 and in the end chose the Bel Canto b/c I was able to get a great deal on it. And, I do trust Kal Rubinson's subjective opinion, who indicated that the Bel Canto was sonically the better performer.
mjbuoni is offline
Old 06-18-2010, 05:56 PM - Thread Starter
mjbuoni's Avatar
Actually, let's keep this thread cable-free. Sorry for mentioning it.
mjbuoni is offline
Old 06-18-2010, 06:21 PM
Bill Mac's Avatar
Quoted: 1268 Post(s)
Liked: 1445
Matt,
Thats great you got the prepro you wanted. I had a Bel Canto PRe3 and I thought it was a great preamp and John at BC is excellent. Its funny that you have the STP SE as I was going to suggest that as well. There is one for sale over at av123 in the classifieds. I almost bought it but I just ordered new speakers and it would have been a stretch cash wise. Plus I really want a sub output with bass management as the 2100 has. I look forward to your thoughts on the Pre6 and how it compares SQ wise with the STP SE for 2 CH music.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is offline
Old 06-18-2010, 07:33 PM
HiFiFun's Avatar
Originally Posted by Selden Ball View Post
I'm not sure what you're implying by your winking smily, and I'll assume you're using "A/V Controller" as a synonym for the more common term "pre/pro" (preamp/processor). Apparently about 2/3 of the currently available (new) HDMI-capable pre/pros have two HDMI outputs, although not all of them have both active at the same time. See the list in the thread http://www.avsforum.com/avs-vb/showthread.php?t=940065
Is any Anthem a "budget" processor? The cheapest current Anthem pre/pro seems to list for about $6K -- certainly not what I would call a "budget processor"!
First A/V controllers are a rather pathetic lot, just like front projectors. Too small a market for most manufactures to care about. The best choice is a the Bel Canto, a product which is long discontinued.
What is a pre-amplifier? Does it amplifier the signal like in a phono stage? They used to amplify but now DAC's generate sufficient voltage. No need for pre-amplification. In fact the volume control typically reduces the gain.
So continue to call them pre-amplifiers, just as 2% milk is allowed to be called "low-fat". I don't care
Second there is no such thing as a budget A/V controller. There could be, but none has been sold. It could consume ~25 watts and be quit slim, with HDMI and S/PDIF inputs and XLR outputs. (Current A/V controllers contain a lot of air. They are big boxes only because of the legacy analog inputs which no-one uses). Throw in bass management and time delay and you could have reference performance for $1K. But that is too logical of a concept for today.
Instead wait for hand-me-downs from receiver technology.
HiFiFun is offline
Old 06-18-2010, 09:26 PM
Quoted: 266 Post(s)
Liked: 148
I believe some volume control chips can generate some gain. But I guess that's being nit picky
Old 06-18-2010, 10:56 PM
UWDawg's Avatar
What about an Arcam AVP700? It got rave reviews only a few years ago and can be found used for well under $1k.
UWDawg is offline
Old 06-18-2010, 11:51 PM - Thread Starter
mjbuoni's Avatar
I will be sure to post my thoughts on how these two preamps compare. It will be easy to do a rapid A/B comparison using the HT bypass on the W4S pre and I now have a SPL meter that measures to 0.1 dB accuracy, so level matching will be precise. Also, my wife has offered to help me switch so I can compare blindly.
mjbuoni is offline
Old 06-27-2010, 06:06 PM - Thread Starter
mjbuoni's Avatar
Wow, so I’ve had the Pre6 (Gen II) in my system for a few days and it has completely lived up to my expectations. First of all, there is no contest between the Pre6 and the Onkyo 885 with regard to sound quality. The Pre6 digs deeper into movie soundtracks and reveals subtle sounds distinctly, where the Onkyo would render such sounds present but veiled. A few examples are: insects buzzing around, the operator speaking on a phone off the hook in another room, individual voices within an audience at a concert, distant conversations that aren’t the focus of a scene, etc. Dialog is rendered through the Pre6 with better articulation and texture, giving voices more character and making quiet conversation easier to dintinguish. Dynamics are as good as I’ve heard, but the Onkyo is very good dynamically as well. To summarize, the Pre6 presents a transparent, neutral and dynamically alive sound that immerses you in a movie like no other preamp/processor I’ve experienced.
For two channel listening, I compared my Wyred 4 Sound STP-SE to the Pre6 by feeding the pre-outs of the Pre6 into the HT bypass input on the W4S pre. Volume level was matched to within about 0.1 dB and my Denon 3800bdci player fed both preamps (2 channel out -> W4S pre, multichannel out -> Pre6). Comparisons were made by switching inputs on the W4S pre between HT bypass and the Denon input. These two preamps were difficult to tell apart. Both were highly transparent, neutral and dynamic. The subtle differences that I observed were: 1) the W4S pre has a slightly lower noise floor (only noticeable with my ear close to the tweeters), although both are very quiet, 2) the W4S pre has just a touch of warmth to the tonal balance, whereas the Pre6 seems dead neutral, 3) the Pre6 provides a more precise level control especially at low volume, whereas the Wyred pre uses a resistor ladder network that forces larger jumps in volume level. That said, I could live with either preamp and consider them both reference quality in my system and to my ears. For now, I will keep both.
mjbuoni is offline
Old 06-27-2010, 07:47 PM
Kal Rubinson's Avatar
Quoted: 678 Post(s)
Liked: 461
To summarize, the Pre6 presents a transparent, neutral and dynamically alive sound that immerses you in a movie like no other preamp/processor I've experienced.
In no small part because it is not a preamp/processor but an analog preamp.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
Old 06-28-2010, 01:40 PM - Thread Starter
mjbuoni's Avatar
Yes, thanks for the clarification Kal. And thank you for your comments that ultimately led me to selecting this incredible unit!
Matt
mjbuoni is offline
