The **Official** Denon 3311CI/ 991 Owner's Thread NO PRICE TALK - Page 316 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #9451 of 10760 Old 05-06-2012, 06:01 PM
jdsmoothie's Avatar
Quoted: 14333 Post(s)
Liked: 6767
Where to set AMP ASSIGN is fairly well explained on p. 53 in the 3311CI Owner's manual.
jdsmoothie is online now
post #9452 of 10760 Old 05-06-2012, 09:57 PM
keagy's Avatar
I have an older Panasonic Plasma (50Px600U) connected to the 3311. HDMI Control is turned on in the 3311 settings. When I power off the plasma the 3311 also turns off and along my Sony Blu-ray. When I turn on the TV only the Blu-ray powers on but not the 3311. Since the 3311 is in between the TV and Blu-Ray I would think it would also turn on (especially since TV power down also turns off both the 3311 and Blu-ray). Any suggestions?
keagy is offline
post #9453 of 10760 Old 05-07-2012, 04:29 AM
jdsmoothie's Avatar
Liked: 6767
As noted in the Owner's manual .. the feature is only designed to power OFF the AVR, not necessarily power it back ON again. You might want to try using a smart power strip.
post #9454 of 10760 Old 05-07-2012, 10:01 AM
keagy's Avatar
keagy is offline
post #9455 of 10760 Old 05-07-2012, 03:54 PM
spager's Avatar
Yea thought I knew it and after investigating and rereading posts the light finally came on.
spager is offline
post #9456 of 10760 Old 05-07-2012, 06:03 PM
Slobaugh's Avatar
Have you tried resetting the microprocessor? Also note that if repair is required, sometimes you can get quicker turn around by shipping to the factory repair center PanurgyOEM in NJ.
No dice with resetting the microprocessor. Called Denon and they believe there is a problem with the center channel, so I am bringing it to a local repair center this week. TV speakers, here I come! Sigh.
Slobaugh is offline
post #9457 of 10760 Old 05-07-2012, 06:36 PM
spager's Avatar
If you have tested thoroughly and I'm pretty sure you have from your post and you are 100% sure your center channel is not blown phone Denon and explain your test and discuss repair if you are sure.
spager is offline
post #9458 of 10760 Old 05-09-2012, 02:25 PM
Murilo's Avatar
Quoted: 137 Post(s)
Liked: 33
I unplugged my avr this week, and I noticed again all my plx II settings are gone.
I have to reapply them for every type of audio signal. Very annoying.
Is there anyway to make this stick?
So for dolby digital, dts master, true hd, lpcm, 2channel, all need to be sent to the avr and reapplied.
I would like to think theres some I am missing.
Murilo is offline
post #9459 of 10760 Old 05-09-2012, 03:04 PM
jdsmoothie's Avatar
Liked: 6767
Did you set the unit to Standby before unplugging it as your settings should otherwise have been maintained?
post #9460 of 10760 Old 05-09-2012, 03:11 PM
spager's Avatar
Also make sure in Manual Setup/Audio Setup the Auto Surround Mode is set to On.
spager is offline
post #9461 of 10760 Old 05-12-2012, 11:40 PM
thevolumnus's Avatar
I know it's a good idea to have timbre matched speakers but what about subwoofers? I was thinking about adding a second sub. There's a good deal for a Klipsch 12" sub on Craigslist in my hometown. I have a 12" JBL. A little extra base would be nice. I have a large living room.
thevolumnus is offline
post #9462 of 10760 Old 05-13-2012, 03:43 AM
glangford's Avatar
Quoted: 263 Post(s)
Liked: 213
Has there been any firmware updates of late? I did one about the the time they started giving away airplay.
glangford is offline
post #9463 of 10760 Old 05-13-2012, 03:54 AM
jdsmoothie's Avatar
Liked: 6767
Although it's ideal to add an identical sub, you can add another brand as well. Refer to the Subwoofers and Bass section in the Audyssey FAQ linked in my sig.
post #9464 of 10760 Old 05-13-2012, 07:37 AM
spager's Avatar
No new firmware as of late.
spager is offline
post #9465 of 10760 Old 05-13-2012, 11:28 AM
It seems strange that since I have a second subwoofer port that I would need to use a y-adapter to utilize audyssey xt. Still, I have one somewhere, so I won't need to buy one. I'm just not getting much base with my music at all. I'm satisfied with the base for movies though.
post #9466 of 10760 Old 05-13-2012, 12:08 PM
batpig's Avatar
Quoted: 3685 Post(s)
Liked: 3528
It is not accurate that you need to use an external y adapter to utilize MultEQ XT.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #9467 of 10760 Old 05-14-2012, 09:15 PM
that unless you have XT32 you are better off using a y adapter rather than utilizing both subwoofer outlets. Do you have a different opinion. I'd be glad to hear it.
post #9468 of 10760 Old 05-14-2012, 09:32 PM
jdsmoothie's Avatar
Liked: 6767
That recommendation actually comes from Audyssey to ensure there is no issue with the sub signal delay between the two subs; however, there's likely no issue with using the dual sub preouts on the 3311CI.
post #9469 of 10760 Old 05-15-2012, 06:07 AM
jdibble's Avatar
Originally Posted by jdibble View Post
I am about done with Denon. I can't get either of my apple TVs to work and nothing has changed. My wife flipped on the receiver and suddenly nothing happened. I can hook it directly to the tv and it works fine but soon as the receiver is involved I get audio skipping and no video. Reset the apple tv, reset the Denon and still no luck. Anyone have a similar experience?
