The **Official** Denon 3311CI/ 991 Owner's Thread NO PRICE TALK - Page 358 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #10711 of 10735 Old 12-18-2016, 08:26 AM
tang7969's Avatar
Quoted: 255 Post(s)
Liked: 184
Originally Posted by vschaos View Post
Dang. Guess I will use this receiver in another room. Any recommendations on a 4k receiver?
I would highly recommend this https://www.amazon.com/Marantz-SR701...s=marantz+7010
I have the Marantz 7008 and it sounds great!! The 7010 has better HDAM technology.
SAMSUNG UN607150- OPPO BDP 103D- PSA 210T L/R -PHANTOM CENTER -ENERGY RC-10 SURROUNDS -PSA S3000i - MARANTZ SR7008 - APPLE TV -MONSTER POWER HTS2600MK -DIRECTV GENIE -HARMONY ELITE
BASEMENT SETUP- SAMSUNG UN466500- ENERGY 50'S L/R -PSA S1500- DENON-AVR-3311CI- PS3 -APPLETV- MINI GENIE
tang7969 is online now
post #10712 of 10735 Old 12-18-2016, 08:34 AM
vschaos's Avatar
Quoted: 27 Post(s)
I will look into it. I've loved my 3311ci. Now that I'm looking at all my gear I may wait to buy another receiver once I can afford a 4k projector. I currently have a benq ht2050 projector. I also only need 7.2 and I have a amp for all my speakers so wouldn't use the receiver for wattage
vschaos is offline
post #10713 of 10735 Old 12-18-2016, 09:52 AM
tang7969's Avatar
Quoted: 255 Post(s)
Liked: 184
I can't say I love the 3311. I have the 3311 and the Marantz 7008 and the Marantz has a much warmer sound to it in my opinion. I really have to crank up the 3311 to get the same level as the Marantz. Good luck.
post #10714 of 10735 Old 12-23-2016, 01:54 AM
jdsmoothie's Avatar
Quoted: 12221 Post(s)
Liked: 5563
Depends on your budget and feature/input/output requirements. The current successor to the 3311CI is the X4300H. Review the first post in the 2016 Denon AVR Owner's thread for more details on the current models.
The "OFFICIAL" 2016 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ
vschaos likes this.
jdsmoothie is online now
post #10715 of 10735 Old 12-23-2016, 07:43 AM
vschaos's Avatar
Quoted: 27 Post(s)
Thank you! I see walmart has the 4300 for $1099 which is not bad at all. I will look into this receiver more!
vschaos is offline
post #10716 of 10735 Old 12-23-2016, 12:01 PM
jdsmoothie's Avatar
Liked: 5563
Any vendor listing a "new" unit for other than MSRP ($1499) is likely an unauthorized dealer so Denon would not honor the 3 year warranty when purchased from that dealer.
post #10717 of 10735 Old 12-23-2016, 12:19 PM
centauro74's Avatar
http://www.accessories4less.com/make...eceiver/1.html
Accesories4less have it for $1099, they sell refurbished from Denon with 1 year warranty.
Sent from my SM-G935V using Tapatalk
centauro74 is offline
post #10718 of 10735 Old 01-11-2017, 09:39 AM
mjclifford's Avatar
Speakers not working
I noticed last night that my AVR-3311CI speakers are not working, specifically the Left and Right Backs. I verified this using the Setup menu and the Manual option to generate test tones.
What steps can you recommend, and the order, to further troubleshoot this issue? I'm in mortal terror of a firmware upgrade, since I've bricked three boxes previously. Is a firmware reset risky?
Any advice is appreciated.
mjclifford
mjclifford is offline
post #10719 of 10735 Old 01-11-2017, 11:58 AM
jdsmoothie's Avatar
Liked: 5563
mjclifford
If the SBL/SBR speakers are configured but the AVR fails to pass a test tone to them, try doing a soft reset by simply powering off and unplugging the AVR power cord for 10 minutes. If still no joy, then you'll need to do a microprocessor reset (p. 116 Owner's manual) which will restore all settings to factory default and wipe out Audyssey as well however, does not change the firmware version.
post #10720 of 10735 Old 01-26-2017, 01:54 PM
4HiMarks's Avatar
Quoted: 14 Post(s)
My 3311 announced there was a firmware update last night. Anyone else get it? What changed?
4HiMarks is offline
post #10721 of 10735 Old 01-26-2017, 07:58 PM
jheadley's Avatar
I got that too and allowed it to proceed. Now I'm stuck in an infinite loop of update failures and retries. Anyone in the same situation that has been able to get the update to finish?
jheadley is offline
post #10722 of 10735 Old 01-26-2017, 08:49 PM
4HiMarks's Avatar
Quoted: 14 Post(s)
Oh, it finished for me. I just haven't detected any change.
