The **Official** Denon 3311CI/ 991 Owner's Thread NO PRICE TALK - Page 354 - AVS | Home Theater Discussions And Reviews
post #10591 of 10605 Old 03-06-2015, 10:50 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 3798 Post(s)
Liked: 2194
Originally Posted by svbp007 View Post
Thanks. This seemed to have worked better than the microprocessor reset. Now I have to redo audyssey etc but I am even curious what this update is about ? Could not find anything on denon website that indicates an update was released past 1+ year...
More than likely it resolves the DD+ distortion issue when Netflix is the source.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call only for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #10592 of 10605 Old 03-06-2015, 11:09 AM
JibJab24's Avatar
Does the Reference Level Offset setting affect only the sub/surrounds or are all the speakers reduced by the set amount? Thanks for the insight, trying to figure out what Dyn EQ does, I never use the Dynamic Volume settings.
JibJab24 is offline
post #10593 of 10605 Old 03-06-2015, 11:19 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2194
Yes. Reference Level Offset is a Dynamic EQ setting so as such, only the bass/surround audio is impacted.
post #10594 of 10605 Old 03-09-2015, 09:40 AM
khaberst's Avatar
Chrome Cast HDMI
Tried using a ChromeCast on HDMI 6 (front aux input) and it allowed me to set it up, then did a reboot and stopped working. I thought it was a the ChromeCast, but then tried it on my TV's HDMI input and it began working again. It is currently running on my HDMI 4 port and working fine. Seems to just be the front HDMI 6 port that isn't working. Any way to resolve this? I haven't tried another video source yet FWIW.
khaberst is offline
post #10595 of 10605 Old 03-09-2015, 09:58 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2194
Some HDMI inputs will work with one source and not another. You can try a soft reset (unplugging AVR for 10 minutes).
post #10596 of 10605 Old 03-09-2015, 12:37 PM
khaberst's Avatar
Thanks, I'll give that a shot.
khaberst is offline
post #10597 of 10605 Old 03-10-2015, 05:55 PM
dhegler's Avatar
I have a Denon avr-991 with HDMI to my main TV and an HDMI splitter to my secondary TV. I can only find out how to make the HDMI audio to to either the AMP or the TV. Is there any way to have both??? The secondary TV is far away and all the wires are already behind the wall. The speakers are all by my main TV, so there is little sound by the secondary TV. Any thoughts???
dhegler is offline
post #10598 of 10605 Old 03-10-2015, 06:02 PM
batpig's Avatar
Quoted: 1666 Post(s)
Liked: 1912
No, it's an either/or setting. Can't do both at the same time -- if the receiver strips and processes the audio it only sends video out the HDMI output.
Newer models have a second matrix HDMI output that do what you want.
batpig is offline
post #10599 of 10605 Old 03-10-2015, 07:42 PM
TheRealDeal1's Avatar
I had the same issue. I just moved the Chromecast to the AVR-4308 in another room. The Chromecast wouldn't work on one of the HDMI ports on the back of the 3311 either so I assumed it would not work on the rest of the HDMI inputs.
TheRealDeal1 is offline
post #10600 of 10605 Old 03-11-2015, 01:18 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2194
The HDMI inputs are not all created equal. Always best to try every HDMI input when adding a new HDMI source.
TheRealDeal1 likes this.
post #10601 of 10605 Old 03-11-2015, 01:22 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2194
One option is to purchase a 4x2 HDMI switch and place it between the sources and the 991 with one output going to 991 and the other to the 2nd TV. Note that when playing the same source to each output, the 991 would be down mixed to stereo only.
http://www.monoprice.com/Product?c_i...seq=1&format=2
post #10602 of 10605 Old 03-11-2015, 02:49 AM
dhegler's Avatar
I already have a switch like that from Monoprice that is 2x1 and use a long red mere HDMi cable in the wall. It may not be "true matrix" though. My understanding is that this is a receiver issue - it can't send audio through HDMi and also through its speakers...
dhegler is offline
post #10603 of 10605 Old 03-11-2015, 03:22 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2194
Correct. However, your issue is resolved with a 4x2 HDMI switch as I suggested.
post #10604 of 10605 Old Yesterday, 10:18 PM
GSF_Bellevue's Avatar
Have a Denon 3311CI and BlueJeans 40ft HDMI cable to a Samsung TV. This was all working flawlessly until last week when the TV started flickering to the point where the previous channel was ghosted behind the current channel. Making TV watching in HD unbearable.
I have done both a network and AVR reset as well as a tested the BD player (which also experiences the flickering).
Anyone have any suggestions about what to do next?
Greg
GSF_Bellevue is offline
post #10605 of 10605 Unread Today, 04:40 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2194
Try using a shorter (eg. 6') cable. If it works, then add an HDMI signal repeater which can be purchased from forum sponsor Monoprice.
Denon Avr 3311ci Receiver , Denon , Receivers Amplifiers
Gear in this thread - 3311ci by PriceGrabber.com