Just an update. It has been over a month since I brought my unit in for repair and I may have another week or two to go. The HDMI board was found to be having issues and has to be sent to Denon for them to repair it. Shocking but they don't have replacement boards that they can send out!
jdibble is offline
post #9470 of 10760 Old 05-15-2012, 06:58 AM
jdsmoothie's Avatar
Liked: 6767
Which is why some folks take the shipping hit and just send out to the factory repair facility PanurgyOEM in NJ, as the turn around is generally only 1-2 weeks. Also note the HDMI board runs $550 and may require more unique installation experience.
post #9471 of 10760 Old 05-15-2012, 12:26 PM
fuzzy02cls's Avatar
Is there much difference between the Denon 3311 & a Yamaha RX-V1900? I'm looking at these used & they are the same price.
I haven't ever owned anything Denon before.
fuzzy02cls is offline
post #9472 of 10760 Old 05-15-2012, 12:38 PM
batpig's Avatar
Liked: 3528
the most important difference is that Denon uses Audyssey technologies, so you get MultEQ XT room calibration (more sophisticated than Yamaha's YPAO) and Dynamic EQ + Volume and Audyssey DSX. Yamaha uses their own proprietary processing for room correction (YPAO) and extra speaker processing (e.g., heights are "presence speakers") and as far as I know doesn't have anything equivalent to Dynamic EQ.
Setup Guide and FAQ
post #9473 of 10760 Old 05-17-2012, 11:37 AM
TechnoG's Avatar
Is there a list anywhere that shows all of the firmware updates (including the reason) for the Denon 3311? I've been away from the forum for awhile and I can't remember where this list was. Thanks!
TechnoG is offline
post #9474 of 10760 Old 05-17-2012, 12:20 PM
jdsmoothie's Avatar
Liked: 6767
It's in post #1 of this thread although hasn't been updated since last summer.
post #9475 of 10760 Old 05-18-2012, 03:15 PM
imws's Avatar
My 3311 was recently repaired by PanurgyOEM in NJ, it took about 10 days in total.
imws is offline
post #9476 of 10760 Old 05-20-2012, 05:37 PM
trexmgd's Avatar
I'm looking for a little help adding a remote wireless speaker to my system. I saw one of these (AR Wireless Speaker) at home depot working across the entire store and sounding decent for a small portable speaker. The unit can be hooked up directly via 1/8" jack or wirelessly using the sending unit. The sending unit takes power and has R/L RCA input jacks. The manual specifies that the preferred method is to use line-level outs, but a variable out such as a headphone jack can be used.
I attempted to hook it up as "Zone 2" (Turned zone "on", plugged RCA Zone 2 OUT to RCA Wireless sender unit IN). Messed with the default levels/volume and got nothing.
Switched over to the other RCA style outs for the DVR and still got nothing.
What am I missing here?
trexmgd is offline
post #9477 of 10760 Old 05-20-2012, 05:39 PM
ccotenj's Avatar
Liked: 101
what sources? keep in mind that hdmi sources will not be sent to zone 2...
- chris
ccotenj is offline
post #9478 of 10760 Old 05-20-2012, 09:46 PM
trexmgd's Avatar
Yes, HDMI. I was hoping to broadcast the music channels over my FiOS/Motorola set top box. IF the newer Motorola box supports sending out both HDMI and component and/or optical, would it then work?
Currently the ONLY inputs I have are HDMI (CABLE BOX, BLU-RAY, XBOX360). What options do I have? I did just order the ipod dock station, fwiw.
trexmgd is offline
post #9479 of 10760 Old 05-21-2012, 02:43 AM
jdsmoothie's Avatar
Liked: 6767
You would have to also connect an optical cable and set the cable box to PCM 2.0 if the audio channels are not already broadcast in that format.
post #9480 of 10760 Old 05-21-2012, 11:27 PM
nordvest's Avatar
This might seem like a strange question but I`ll ask it anyway
Is there any setting I can use so that I get sound just from the center speaker while watcing tv? I`m asking because for caual tv viewing the whole surround experience can be a bit overwheliming for all kinds of programs all the time...
Ideally I wouls have liked to program a setup where I downmix everything to the center channel and assigned a Quick Select for it and another Quick select for normal surround when I`m watching for films, sports etc. Is this possible??
(Obviously I could have used just the tv speakers in this scenario but they are unbearable to listen to and besides I need the auto lip sync on the Denon to correct the audio delay from my PVR)
nordvest is offline
Denon Avr 3311ci Receiver , Denon , Receivers Amplifiers