4HiMarks is offline
post #10723 of 10735 Old 01-27-2017, 01:31 AM
jdsmoothie's Avatar
Liked: 5563
Fixed the inability to log on to Pandora.
http://denon.custhelp.com/app/answer...-using-pandora
post #10724 of 10735 Old 01-27-2017, 06:35 AM
4HiMarks's Avatar
Quoted: 14 Post(s)
Well, that was never a problem for me, although I've only tried it a couple of times.
4HiMarks is offline
post #10725 of 10735 Old 01-27-2017, 12:43 PM
scott967's Avatar
Quoted: 16 Post(s)
It was an "Ether IMG" update so I assumed something that jdsmoothie confirmed for us. Took 8 mins once the update started, with the usual wait for finding server / authenticating prior to the update actually starting.
scott s.
scott967 is offline
post #10726 of 10735 Old 01-29-2017, 04:40 PM
Liked: 0
AVR-3311ci firmware
Hi,
I have an AVR-3311ci that works just fine but is unable to get updates via the Denon Update server. A previous update seems to have not completed and the ethernet rom looks like it was corrupted or erased and not reprogrammed. I have the documentation on doing a manual firmware reload using DFW and wanted to give that a shot to see if it would reprogram the firmware on the unit. Since the unit is out of warranty you can no longer download it from Denon, I contacted support and they basically said to wait for it to be posted to the site (there is a newer update coming out to fix the Pandora issues). However I don't think it will ever be posted as a manual download since their policy for out of warranty units is to only update via DPMS.
Does anyone have any copy of the manual firmware install? I believe this unit is running june 2010 code so anything after that should work.
frs2 is offline
post #10727 of 10735 Old 01-30-2017, 04:28 AM
jdsmoothie's Avatar
Liked: 5563
Originally Posted by frs2 View Post
Hi,
Not necessarily true, as there are currently firmware downloads available going back to the 2012 models all of which are out of warranty.
Have you tried doing a "network reset" (ie. press/hold UP/DOWN arrow buttons on front panel while powering on the AVR)?
post #10728 of 10735 Old 01-30-2017, 05:03 AM
centauro74's Avatar
Did the update last night,, it went smoothly in 8 minutes, I can testify Pandora works much better now.
post #10729 of 10735 Old 01-30-2017, 04:35 PM
Liked: 0
Sorry, maybe it's units over 5 years old then. They just released updates for a number of older models to fix Spotify but they aren't posted to the site.
I did try a network reset, no good. The FBL, SBL, IMG, and MAC don't show real values like they should, seems like the ROM isn't programmed.
frs2 is offline
post #10730 of 10735 Old 01-31-2017, 01:47 AM
jdsmoothie's Avatar
Liked: 5563
That would be the inability to log on to Pandora which impacted all networking capable 2010 - 2016 Denon and Marantz models (except those models with the built-in HEOS module), and it's only been in the past 3 years that the USB updates have been made available on the Denon website for the lower level models so I'm actually surprised they even went back to 2012. It's possible the 2010 and 2011 models cannot be updated by USB or they're just late in adding them to the site.
post #10731 of 10735 Old 02-09-2017, 04:05 PM
IMRIZZO's Avatar
Quoted: 44 Post(s)
Liked: 125
has anyone here experience a problem with recent firmware (last week). Since I've updated strange problem has started, usually S/W does an auto shut down between LFE signals and shutdown 10 minutes after powering down. Not no more I've done a complete unplug waited 10 minutes restarted but problem still exist ? Sub stays powered up? Any ideas TIA.
LG OLED 55B6P~Oppo UDP203~SonyXBR929~Denon 3311~Mirage V2 SPK-SYS w/ S10 SW~ DVP5000~Harmony1100
Optimum via SA8300-HDDVR
IMRIZZO is offline
post #10732 of 10735 Old 02-09-2017, 09:10 PM
jdsmoothie's Avatar
Liked: 5563
Is the sub still set to "Auto" or was it changed to "On"?
post #10733 of 10735 Old 02-10-2017, 07:46 AM
IMRIZZO's Avatar
Quoted: 44 Post(s)
Liked: 125
the Sub is still set as Auto I did another complete power down on all equipment left it off 1 hr then reconnected went through every setup via HarmonyR all working properly now, btw thanks for your response
IMRIZZO is offline
post #10734 of 10735 Old Today, 05:15 PM
theanimala's Avatar
Today I noticed my subwoofers are not making any noise. My AVR-991 sees them, no changes in settings. Tried playing test tones and while it's saying sound is on, nothing is coming through them. I did the firmware update today, soft reset, then microprocessor reset all with no luck. Confirmed both subwoofers are plugged in. Anything else this could be?
theanimala is offline
post #10735 of 10735 Unread Today, 11:58 PM
jdsmoothie's Avatar
Liked: 5563
Pull the cable from the sub pre-out and rub your finger over the tip of the cable. Hear static from the sub? If no, either the cable or the sub is defective. Use a different cable to test (can use a red/white/yellow composite video cable for testing).
Denon Avr 3311ci Receiver , Denon , Receivers Amplifiers
