ADA Cinema Rhapsody Mach IV: Official Owner's Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 79 Old 02-24-2012, 09:16 AM
CCLAY's Avatar
Ah yes. I found the 'ADA Mach IV.....WOW' thread. Thanks guys
My Home Theater is a work in progress.
CCLAY is offline
post #62 of 79 Old 05-24-2012, 01:15 AM
pras1011's Avatar
Quoted: 23 Post(s)
Can someone send me the latest software for the Ada suite 7.1hd 1.3 hdmi?
pras1011 is online now
post #63 of 79 Old 01-09-2013, 01:41 AM
Tom Edge's Avatar
Hi. Can anyone point me in the direction of the proper user manual for the CRM4 please ? Thanks Tom
Tom Edge is offline
post #64 of 79 Old 01-10-2013, 10:46 PM
Tom Edge's Avatar
Is set up feasible by myself on this unit, or will I need to employ the services of a trained ADA installer ? Thanks Tom
Tom Edge is offline
post #65 of 79 Old 04-18-2016, 09:45 AM
Claesson's Avatar
Quoted: 35 Post(s)
Have a problem I hope maybe one you guys can help me out with!
I have a HTPC as my main source for movie watching. It has been around for the past two exchanges of preamp and I've always managed to bitstream HD audio to my preamp. But with the MACH IV only regular DTS / Dolby Digital is working properly. When I try to bitstream HD audio the Mach IV only receives LEFT and RIGHT signal. I searched the whole internet for answers and what I suspect is the problem is the HDMI passthrough. I think my HTPC only sees what my TV can receive. On the properties for my “AMD HDMI Output” it says that maximum number of supported channels is two. I´ve tried every fix I can find on internet.
Best regards
Claesson is offline
post #66 of 79 Old 06-02-2016, 11:45 PM
LeeOsX's Avatar
Quoted: 18 Post(s)
just there has no way that i can set address of this preamp, installed a windows xp for this one, has anyone has a proper instruction for it?
LeeOsX is offline
post #67 of 79 Old 06-03-2016, 05:28 AM - Thread Starter
thebland's Avatar
Quoted: 1490 Post(s)
Liked: 841
You have the software but it is not connecting? What version?
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
post #68 of 79 Old 06-05-2016, 09:47 PM
LeeOsX's Avatar
Quoted: 18 Post(s)
i've got the latest iso-e ver. 5 and iso-e 4, but none of them could find ip for me, but a little bit weird is that i can use Suite HD to control certain function, but no data will be reported like version request
LeeOsX is offline
post #69 of 79 Old 06-05-2016, 09:58 PM
LeeOsX's Avatar
Quoted: 18 Post(s)
Best regards
do you still need help? if so install a teamviewer, i can help you remotely
LeeOsX is offline
post #70 of 79 Old 06-06-2016, 12:42 AM
Claesson's Avatar
Quoted: 35 Post(s)
The problem is solved It was the EDID answer from my projector that said to HTPC that it could only handle 2 channels. An EDID manager from Atlona solved the issue. This would be something for ADA to implement in the mach 5, EDID management.
But since this was my HTPC should it not be possible to make an EDID override in the software of my computer?
BR
Claesson
Claesson is offline
post #71 of 79 Old 06-06-2016, 08:56 AM
LeeOsX's Avatar
Quoted: 18 Post(s)
BR
Claesson
how you connect your system?
HTPC> pre amp > Projector?
have you set the passthrough in the system?
LeeOsX is offline
post #72 of 79 Old 06-10-2016, 01:58 AM
Claesson's Avatar
Quoted: 35 Post(s)
Right now it´s the setup is like this,
HTPC -> Atlona EDID manager -> ADA -> Projector
There is only passthrough in the ADA Mach 4. It acts like a HDMI switch.
Best regards
Claesson is offline
post #73 of 79 Old 06-10-2016, 06:28 PM
mmiles's Avatar
Quoted: 465 Post(s)
Liked: 214
Is ADA still around to help?
Mike Miles
mmiles is offline
post #74 of 79 Old 06-10-2016, 07:11 PM
Perfectionist2's Avatar
Quoted: 42 Post(s)
yes, they're around. are they available to help? that's a different question . . .
Perfectionist2 is offline
post #75 of 79 Old 06-12-2016, 08:32 AM
LeeOsX's Avatar
Quoted: 18 Post(s)
Best regards
I will try on my setup ...habe you ever tried do it without the edid manager?
通过我的 Nexus 6 上的 Tapatalk发言
LeeOsX is offline
post #76 of 79 Old 09-09-2016, 02:36 PM
Claesson's Avatar
Quoted: 35 Post(s)
I´m getting a bit worried about ADA, tried to email them with questions a couple of times but no answer. Anyone knowing whats going on with them?
Claesson is offline
post #77 of 79 Old 09-23-2016, 01:31 AM
LeeOsX's Avatar
Quoted: 18 Post(s)
ada released new preamp for atoms..
LeeOsX is offline
post #78 of 79 Old 09-25-2016, 12:58 AM
Claesson's Avatar
Quoted: 35 Post(s)
At Cedia 2016?
Why are they so inactive on this forum and its website and reply to emails? They must show the world that they are here to stay. Updating their website to begin with. Maybe get a facebook page so you can follow them there.
I hope ADA makes a comeback, I really like their preamps.
BR
Claesson is offline
post #79 of 79 Old 10-24-2016, 09:34 AM
Claesson's Avatar
Quoted: 35 Post(s)
I´m having issues to get my Mach IV to work togheter with iRule. I´ve setup up an ip-adress through ISO-E5. I´ve inserted the commands from iRule database and created a gateway in the iRule app. The gateway is UDP protocol and I´ve set the ip-adress I gave the ADA in ISO-E5 and finally I used port 48716.
Is there anything I didn´t do correctly?
Thx!
Claesson
Claesson is offline
