The **Official** Denon 3311CI/ 991 Owner's Thread NO PRICE TALK - Page 353 - AVS Forum
post #10561 of 10570 Old 12-27-2014, 09:16 AM
evil_lives's Avatar
My 3311 suddenly has the red ring problem(over current)??. I have tried system and network resets. Checked all my speaker and HDMI connections, and everything seems good?
Strange thing is if I leave it unplugged for a day or so.. it will work fine for about a week, and then fail on power up?.
I can't see it being a heat issue?? it is not covered and the top is always cool? I even took canned air and gave it a good once over to make sure it wasn't dust?.
Any help would be appreciated.. it's starting to get on my nerves..
Peace.
evil_lives is offline
post #10562 of 10570 Old 12-28-2014, 05:55 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 2643 Post(s)
Liked: 1900
If it's a fast blinking light (ie. 2x/sec) then more than likely amp failure if nothing is connected when it powers off. The 3311CI comes with a 3 year warranty, which although has likely expired, if purchased with a credit card, the card issuer may add an additional 4th year.
"JD" – jd@avscience.com ; Call me --> 585-645-1006, AVScience - AVSForum sponsor and dealer for AVRs and Speakers
Daily 8am – 8pm EST
Call for info on Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #10563 of 10570 Old 01-04-2015, 05:04 AM
Liked: 0
Hi All,
I have a 3311 for a year now without any issues so far, but that changed during christmas holiday.
One of the most used function for me is Denon Internet Radio - but suddenly, all internet audio stopped working. I get only "Server Disconnected" message every time I go through my saved list. Also Denon Internet Radio (vTuner) is not longer present in my NET AUDIO/USB, everything (like favourites, library ..) is gone and search by keyword only returns "empty".
I did not change anything on my network infrastructure. I am using TP-Link router connected to optical modem.
All other net functions like FLAC streaming, DLNA push, playing from NAS works without any issue.
I would be helpful if you guys have any suggestion what to check.
Tomas
GoRingo is offline
post #10564 of 10570 Old 01-04-2015, 06:04 AM
chi_guy50's Avatar
Quoted: 434 Post(s)
Liked: 199
Originally Posted by GoRingo View Post
Hi All,
Tomas
I saw this issue occasionally on my 3311; I attributed it to the type of glitch that can arise on any computer system, especially when two or more programs need to interoperate.
Did you check the status of your vTuner account tied to the AVR? If not, in the web controller click on the "Jump to vTuner" link as shown on the Net Audio screen shot you posted (or go to this web page), log in to your account, and verify that your favorites are still saved there. Also, verify that it is still linked to the correct ID (MAC address) of your 3311.
If the vTuner account is in order, try a soft reset of the 3311 (disconnect power cord for at least 10 minutes). That usually did the trick for me, but if you still have the problem, try reestablishing a network connection (set IP control to off, turn off power, then turn power on again and select a network source).
GoRingo likes this.
chi_guy50 is offline
post #10565 of 10570 Old 01-04-2015, 08:46 AM
Liked: 0
Originally Posted by chi_guy50 View Post
I saw this issue occasionally on my 3311; ....
Yes I did check the vTuner, all fine.
I tried to do soft reset, not helped.
Now I changed the connection of the Denon from router directly to modem - Internet Radio went back! But I soon as I plug Denon to router, all gone again. So I guess there is something with the router settings. Is there any specific port need to be open for streaming?
GoRingo is offline
post #10566 of 10570 Old 01-04-2015, 09:12 AM
Liked: 0
Finally a fix for me was what you suggested: disable and enable DHCP, re-establish connection. Addition to that (and I think that was the root cause) I found some restriction setting applied in the Router settings. This restriction was valid for the IP used before by other device, but as DHCP assign the same address to the Denon --> problem.
Anyway thank you for your help - pointed me to the right direction.
Tomas
GoRingo is offline
post #10567 of 10570 Old 01-04-2015, 09:49 AM
chi_guy50's Avatar
Quoted: 434 Post(s)
Liked: 199
Tomas
I'm glad you were able to resolve your problem. The router settings would have been the next item on the troubleshooting checklist, but it's best to start with the simple stuff first and move up the ladder to the more complex. (Plus, I'm not familiar with your particular router so I'm not sure how much help I could have been there.)
post #10568 of 10570 Old 01-05-2015, 02:56 PM
scott967's Avatar
Recommend just using a static addr for the Denon. Don't see any benefit to using DHCP.
scott s.
scott967 is offline
post #10569 of 10570 Unread Today, 05:04 AM
Liked: 0
3311 and new Samsung tv
Hi all. I have a weird issue with the AVR. It seems to do everything fine except display menu or tuner details on the TV. I also can't get the audio to come throught the HDMI cable (v2 & 1.4). Hdmi cable is connected via the ARC points. I am wondering if ARC needs to be configured via the menu that I cant get too.... I have done the reset once already.
Thoughts?
ShadyF is online now
post #10570 of 10570 Unread Today, 05:09 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1900
Ensure the AVR has the Video Convert setting enabled. Also the Samsung must have Anynet+ enabled and audio set to "External speakers" and the AVR must have HDMI Control set to ON.
Daily 8am – 8pm EST
Denon Avr 3311ci Receiver , Denon , Receivers Amplifiers
Gear in this thread - 3311ci by PriceGrabber.com
